Trailer hitch configuration for 2011 Audi Q5 ?
MLB
C?ID=348541
Hi, i installed the audi oem hitch (and electrical connections) and used vcds to tick all the right boxes (i think), but theres an odd behavior:
Without trailer attached the parking/proximity sensors in the bumper seem to see the protruding hitch as an apparent obstacle.
So, reversing to connect trailer has the annoying beep tone. If i press the button to turn off the parking assist beep it ALSO turns off the backup camera!
Which i need, duh!
:0)
How do I temporarily turn off the beep tone without deactivating the backup camera? Or is there a VCDS setting that ive overlooked?
Thanks,
--Michael
Recent autoscan:
Friday,05,October,2018,19425432435303
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
VIN: WA1WKAFP5BA030617 License Plate:
Chassis Type: FP-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3C 42 46 47 52 53 55 56
5F 62 69 6C 6D 72
VIN: WA1WKAFP5BA030617 Mileage: 149210km-92714miles
Address 01: Engine (J623-CALB) Labels:| 06E-907-559-CAL.clb
Part No SW: 8R0 907 559 G HW: 8F0 907 559 A
Component: 3.2 SIMOS8.2 H07 0003
Revision: --------
Coding: 0121000A190F0121
Shop #: WSC 06335 000 00000
ASAM Dataset: EV_ECM32FSI0218R0907559G 001003
ROD: EV_ECM32FSI.rod
VCID: 44D14FBE9E134157FAD-8010
6485 - Oxygen (Lambda) Sensor B1 S2
P0139 00 [096] - Response too Slow
Mileage: 148327 km
Date: 2019.09.28
Time: 07c00c17
Engine speed: 1845.00 /min
Vehicle speed: 87 km/h
Coolant temperature: 76 °C
Intake air temperature: 20 °C
Voltage terminal 30: 14.116 V
Unlearning counter according OBD: 22
Engine speed: actual: 1824 /min
MAF_ENVD: 81.70588 mg/stroke
Coolant temperature (unfiltered): 76.5 °C
Engine: operating status: PUC
T_AST_ENVD: 128.50 s
STATE_LS_ENVD[1]: 4
Address 02: Auto Trans (J217) Labels:| 0B6-927-156.clb
Part No SW: 8R0 927 158 H HW: 0B6 927 156  Component: 0B6 32 FSIUSA H05 0006
Revision: --H05---
Coding: 001012
ASAM Dataset: EV_TCMAL651211 001012
ROD: EV_TCMAL651.rod
VCID: 42DD49A684074F67C81-8016
Address 03: ABS Brakes (J104) Labels:. 8R0-907-379-V1.clb
Part No SW: 8R0 907 379 H HW: 8R0 907 379 H
Component: ESP8 quattro H06 0100
Coding: 049D18
Shop #: WSC 06335 123 12345
VCID: 45D752BA95A9785FED3-8010
Part No SW: 8K0 907 064 CS HW: 8K0 907 064 CS
Component: BCM2 2.0 H05 0431
Coding: 0D0500
VCID: 03538CA2DB1D866F837-8056
Subsystem 1 - Part No SW: 8K0 905 852 D HW: 8K0 905 852 D
Component: J764 ELV MLB H37 0042
Serial number: 0210000168392013
Address 08: Auto HVAC (J255) Labels:. 8Tx-820-043-3Z.clb
Part No SW: 8T1 820 043 AK HW: 8T1 820 043 AK
Revision: C1000000 Serial number: 01250820100420
Coding: 46112000
VCID: 7AADF146ACD7C7A7D01-802E
Part No SW: 8K0 907 063 P HW: 8K0 907 063 P
Component: BCM1 1.0 H29 0392
Revision: 10029001 Serial number: 00000000775553
Coding: 26001091063CAF010000080300001D0D4F1C660802010161000000
VCID: 3C21375EE663399782D-8068
Subsystem 1 - Part No SW: 8R1 955 119 A HW: 8R1 955 119 Labels:
1KX-955-119.CLB
Component: WWS416 100810 H10 0050
Serial number: 90243014100728205408
Coding: 01DD13
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels:
8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11023953
Coding: 024D25
Subsystem 3 - Part No SW: 8K0 941 531 AL HW: 8K0 941 531 AL
Component: E1 - LDS H08 0090
Serial number: 00000000000808101391
Subsystem 4 - Part No SW: 8K0 907 410 C HW: 8K0 907 410 C
Component: HOMELINK H01 0010
Address 10: Park/Steer Assist (J446) Labels:. 8K0-919-475.clb
Part No SW: 8K0 919 475 R HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0070
Revision: 11001001 Serial number: 50931024508042
Coding: 300108
VCID: 48C95B8EA2BB6537165-801C
Address 15: Airbags (J234) Labels:* 8R0-959-655.clb
Part No SW: 8R0 959 655 F HW: 8R0 959 655 F
Component: AirbagVW-AU10 H41 0610
Serial number: 003GPD0G8LN$
Coding: 303633313432303030304A55304C38523053
ROD: EV_AirbaAU10SMEAU416.rod
VCID: 47CB58B2AF256A4F1FF-8012
Subsystem 1 - Part No SW: 8R0 959 339 A HW: 8R0 959 339 A
Component: BF-Gewichtss. H02 0040
Serial number: 5810000R10000012G5
Serial number: 6334MSME5665035EH
Serial number: 6344MSME56454657G
Serial number: 6352QSME576A151EQ
Serial number: 6362QSME0C6E453CY
Serial number: 63732SME106E0434V
Serial number: 63832SME4E6B4C02A
Part No SW: 8K0 953 568 F HW: 8K0 953 568 F
Component: Lenks.Modul H17 0014
Revision: -------- Serial number: 90319JHH000AA  Coding: 000017
VCID: 3D273A5AFD79309FB53-8068
Component: E221 - MFL H04 0010
Address 17: Instruments (J285) Labels:. 8R0-920-xxx-17.clb
Part No SW: 8R0 920 981 G HW: 8R0 920 981 G
Component: KOMBIINSTR. H13 0258
Revision: 00000000 Serial number: EK0229R8A
Coding: 8B1E22000B00D705020200
VCID: 3E253D56F07F2B87AC9-806A
Part No SW: 8T0 907 468 AE HW: 8T0 907 468 L
Component: GW-BEM 5CAN-M H10 0117
Revision: FC100058 Serial number: 5800F10807002E
Coding: 00C303
VCID: 04518FBEDE138157BAD-8050
Subsystem 1 - Part No SW: 8R0 915 181 HW: 8R0 915 181
Component: J367-BDM H07 0140
Serial number: 00000000005659207101
Part No SW: 8R0 959 760 B HW: 8R0 959 760 B
Component: MEM-FS H06 0074
Revision: AA000000 Serial number: 00001002067841
Coding: 00581B00000044440000
VCID: 40D943AE8A8B5D77DE5-8014
Address 3C: Lane Change Labels: Redir Fail!
Part No SW: 8R0 907 566 A HW: 4L0 907 566 A
Component: J0769_SWA_MasterH11 0040
Revision: 00H11000 Serial number: 6PZ 009 014-05
Coding: 0000007
Shop #: WSC 06335 444 00001
VCID: 3C21375EEA63399782D-8068
Subsystem 1 - Part No: 8R0 907 568 A
Component: J0770_SWA_Slave_H09 0040
Subsystem 2 - Serial number: 6PZ 009 014-25
Subsystem 3 - Serial number: 5F22.08.1000H090003CX12539ÿ
Subsystem 4 - Serial number: X12539ÿ
Part No SW: 8K0 959 793 M HW: 8K0 959 793 M
Component: TSG FA H12 0357
Revision: Serial number: 0000107066130
Coding: 011D13205E00440004
VCID: 4ACD6186BCB79727001-801E
Revision: 00002001 Serial number: 0134451756
Coding: 0126023A20FA749584B0053A20000000
Subsystem 1 - Part No SW: 8K0 959 719 HW: 8K0 959 719  Component: GTO BF H06 0050
Serial number: 00000000000000295448
Subsystem 3 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 4 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
Part No SW: 8T0 035 223 AN HW: 8T0 035 223 AK
Component: DSP Prem H10 0190
Revision: 00010001 Serial number: 34882004163401
Part No SW: 8K0 959 792 M HW: 8K0 959 792 M
Component: TSG BF H12 0357
Revision: Serial number: 0000107528298
VCID: 49CF5E8AB9B19C3F09B-801C
Address 53: Parking Brake (J540) Labels: 8K0-907-801-V1.clb
Part No SW: 8K0 907 801 H HW: 8K0 907 801 H
Component: EPB Audi B8 H09 0100
Revision: 00000003 Serial number: 10000000595185
VCID: 34311F7ECE33F1D74AD-8060
Address 55: Headlight Range Labels: 8T0-907-357.clb
Part No SW: 8H0 907 357 C HW: 8H0 907 357 C
Component: AFS 1 H01 0030
Coding: 0000021
Shop #: WSC 06334 000 00000
VCID: 323D19663827FFE7581-8066
Component: Radio U SIRIU H51 0133
Revision: AB001007 Serial number: 471I/0A7525078
Coding: 020007010000000001
VCID: 2411EF3E7ED36157DAD-8070
Part No SW: 8T1 035 664 F HW: 8T1 035 664 B
Component: H-BN-NA H49 0189
Revision: -------- Serial number: 490F+0A7571845
Coding: 010200060105A1EF51000B0E000000030000
Shop #: WSC 44055 001 104857
VCID: 3B233442E36D3EAF8B7-806E
Subsystem 1 - Part No: 8R0 060 884 P
Component: NAR 2010 0407  Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0098
Serial number: 9466HR0A0081045
Subsystem 3 - Part No SW: 8T0 919 609 G HW: 8T0 919 609 G
Component: E0380 Bedient H08 0100
Serial number: 00000000616150
Component: CD-Database 1886
02244 - Button in Control Head is Stuck
Reset counter: 198
Mileage: 149208 km
Date: 2019.10.05
Time: 18U00U01
Voltage: 12.90 V
Bin. Bits: 10000000 00000000
Bin. Bits: 00000000 00000000
Part No SW: 8K0 959 795 F HW: 8K0 959 795 F
Component: TSG HL H11 0357
Revision: Serial number: 0000107395534
Coding: 010C13204000240004
Address 69: Trailer (J345) Labels:. 8K0-907-383.clb
Part No SW: 8K0 907 383 E HW: 8K0 907 383 E
Component: Anhaenger H09 0100
Revision: 1A001001 Serial number: 00000325781502
Coding: 0200000000000000
VCID: 36352576D84FE3C7749-8062
Address 6C: Back-up Cam. Labels: 8T0-907-441.clb
Part No SW: 8R0 907 441 A HW: 4L0 907 441 B
Revision: --H04--- Serial number: 525PA8-J06A10S
Coding: 1010010
VCID: 34311F7EC233F1D74AD-8060
Address 6D: Trunk Elect. (J605) Labels: Redir Fail!
Part No SW: 8R0 827 851 B HW: 8R0 827 851 B
Component: J605 Master H50 0330
Revision: -------- Serial number: 8R0827851B
Subsystem 1 - Part No SW: 8R0 827 852 B HW: 8R0 827 852 B
Component: J756 Slave H50 0330
Serial number: 8R0827852B
Address 72: Door, Rear Right (J389) Labels:. 8K0-959-795.clb
Component: TSG HR H11 0357
Revision: Serial number: 0000107395531
End----(Elapsed Time: 02204, VBatt start/end: 12.3V/12.4V. VIgn 0.0V)------
Looks to me like you have not coded 10: Park/Steer Assist to tell it you have a trailer hitch installed.
MLB
C?ID=348541
Yep, I found the setting for trailer config under the #10 parking assist section, tahnks. overlooked that one before.
