NEEDLE SWEEP PROBLEM ON AUDI A4 B9 WITH VIRTUAL COCKPIT
ib97
Croatia
C?ID=375363
Rev counter just stops when it's returning from 6000 rpm. What could be the problem ?
Here is auto scan if that helps.
Chassis Type: F4-AU49 (4M2)
Scan: 01 02 03 08 09 13 15 16 17 19 29 39 3C 42 44 46 52 5F 6C 74
          81 8B A5 AC BB BC CF D6 D7
VIN: WAUZZZF40GXXXXXXX   Mileage: 51864km-32226miles
Address 01: Engine (J623-DETA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 AG    HW: 04L 907 309 L
   Component: R4 2.0l TDI   H33 1969
   Revision: B1H33---
   Coding: 0A254032236605083438
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TDI01104L906026AG 001006
   ROD: EV_ECM20TDI01104L906026AG_001.rod
   VCID: 6FBA28833713E80F20D-803A
21376 - Reductant Metering Module
          P20FE 00 [096] - Malfunction
9645 - Reductant
          P20E8 00 [096] - Pressure too Low
   Part No SW: 8W0 927 155 K    HW: 0CK 927 156 S
   Component: 0CL 20TDIRdWH06 0002
   Revision: --H06---    Serial number: 0000000181
   ASAM Dataset: EV_TCMDL382021 002021
   ROD: EV_TCMDL382021_AU49.rod
   VCID: 47CAA0237F23104F48D-8012
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 K
   Component: V553 MTFP  HB1 0572
   Serial number: 75117051160029000553
Address 03: ABS Brakes (J104)       Labels: 8W0-907-379-PRE-V1.clb
   Part No SW: 8W0 907 379 F    HW: 8W0 907 379 D
   Component: ESP9 Premium  H09 0593
   Coding: 0CAA489928A70A99159F4898008552A2E6A59A30121450A812004A4567A559
   Shop #: WSC 39453 001 1048576
   ASAM Dataset: EV_ESP9BOSCHAU49X 012014
   ROD: EV_ESP9BOSCHAU49X_012.rod
   VCID: 48C8A31F723D1F37417-801C
12615680 - FlexRay Databus
          U0080 00 [096] - Defective
          [FlexRay_controller_0_channel_A_no_synchronisation]
419328 - TPMS Warning; Front Right Tire
          C1057 00 [032] - Flat
419584 - TPMS Warning; Rear Left Tire
          C1059 00 [032] - Flat
419840 - TPMS Warning; Rear Right Tire
          C105B 00 [032] - Flat
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 G    HW: 8W0 820 043 G
   Component: Klima Zone 3  H32 0052
   Coding: 141800285544400D02000100800000000000000000000000000000000000
   Shop #: WSC 06325 790 00001
   ROD: EV_AirCondiBHTCAU491.rod
   VCID: 372AD0E30FC360CF38D-8062
   Subsystem 1 - Part No SW: 4M1 820 021     HW: 4M1 820 021
   Component: J216 FLuftV  H05 0001
   Serial number: 00000000000000730516
   Component: AQ_Hum_Sensor  H01 0003
   Serial number: AA998C08000000000001
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: Klima Heck  H34 0050
   Part No SW: 8W0 907 063 AG    HW: 8W0 907 063 G
   Component: BCM1 MLBevo   H12 0228
   Coding: 07501143E17900CD01458714182C00B9130331000000000000000000600016810A4501AB22B70A
   ASAM Dataset: EV_BCM1BOSCHAU736 015005
   ROD: EV_BCM1BOSCHAU736_015.rod
   VCID: 00587B3F1A8DE777C97-8054
   Subsystem 1 - Part No SW: 8W1 955 119     HW: 8V1 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS491 151129  043 0813
   Serial number: 894353?0401533304257
   Coding: 5BC7F7
   Serial number: 61236189
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AA    HW: 4M0 941 531 AA
   Component: E1 - LDS  H06 0008
   Serial number: 20 11 2015  00160617
   Serial number: GX1CE114121511910248
   Coding: 030000
   Interior Light Module:
   Subsystem 5 - Part No SW: 8W0 947 135 D    HW: 8W0 947 135
   Component: J528-Dachele  H13 0082
   Serial number: B00060789
   Subsystem 6 - Part No SW: 8W0 925 301 BF    HW: 8W0 925 301 BF
   Component: SL-B9/Q5NF  H15 0010
   Serial number: 2815000132580005
   Part No SW: 8W0 907 561 B    HW: 8W0 907 561
   Component: LRR4          H08 0220
   Coding: 3477FFF358FFEC0A949C80A0
   ASAM Dataset: EV_ACCBOSCHAU49X 002018
   ROD: EV_ACCBOSCHAU49X_002.rod
   VCID: 3D26C2CB2DFF4A9FE21-8068
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655     HW: 8W0 959 655
   Component: Airbag10.44   H52 0084
   Serial number: 003M6001KEXD
   Coding: AECCF0C00C800000985400F3C00C00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 005012
   ROD: EV_AirbaAU10BPAAU736_005_AU49.rod
   VCID: 06546D2738A9C947F3B-8052
   Belt Pretensioner left:
   Subsystem 1 - Part No SW: 4M0 980 945     HW: 4M0 980 945
   Component: BeltPretRevFL  205 2033
   Serial number: 8W0857705A0027Q00545
   Coding: 88001B
   Belt Pretensioner right:
   Subsystem 2 - Part No SW: 4M0 980 946     HW: 4M0 980 946
   Component: BeltPretRevFR  205 2033
   Serial number: 8W0857706A0028Q01258
   Coding: 88001B
   Subsystem 3 - Part No SW: -----------    HW: 442 061 301 16
   Serial number: 3577Y009B1AA1C848304
   Subsystem 4 - Part No SW: -----------    HW: 442 060 501 16
   Serial number: 3587Y00C11AF3D11B12%
   Subsystem 5 - Part No SW: -----------    HW: 442 0B0 901 16
   Serial number: 3517700C51E4DF12015A
   Subsystem 6 - Part No SW: -----------    HW: 442 0B0 901 16
   Serial number: 3527700BB1E673E2524I
   Subsystem 7 - Part No SW: -----------    HW: 442 0C1 701 16
   Serial number: 3557500B11E5C6B6237I
   Front Sensor Passenger:
   Subsystem 8 - Part No SW: -----------    HW: 442 0C1 701 16
   Serial number: 3567500B11E5C6B120FJ
   Pedestrian Protection Center:
   Subsystem 9 - Part No SW: -----------    HW: 442 0C1 601 16
   Serial number: 2307500BD1E9F115D0CQ
   Subsystem 10 - Part No SW: -----------    HW: 442 432 101 16
   Component: PedPSensor_D2  256 0887
   Serial number: I0M9M00B71AA1C83340C
   Subsystem 11 - Part No SW: -----------    HW: 442 432 101 16
   Component: PedPSensor_P2  256 0887
   Serial number: I0N9M00C11AA1C83656I
   Part No SW: 4M0 907 129 HH    HW: 4M0 907 129 HH
   ROD: EV_SMLSKLOAU736_006.rod
   VCID: 7DA602CB6D7F8A9FA21-8028
   Part No SW: 8W5 920 790 B    HW: 8W5 920 790 B
   Component: FBenRDW       H12 0275
   Coding: 048451C07C98000800A3E9601000400000000000
   ASAM Dataset: EV_DashBoardAU736 001020
   VCID: 41DEBE3B51072E7F869-8014
   Part No SW: 4M2 907 468 A    HW: 4M2 907 468 A
   Component: Gateway       H13 4079
   Revision: 3C060055    Serial number: 5543C01D716119
   Coding: 0301000100000F4044000000005900125C900007000000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 002040
   ROD: EV_GatewCONTIAU736_002_AU49.rod
   VCID: 3634DDE708C999C723B-8062
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0002
   Serial number: 20160119210308 02185
   Subsystem 2 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 0995168903
   Part No SW: 4M0 907 397 AC    HW: 4M0 907 397 C
   Component: LCM_MLBevoH05 0023
   VCID: 78A813DF425DAFB7F17-802C
   Part No SW: 4M0 907 566 B    HW: 4M0 907 566
   Component: MRR1Rear      H13 0230
   Revision: --------
   Coding: 0EC002
   Shop #: WSC 06324 790 00001
   ASAM Dataset: EV_RearRadarS1BoschAU736 001015
   VCID: 3430E7EF1EB58BD71DF-8060
   Part No SW: 4M0 959 793 G    HW: 4M0 959 793 C
   Component: TSG FS        009 0052
   Serial number: 0000183754786
   Coding: 001F9B2150000080000010B0
   VCID: 42DCB137540135679F3-8016
   Part No SW: 8W0 909 144 F    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0407
   Coding: 0D888080008080
   ASAM Dataset: EV_EPSZFAU49X 002015
   ROD: EV_EPSZFAU49X_002.rod
   VCID: 40D8BB3F5A0D2777897-8014
   Part No SW: 8W0 907 064 CC    HW: 8W0 907 064 C
   Component: BCM2 MLBevo   016 0344
   Coding: 01340000000000A0630980000E00000033004000004F02502F0400000104803F001F0001000000
   ASAM Dataset: EV_BCM2HellaAU736 012013
   ROD: EV_BCM2HellaAU736_012_AU49.rod
   VCID: 7F5AF8C36773988FB0D-802A
   Subsystem 1 - Part No SW: 3AA 962 243 F    HW: 3AA 962 243 F
   Component: GEB.F.Heckoef  H16 0816
   Serial number: 94063857
   Part No SW: 4M0 959 792 D    HW: 4M0 959 792 C
   Component: TSG BFS       009 0050
   Serial number: 0000183284087
   Coding: 001F9B215C000080000010B0
   VCID: 3E24C5C720F95187FBB-806A
   Part No SW: 8W0 035 036 R    HW: 8W0 035 036 A
   Component: MU-P-LN-EU    051 0442
   Serial number: A667A0GB007049
   Coding: 01940101FF0A000013110001000A00332F0002E5017001009E
   Subsystem 1 - Part No SW: V03 959 801 FA    HW: -----------
   Component: ECE 2016  --- 0134
   Subsystem 2 - Part No SW: 8W0 919 605     HW: 8W0 919 605
   Component: AU49x_DU_HIGH  H40 0008
   Serial number: AUZ8Z9FBJ00RS5
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 P    HW: 8W0 919 614 P
   Component: ControlUnit_H  H22 0139
   Serial number: C1000011121500040032
   Compact Disc Database:
   Component: Gracenote2  --- 1011
3086 - Antenna for Telephone Mount
          B1564 01 [008] - Electrical Failure
                    Reset counter: 30
                    Mileage: 51524 km
                    Date: 2019.10.02
                    Time: 17:29:01
                    Voltage terminal 30: 14.6 V
                    Status of telephone-Antenna diagnostic: OK
                    Status of telephone-Telephone baseplate diagnostic: not connected
                    Status of telephone-Handset in handset holder (cradle): selected
                    Status of telephone-Handset holder (cradle): connected
   Part No SW: 4M0 907 428 D    HW: 4M0 907 428
   Component: Areaview 2    H11 0311
   Serial number: C854606JG002918
   Coding: 02940101BE0FA10008404000
   ASAM Dataset: EV_CamSysRVAV2CE2MLBEv 004015
   ROD: EV_CamSysRVAV2CE2MLBEv_004.rod
   VCID: 3332E4F31BBB8CEF045-8066
Address 74: Chassis Control (J775)       Labels:* None
   Part No SW: 8W0 907 777 C    HW: 8W0 907 777 C
   Component: Fahrwerk-SG   H34 1203
   Serial number: 1401160186
   Coding: 1050404158
   ASAM Dataset: EV_ChassContrContiAU426 001001
   ROD: EV_ChassContrContiAU426.rod
   Part No SW: 8W1 713 041 E    HW: 8W1 713 041 E
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20160105000189
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   ROD: EV_GSMWaehlZFAU736.rod
   VCID: 3536DAEB15CF92DF2A1-8060
Address 8B: Adaptive Cruise 2 (J850)       Labels: None
   Part No SW: 8W0 907 541 B    HW: 8W0 907 541
   ASAM Dataset: EV_ACC2BOSCHAU49X 002018
   ROD: EV_ACC2BOSCHAU736_002_AU73.rod
   VCID: 3B22CCD333EB44AFDC5-806E
Address A5: Frt Sens. Drv. Assist (R242)       Labels:* Redir Fail!
   Part No SW: 8W0 907 217 B    HW: 8W0 907 217
   Component: BVS           H13 0042
   Coding: 0404090100000404022023A6CD0000FCB0F0C020C020
   ROD: EV_BVSMLBevKOSTAAU736_AU49.rod
Address AC: Reductant Control (J880)       Labels: 4M0-907-355.clb
   Part No SW: 4M0 907 355     HW: 4M0 907 355
   Component: SCR-Stg-G3H10 0003
   ASAM Dataset: EV_RDCMINERGAU736 005009
   ROD: EV_RDCMINERGAU736_AU49.rod
   VCID: 6E8435873019E1072BB-803A
   Part No SW: 4M0 959 795 D    HW: 4M0 959 795 C
   Component: TSG HFS       009 0050
   Serial number: 0000183350600
   Coding: 000F992000000080000010A0
   Component: TSG HBFS      009 0050
   Serial number: 0000183350599
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
Address CF: Lane Chge Asst 2 (J770)       Labels: None
   Part No SW: 4M0 907 590 B    HW: 4M0 907 590
   Revision: --------
   Coding: 0EC002
   ASAM Dataset: EV_RearRadarS2BoschAU736 001015
   VCID: 313EEEFBE1A7BEFF769-8064
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 16743D67680979C703B-8042
   Component: LED1R         H09 0003
End----(Elapsed Time: 01:57, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
TBAx
C?ID=287144
Maybe a software bug in your VC/AID?
Can you post a video.
dgp
Australia
C?ID=380715
Isn’t your tacho just returning to the idle position?
TBAx
C?ID=287144
I guess dgp is correct. It just looks a bit choppy, which is because of the digital cockpit not having to control/actuate an actual needle, which would result in a smooth movement.
