Hello there,
I need help.
The unit J234 from the Airbag System, is not allowing to / rejects the cleaning of the errors.
I send 3 pictures that show the errors and the Log of the SCAN:
In the adaptation, the function CRC also is rejected by the unit.
I would really appreciate a lot of help in this one.
I think it will also need a code to make the adaptation of the CRC.
I need help.
Thursday,17,October,2019,12:43:06:52040
VCDS Version: 19.6.2.0
VIN: WVWZZZ6RZFY070296 License Plate:
Mileage: 148357km-92184mi Repair Order: URBANO
Chassis Type: 6R-VW26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZFY070296 Mileage: 148357km-92184miles
Address 01: Engine (J000-CUSB) Labels:. 04B-907-445-V1.clb
Part No SW: 04B 906 027 AL HW: 04B 907 445
Component: R3 1.4l TDI H07 2762
Revision: 21003001
Coding: 01114012430401080000
Shop #: WSC 00788 648 00255
ASAM Dataset: EV_ECM14TDI03004B906027AL 003001
ROD: EV_ECM14TDI03004B906027_003_VW26.rod
VCID: 6BDE53EA824EB81762-803E
Readiness: N/A
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 HW: 6R0 907 379 BA
Component: ESP9.0i H03 0002
Serial number: 08501357140504
Coding: 21DD2885892A33C0091610720057841491CC90080007C5090C00
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 6CDC50F68740BF2F6B-8038
0608 - TPMS Display
C1146 F0 [137] - Not Available
Reset counter: 164
Mileage: 148357 km
Date: 2019.10.17
Time: 12:27:33
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6C0 820 045 A HW: 6C0 820 045 A
Component: AC Manuell H02 0103
Serial number: 1405261B-0403
Coding: 201000001000000200
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 1D3A4D320C7A86A7AC-8048
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 A HW: 6C0 937 089
Component: BCM PQ26 Hi4R H06 BCM PQ26 Hi4R H06 00470047
Serial number: 007278006845
Coding: 000008404253005B4B844000400703880000580251010000000000000000
ASAM Dataset: EV_BCMA0 004003
ROD: N/A
VCID: 2E589AFE71DC0D3F05-807A
Drivers Door Control Module:
Subsystem 1 - Part No SW: 6R0 959 801 AT HW: 6R0 959 801 AT Labels: 6R0-959-801.CLB
Component: J386__TSG_FT 003 8612
Serial number: KU0KU013051441338575
Coding: 0400A0
Subsystem 2 - Part No SW: 6R0 959 802 BE HW: 6R0 959 802 BE Labels: 6R0-959-802.CLB
Component: J387__TSG_BT 003 8612
Serial number: KU0KU013051441332625
Coding: 1400A0
Subsystem 3 - Part No SW: 6R0 959 811 N HW: 6R0 959 811 N
Component: J388__TSG_HL 003 8610
Serial number: KU0KU019051441393133
Coding: 0400A0
Subsystem 4 - Part No SW: 6R0 959 812 N HW: 6R0 959 812 N
Component: J389__TSG_HR 003 8610
Serial number: KU0KU022051441422857
Coding: 1400A0
8202 - Bulb for Left DRL
B121D 15 [009] - Open or Short to Plus
Reset counter: 164
Mileage: 148357 km
Date: 2019.10.17
Time: 12:27:35
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 A HW: 6C0 959 655 A
Component: VW20Airbag01B 001 0330
Revision: -------- Serial number: 003LM002597Q
Coding: 88C0C000000000005C0000CA000800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3162818260E212C718-8064
Subsystem 1 - Part No SW: ----------- HW: 410 820 805 14
Component: SideSensor_Df 151 0800
Serial number: 3575H00AB1569C5232FW
Subsystem 2 - Part No SW: ----------- HW: 410 820 805 14
Component: SideSensor_Pf 151 0800
Serial number: 3585H00A9155F0B0523I
Subsystem 3 - Part No SW: ----------- HW: 442 150 905 14
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00AF1519FB4C27W
Subsystem 4 - Part No SW: ----------- HW: 442 150 905 14
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00B31519FB652EO
8 Faults Found:
0015 - Internal Control Module Memory Check Sum Error
B2000 00 [008] - -
Mileage: 146884 km
Date: 2019.09.27
Time: 19:34:32
0168 - Internal Control Module Memory Check Sum Error
B2000 00 [137] - -
Mileage: 146977 km
Date: 2019.09.28
Time: 13:42:43
9629952 - Indicator Lamp for Passenger Airbag Enabled
B12F1 00 [136] - -
Mileage: 146841 km
Date: 2019.09.27
Time: 18:46:07
10487296 - Control Module Does Not Match Vehicle
B2006 00 [008] - -
Mileage: 146841 km
Date: 2019.09.27
Time: 18:46:08
0027 - Internal Control Module Memory Check Sum Error
B2000 00 [137] - -
Mileage: 146884 km
Date: 2019.09.27
Time: 19:34:32
9445397 - Key switch for deactivation of passenger-side airbag
B1020 15 [136] - Open or Short to Plus
Mileage: 148322 km
Date: 2019.10.14
Time: 17:24:49
9445417 - Key switch for deactivation of passenger-side airbag
B1020 29 [136] - Signal Implausible
Mileage: 146870 km
Date: 2019.09.27
Time: 19:26:05
9446677 - Redundant signal path for airbag shut-off; passenger side
B1025 15 [136] - Open or Short to Plus
Mileage: 148322 km
Date: 2019.10.14
Time: 17:24:49
Part No SW: 6C0 920 741 A HW: 6C0 920 741 A
Component: KOMBI 211 0260
Coding: 072409002180000800082A001000000000000000
ASAM Dataset: EV_DashBoardVDDMQBAB 009036
VCID: 214271C23002A24788-8074
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 HW: 6C0 937 089
Component: GW MQB A0 H06 0047
Revision: -------- Serial number: 007278006845
Coding: 030100044F0A590071000000000000010001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 001001
ROD: EV_GatewA0Lear_001_VW26.rod
VCID: 65CA25D264AA8E6734-8030
Subsystem 1 - Part No SW: 6C0 959 442 HW: 6C0 959 442 Labels: 3C8-959-537.CLB
Component: E221__MFL-TAT H03 0015
Serial number: 1391403580300457AB1B
Coding: 240000
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 61139N38512821225682
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 M HW: 6C1 909 144 D
Component: EPS_TRW_ALow 312 3211
Serial number: PE640137
Coding: 0007
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: 32608E8E65E429DF61-8066
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-ENT2.clb
Part No SW: 6C0 035 869 B HW: 6C0 035 869 B
Component: MU-E--ER 820 6180
Serial number: 30051400011288
Coding: 02620000BE00000041110001000000001F0000840000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001017
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 2A5096EE4D34611FD9-807E
End-------------------------(Elapsed Time: 03:14)--------------------------
