09 Central Elects, the coding shows 00000000000000000000000000
mrlapou
C?ID=42756
Currently do not have forum permission to post a thread in VCDS Support section.
Just carried out a scan with the new upgrade HEX-V2 cable and latest version of VCDS software.
My question is, under : 09 Central Elects, the coding shows 00000000000000000000000000
Why is this?
A window popped up asking if I was agreeing to using a VIN number token to do an adaption. I entered the last 3 digits in the pop up window believing it was the vin number for the car. Was this the correct vin to enter or should it have been the vin at the top of the scan?
Tuesday,15,October,2019,11:01:51:33763
VIN: WVGZZZ5NZHW827920   License Plate: FL66NYW
Mileage: 54456km-33837mi   Repair Order:
Chassis Type: 5N-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 29 39 42 44 52 55 5F 6C
          6D A5 BB BC CA D6 D7
VIN: WVGZZZ5NZHW827920   Mileage: 54456km-33837miles
CA-Sunroof -- Status: Malfunction 0010
D6-Light Ctrl Left 2 -- Status: Malfunction 0010
D7-Light Ctrl Right 2 -- Status: Malfunction 0010
Address 01: Engine (J623-DFGA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 026 HT    HW: 04L 907 309 P
   Component: R4 2.0l TDI   H24 3030
   Revision: B4H24---
   Coding: 0125003203661D082000
   ASAM Dataset: EV_ECM20TDI01104L906026HT 004002
   ROD: EV_ECM20TDI01104L906026GP_004.rod
   VCID: 035388274B9D262FD45-8056
12002 - Diesel Particle Filter; Differential Pressure Sensor
          P2453 00 [237] - Implausible Signal
                    Mileage: 54225 km
                    Date: 2019.10.10
                    Time: 12:38:55
                    Engine speed: 0.00 /min
                    Coolant temperature: 86 ∞C
                    Intake air temperature: 57 ∞C
                    Voltage terminal 30: 13.180 V
                    Particle filter: air pressure sensor 1 bank 1: raw value: 579 hPa
                    Particl.filt.: different.press.sensor 1 bank 1: adaptat. value: 379 hPa
                    Par.fil: diff.pr.sens.1 bank 1: offset: 134 hPa
                    Particl.filt.: differential pressur.sensor 1 bank 1: dyn.offset: 200 hPa
                    Extern.temp.sens.1 bank 1: raw value: 14.0 ∞C
                    Particle filter: soot mass measured: 13.45 g
                    Particle filter: soot mass calculated: 12.95 g
31489 - Differential Pressure Sensor for DPF
          P154B 00 [175] - Faulty
                    Fault Frequency: 9
                    Mileage: 54123 km
                    Date: 2019.10.06
                    Time: 18:56:45
                    Coolant temperature: 20 ∞C
                    Intake air temperature: 22 ∞C
                    Voltage terminal 30: 12.520 V
                    Engine status: COENG_STANDBY
                    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
31490 - Differential Pressure Sensor for DPF
                    Fault Frequency: 9
                    Mileage: 54123 km
                    Date: 2019.10.06
                    Time: 18:56:45
9879 - Sense Circuit for Heater for NOx Sensor 1 Bank 1
          P2209 00 [096] - Implausible Signal
                    Mileage: 54379 km
                    Date: 2019.10.13
                    Time: 18:02:44
                    Engine speed: 1464.00 /min
                    Normed load value: 73.3 %
                    Vehicle speed: 84 km/h
                    Coolant temperature: 65 ∞C
                    Intake air temperature: 63 ∞C
                    Voltage terminal 30: 14.400 V
                    NOx sensor before SCR cat conv: NOx concentration: 79 ppm
                    NOx sensor before SCR catalytic converter: supply voltage: 14080 mV
                    Extern.temp.sens.1 bank 1: raw value: 12.0 ∞C
                    Mean injection quantity: 18.90 mg/stroke
Readiness: 1 3 0 0 0
   Part No SW: 0DL 300 011 A    HW: 0DE 927 711
   Component: GSG DQ500     H12 1412
   Revision: 00H12V32
   VCID: 2615F1B3986F330793B-8072
   Part No SW: 5Q0 614 517 BH    HW: 5Q0 614 517 AD
   Component: ESC           H25 0507
   Revision: 00000000    Serial number: 62316000000777
   Coding: 0AEE929A34220B734780670262C34950492CD0E2E646927D38625078C22A02
   VCID: 78A9EFCB025B75F7F17-802C
8352 - Databus
          [FCAN: TSG_FT_02 is not received]
                    Reset counter: 155
                    Mileage: 52512 km
                    Date: 2019.09.14
                    Time: 11:50:32
Address 08: Auto HVAC (E87)       Labels:| 3V0-907-044.clb
   Part No SW: 5NA 907 044 K    HW: 5NA 907 044 K
   Component: AC Automat    H35 4003
   Revision: 20K08000    Serial number: 00000B00213997
   Coding: 0012012420211001110510000010112A
   ASAM Dataset: EV_ACClimaPrehVW37X 002014
   ROD: EV_ACClimaPrehVW37X.rod
   VCID: 47CB5C373F25CA0F48D-8012
   Subsystem 1 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
   Component: E265KlimaHeck  H02 0201
459021 - Databus
          [T¸rsteuerger‰t Fahrerseite - kein Signal/Kommunikation]
                    Reset counter: 155
                    Mileage: 52512 km
                    Date: 2019.09.14
                    Time: 11:50:32
   Part No SW: 5Q0 937 084 CG    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H34 0236
   Serial number: 02001623903987
   ROD: EV_BCMBOSCH_017.rod
   VCID: 7F5B04D7277542CFB0D-802A
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 160728  033 0372
   Serial number: 00000001607250306391
   Component: RLHS  042 0105
   Serial number: S5Y16M08D31H12M56S12
   Coding: 06A8DD
   Serial number: 000000000ZY161960H5R
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000066838942
549909 - Databus
          [TSG_FT_01 Datenbus fehlende Botschaft]
                    Reset counter: 155
                    Mileage: 52512 km
                    Date: 2019.09.14
                    Time: 11:50:31
551445 - Databus
          [TSG_HFS_01 Datenbus fehlende Botschaft]
                    Reset counter: 155
                    Mileage: 52512 km
                    Date: 2019.09.14
                    Time: 11:50:31
   Part No SW: 3Q0 919 298 A    HW: 3Q0 919 298
   Component: PLA 3.0 12K   H10 0021
   Serial number: 001808167478092
   Coding: 0331563851
   ASAM Dataset: EV_EPHBO2CVW3260000 010016
   ROD: EV_EPHBO2CVW3260000.rod
   VCID: 3B2330C773ED9EEFDC5-806E
13679388 - Databus
          [Lenkhilfe - LH_EPS_01.EPS_PLA_Status - Fehlerspeicher auslesen]
                    Reset counter: 180
                    Mileage: 52512 km
                    Date: 2019.09.14
                    Time: 15:31:45
1080304 - Parking Sensor(s); Rear
          B107B F0 [008] - Function Limitation due to External Factors
                    Reset counter: 169
                    Mileage: 53663 km
                    Date: 2019.09.24
                    Time: 10:36:58
   Component: ACCCONTIMQB   H01 0233
   Coding: 320067C358FF8728749C8145304087
   VCID: 3E2539D360FF8BC7FBB-806A
1086 - Databus
          [FAULT_TIMEOUT_TSG_FT_02]
                    Reset counter: 155
                    Mileage: 52512 km
                    Date: 2019.09.14
                    Time: 11:50:32
                    Voltage terminal 15: 12.0 V
                    Control Module temperature: 44 ∞C
                    Longitudinal_acceleration_vehicle_reference: 0.28 m/s≤
0836 - Databus
          [FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
                    Fault Frequency: 17
                    Reset counter: 170
                    Mileage: 52542 km
                    Date: 2019.09.15
                    Time: 10:32:09
                    Voltage terminal 15: 13.9 V
                    Control Module temperature: 36 ∞C
                    Longitudinal_acceleration_vehicle_reference: 0.03 m/s≤
   Part No SW: 5Q0 959 655 AR    HW: 5Q0 959 655 AR
   Component: AirbagVW21    003 0315
   Serial number: 003TDR228A3B
   Coding: 98CCC0C00C0000005C5400CF008800000065
   VCID: 1079B76B0AEB4DB7597-FFFE
   Serial number: 5NC857705C0237Q01617
   Coding: 80000D
   Serial number: 5NC857706C0236Q00996
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 002 608 16
   Serial number: 357000000008D215CD1R
   Subsystem 4 - Part No SW: -----------    HW: 480 002 508 16
   Serial number: 358000000005EB399D1
   Subsystem 5 - Part No SW: -----------    HW: 480 402 908 16
   Serial number: 3510001A72216EE1F2FD
   Subsystem 6 - Part No SW: -----------    HW: 480 400 109 16
   Serial number: 3520001BD22707F19585
   Subsystem 7 - Part No SW: -----------    HW: 480 402 808 16
   Serial number: 3550001AB2216EE3F50B
   Subsystem 8 - Part No SW: -----------    HW: 480 402 608 16
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001A52216EE364D7
   Subsystem 9 - Part No SW: -----------    HW: 480 402 608 16
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001AD2216EE1C3EK
   Subsystem 10 - Part No SW: -----------    HW: 480 402 608 16
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001A52216EE632A
   Subsystem 11 - Part No SW: -----------    HW: 480 002 308 16
   Serial number: I0M000000004C37DDD1K
   Subsystem 12 - Part No SW: -----------    HW: 480 002 308 16
   Serial number: I0N00000000494BC0E1A
1054464 - Databus
          [NWD: 0x117 ACC_10 Timeout]
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20160824400233
   Coding: 0C10
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 41DF422F1101F43F869-8014
   Part No SW: 5NA 920 791 A    HW: 5NA 920 791 A
   Component: KOMBI         405 2153
   Coding: 27A400086F84260001886B031401000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
16776994 - Databus
          [TSG_FT_02 keine Kommunikation]
                    Reset counter: 155
                    Mileage: 52512 km
                    Date: 2019.09.14
                    Time: 11:50:32
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1265
   Revision: --------    Serial number: 0005238889
   Coding: 030500041F087300FB07225E1E0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 7CA1F3DB366359D795F-8028
   Subsystem 2 - Part No SW: 5TA 959 442 B    HW: 5TA 959 442 B  Labels: 3C8-959-537.CLB
   Serial number: 2231623360302477AS2B
   Coding: 2D0000
131658 - Door Control Module - Driver's Door
          U0199 00 [008] - No Communications
          [Timeout Knoten 0x4A / 42 - T¸rsteuerger‰t Fahrerseite]
                    Reset counter: 155
                    Mileage: 52512 km
                    Date: 2019.09.14
                    Time: 11:50:34
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: On
197175 - Control unit for battery monitoring
          U1050 00 [009] - No Communication
          [BDM (LIN#1) Timeout]
                    Reset counter: 114
                    Mileage: 52512 km
                    Date: 2019.09.14
                    Time: 10:03:31
                    Supply voltage: Terminal 30: 12.1 V
                    Terminal 15: On
   Serial number: HA1-00019.07.16
   Coding: 0101
   VCID: 4ACD65032C373767573-801E
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 B    HW: 8V0 907 399 B
   Component: LCM_MLBevoH07 0014
   VCID: 45D7563F0529D81FBA1-8010
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Serial number: 060416ED313449
   Coding: 003F0A20D001048000001000
   VCID: 43D348270B1DE62F945-8016
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 9307
   ROD: EV_SteerAssisMQB_013.rod
   Serial number: 150816EHE01951
   Coding: 003F0020DE01048000001000
   VCID: 42DD4D231407EF279F3-8016
65570 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [T¸relektronik Fahrer (J386)]
                    Reset counter: 155
                    Mileage: 52512 km
                    Date: 2019.09.14
                    Time: 11:50:32
65572 - Local Data Bus
          U10BA 00 [008] - No Communication
          [T¸relektronik Fahrerseite hinten (J388)]
                    Reset counter: 155
                    Mileage: 52512 km
                    Date: 2019.09.14
                    Time: 11:50:32
   Part No SW: 7P6 907 357 E    HW: 7P6 907 357 A
   Component: AFS-ECU       H07 0051
   Coding: 08AE00104B200201
   ROD: EV_HeadlRegulAFSMQBMAX_VW37.rod
   Part No SW: 3Q0 035 874 B    HW: 3Q0 035 874 B
   Component: MU-S-ND-ER    840 0757
   Coding: 02730601FF00000051110101008808001F0100E6012000008F
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 313F12EFA1A164BF769-8064
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL038HB
   Subsystem 2 - Part No SW: 5NA 919 866     HW: -----------
   Component: ECE1 2018/19  --- 1030
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0123060122002017000040
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
   VCID: 77ABECF70F457A8FF8D-8022
   Part No SW: 5Q0 959 107 J    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0253
   Revision: --------    Serial number: 30871625900000
   Coding: 0A00
   ASAM Dataset: EV_DeckLidCONTIAU736 001012
   VCID: 3FDB44D767F582CFF0D-806A
0056 - Databus
                    Reset counter: 155
                    Mileage: 52512 km
                    Date: 2019.09.14
                    Time: 11:50:35
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 17081611K10276
   Coding: 000307060000040100021344C050A10094000E200040
   VCID: 3A2D35C37CD7A7E7C73-806E
1135140 - Databus
          [APS_03_US_Fehler_HS]
                    Reset counter: 169
                    Mileage: 53663 km
                    Date: 2019.09.24
                    Time: 10:36:58
                    Control Module temperature: 42 ∞C
                    Outside air temperature: 16.0 ∞C
                    Vehicle speed: 73.22 km/h
                    System run time: 13170.3 s
                    Voltage terminal 15: 14.0 V
                    mid: 02 65
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 0
                    Software_Info_3: 2
                    Software_Info_2: 2
                    Software_Info_1: 0
   Serial number: 290716EGS03559
   Coding: 002A00200100048000001000
   Serial number: 290716EGS0325A
   Part No SW: 4M0 907 594 J    HW: 4M0 907 594
   Component: SAD_STG_1     013 0005
   Coding: 308040732602
   ROD: EV_SunRoofCONTIAU736_006.rod
   VCID: 3D273EDF6DF990DFE21-8068
0304 - Databus
                    Reset counter: 155
                    Mileage: 52512 km
                    Date: 2019.09.14
                    Time: 11:50:32
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   VCID: 1675C173280FA38703B-8042
0774 - Light Bulb for Low Beam
          C1198 29 [008] - Signal Implausible
                    Reset counter: 190
                    Mileage: 52944 km
                    Date: 2019.09.21
                    Time: 12:45:15
   Component: LED1R         H09 0003
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
                    Reset counter: 190
                    Mileage: 52944 km
                    Date: 2019.09.21
                    Time: 12:45:15
End----------(Elapsed Time: 02:10, VBatt start/end: 12.0V/12.2V)-----------
South Molton, UK
On 2019 models many modules no longer use long coding, all settings are done using adaptation channels.
Fixed/Verified.
My question is, under : 09 Central Elects, the coding shows 00000000000000000000000000[/code]
Why is this?
Because you have an MK7.5 style BCM and VW has moved everything that could previously be changed in Coding to various Adaptation channels.
Making you type the last three digits of the VIN in order to register the VIN is a means of ensuring that people don't whine at us that they registered a VIN "by accident".
It's primarily BCMs. Just about every other module in his car still has a non-zero coding string.
mrlapou
C?ID=42756
Thanks to all, for the brill replies.
Now need to find a site / list that translates the German terms in adaption selections to English.
^^^^ good way to complete that particular task IMO - is to make an adaptation channel map of your BCM in CSV format - then you will have a database file that can be read by higher order application like MS Excel/MS access etc. After that, and depending on your level of conviction, it's just a matter of copy-and-paste and Mr Google's handy-dandy translator (and dedication)!!
PS: Interesting DTC s - you might start by translating the errors (perhaps) :D
I might be able to help with that:
TSG = Tür Steuer Gerät = Door Control Module.
FT_01 = Fahrer Tür = Driver's Door; not sure what the 01 is about.
HFS_01 = Hinten Fahrer Seite = Rear Driver's Side
Datenbus fehlende Botschaft = Databus Missing Message
Is it possible someone was checking fuses and unpluged one on 2019.09.14?
If it were mine, I would clear those faults and not worry about them unless they come back.
But I would also be more concerned with the Engine faults than anything else. Those have a high probability of leading to a plugged up DPF...
mrlapou
C?ID=42756
Spot on. Some faults codes were caused by unplugging a live fuse. :)
The differential DPF pressure sensor was changed, which cleared the engine management light and all codes.
However after about 350 miles later, scan now shows return of P2209 NOx sensor 1 bank 1 implausible signal. At the same time the supplementarity / quick cabin heater function has stopped working. On the colder days, it takes about 3 miles to feel heat from vents and about 9 miles / 15mins for the cabin temp to come up to about 22c.
The heater fan also does not seem to regulate speed settings.
The Auto supplementary heater setting is on in the climate control 'menu' screen on the headunit.
Here is the latest scan.. The Central Elects fault code
is caused by unplugging the two pin connector on the battery terminal to deactivate the stop/start. I did this on my previous Mk7 TDi with came engine and gearbox as my current Mk3 MY66 Tiguan with no issue.
Thursday,31,October,2019,10:13:49:33763
Mileage: 55045km-34203mi   Repair Order:
VIN: WVGZZZ5NZHW827920   Mileage: 55045km-34203miles
CA-Sunroof -- Status: OK 0000
   Revision: B4H24---
          P2209 00 [101] - Implausible Signal
                    Mileage: 54489 km
                    Date: 2019.10.17
                    Time: 12:21:08
                    Engine speed: 1485.50 /min
                    Normed load value: 73.7 %
                    Vehicle speed: 85 km/h
                    Coolant temperature: 62 ∞C
                    Intake air temperature: 55 ∞C
                    Voltage terminal 30: 14.580 V
                    NOx sensor before SCR cat conv: NOx concentration: 60 ppm
                    Extern.temp.sens.1 bank 1: raw value: 7.0 ∞C
                    Mean injection quantity: 15.21 mg/stroke
28991 - No Communications with NOX Sensor 1
          U029D 00 [036] - -
                    Mileage: 55018 km
                    Coolant temperature: 15 ∞C
                    Intake air temperature: 15 ∞C
                    Voltage terminal 30: 11.440 V
                    Cruise Control System (CCS): status-Bits 0-7: 6
                    CAN status - brake control module 1-Bits 0-7: 8
                    selected gear-Bits 0-7: 0
   Revision: 00H12V32
   Coding: 0E45DD
   Coding: 06A8DD
   Coding: 0331563851
13679388 - Databus
                    Reset counter: 204
                    Mileage: 54575 km
                    Date: 2019.10.19
                    Time: 18:28:29
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 1079B76B0AEB4DB7597-8044
   Belt Pretensioner left:
   Coding: 80000D
   Belt Pretensioner right:
   Coding: 80000D
   Pedestrian Protection Driver:
   Pedestrian Protection Center:
   Coding: 0C10
   Coding: 2D0000
                    Reset counter: 154
                    Mileage: 54473 km
                    Date: 2019.10.16
                    Time: 10:35:54
                    Supply voltage: Terminal 30: 11.6 V
                    Terminal 15: On
66565 - Diagnostic Databus
          U1202 00 [008] - Malfunction
          [Bus defekt CAN-Diagnose]
                    Reset counter: 194
                    Mileage: 54473 km
                    Date: 2019.10.16
                    Time: 16:49:16
                    Supply voltage: Terminal 30: 11.5 V
                    Terminal 15: On
   Coding: 0101
   Coding: 9307
   Coding: 0A00
End----------(Elapsed Time: 01:59, VBatt start/end: 12.0V/12.0V)-----------
You mean the fault in the Gateway?
I would plug it back in for a while as a test. If the Gateway doesn't know the battery's State-of-Charge, it may not allow the auxiliary electric heater to function.
mrlapou
C?ID=42756
Thank you.....Sounds like a good plan which I'll implement...
mrlapou
C?ID=42756
Reconnecting the stop start sensor at battery terminal made no difference!
It didn't cost much to try this though, right?
mrlapou
C?ID=42756
Update.. VW checked the heating systems and found no fault.
Dispite the option to check or uncheck 'auto supplementary heater ' via the head unit, it seems the VW build code label which is stuck on the inside of the service booklet, does not show the code for the heater. Conclusion... one not fitted.
ED: https://www.ebay.co.uk/itm/122967206482/
However the NOx code remained and the sensor was changed.
In the past 3 weeks, the NOx and DPF differential seniors have been changed under warranty, which could have been a huge bill !!!!
