Touareg T1 - Lamp for Low Beam; Left (M29) 007 - Short to Ground
hallkbrdz
Oklahoma, USA
C?ID=52136
I bought the '06 v10 Touareg about a month ago. The headlights worked when I bought it, but were very dim. It had cheap bulbs in it that probably burnt the chrome (lovely).
I replaced the hardly insulated short jumper behind trays that somehow worked, and the bulbs with Sylvania Basic D1S. Both lows worked but were still not very bright. After a week the left light fails to turn on, right at the start of a trip of course...
I then bought a new Valeo ballast and replaced the left one thinking that was the problem. Still no left light, shows the below error in VCDS:
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 N
Component: 3002
Coding: 0111838
Shop #: WSC 22188 444 89171
VCID: 4796E2DA3580D07718-5120
007 - Short to Ground (BUT WHERE?)
Thinking it was the internal headlight module wiring, I bought and replaced the headlight units with new Valeo ones, swapping the low bulbs and ballasts. Still no left light! I cleared the code, turned the vehicle off. Started it up - still the same error.
I tested the short 3-wire jumper from the ballast to the bulb, and it appears to be fine as I swapped left and rights with no change. Then I poked around in VCDS some more and realized that if I select 39 - the right headlight, it connects to the controller fine. If I select 29 - the left headlight, nothing. VCDS cannot find it! The rest of the lights work fine on that side (high, turn, marker). From what I can tell these are all driven from the "Vehicle Electrical System Central Control Unit" module under that dash.
I'm still looking for a good wiring diagram for 2006 xenons so I can actually test voltages and find the short to ground (if that is still true, and not something that just needs to be re-coded or reset). Recommendations?
Thanks in advance,
Bryan
Here is a full scan I did earlier before replacing anything:
Monday,12,August,2019,13:43:53:11556
VCDS Version: 19.6.1.0 (x64)
VIN: WVGPT77L46D063114   License Plate: TOURAG
Mileage: 339690km-211073mi   Repair Order:
0111838
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGPT77L46D063114   Mileage: 339690km-211073miles
   Part No SW: 070 906 016 CQ    HW: 028 101 196 2
   Component: V10 5,0L EDCG000AGMª8472
   Revision: --H02---    Serial number: VWZ3Z0F6459651
   Coding: 0060575
   Shop #: WSC 66565 257 00032
   VCID: 61C21C42BB648E47F6-5120
Address 02: Auto Trans        Labels: 09D-927-750.clb
   Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
   Component: AL 750 6A           0856
   Revision: 00H37000    Serial number:
   Coding: 0004216
   Shop #: WSC 31414 000 00000
   VCID: 7F06BA3A2DD058B7E0-513C
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0022786
   VCID: 3D7A8032675C8AA7B2-513C
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 137 A    HW: 5WK 485 02
   Component: 29 Kessy            6700
   Revision: 67005915    Serial number: VWZ3Z0F6459651
   Coding: 0147688
   VCID: 3162AC02AB047EC726-513C
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77F6521A05E060F7A8-513C
   Part No: 7L6 907 044 T
   Component: CLIMAtronic 2+2     4222
   Coding: 0021030
   VCID: 458AE8D20F8CC267EA-513C
   Subsystem 1 - Part No: 7L6 907 049 E
   Component: CLIMAtronic FOND    0400
00710 - Defroster Flap Positioning Motor (V107)
02600 - Rear Right Temperature Flap Motor (V314)
   Component:                     3002
   Coding: 0111839
   VCID: 4796E2DA3580D07718-513C
Address 11: Engine II        Labels: Redir Fail!
   Component: V10 5,0L EDCG000AGSª8472
   Coding: 0060575
   VCID: 61C21C42BB648E47F6-513C
   Part No: 3D0 909 601 H
   Component: 05 Airbag 8.4E++H01 0562
   Revision: BB38727     Serial number: 0007756?
   Coding: 0012341
   VCID: 2854416698DE3F0FF1-5120
   Subsystem 1 - Part No: 7L0 959 339 C
   Component: BF-Gewichtsens. 006 0008
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 F
   Component: Lenksaeulenmodul    3501
   Coding: 0010032
   Shop #: WSC 31414 790 00001
   VCID: 4280F3CE1EA2F55FCF-5120
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 981 R
   Component: KOMBIINSTRUMENT RB8 3211
   Coding: 0005231
   VCID: 4894E1E6389EDF0F11-513C
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 815 071 D
   Component: Standheizung E1MAC
   Coding: 0000100
   VCID: 336EA60A51184CD754-5120
   Part No: 6N0 909 901
   Coding: 0000006
   Shop #: WSC 22188 444 52556
   VCID: 70E46906608E37CF69-513C
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
   VCID: 458AE8D20F8CC267EA-5120
   Part No: 0AD 927 755 AT
   Component: TRANSFERCASE        0114
   VCID: 0D1A10F2177C7A27E2-513C
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   VCID: 36689F1E426A59FF73-513C
   Component: Sitzverstellung     0703
Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
   Part No: 7L6 919 887 M
   Component:      Navigation     0047
   Coding: 0000101
   VCID: 50A4C986C0CE17CF49-513C
Address 39: Right Light        Labels: 3D0-909-158.lbl
   Part No: 3D0 909 158
   Component: EVG GDL+AutoLWR(r)  0001
   Coding: 0000003
   VCID: 67D6025A5540F07738-5102
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L0 959 933 J
   Component:    HSG              5115
   Coding: 0000085
   VCID: 438EF6CA01B8FC57C4-4B00
   Subsystem 1 - Part No: 7L0 959 701 H
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 H
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 D
   Component: Tuersteuergeraet HR 0201
00927 - Terminal 30 (Right)
01516 - Terminal 30; Left
00926 - Terminal 30
00488 - Rear Right Outside Door Handle Central Locking Button (E372)
   Part No: 7L6 035 456
   Component: 08K Audioverst.     0105
   VCID: 70E46906608E37CF69-5120
   Subsystem 1 - Part No: 7L6 035 456
No Faults Found
Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
   Part No: 7L6 035 186 E
   Component:        Radio        0047
   Coding: 0014062
   VCID: 356A98125F6C52E77A-5120
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 K
   Component: Front Wiper         4027
   Coding: 0000341
   Shop #: WSC 31414 000 376832
   VCID: 3C7C8D367C4683AF85-513C
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   Coding: 0000002
   VCID: 38749126487EAF8F61-5120
   Part No SW: 7L6 907 441     HW: 7L6 907 441
   Component: J772__Rearview      0051
   Revision: 00H07000    Serial number:    PA8 J620637
   Coding: 0000101
   VCID: 72E0630E6E8205DF9F-513C
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 T
   Component: DACHDISPLAY         0539
   Revision: 00900539    Serial number: 2009289.07
   VCID: 4894E1E6389EDF0F11-5120
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 397294227374B6879E-513C
End-------------------------(Elapsed Time: 09:50)--------------------------
South Molton, UK
erWin?
Buy a short subscription, enter your Vin and download every document relevant to your T1 - even if you don't need them now you may need them in the future :thumbs:
hallkbrdz
Oklahoma, USA
C?ID=52136
Yes, I have the erWin wiring diagrams, although they are wrong in regards to the HID bulb. Pins 6 and 8 are for the halogen high beam, not the HID. That of course is from the jumper from the J567 Left Headlight Range Control Module.
I don't see that anything is wrong ground wise that would set off that code - at least now. Is that a stored fault that I somehow need to clear? If not - where does that come from?
Below is what I traced out, and the Volts column shows what I found at each pin with the headlights on in the high-beam mode with the headlight module disconnected.
Pin		Black 14	        White 12	        Size Volts	Actually goes to
1		blk			blk			0.35	     6		Ctrl - J567 Left Headlight Range Control Module - Headlight Range Adjustment Connection
2		blk			blk			0.75	     14	Ctrl - +v J567 Left Headlight Range Control Module - Plus Connection 3
3		orange		orange		0.5	     0.18	Blk +v - N395 Left Headlight Reflector Adjustment Solenoid
4		li			li			0.5	     14	Blk +v - M1 Left Parking Light
5		red			red			0.75	     0.39	Ctrl GND - J567 Left Headlight Range Control Module - From J519 Vehicle Electrical System
6		orange		orange		1.5	     0.19	(1) Blk +v - M30 Left High Beam Headlight (passing)
7		brn			brn			0.5	     0		Ctrl GND - J567 Left Headlight Range Control Module
8		brn			brn			1.5	     0		(1) Brn GND - M30 Left High Beam Headlight  (passing) and N395 Left Headlight Reflector Adjustment Solenoid
9		li			li			0.75	     0.13	Blk +v M5 Left Front Turn Signal Light
10		brn			brn			1.0	     0		Brn GND - M5 Left Front Turn Signal Light and M1 Left Parking Light
11		blk			blk			0.35	     9.16	Ctrl - J567 Left Headlight Range Control Module - OBD Connection 1
12		blk			blk			0.35	     11.52	Ctrl - J567 Left Headlight Range Control Module - Headlight Range Adjustment Connection
13		Unused		N/A
14		Unused		N/A
Voltage reference is to Pin 10 as ground
(1) erWin shows J343 Left High-intensity Gas Discharge Lamp Control Module
J343 Left High-intensity Gas Discharge Lamp Control Module connects through J567 Left Headlight Range Control Module
hallkbrdz
Oklahoma, USA
C?ID=52136
I tried swapping the right headlight into the left side - no surprise, no low beam.
I then measured the same pins on the right side. Pin voltages side by side:
Pin - Left / Right
1 - 6 / 6
2 - 14 / 14
3 - 0.18 / 14
4 - 14 / 14
5 - 0.39 / 14
6 - 0.19 / 0.05
7 - 0 / 0 - Ground
8 - 0 / 0 - Ground
9 - 0.13 / 0.18
10 - 0 / 0 - Reference ground
11 - 9.16 / 9.12
12 - 11.52 / 11.52
So to activate the low beam I should have +14 on 3 and 5 where I now have what look like low float voltages - not shorts. So the J519 Vehicle Electrical System Control Module seems suspect.
I see in erWin references to a self diagnostic. Can I do that with VCDS?
If I do need to replace the J519, which I believe is the BCM 7L6937049(N) - where would I code that?
Thanks in advance
MartinsX
Riga, Latvia
C?ID=268515
Maybe check fuses and wiring first ;)
hallkbrdz
Oklahoma, USA
C?ID=52136
I did. The fuses are fine (verified with a VOM) and all of the wiring was replaced with new, except for the main harness. Based on the voltage values, nothing is actually shorted to ground. Before with the cracked and missing insulation - sure.
For now I'm just going to splice in a relay in the headlight tray jumper triggered by the running lights for 3 and 5 to supply voltage for the low beam.
hallkbrdz
Oklahoma, USA
C?ID=52136
Resolved. It was a bad contact on the left #35 fuse. Checked good (12v both sides), but found it as I got desperate and removed and reinserted every single fuse. Figures...
35 15A Vehicle electrical system control module – Headlamps (high/low beam)
