2018 Audi Q3 1.4 TFSi. Fuel bleed after tank replacement
invernesspl
C?ID=345478
Hi,
I have a 2018 Audi Q3 1.4 TFSi. The fuel tank was damaged and has now been replaced. I have put 10 litres of fuel in the new tank, but I cannot get the car to start. VCDS is not showing any faults, but I am guessing that the fuel lines need to be bled?
Can anyone help? I can't seem to find how to get the fuel pump to run in VCDS or any info on how to bleed it.
Many thanks.
Jef
HQ
Fault codes or not, please always include a full Auto-Scan. If I want to try and look at wiring diagrams for this... I have no clue what I'm digging into...... I don't know what ECM you have installed.... all I know is this is some 2018 Q3 with some 1.4 and I'm a bit dim so I need a better starting point that the Auto-Scan gives.
Regards.
invernesspl
C?ID=345478
Regards.
Thanks for reply, i'll copy the Auto Scan in the morning and post it here.
invernesspl
C?ID=345478
Regards.
Hi, here is the autoscan:
Wednesday,16,October,2019,11:13:15:41168
VIN: WAUZZZ8U8JR052298   License Plate:
Chassis Type: 8U-AU21 (8U0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 44 46 52 55 5F 62 6D 72
VIN: WAUZZZ8U8JR052298   Mileage: 2840km-1764miles
Address 01: Engine (J623-CZEA)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 LA    HW: 04E 907 309 CN
   Component: R4 1.4l TFS   H24 3859
   Revision: R8H24---
   Coding: 001D0032242419082000
   Shop #: WSC 00049 770 00163
   ASAM Dataset: EV_ECM14TFS01104E906027LA 001003
   ROD: EV_ECM14TFS01104E906027LA.rod
   VCID: 6E85CDD0701D0877285-803A
Readiness: 1110 0001
   Part No SW: 02E 300 066 L    HW: 02E 927 770 AT
   Component: GSG DSG AG6     541 5205
   Revision: 06454104    Serial number: 00001711140193
   VCID: 221DE9E0F8C5FC17FCD-8076
Address 03: ABS Brakes (J104)       Labels: 5N0-614-109-V1.clb
   Part No SW: 5N0 614 109 CL    HW: 5N0 614 109 CL
   Component: ESC-EBC460iV1 H14 0014
   Serial number: A01NZ7W
   Coding: 21F124A1B125E36E2079840924CB8DC704365700F08B4881
   ASAM Dataset: EV_Brake1ESCEPBTRW 006353
   ROD: EV_Brake1ESCEPBTRW_006.rod
   VCID: 77ABE8B40F4749BFFB3-8022
0799 - Databus
          [MSG_LH3_LM_INVALID]
                    Reset counter: 229
                    Mileage: 2849 km
                    Date: 2019.10.09
                    Time: 13:37:08
                    Additional_Codes: 00 00 00 09 E1 7F 40 4F 0A
                    DTC: 00 03 1F
                    Additional2: 00 05 00 00 05 22 90 01 90 01
   Part No SW: 8U0 820 043 J    HW: 8U0 820 043 J
   Component: E87  Klimavoll      0220
   Revision: 00H05000    Serial number: 8U0820043J
   VCID: 38292B884E5986C7329-806C
   Part No SW: 8X0 907 063 AF    HW: 8X0 907 063 AF
   Component: BCM PQ35  M   113 0821
   Revision: AB113821
   Coding: 0E000A2CA805F1C0201849C00144094C43FF25AA006F912BE400878400C1
   Shop #: WSC 00049 770 00147
   VCID: 005983685A090E07CA9-8054
   Subsystem 1 - Part No SW: 8U2 955 119     HW: 8U2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS316 171119  H38 0090
   Serial number:         171206095514
   Coding: 0047F7
   Serial number: 63163783
   Coding: 02006E
   Subsystem 3 - Part No: 8X0 951 177 A
   Component: Sensor, DWA 0  005 0002
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 AK    HW: 4H0 919 475 AG
   Component: PARKHILFE 8K  H01 0090
   Revision: 11001001    Serial number: 61031736200321
   Coding: 08C30E
   ASAM Dataset: EV_EPHVA18AU21X0000 003009
   ROD: EV_EPHVA18AU21X0000_003.rod
   VCID: 0F7BB05417D7617F433-805A
   Part No SW: 8U0 959 655 D    HW: 8U0 959 655 D
   Component: AirbagVW-AU10 H12 0910
   Serial number: 003S0R0KDBW5
   Coding: 30523232333030303030554A305238553053
   Shop #: WSC 00049 770 00119
   ASAM Dataset: EV_AirbaAU10SMEAU316 001010
   ROD: EV_AirbaAU10SMEAU316_001.rod
   VCID: 48C95B483239F647429-801C
   Subsystem 1 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3496KSME5C525343ZZZZ
   Subsystem 2 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Serial number: 3506KSME0B464543ZZZP
   Serial number: 3516KSME7F025543ZZZU
   Serial number: 3526KSME15474543ZZZN
   Subsystem 5 - Part No SW: 8U0 959 651     HW: 8U0 959 651
   Serial number: 3555USME064C2343ZZZ-
   Part No SW: 8X0 953 521 AF    HW: 5K0 953 569 BD
   Revision: FF010018    Serial number: 20171204201122
   Coding: 1894204000
   ROD: EV_SMLSNGVOLWSR8C.rod
   VCID: 005983685A890E07CA9-8054
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Serial number: 16 12 2017  E0021937
   Part No SW: 8U0 920 980 H    HW: 8U0 920 980 H
   Component: KOMBI_MEDIUM  H05 0540
   Coding: 42CF01
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 41DF466C1103C70F857-8014
   Part No SW: 8U0 907 468 AQ    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0090
   Revision: 1P170044    Serial number: 4441P17C0400C7
   Coding: FBCF7A5A000108610353
   VCID: 117FB62C0163778F557-8044
   Subsystem 1 - Part No SW: 1K0 915 181 L    HW: 1K0 915 181 L
   Component: J367-BDM  H07 0270
   Serial number: 44193742035831810902
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663 D
   Serial number: 17111100000000000557
   Component: IMMO          H05 0540
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 H    HW: 8X0 959 793 H
   Component: TSG FA        H11 0415
   Coding: 011806204001000000
   VCID: 52FD7920C4E54C972CD-8006
   Part No: 5N0 909 144 R
   Component: EPS_ZFLS Kl. 300    3501
   Revision: 00H22000
   Shop #: WSC 00049 770 00152
   VCID: 40D943681689CE078A9-8014
            000 - - - MIL ON
                    Fault Status: 11100000
                    Mileage: 2849 km
                    Date: 2019.10.16
                    Time: 11:10:37
                    Battery Volts: 12.2 V
                        DD
                    Temperature: 18.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
   Part No SW: 8X0 959 792 H    HW: 8X0 959 792 H
   Component: TSG BF        H11 0415
   VCID: 51FF762CC1E3378F157-8004
   Part No SW: 8X0 907 357 E    HW: 8X0 907 357 B
   Serial number: 171207-0002-041
   Coding: 11C794101000A500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 44D14F780E11D227AE1-8010
   Part No SW: 8U1 035 192 D    HW: 8U1 035 192 A
   Component: RMC Nav Plus  H62 0186
   Coding: 01010600024053470823020103010000000000
   VCID: 363525B0484D70B7205-8062
   Subsystem 1 - Part No SW: 8U0 919 603 A    HW: 8U0 919 603 A
   Component: DUBasic AU316  H43 0018
   Serial number: AUZ8ZDH5J01Q3K7
   Part No SW: 8X0 959 795 C    HW: 8X0 959 795 C
   Component: TSG HL        H08 0415
   Coding: 010006200001000000
   VCID: 4FFB7054D7D7217F033-801A
   Part No SW: 8U0 959 107 A    HW: 8U0 959 107 A
   Component: HDSG-Modul    H02 0552
   Revision: 15001001    Serial number: 355700341
   Coding: 183307C002
   ASAM Dataset: EV_HDSGAU316 001001
   ROD: EV_HDSGAU316.rod
   VCID: 3D273A9C6DFBA3EFE1F-8068
   Component: TSG HR        H08 0415
End----------(Elapsed Time: 01:21, VBatt start/end: 12.2V/12.4V)-----------
invernesspl
C?ID=345478
probably worth noting, the car was parked up with a dead battery for a few weeks.
Jef
HQ
Generally speaking, with gas engines, there is no real need to bleed the fuel system, it will take care of itself quickly.
I do see two things that look like they can run the lift pump in the fuel tank. Under [Basic Settings - 04] you will find:
IDE03999 - Drain fuel tank
And then under [Output Test - 03] there is:
IDE00219-ENG16746 - Fuel pump electronics
But I'm not so confident that will resolve your no start issues. I don't see the harm in doing the Basic Settings for maybe 60 seconds and then see what happens. If the car still doesn't start, maybe unhook the fuel line in the engine bay and feed it into an empty diet Dr Pepper soda bottle, do the Basic Settings again and see that fuel is actually being pumped up to the engine bay.
Is the battery currently in good condition?
Is there any kind of compression issues?
invernesspl
C?ID=345478
Hi,
Thanks. I have actually tried running both of those tests, but it would only let me run them once each for some reason? The fuel pump ran for 30 seconds and then stopped, but unfortunately the car still wont start.
The car has only done 1,700 so is virtually brand new. I've had a battery charger on it and set it to boost whilst cranking (battery seems ok on its own though)
Really don't know what to try next!?
invernesspl
C?ID=345478
I've just removed the black fuel line under the bonnet and there was quite bit of fuel pressure in there, so the fuel has reached the engine. the return white fuel line though did not have any pressure in? not sure how that system works if i'm honest.
I'm beginning to think the fault lies somewhere else other than fuel. What else could prevent it starting?
Jef
HQ
How is the compression? Do you have spark? If you spray a little bit of starter fluid into the intake during cranking, does it fire? Does the tachometer show RPM during cranking?
invernesspl
C?ID=345478
The rev counter is showing 400rpm or so when cranking, i've not checked for a spark as haven't disturbed anything around the engine as yet, the car has only covered 1,700 miles from new so compression cant be an issue - it cant be anything serious. As it is under warranty I might hand it to Audi dealer to take a look, they might be able to diagnose something my ross-tech software cant perhaps?
Jef
HQ
Not to be a Jack here... but how do you know compression is good? 1700 is just a number on the odometer, not an indication of compression. You've got an engine that doesn't fire, one must check the basics. Odds are it isn't the compression, but until you actually do the test with a gauge and get data, you can't confirm it is good.
</jack mode>
Gone But Not Forgotten
JPPSG
NO FOD!
morski
Cheshire UK
C?ID=90186
Being under warranty why didnt the main dealer replace the damaged fuel tank? Must have been an impact or something. How severe was it? The fuel pump/filter sits inside the tank so have you reused the original? Is it 100% ok or could that be damaged? Too many unknowns..
