Tuesday,05,November,2019,20:10:55:38498
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 19.6.2.0 (x64) HEX-V2 : 0.4508.4
VIN: WVGZZZ7PZBD010957 License Plate: KCK577Z 5TH NOV 2019
Mileage: 221892km-137877mi Repair Order:
Chassis Type: 7P-VW52 (7P6)
Scan: 01 02 03 05 08 09 0E 10 13 15 16 17 19 42 46 52 53 56 5F 62
6C 6D 72
VIN: WVGZZZ7PZBD010957 Mileage: 221892km-137877miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: Malfunction 0010
0E-Media Player 1 -- Status: Cannot be reached 0100
13-Auto Dist. Reg -- Status: Cannot be reached 0100
17-Instruments -- Status: Cannot be reached 0100
56-Radio -- Status: Cannot be reached 0100
6C-Back-up Cam. -- Status: Cannot be reached 0100
Address 01: Engine (J623-CASA) Labels:. 059-907-401-V2.clb
Part No SW: 7P0 907 401 HW: 7P0 907 401
Component: 3.0TDI EDC17 H15 0005
Revision: 51H15---
Coding: 292A4012232601020000
Shop #: 31414 790 00001
Dataset: EV_ECM30TDI0117P0907401 002007
ROD: EV_ECM30TDI0117P0907401.rod
VCID: 6C81C3F2E602914705F-8038
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 H HW: 0C8 927 750 H
Component: AL1000 AISIN 001 1714
Coding: 001568
Shop #: 99999 999 83333
Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001_VW52.rod
VCID: 313F128601A03CAF769-8064
Address 03: Brakes (J104) Labels:* 7P0-907-379.clb
Part No SW: 7P0 907 379 G HW: 7P0 907 379 A
Component: MK25A H33 0421
Revision: -------- Serial number: 417800010EC010
Coding: 5B6B13C349252553DAFDC89892D9A4507700
Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00700.rod
VCID: 41DF4246B100AC2F869-8014
Address 05: /Start Auth. (J393) Labels:. 8K0-907-064-05.clb
Part No SW: 4H0 907 064 AM HW: 4H0 907 064 J
Component: BCM2 2.0 H13 0208
Coding: 01B60000000000000000
VCID: 74B1DB92BEB24987DDF-8020
Subsystem 1 - Part No SW: 7P6 959 754 L HW: 7P6 959 754 L
Component: FBSTOUAREGIDG H05 0051
Serial number: 0510000035589007
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV H38 0044
Serial number: 0210000079781011
013 - Check Memory - Intermittent
Fault Status: 00101101
Reset counter: 146
Mileage: 220737 km
Date: 2019.09.29
Time: 15:15:25
Address 08: Auto HVAC (J255) Labels:| 7P6-907-040.clb
Part No SW: 7P6 907 040 AA HW: 7P6 907 040 AA
Component: Klima 2 Zonen H18 0511
Coding: B626000890
Dataset: EV_AirCondiFront 004001
VCID: 73B3D88EBB3C4EBFC45-8026
Part No SW: 4H0 907 063 D HW: 4H0 907 063 D
Component: BCM1 2.0 H11 0083
Revision: 15011002 Serial number: 00000000719156
Coding: 26001011C1345D010005000300001D0D431D470807000241000000000000
VCID: 290FFAE629F0446FBE9-807C
Subsystem 1 - Part No SW: 7P0 955 120 HW: 955 120
Component: WWS 100621 31 0020
Serial number: 90243401100622045945
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: H09 0011
Serial number: 10034527
Coding: 035223
Subsystem 3 - Part No SW: 7P6 941 431 B HW: 7P6 941 431 B
Component: E1 - H04 0031
Serial number: 00000000002503100271
01757 - Headlight Washer Pump (V11)
Fault Status: 01101100
Reset counter: 102
Mileage: 221809 km
Date: 2019.11.03
Time: 03:24:00
Reset counter: 98
Mileage: 221719 km
Date: 2019.10.29
Time: 12:09:00
Address 0E: Media Player 1
Address 10: Park/Steer Assist (J446) Labels:| 7P6-919-475.clb
Part No SW: 7P6 919 475 HW: 7P6 919 475
Component: PARKHILFE 8K H03 0016
Revision: -------- Serial number: 38941016801832
Coding: 508501
Dataset: EV_VW526ParkiAssis2 001008
ROD: EV_VW526ParkiAssis2.rod
VCID: 55F786165588308FCA1-8000
Address 13: Auto Dist. Reg
Address 15: Airbags (J234) Labels:| 7P0-959-655.clb
Part No SW: 7P0 959 655 A HW: 7P0 959 655 A
Component: VW10Airbag07K H05 0020
Revision: -------- Serial number: 003FH000MC0Q
Coding: 00000000000000000000000000000000374B
Dataset: EV_AirbaVW10BPAVW526 001001
ROD: EV_AirbaVW10BPAVW526_001.rod
VCID: 3FDB44BEC7F4DADFF0D-806A
Serial number: 3575LRB405T0IRE2D9G1
Serial number: 3585LRB405J6U4L27P9/
Serial number: 3515RRB405L6T8MI59NE
Serial number: 3525RRB405F6T8MI60L%
Serial number: 3555NRB405F6NG4ENP87
Serial number: 3565NRB40536P1I8L076
Part No SW: 4H0 953 568 A HW: 7P6 953 507
Component: Lenks.Modul H07 0007
Revision: -------- Serial number: 90815JG70000O
Coding: 000015
VCID: 313F128601203CAF769-8064
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Serial number: 0017990
Address 17: Instruments (J285) Labels:| 7P6-920-xxx-17.clb-SRI1
Part No SW: 7P6 920 980 G HW: 7P6 920 980 G
Component: Kombi H09 0114
Revision: 08140052 Serial number: 658120710593027
Coding: 2727310022002600010004
Dataset: EV_KombiUDSRBVW526 001011
ROD: EV_KombiUDSRBVW526.rod
VCID: 40D94742BA0AA527897-8014
Part No SW: 7P6 907 530 A HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5179
Revision: -------- Serial number: 00000000024384
Coding: 0001035600
Shop #: 00046 000 00000
Dataset: EV_GatewVW526UDS 001005
ROD: EV_GatewUDS_VW52.rod
VCID: 3635219AE8CE1B9723B-8062
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005659148853
5807 - Rear View Camera System Control Module
U104C 00 [009] - No communication
Reset counter: 98
Mileage: 221719 km
Date: 2019.10.29
Time: 12:08:37
Voltage terminal 30: 13.7 V
Voltage terminal 15: 13.7 V
Control Module temperature: 37 �C
System status: Terminal 15 on
Engine running: On
IN ZAS_Te_X: On
Terminal 15 status: On
Datenfeld: 0
4224 - No Communication with Engine Control Module (SAE /)
U0100 00 [008] - -
Reset counter: 142
Mileage: 221814 km
Date: 2019.11.03
Time: 11:29:44
Voltage terminal 30: 12.2 V
Voltage terminal 15: 0.0 V
Control Module temperature: 38 �C
System status: Awake_Timer_active
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
0267 - Optical data bus
U1049 00 [009] - Open circuit
Reset counter: 98
Mileage: 221719 km
Date: 2019.10.29
Time: 12:21:24
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 0
0276 - FlexRay Databus
U1032 00 [009] - Initialization Failed
Reset counter: 98
Mileage: 221719 km
Date: 2019.10.29
Time: 12:08:37
Engine running: On
IN ZAS_Te_X: On
Datenfeld: 0
Part No SW: 4H0 959 793 F HW: 4H0 959 793 F
Component: FA H07 0162
Revision: -------- Serial number: 0000105978296
Coding: 011D0620D001451005080002
VCID: 3C2133B2D662C1C7D5F-8068
Revision: 00002001 Serial number: 0132336216
Coding: 011B162228B9108083200624000000000000000000000000000000000000
Subsystem 1 - Part No: 7P6 951 171
Component: DWA-Sensor 002 0204
Component: BACKUP HO H05 1501
01316 - Control Module
Reset counter: 146
Mileage: 220737 km
Date: 2019.09.29
Time: 15:15:25
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: BF H07 0162
Revision: -------- Serial number: 0000105673203
Coding: 011D0620D001451005080000
VCID: 3B2330AED36CC6FFDC5-806E
Address 53: Parking Brake (J540-) Labels:| 7P0-907-801.clb
Part No SW: 7P0 907 801 D HW: 7P0 907 801 D
Component: H51 1000
Revision: 00000000 Serial number: A10627001DE
Coding: 01040000
Dataset: EV_ParkbA7 000006
ROD: EV_ParkbA7.rod
VCID: 34311B92FEB209871DF-8060
Slave 3:
Address 56: Radio
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: HL H09 0162
Revision: -------- Serial number: 0000106248638
Coding: 011C06200001251005080000
VCID: 3A2D35AADC56FFF7C73-806E
Address 6C: Back-up Cam.
Address 6D: Trunk Elect. (----) Labels:| 7N0-959-107.clb
Part No SW: 7P6 959 107 C HW: 7P6 959 107
Component: HDSG-Modul H10 0043
Revision: 22010001 Serial number: 169500763
Coding: 0523310002
Dataset: EV_HeckkTouar 202142
ROD: EV_HeckkTouar.rod
0004 - No Basic Setting
B2010 00 [137] - -
[Steuerger�t nicht kalibriert]
Reset counter: 98
Mileage: 221719 km
Date: 2019.10.29
Time: 12:08:37
Voltage terminal 30: 13.71 V
Component: HR H09 0162
Revision: -------- Serial number: 0000106248443
End----------(Elapsed Time: 01:35, VBatt start/end: 12.0V/12.0V)-----------
