Q2 2019 reverse cam
macapple
Verified VCDS-User
malaysia
C?ID=363509
After retrofitting reverse cam on Q2
when image revert back to radio , my mmi hang on volume button , if car did not engage reverse cam , i have no issue , so i did tried to off the reverse cam option , after numerous of trying , the car image still appear when engaging reverse , anyway to revert back to original code ? or another one did encounter this problem before ? after reverse cam revert back to the radio MMI , the steering wheel button volume was not functioning and then the whole mmi hang , which i need to reset the whole mmi system , after reset the whole mmi , radio and steering is working well as normal till you engage the reverse camera again
so now need help on revert back the MMI without reverse camera to confirmed the camera is faulty or is any code that can help to resolve the issue
Monday,14,October,2019,15:58:58:63906
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZGA6KA082xxx   License Plate:
Mileage: 1308km-812mi   Repair Order:
Gateway Installation List:  3Q0 907 530 AA
Monday,14,October,2019,16:02:00:63906
Chassis Type: GA-AU37 (3Q0)
Scan: 01 02 03 05 08 09 10 15 17 19 29 2B 39 42 44 4B 52 5F 6D D6
          D7
VIN: WAUZZZGA6KA082xxx   Mileage: 1308km-812miles
Address 01: Engine (J623-CHZJ)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04C 906 026 AL    HW: 04C 907 309 AL
   Component: R3 1.0l TFS   H26 5154
   Revision: W1H26---
   Coding: 0225003223241D083000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM10TFS01104C906026AL 002007
   ROD: EV_ECM10TFS01104C906026AL_AU37.rod
   VCID: 6B96CFE6827C521762-803E
   CAN Converter 01:
Readiness: 1110 0001
   Part No SW: 0CW 300 043     HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1601
   Revision: 00005008    Serial number: CU501905267142
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 74A4D49ADF428DEFB3-8020
   Part No SW: 5Q0 614 517 EH    HW: 5Q0 614 517 BR
   Component: ESC           H82 0107
   Revision: 00000000    Serial number: 61559000001846
   Coding: 34008A8D2028246E897C0E0562C6242C51042491704624F20221F004121B4A0300000633D2D21212FF35351919323200
   ROD: EV_Brake1UDSContiMK100IPB_038.rod
   VCID: 7BB6FFA6F21CC297F2-802E
   Part No SW: 3Q0 959 435 L    HW: 3Q0 959 435 L
   Component: VWKESSYMQB    037 1204
   Revision: 00037000    Serial number: 0519035895
   Coding: 030C0C1720
   ASAM Dataset: EV_KessyHellaMQBAB 004046
   VCID: 43C64746CA6C7A57FA-8016
   Part No SW: 8V0 820 043 AA    HW: 8V0 820 043 AA
   Component: AC Automat    H03 0140
   Revision: 20001000    Serial number: 00000001843432
   Coding: 06100003110000001000000000001400
   ASAM Dataset: EV_AirCondiFrontVaAU37X 008022
   VCID: 71AADD8EA050B8C758-8024
   Subsystem 1 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 0DC011B900PAG0MUFU03
   Part No SW: 5Q0 937 084 DD    HW: 5Q0 937 084 CG
   Component: BCM MQBAB H   H38 0273
   Serial number: 01001915901893
   ROD: EV_BCMBOSCH_019_VW37.rod
   VCID: 7DB2F1BEEC08CCA7CC-8028
   Subsystem 1 - Part No SW: 81A 955 555 A    HW: 81A 955 555
   Serial number: 23123467X81A955555A0
   Coding: 80005E
   Subsystem 2 - Part No SW: 8V0 941 531 AQ    HW: 8V0 941 531 AQ
   Component: E1 - LDS MQB  H06 0032
   Serial number: 21 03 2019  20001677
   Steering Column Switch:
   Subsystem 3 - Part No SW: 82A 953 521 BF    HW: 5Q1 953 549
   Component: J527 SMLS MQB  004 0070
   Serial number: 00000030051904400338
   Part No SW: 5QA 919 283 C    HW: 5QA 919 283
   Component: PDC 4 KanalH07 0050
   Serial number: 000308419319165
   Coding: 0600000011
   ASAM Dataset: EV_EPHVA14AU3700000 009037
   ROD: EV_EPHVA14AU3700000_009.rod
   VCID: 4AD86A62ED46AB1F39-801E
   Part No SW: 5Q0 959 655 BN    HW: 5Q0 959 655 BN
   Component: AirbagVW21    007 0403
   Serial number: 003FHR5CRZT+
   Coding: 88CCF0000000000058000000C0C8000000C5
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 0D52A17EDCA8FC27DC-8058
   Subsystem 1 - Part No SW: -----------    HW: 480 001 106 19
   Serial number: 3570000000060A8CDC3-
   Subsystem 2 - Part No SW: -----------    HW: 480 001 106 19
   Serial number: 35800000000208E85D3Q
   Subsystem 3 - Part No SW: -----------    HW: 480 401 406 19
   Component: SideSensor_Dr  005 6149
   Serial number: 35100019AF03BAC5795K
   Subsystem 4 - Part No SW: -----------    HW: 480 401 406 19
   Component: SideSensor_Pr  005 6149
   Serial number: 35200019AF03BAC5833E
   Subsystem 5 - Part No SW: -----------    HW: 480 400 106 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001A0EE9B781452D
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 480 400 106 19
   Component: FrontSensor_P  005 6149
   Serial number: 3560001A0EE9B78147FT
   Part No SW: 81A 920 750 D    HW: 81A 920 750 D
   Component: KOMBI         H21 2700
   Coding: 25A5221C2A8000080100AA001000000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009068
   VCID: 2502F9DE2418A467F4-8070
   Component: GW MQB High   442 4368
   Revision: --------    Serial number: 0009675910
   Coding: 030100043F0857005B00004A100B00000001010000000000000000000000
   ROD: EV_GatewNF.rod
   VCID: 6E90C6F2B16EA73F45-803A
   Component: 1-01-02-01-04
   Subsystem 2 - Part No SW: 81A 951 523     HW: 81A 951 523
   Component: J453 MFL  H04 0004
   Serial number: 20190604111625 21197
   Serial number: 75886003911905241446
Address 29: Left Light (J1018)       Labels: 8S0-907-397.clb
   Part No SW: 8S0 907 397 C    HW: 8S0 907 397 C
   Component: LCM_MQB       H07 0022
   VCID: 41CA4D4ED0706847E8-8014
   Serial number: 19000140932008
   Coding: 0800000000000000
   ROD: EV_ELVMarqMQBA0_AU37.rod
   VCID: 332617869ACCCAD76A-8066
Address 39: Right Light (J1023)       Labels: 8S0-907-397.clb
   Part No SW: 5Q0 959 593 F    HW: 5Q0 959 593 F
   Component: TSG FS002 0287
   Serial number: YE007SEL04157
   Coding: 00121B205001000000001002
   VCID: 44C4445ACF627D6FC3-8010
   Subsystem 1 - Part No SW: 5Q0 959 408     HW: 5Q0 959 164
   Component: FOND_FHSG_DRV  007 0010
   Serial number: 00000000000030800328
   Coding: 0D0000
   Part No SW: 3Q0 909 144 M    HW: 3Q0 909 144 L
   Coding: 811F0000
   ROD: EV_SteerAssisMQB_015.rod
   VCID: 3C343CBAB79205AFBB-8068
   Component: FCM MQB Low   002 0345
   Serial number: 01061910800673
   Coding: 000000050900116600102B00020000000000000000000000000000000000
   ASAM Dataset: EV_MultiModulContiVW48X 002006
   ROD: EV_MultiModulContiVW48X_002_VW41.rod
   VCID: 3522299E94B8D4E744-8060
   Part No SW: 5Q0 959 592 F    HW: 5Q0 959 592 F
   Component: TSG BFS002 0287
   Serial number: YE007SEP2316E
   Coding: 001213205C01000000001002
   Subsystem 1 - Part No SW: 5Q0 959 407     HW: 5Q0 959 163
   Component: FOND_FHSG_PSG  007 0010
   Serial number: 00000000000030881977
   Coding: 150000
   Part No SW: 81A 035 824 D    HW: 81A 035 824 D
   Component: MU-S--ER      722 0962
   Coding: 01720600EF0A000011110001000A00002F002A160170010002
   Shop #: WSC 19460 666 12345
   ASAM Dataset: EV_MUStd6C3DELP 001013
   ROD: EV_MUStd6C3DELP_AU37.rod
   VCID: 2404E4DA2F225D6FE3-8070
   Subsystem 1 - Part No SW: 81A 919 604 B    HW: 81A 919 604 B
   Component: DU Std AU216  H42 0100
   Serial number: INX00104031900020241
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 81C 919 614     HW: 81C 919 614
   Component: ControlUnit_B  H20 0200
   Serial number: APVAK127041900060112
7178 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Park assist OPS (0x0A) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 130
                    Mileage: 1308 km
                    Date: 2019.10.14
                    Time: 15:59:23
                    Voltage terminal 30: 12.4 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number: A2-C737-6291-8
   Coding: 1A28
   VCID: 48DC506AF34A590F2F-801C
   VCID: 177EC316EE7406F776-8042
End----------(Elapsed Time: 01:16, VBatt start/end: 12.5V/12.5V)-----------
Since there is no indication that your VCDS isn't working as expected, this does not belong in Product Support. Moved to Retrofits.
Do you have a scan and channel maps from before you started?
Have you looked at your CodingLog and AdpLog files to be sure that you have reverted everything correctly?
macapple
Verified VCDS-User
malaysia
C?ID=363509
i do not have a scan and channel maps ... i bought an 3rd party reverse camera which mention do not need to do any coding , but after driving , as mention , engaged the reverse gear , the whole mmi hang
South Molton, UK
macapple
Verified VCDS-User
malaysia
C?ID=363509
Have you checked the VCDS CodingLog and AdpLog files as Uwe suggested?
BTW adding a reverse camera and not needing coding changes seems very unlikely to me...
i did check the log but somehow is i trying to close the reverse camera image on the mmi instead of the beginning , as now i trying to close/revert the reverse cam image to where my original car is
yes - not sure how they did it , but i just follow their instruction without any coding , the rear reverse camera appear on it own
