I just purchased a HEX V2 interface from Gendan Automotive to diagnose an ABS issue with my 2014 VW Crafter. As you can see from the attached auto scan only a limited number of modules are being scanned by the unit.
When trying to access any of the other modules directly (not via auto scan) I get 'No response from controller' message. The engine module more often than not fails to connect 'CAN failed' can been seen in the top left of the VCDS interface before showing the 'No response...' error.
Test shows CAN:OK K1:OK K2:OK
The primary system I'm using VCDS on is a late 2008 Macbook Pro running Windows 10 home bootcamp. I've now run the software on two other laptops - Windows 10 Pro on regular laptop and lastly an older laptop running Windows 7. All three give the same results.
I've covered all the points listed on the FAQ page, in particular the points pertaining to flakey connections, none have changed the outcome on any of the aforementioned operating systems. I'm using the latest version of VCDS available.
The VCDS manual states "Communication with all control modules is supported with the following functions; Control Module ID and Advanced ID, Fault Codes (Read and Clear), Supported Codes, Security Access, and Adaptation" - but the deeper I dig into the forum it seems this might not be the case, since the crafters limited availability in the US makes them difficult to study.
Has anyone overcome a similar issue or have I just been wasting my time?
Sunday,13,October,2019,18:23:29:31478
VIN: WV1ZZZ2EZE6017076 License Plate:
Chassis Type: 2E-N/A (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (J623-CKTC) Labels:. 03L-906-012-CKT.clb
Part No SW: 03L 906 012 C HW: 03L 906 012 A
Component: R4 2.0l TDI H26 9977
Revision: 72H26--- Serial number: VWXDZ0M1047972
Coding: 0119401020440C080000
ASAM Dataset: EV_ECM20TDI01103L906012C 002018
ROD: EV_ECM20TDI01103L906012A_002.rod
VCID: 2411EC4DDE5C50478DF-8070
Address 93: LT3 Immo Labels: 2E0-905-865-93.clb
Part No SW: 2E0 905 843 B HW: 906 900 370 2
Component: IMMO 1231 1306
Revision: 00231000 Serial number: VWXDZ0M1047972
VCID: 2615F645A4E0A25793B-8072
Address 94: LT3 Airbag
Part No HW: 9069005701
Shop #: WSC 00117 555 00000
ASAM Dataset: 3 3332
ROD: CRFT_AB_3_3331.rod (*)
VCID: 55F78189C586F9CFCA1-8000
Address 96: LT3 Instruments
Part No SW: 9069025601 HW: 9069010401
ASAM Dataset: 32 1048
ROD: CRFT_KOMBI_32_1048.rod
VCID: 065596C548A08257F3B-8052
Address 99: LT3 Ign. Switch
Part No HW: 9069003702
ASAM Dataset: 67 259
ROD: CRFT_EZS_67_259.rod
Address 9A: LT3 Central Locks Labels: 2E0-905-865-93.clb
Component: HF-FFB 1231 1306
Revision: 00231000 Serial number: 12345678901234
Address 9B: LT3 Driver Door
Part No HW: 9069000501
ASAM Dataset: 33 263
ROD: CRFT_FTUHR_33_263.rod
Address B4: LT3 Central Elec.
Part No SW: 9069024301 HW: 9069014500
ASAM Dataset: 33 852
ROD: CRFT_EZE_33_851.rod (*)
VCID: 025D8AD56488BE77DF3-8056
Address B6: LT3 Steering Wheel
Part No SW: 9065402545 HW: 9065402545
ASAM Dataset: 72 257
ROD: CRFT_SML_72_257.rod (*)
VCID: 084998FD42B49427817-805C
End----(Elapsed Time: 01:02, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
