Hi
Hopefully someone may have seen this before but I'm a little perplexed by this one as it doesnt make sense
Picked up a 2006 caddy last week as a fixer upper, starts and runs OK when I got it the guy said there was a wiring fault with the cluster and it didnt work, went through the wiring and it was just a blown 5a fuse. Put in a new fuse cluster comes on and everything works fine - BUT the immo light is flashing and a message immobiliser adjustment failure in the display.
VCDS says there is no key signal 01176 so that being the case the van should not run but it does, its had a new key at some point and I only have 1 key so cant test with another.
Logic says put a new key reader on the ignition barrel but I'm then woriied the immo will kick in
Does anyone have any thoughts or has seen this before? any wisdom apopreciataed
Scan attached
Thanks in advance
Ian
Scan attached
Thanks in advance
Ian
Address 44: DTCs clearedSunday,13,October,2019,18:17:55:17347
VCDS Version: 19.6.2.0 (x64)
VIN: WV1ZZZ2KZ7X015100 License Plate: GP06XAK
Mileage: 309930km-192581mi Repair Order:
Chassis Type: 2K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WV1ZZZ2KZ7X015100 Mileage: 309930km-192581miles
Address 01: Engine Labels: 03G-906-021-BLS.clb
Part No SW: 03G 906 021 AQ HW: 028 101 239 0
Component: R4 1,9l EDC 000SG 7872
Revision: --H02--- Serial number: XXXXXXXXXXXXXX
Coding: 0000071
Shop #: WSC 35110 377 00157
VCID: 6ED46F2679D4C63F45-803A
Address 03: ABS Brakes Labels: 1K0-907-379-MK70.lbl
Part No: 1K0 907 379 P
Component: ASR FRONT MK70 0105
Coding: 0017106
VCID: 3F8AE2626E3E7FB79E-806A
Part No: 1K0 820 047 FH
Component: Climatic PQ35 120 0606
VCID: 6FEA72227EDECF374E-803A
Address 09: Cent. Elect. Labels:. 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 D HW: 3C0 937 049 D
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000005847999
Coding: 00884F030004100000000000000000000009FB075C
Shop #: WSC 35110 377 08192
VCID: 2A5CA33685BCEA1FD9-807E
Subsystem 1 - Part No: 2K2 955 119 C Labels: 1KX-955-119.CLB
Component: Wischer 130606 020 0501
Coding: 00038805
Shop #: WSC 35110
Address 15: Airbags Labels: 6Q0-909-605-VW52.lbl
Part No SW: 6Q0 909 605 AH HW: 6Q0 909 605 AH
Component: 2Q AIRBAG VW52 025 2400
Revision: 06025000 Serial number: 0037TR06LDT6
Coding: 0012881
Shop #: WSC 35110 377 00158
VCID: 7DF6586A24B2ADA7CC-8028
Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC
Component: Lenksäulenmodul 636 0070
Coding: 0000012
VCID: 74E07D4E17F8ECEFB3-8020
Part No SW: 1T0 920 963 A HW: 1T0 920 963 A
Revision: V0003000 Serial number: VWZ7Z0F7012010
Coding: 0017401
Shop #: WSC 00041 067 57207
VCID: 3362BE525276ABD76A-8066
Address 19: CAN Gateway Labels:. 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H04 0010
Revision: H04 02 Serial number: 22050602000624
Coding: 3D0F034007007401
VCID: 2C50A52E8F48F42F2B-8078
Reset counter: 200
Mileage: 309934 km
Time: 23:32:34
Component: IMMO VDD 1610
Shop #: WSC 00137 211 56823
01176 - Key
Reset counter: 200
Mileage: 309934 km
Time: 23:33:40
Part No SW: 1T0 959 701 D HW: 1T0 959 701 D
Component: Tuer-SG 005 0930
Coding: 0000560
VCID: 3878897E4B10488F5F-806C
Part No: 1K2 909 144 L
Component: EPS_ZFLS Kl.140 H07 1806
Shop #: WSC 35110 666 38454
VCID: 3566804A5C02B5E744-8060
Address 46: Central Conv. Labels:. 1K0-959-433-MIN.clb
Part No: 1K0 959 433 AK
Component: KSG 0401
Coding: 008A0C087F2D8405485A010010C0
Shop #: WSC 08224 211 56823
VCID: 79FE4C7A309A9187E0-802C
Part No SW: 1T0 959 702 D HW: 1T0 959 702 D
Coding: 0000560
VCID: 397E8C7A701A5187A0-806C
Address 56: Radio
End-------------------------(Elapsed Time: 01:21)--------------------------
