- Oct 12, 2019
- 3
- 2
- Irwin, PA, USA
- C?ID=379550
HI All,
Have a 2008 A4 cab to the dealer and they said the control module was bad.
I order the module and the Ross-Tech tool.
Did the auto scan and came up with other faults? Are they part of what the module does.
To reprogram the new module, i look but could not find what i thought i needed.
Thanks for the help.
I am new to the forum.
Rich
Hope i did this right.
Rich
Sunday,13,October,2019,12:44:27:03103
Dealer/Shop Name: RDP
VIN: WAUDF48H18K013841 License Plate:
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
63 65 67 73 75 76 77
VIN: WAUDF48H18K013841 Mileage: 54500km-33864miles
Address 01: Engine Labels:. 06F-907-115-AXX.clb
Part No SW: 8E1 910 115 G HW: 8E0 907 115 D
Component: 2.0l R4/4V TFSI 0010
Revision: 5EH15--- Serial number:
Coding: 011C010A190F0120
Shop #: WSC 00672 785 00200
VCID: 2615F62084E7CCC793B-8072
049412 - No Communication with Cruise Control Module
U0104 - 008 - - Intermittent
Fault Frequency: 197
Mileage: 53553 km
RPM: 1155 /min
Load: 23.1 %
Temperature: 85.0°C
Temperature: 73.0°C
Absolute Pres.: 970.0 mbar
Voltage: 12.446 V
049508 - No Communications with HVAC Control Module (J301)
U0164 - 008 - - Intermittent
Fault Frequency: 50
Mileage: 53553 km
RPM: 1198 /min
Load: 19.6 %
Temperature: 84.0°C
Temperature: 66.0°C
Voltage: 11.811 V
Part No SW: 8E1 910 156 K HW: 09L 927 156 B
Component: AG6 09L 2,0TFSI USA 0080
Revision: --H01--- Serial number: 4428893
Coding: 0000002
VCID: 2F3B1304AB1D8D8F60D-807A
049682 - Steering Column Control Module
U0212 - 000 - No Communications - Intermittent
Fault Frequency: 218
RPM: 832 /min
RPM: 640 /min
(no units): 30.0
(no units): 33.0
Temperature: 69.0°C
T.B. Angle: 0.0°
Address 03: ABS Brakes Labels: 8E0-910-517.clb
Part No SW: 8E0 910 517 J HW: 8E0 614 517 BH
Component: ESP8 quattro H06 0140
Coding: 0004528
VCID: 2E050E00AC1784876BB-807A
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00100
Shop #: WSC 00672
VCID: 6D87C90C64813F9F121-50F4
49-00 - No Communications
Address 15: Airbags Labels: 8H0-959-655-94.lbl
Part No SW: 8H0 959 655 H HW: 8H0 959 655 H
Component: Airbag 9.42 H01 1830
Revision: 92H01183 Serial number: 003D00004K2%
Coding: 0132105
VCID: 3FDB43447B7D7D0FF0D-806A
Subsystem 1 - Part No: 8H0 910 339 B
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 0272P
Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†6332BRB403877890Nÿ†63
Subsystem 5 - Serial number: 77890Nÿ†6342BRB403876FA8$ÿ†63
Subsystem 6 - Serial number: 76FA8$ÿ†63729RB403A0DA1FZÿ†63
Subsystem 7 - Serial number: 0DA1FZÿ†63829RB403A111E3Hÿ
Subsystem 8 - Serial number: 111E3Hÿ
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8H0 920 982 B HW: 8H0 920 982 B
Component: KOMBI+WFS 4 H10 0200
Revision: 0200 Serial number: 00000000000000
Coding: 0007261
Shop #: WSC 06442 444 57235
VCID: 30391078B6339277797-50F4
Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl
Coding: 0007261
Address 26: Auto Roof Labels: 8H0-959-255.lbl
Part No: 8H0 959 255 B
Component: VSG B6 CABRIO 7195
VCID: 3537216C4951B75F2A1-50F4
02023 - Terminal 87
Address 37: Navigation Labels: 8E0-035-192-RNSE.clb
Part No SW: 8H0 035 192 H HW: 8H0 035 192 H
Component: RNS-E US H74 0260
Revision: 04S Serial number: AUZBZ7H2500226
Coding: 0413617
VCID: 2C0104089A2BF69745F-5160
Reset counter: 245
Date: 2009.08.16
Time: 11:45:26
Voltage: 10.10 V
Reset counter: 245
Date: 2009.08.16
Time: 10:59:08
Voltage: 10.50 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Part No SW: 4L0 910 357 HW: 4L0 907 357
Component: AFS 1 H01 0040
Coding: 0000019
VCID: 698FBD1C557923BF7E9-803C
Subsystem 1 - Part No: 8E0 941 329 A
Component: AFS-Modul links H05 0030
Subsystem 2 - Part No: 8E0 941 329 A
Component: AFS-Modul rechtsH05 0030
Address 56: Radio Labels: 8E0-035-192-RNSE.clb
Coding: 0413617
Reset counter: 245
Date: 2009.08.16
Time: 11:45:26
Voltage: 10.10 V
Reset counter: 245
Date: 2009.08.16
Time: 10:59:08
Voltage: 10.50 V
Mileage: 655350 km
Count: 65535
Clock: 255:255
Address 63: Entry Assist,D Labels: None
Part No: 8H0 959 760 A
Component: EasyEntry F H13 0010
Coding: 00005
Shop #: WSC 00065
VCID: 3537216C4C61B75F2A1-4B3C
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0062121
VCID: 2A0D021090DFE8A7B73-5160
Address 73: Entry Assist, P Labels: None
Component: EasyEntry BF H13 0010
Coding: 00005
Shop #: WSC 00065
8 Faults Found:
37-10 - Faulty - Intermittent
80-10 - Single-Wire Operation - Intermittent
02010 - Left Entry Assistance Control Module (J572)
Part No SW: 8P0 862 335 R HW: 8P0 862 335 R
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005069288
Coding: 0011807
VCID: 45D751AC19B127DFBA1-50D0
End----------(Elapsed Time: 05:16, VBatt start/end: 14.4V/14.2V)-----------
