Passat GTE e-mode not working
fdim
Copenhagen, Denmark
C?ID=379899
I've bought a used Passat GTE from 2016 in July and only a a bit later noticed that secondary/backup key does not work (car has keyless entry).
Now since I still have some kind of warranty from the seller, I brought the car back hoping that they could fix the key (and align the wheels - original reason why I went). They have tried what they could and said that I need to go to authorized service to recode the keys.
On the same day I went to authorized VW service and they did fix the issue (both keys work), but for whatever reason driving mode buttons stopped working! Fast forward to next week - they kept the car for 4 days and made no progress and still has no idea what went wrong (even has someone from Germany looking into), but every promise they made so far did not come true. So here I am :)
Normally car has an e-mode switch that lets me toggle between all electric, hybrid and battery charge modes and a GTE button that enables combined power (218hp). Basically now the button light just flashes and nothing happens.
So my question is, perhaps someone here knows a bit how car modules are related in regards to driving modes? That would be a reason enough to order VCDS / hex-v2 and compare my coding values with other GTE readings here
My gut feeling says that this is a software glitch that disabled some feature (wrong coding) in one of the modules when they got configuration by VIN number when they coded the keys! Much like for this unlucky guy: https://www.speakev.com/threads/e-mode-gte-buttons-unresponsive.129902/ (sadly no reply)
And since they are authorized they may not be allowed to change the defaults(as they come with the cost for new cars :D - just guessing)
Thanks!
golfi_vend
Tartu, Estonia
C?ID=195131
GTE is a mess compared to petrol/diesel. Even a simple mib upgrade results in headache.
If everything is stock then I'd do SWC snd restore coding/adaptions/calibration to stock.
Does Your cruise still work?
^^^ the similarity to siLc's link is compelling, but perhaps before blaming FeC, it might be prudent to first confirm that the driving mode function is correctly programmed into the vehicle. Posting-up a copy of an unedited, current auto-scan might be a logical first step in this process - perhaps?
fdim
Copenhagen, Denmark
C?ID=379899
You've got me worried that I went to test it at 23:40... Fortunately it still works!
As for equipment, I am not aware of anything custom. At least driving modes are standard in the GTE (or was present in all the cars I've seen for sale)
Sounds like I need to get hold of HEX-v2 before I can do that?
As for FeC, here is the list from the car (under installed):
- 00030000
- 00040100
- 00050000
- 00060100
- 00060300
- 00060800
- 00060900
- 00070200
- 09300008
Available list is empty thought. Another interesting thing is that installation date for all of the codes is the day when I picked up the car - so I guess they tried to reset something.
^^^^ that's an entirely unremarkable set of Fec s!!:D
00030000 AMI (USB Enable)
00040100 Navigation
00050000 Bluetooth
00060100 Vehicle Data Interface
00060300 Mirror Link
00060800 Apple Carplay
00060900 Google Automotive Link
00070200 SDS for Nav
093000xx Nav Maps EU
Edit: Alas I can't find the "Driving mode" FeC number in my data base - just this entry about the software purchase number (not sure where I got this): 5G0054809 - Driving Modes
fdim
Copenhagen, Denmark
C?ID=379899
@DV52 I've got the Hex-v2 cable, the scan is below:
Thursday,31,October,2019,17:39:45:58833
VIN: WVWZZZ3CZHE014103   License Plate: CJ69931
Mileage: 76033km-47244mi   Repair Order:
Chassis Type: 3C-VW48 (5QE)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 23 2B 42 44 51 52 55 5F
          6C 75 8C A9 BB BC C6
VIN: WVWZZZ3CZHE014103   Mileage: 76037km-47247miles
51-Electric Drive -- Status: Malfunction 0010
8C-Hybrid Battery -- Status: Malfunction 0010
Address 01: Engine (J623-CUKC)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 023 AH    HW: 04E 907 309 F
   Component: R4 1.4l TFS   H22 3379
   Revision: X3H22---
   Coding: 011D0012636405083000
   Shop #: WSC 63878 003 1048576
   ASAM Dataset: EV_ECM14TFS01104E906023AH 006006
   ROD: EV_ECM14TFS_006_VW48.rod
   VCID: 6695B65218E9902753B-8032
   Part No SW: 0DD 300 040 E    HW: 0DD 927 770 C
   Component: GSG DQ400E    H32 1601
   Revision: 00032056    Serial number: TFK01801170181
   Shop #: WSC 00099 780 00200
   ROD: EV_TCMDQ400021_VW37.rod
   VCID: 2411EC5AAE55A2378DF-8070
25355 - Control Module for Electric Drive Power Output
          U0110 00 [040] - No Communications
                    Mileage: 76030 km
                    Date: 2019.10.31
                    Time: 10:26:46
                    Engine speed: 6.25 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 52 km/h
                    Control Module temperature: 57 �C
                    CURRENT pressure: -9.5 bar
                    Clutch: primary stat: Driving
                    selected gear: GANG_6
                    Driving position: N
                    Accelerator position: 0.4 %
                    DTC memory status: 16896
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379-OMG-V1.clb
   Part No SW: 5Q0 614 517 BL    HW: 5Q0 614 517 AH
   Component: ESC           H62 0855
   Revision: 00000000    Serial number: 61426000000315
   Coding: 0FEC408F382123704778060041C649F0021CC4E26082927138A1F078C20202
   ASAM Dataset: EV_Brake1UDSContiMK100OMG 003019
   ROD: EV_Brake1UDSContiMK100OMG_003_VW48.rod
   VCID: 7CA1F43A76653AF795F-8028
14 Faults Found:
8289 - Databus
          U1122 00 [044] - Implausible Message
          [FCAN: Unpausible EPS_DSR_Statussignal]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:37
16412 - Display for Tire Pressure Monitoring
          C1146 02 [044] - Signal Failure
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:47
8214 - Databus
          U1121 00 [044] - Missing Message
          [FCAN: Diagnose_01 message is not received]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:37
16413 - Display for Tire Pressure Monitoring
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:47
8192 - Databus
          [FCAN: ACC_07 message is not received]
                    Mileage: 76030 km
                    Date: 2019.10.31
                    Time: 11:39:04
8196 - Databus
          [FCAN : ACC_10 message is not received]
                    Mileage: 76030 km
                    Date: 2019.10.31
                    Time: 11:39:04
8264 - Databus
          [FCAN: Tsk_06 message is not received]
                    Mileage: 76030 km
                    Date: 2019.10.31
                    Time: 11:39:04
8204 - Databus
          [FCAN: Airbag_02 message is not received]
                    Mileage: 76030 km
                    Date: 2019.10.31
                    Time: 11:39:04
8260 - Databus
          [FCAN: Pla_01 message is not received]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:37
8206 - Databus
          [FCAN: Airbag_03 message is not received]
                    Mileage: 76030 km
                    Date: 2019.10.31
                    Time: 11:39:04
8232 - Databus
          [FCAN: Kombi_02 message is not received]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:37
8234 - Databus
          [FCAN: Kombi_03 messag is not received]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:37
8258 - Databus
          U1121 00 [032] - Missing Message
          [FCAN: Motor_20 message is not received]
                    Mileage: 76030 km
                    Date: 2019.10.31
                    Time: 11:39:04
8246 - Databus
          [FCAN: Motor_Code_01 message is not received]
                    Mileage: 76030 km
                    Date: 2019.10.31
                    Time: 10:26:26
   Part No SW: 3Q0 959 435 E    HW: 3Q0 959 435 E
   Component: VWKESSYMQB    036 0811
   Revision: 00036000    Serial number: 0406321036
   Coding: 0F2000070F
   ASAM Dataset: EV_KessyHellaMQBAB 004039
   ROD: EV_KessyHellaMQBAB_VW48.rod
   VCID: 3C21343A36E5FAF7D5F-8068
   Part No SW: 5GE 907 044 AK    HW: 5GE 907 044 AK
   Component: Climatronic   H04 1502
   Revision: 00001K07
   Coding: 12021004200110010815500000101822
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 055791DE05AF7B3FFA1-8050
   Geber f�r K�ltemitteldruck/K�ltemitteltemperatur:
   Subsystem 3 - Part No SW: 3Q0 963 231 C    HW: 3Q0 963 231 C
   Component: J848 HV-PTC  200 0203
   Serial number: -00102.2T.5B20340217
   Air quality sensor:
   Air Conditioning Compressor Sub:
H02
   Part No SW: 5Q0 937 086 BH    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 032 0222
   Revision: --------    Serial number: 8658310516016T
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_BodyContrModul1UDSBosc 017002
   ROD: EV_BCMBOSCH_017.rod
   VCID: 015F85CE1187571FC69-8054
   Subsystem 1 - Part No SW: 3G1 955 119 A    HW: 3G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    160417  042 0607
   Serial number:         160502180659
   Component: RLHS  042 0105
   Serial number: S6Y16M06D09H12M47S44
   Coding: 00A8DD
   Subsystem 3 - Part No SW: 3G0 941 633 J    HW: 3G0 941 633 J
   Serial number: 01 04 2016  10000366
   Part No SW: 5QA 919 298     HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0161
   Serial number: 000305183616131
   Coding: 1271161851
   Shop #: WSC 05311 115 00081
   ASAM Dataset: EV_EPHVA2CAU3700000 009017
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 0D47A9FE5DDF037FB21-8058
   Part No SW: 3Q0 907 572 B    HW: 3Q0 907 572 B
   Component: ACC BOSCH MQB H04 0194
   Coding: 5200670359FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 34311C1A1EB532B71DF-8060
   Part No SW: 5Q0 959 655 S    HW: 5Q0 959 655 S
   Component: AirbagVW20    010 0870
   Serial number: 003MFR02623.
   Coding: 88CCC000002000005C5400CF004800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 50F9708A8A6D6E97197-8004
   Subsystem 1 - Part No SW: -----------    HW: 480 002 705 16
   Serial number: 357000000009A2899A1U
   Subsystem 2 - Part No SW: -----------    HW: 480 002 705 16
   Serial number: 358000000002A2899A1O
   Subsystem 3 - Part No SW: -----------    HW: 480 400 306 16
   Serial number: 3510002AF2057291312P
   Subsystem 4 - Part No SW: -----------    HW: 480 401 105 16
   Serial number: 3520002C7205728502BU
   Subsystem 5 - Part No SW: -----------    HW: 480 402 702 16
   Serial number: 3550002C11EDD3E4A36N
   Part No SW: 3Q0 953 521 DJ    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160325500805
   Coding: 0410
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 7BA3F726736B3DCF9C5-802E
   Part No SW: 3G0 920 795 B    HW: 3G0 920 795 B
   Component: KOMBI         404 2153
   Coding: 07240B182FC0000801886B111201002000000000
   Shop #: WSC 00021 204 00000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009052
   VCID: 2C01047AC6856A7745F-8078
Address 19: CAN Gateway (J533)       Labels:* Redir Fail!
   Part No SW: 5QE 907 530 F    HW: 5QE 907 530 A
   Component: GW MQB EV     312 3265
   Revision: --------    Serial number: 22051610800080
   Coding: 020300172EF21000FB0052785C1D00000001070100010000000300000000
   ASAM Dataset: EV_GatewEVConti 013020
   ROD: EV_GatewEVConti_013.rod
   VCID: 49CF5DEE69375F5F5E9-801C
   Subsystem 1 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0040
   Serial number: 29160000993850086206
   Coding: 2DFFFF
   Subsystem 2 - Part No SW: 3Q0 915 181 B    HW: 3Q0 915 181 B
   Serial number: 5590489703
   Analog clock:
   Subsystem 3 - Part No SW: 3G0 919 204 C    HW: 3G0 919 204 C
   Component: Analoguhr  209 2002
Address 23: Brake Booster (J539)       Labels:* None
   Part No SW: 5QE 909 059 E    HW: 5QE 909 059 B
   Component: EBKV          H14 0200
   Serial number:   085430010193
   Coding: 05720100431900030002060500
   ASAM Dataset: EV_BrakeBoostBoschMQBOMG 004001
   ROD: EV_BrakeBoostBoschMQBOMG_004_VW48.rod
   Brake Assistance Sub:
   Subsystem 1 - Part No SW: 5QE 909 057 C    HW: 5QE 909 057 A
   Component: VX70BrakeAssi  H04 0152
   Serial number: 05802861200516062508
151552 - No Communication with ESP (Vehicle Dynamics) Control Module
          U0122 00 [040] - -
          [iBoVAG_ComScl_ESP_07_Timeout]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:36
250112 - Implausible Data Received from Engine Control Module
          U0401 00 [040] - -
          [iBoVAG_Scl_Motor_EV_02_TS_Istmoment_Error]
                    Mileage: 76030 km
                    Date: 2019.10.31
                    Time: 10:26:26
   Serial number: 16000111935011
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BFD50E2127479F369-8024
   Serial number: 270516EEQ34131
   Coding: 003F1F20D000020000001000
   VCID: 43D34FC64B1B850F945-8016
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000836213
   Coding: 01010010005100
   Shop #: WSC 00015 115 00300
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008_VW41.rod
   VCID: 3D27393E2DFFF3FFE21-8068
   Part No SW: 3G0 907 080 E    HW: 3G0 907 080 C
   Component: LE Gen 3.3H09 0072
   Revision: 00H09000
   Coding: C0020000000000000000
   ASAM Dataset: EV_DMCM08530113G0907080E 001017
   ROD: EV_DMCM08530113G0907080E.rod
   VCID: 270BFB56DF63492FA8D-8072
31708 - Control Module for Electric Drive Power Output
          P0A1B 00 [040] - -
                    Voltage terminal 30: 12.580 V
                    Drive control condition: failure
                    Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE: 12
31625 - Sensor / Hybrid CAN Bus (SAE Bus A)
          U0028 00 [040] - Malfunction
                    Mileage: 76030 km
                    Date: 2019.10.31
                    Time: 10:26:26
                    Voltage terminal 30: 12.597 V
                    Drive control condition: DisCharge
                    Drive control condition-Test_Program_Rbe Asw Invr Enum rbe Cmn Glb Drv Ctrl UBYTE: 13
   Serial number: 190516EEJ16535
   Coding: 003F1120DE00020000001000
   VCID: 42DD4AC254018C079F3-8016
   Coding: 03DA000009010000
   Shop #: WSC 05311 000 08193
   VCID: 75B7E11E554F6BBFEA1-8020
   Part No SW: 3G0 035 043 D    HW: 3G0 035 043
   Component: MU-H-N-EU     H51 0687
   Serial number: A683E0GS028890
   Coding: 02840201FF00000051110001000808001F0209E401200000DF
   VCID: 1D67D9BE8D3F93FFC21-8048
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL02627
   Subsystem 2 - Part No SW: V03 959 806 FM    HW: -----------
   Component: ECE 2019/2020  --- 0177
   Compact Disc Database:
   Component: Gracenote2---  --- 1013
7191 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Driving mode selection (0x17) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 167
                    Mileage: 76030 km
                    Date: 2019.10.31
                    Time: 14:39:48
                    Voltage terminal 30: 13.3 V
                    BAP-BAP_Function_ID: 02
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H09 0170
   Coding: 0184020162002017000041
   ASAM Dataset: EV_CamSysRVRVCPANAMQBAB 005007
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW48.rod
   VCID: 77ABEB164F4319AFF8D-8022
   Part No SW: 5QE 035 284 C    HW: 5QE 035 284 C
   Component: OCULowMQBEU   012 0715
   Coding: 0284720110829A0300F800000000
   ROD: EV_OCULowMQB.rod
   VCID: 44D14CDA4E158237ADF-8010
Address 8C: Hybrid Battery (J840)       Labels: 5QE-915-227.clb
   Part No SW: 3Q0 915 227 P    HW: 3Q0 915 227 K
   Component: K8C           H05 0520
   Serial number: 26041616010113
   ASAM Dataset: EV_BECM09620213Q0915227P 002009
   ROD: EV_BECM09620213Q0915227P.rod
   VCID: 3E253E3220F9E8E7FBB-806A
   Battery Junction Box:
   Subsystem 1 - Part No SW: 3Q0 915 227 J    HW: 3Q0 915 227 J
   Component: A2 HVSMBJBECU  H08 0410
   Serial number: 00000024031615010170
   Cell module: control module 1:
   Subsystem 2 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC1  H04 0442
   Serial number: 16306ZKK311A01040680
   Cell module: control module 2:
   Subsystem 3 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC2  H04 0442
   Serial number: 16306ZKK311A01041383
   Cell module: control module 3:
   Subsystem 4 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC3  H04 0442
   Serial number: 16306ZKK311A01041393
   Cell module: control module 4:
   Subsystem 5 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC4  H04 0442
   Serial number: 16306ZKK311A01040846
   Cell module: control module 5:
   Subsystem 6 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC5  H04 0442
   Serial number: 16306ZKK311A01040904
   Cell module: control module 6:
   Subsystem 7 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC6  H04 0442
   Serial number: 16303ZKK311A01040145
   Cell module: control module 7:
   Subsystem 8 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC7  H04 0442
   Serial number: 16306ZKK311A01040838
   Cell module: control module 8:
   Subsystem 9 - Part No SW: 5QE 915 591 H    HW: 5QE 915 591 H
   Component: J1068MQB CMC8  H04 0442
   Serial number: 16223ZKK311A01040765
8 Faults Found:
28817 - HV Battery Cell Balancing Circuit 1
          P0DAC 00 [040] - Electrical Malfunction
          [Diag_H_CC0]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:37
                    Current of H-V / hybrid battery: 0.000 A
28818 - HV Battery Cell Balancing Circuit 2
          P0DB0 00 [040] - Electrical Malfunction
          [Diag_H_CC1]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:37
28819 - HV Battery Cell Balancing Circuit 3
          P0DB4 00 [040] - Electrical Malfunction
          [Diag_H_CC2]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:37
28820 - HV Battery Cell Balancing Circuit 4
          P0DB8 00 [040] - Electrical Malfunction
          [Diag_H_CC3]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:37
28821 - HV Battery Cell Balancing Circuit 5
          P0DBC 00 [040] - Electrical Malfunction
          [Diag_H_CC4]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:37
28822 - HV Battery Cell Balancing Circuit 6
          P0DC0 00 [040] - Electrical Malfunction
          [Diag_H_CC5]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:37
28823 - HV Battery Cell Balancing Circuit 7
          P0DC4 00 [040] - Electrical Malfunction
          [Diag_H_CC6]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:37
28824 - HV Battery Cell Balancing Circuit 8
          P0DC8 00 [040] - Electrical Malfunction
          [Diag_H_CC7]
                    Mileage: 76030 km
                    Date: 2019.10.29
                    Time: 15:28:37
   Part No SW: 3G0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H07 0006
   Serial number: 160511200777
   VCID: 698FBD6E09F7BF5F7E9-803C
   Serial number: 260516EEQ2253B
   Coding: 000E11200100020000001000
   VCID: 45D751DE452FBB3FBA1-8010
   Serial number: 260516EEQ22538
   Part No SW: 5QE 915 682 M    HW: 5QE 915 682 M
   Component: OBC KOSTAL    H31 4006
   Revision: --------    Serial number: 1105160DT000VR
   Coding: 115068222000
   ASAM Dataset: EV_OBCSinglPhaseKLOMQB11P 004001
   ROD: EV_OBCSinglPhaseKLOMQB11P.rod
   VCID: 57EB8B96AF8339AFD8D-8002
13705502 - Databus
          [Einheiten_01_TimeOut]
                    Reset counter: 207
13705485 - Databus
          [Diagnose_01_TimeOut]
                    Reset counter: 207
13705520 - Databus
          [DC_HYB_01_TimeOut]
                    Reset counter: 207
13705540 - Databus
          [Errorvalue_ ESP_21_CHK]
                    Reset counter: 207
                    Mileage: 75611 km
                    Date: 2019.10.11
                    Time: 14:51:15
End------(Elapsed Time: 02:18, VBatt start/end: 12.6V/12.7V, udsna)--------
I can only see one lead, any ideas?
          U1111 00 [009] - -
                    Reset counter: 167
                    Mileage: 76030 km
                    Date: 2019.10.31
                    Time: 14:39:48
There are a large number of "missing message" kind of faults dated two days ago. Did anything particular happen 2019.10.29 at about 3:30 in the afternoon?
My guess is that the root cause behind lack of e-drive is drive lies in the "HV Battery Cell Balancing Circuit" faults in the 8C: Hybrid Battery (J840). But that's only a guess.
The first thing I would do if this was my car is clear all those fault codes in all the systems, and then see what comes back.
PS: You are now Verified and I'm moving this to Car Repair Support.
fdim
Copenhagen, Denmark
C?ID=379899
Okay, so this is a bit funny - I ordered the cable in the weekend and to my surprise I got a call from VW service on Monday that someone in Germany (they were in touch) wants to investigate further on what went wrong and asked me if I can leave them the car for few days - of course I said yes.
So, the car was in a VW service for last 3 days and they were trying to find the cause. No luck, I was told that this particular car, from manufacturer's standpoint *should* not have this feature and that they will reach out to the seller in France from where the car was imported. I may hear from them again, but who knows - warranty is out anyway. There was a 3 week radio silence before and this is the reason why I ordered the cable.
I am starting to have a feeling that previous owner retrofitted some equipment and/or did some changes that now got revered after keys were paired or VW screwed up and did not link some feature to the VIN...
For example the fault that I have is listed by this guy: https://forums.ross-tech.com/showthread.php?14756-2016-GTI-clubsport-Driving-mode-not-working
The difference is that as far as I know GTEs comes with these modes by default, while in others it's hidden/disabled behind a FeC or SWAP.
Anyway, I was comparing the coding values of CAN gateway and 5F but I am yet to find a reference that has MIB-HIGH variant: https://forums.ross-tech.com/showthread.php?9415-2017-Passat-GTE-1-4TSI&highlight=1.4TSI
EDIT: The car itself drives OK as it would be in a hybrid mode, and if I push accelerator till the very end (after a 'tick') - electric engine also kicks in. So I do not think that there is a hardware fault, only software glitch.
I am also very tempted to do this and see what happens: https://www.speakev.com/threads/who...ds-controller-channel-map.22361/#post-1224225
fdim
Copenhagen, Denmark
C?ID=379899
I've played around today a bit, charged the battery and cleared the error codes. Only 1 came back that I mentioned previously.
I also exported adaptations for all controllers that if someone needs can find here
Aside of that, does anyone know what does this adaptation do: ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration? It was disabled originally
EDIT: hm, seems like transport mode is enabled for 09 BCM, could this have some kind of side effects?
fdim
Copenhagen, Denmark
C?ID=379899
a month later...
The driving modes are now working! Finally it's back to normal
When they took in the car yesterday the mechanic basically said they they got instructions to try and pair with single key to see what happens.
And today I got a call that everything is working! I haven't got much details from the workshop, but they said that they did same procedure as last time and for some reason this time it worked.
So I guess either their tool got a bugfix or it was an actual issue on VW side (ahem unchecked checkbox and missing feature for my VIN)
I'll update the post when I'll do an autoscan to see if anything is different
