Setting chirp upon locking car.
marble
Singapore
C?ID=291009
Hi,
I've gotten a new B9 A5 recently and would like to activate chirp on locking the car. However after much tries, it still did not work. The closest i got was this post:
https://www.audi-sport.net/xf/threads/vcds-modifications.291602/#post-2885389
Basically for some modifications you have to "allow them" before you can code or adapt them which limits the use of VCDS for the moment. Ross-Tech will be releasing a new cable next year which will sit between Hex-CAN and Hex-NET and hopefully they will introduce the ability to access this matrix and parameterisation...
An example for permissions - Acoustic Alarm Beep on Lock and Unlock:
*via VAG CAN Professional
Control Module 46
Access Permissions and Programming Matrix
Search for Horn Acknowledgment and set to "active"
Exit
Adaptation Channel beep-time closing central locking = Single Beep (Double or No Beep also available)
Adaptation Channel beep-time opening central locking = Double Beep (Single or No Beep also available)
Exit
So you could complete steps 5 and 6 but without step 3 both 5 and 6 will not work.
I can see the option inside MMI but no matter how i change the adaptations single beep/double beep/beep duration i am still unable to get it to work. I had no issues getting it to work on the golf 1.0. Any ideas how to go on from here?
Do we have an Auto-Scan from this car somewhere?
marble
Singapore
C?ID=291009
My bad. Here is the auto scan for 46
Address 46: Central Conv. (J393) Labels: None
Part No SW: 8W1 907 064 AC HW: 8W1 907 064 C
Component: BCM2 MLBevo 044 0529
Coding: 01350000402010E0630980000C00080011024010804002502F0400004504803F001F0001030010
Shop #: WSC 06335 790 00001
ASAM Dataset: EV_BCM2HellaAU736 017017
ROD: N/A
VCID:
No ASAM data for: "EV_BCM2HellaAU736"
Subsystem 1 - Part No SW: 3AA-962-243-H
Component: GEB.F.HeckoefH16 0905
Serial Number:
No fault codes found.
That's just snippet, not an Auto-Scan. Moreover, it looks like VCDS can't find any ASAM data for the module and without the rest of the scan for context, I haven't a clue why this would be.
marble
Singapore
C?ID=291009
Woopps.. heres the full auto scan..
Monday,14,October,2019,15:07:03:04807
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZF54KA999999   License Plate:
Chassis Type: F5-AU49 (4M1)
Scan: 01 02 03 08 09 15 16 17 19 29 36 39 42 44 46 52 5F 6C 6D 81
          BB BC D6 D7
VIN: WAUZZZF54KA999999   Mileage: 988km-613miles
Address 01: Engine (J623-CVKB)       Labels:. 06L-907-115-V1.clb
   Part No SW: 8W0 907 115 K    HW: 06L 907 309 A
   Component: R4 2.0l TFSI  H43 0006
   Revision: S1H43---
   Coding: 1A2500132324050334080000000000000000000000000000
   Shop #: WSC 06314 790 00001
   ASAM Dataset: EV_ECM20TFS0118W0907115K 001007
   ROD: EV_ECM20TFS0118W0907115K.rod
   VCID: 41CA9799D99B9D99E9-9999
   Part No SW: 8W2 927 155 BL    HW: 0HK 927 156 B
   Component: 0CK 20TFSIRdW H01 0003
   Revision: --H01---    Serial number: 0000000000
   ASAM Dataset: EV_TCMDL382021 002031
   ROD: EV_TCMDL382021_AU49.rod
   Subsystem 1 - Part No SW: 0CK 927 152 AA    HW: 0CK 321 281 L
   Component: V553 MTFP  003 0576
   Part No SW: 8W0 907 379 AF    HW: 8W0 907 379 J
   Component: ESP9 Plus     H16 0777
   Coding: 08AA089A10A90A9D119E4891007F5292E5B5C0101008508812004A49A7AD03
   Shop #: WSC 06334 790 00001
   ROD: EV_ESP9BOSCHCMP_002.rod
Address 08: Auto HVAC (E87)       Labels:* Redir Fail!
   Part No SW: 8W0 820 043 S    HW: 8W0 820 043 S
   Component: Klima Zone 3  H60 0251
   Coding: 140801885544040D10000100080000000000000000000000000000000000
   ROD: EV_AirCondiBHTCAU491.rod
   Subsystem 1 - Part No SW: 4M2 820 021 C    HW: 4M2 820 021 C
   Component: J126 FLuftV  H09 0004
   Subsystem 3 - Part No SW: 8W0 919 158     HW: 8W0 919 158
   Component: E265 Kli Fond  H40 0080
   Part No SW: 8W0 907 063 DF    HW: 8W0 907 063 BF
   Component: BCM1 MLBevo   H13 0313
   Coding: 07501B43E11A00CD051457181B2D08F9110B3108000000000000000020001A810A450122025605
   ASAM Dataset: EV_BCM1BOSCHAU736 019008
   ROD: EV_BCM1BOSCHAU736_019.rod
   Subsystem 1 - Part No SW: 8W6 955 119 C    HW: 8W6 955 119 A
   Component: 494 RL 190628  036 0481
   Coding: FFC7F7
   Coding: 02005D
   Subsystem 3 - Part No SW: 4M0 941 531 AG    HW: 4M0 941 531 AG
   Component: E1 - LDS  H06 0008
   Coding: 210000
   Interior Light Module:
   Subsystem 5 - Part No SW: 4K0 947 135 AC    HW: 4K0 947 135 AC
   Component: Dachmodul  H42 0415
   Coding: 010104
   Subsystem 6 - Part No SW: 8W0 925 301 BC    HW: 8W0 925 301 BC
   Component: SL-B9/Q5NF  H17 0010
Address 15: Airbags (J234)       Labels:| 8W0-959-655.clb
   Part No SW: 8W0 959 655 F    HW: 8W0 959 655 F
   Component: Airbag10.44   H03 0109
   Coding: AACCF00000800000580000F3D0CC00000000
   ASAM Dataset: EV_AirbaAU10BPAAU736 006016
   ROD: EV_AirbaAU10BPAAU736_006_AU49.rod
   Subsystem 1 - Part No SW: -----------    HW: 442 062 006 19
   Subsystem 2 - Part No SW: -----------    HW: 442 062 006 19
   Subsystem 3 - Part No SW: -----------    HW: 442 0B2 406 19
   Subsystem 4 - Part No SW: -----------    HW: 442 0B2 406 19
   Subsystem 5 - Part No SW: -----------    HW: 442 0C2 906 19
   Front Sensor Passenger:
   Subsystem 6 - Part No SW: -----------    HW: 442 0C2 906 19
   Part No SW: 4N0 907 129 S    HW: 4N0 907 129 S
   Part No SW: 8W5 920 790 E    HW: 8W5 920 790 E
   Component: FBenRDW       H19 0417
   Coding: 24A448C6288000080120EF401000000000000000
   ASAM Dataset: EV_DashBoardAU736 001032
   Part No SW: 4M1 907 468 J    HW: 4M1 907 468 E
   Component: Gateway       H24 0152
   Revision: CA010001    Serial number: 0000000000
   Coding: 03010001000086402907000000590012C8180000100000000100000000000000
   ASAM Dataset: EV_GatewCONTIAU736 004190
   ROD: EV_CGateCONTIAU491_004_VW53.rod
   Subsystem 1 - Part No SW: 8W0 951 523 F    HW: 8W0 951 523 F
   Component: J453 MFL  H04 0004
   Part No SW: 4M0 907 397 AB    HW: 4M0 907 397 B
   Component: LCM_MLBevoH05 0024
   Coding: 00781B000000B0010000010101010000000000000000000000000000000000
   Part No SW: 8W0 959 593 H    HW: 8W0 959 593 F
   Component: TSG FS        009 0130
   Coding: 001DCB625E01000000011400
   Part No SW: 8W0 909 144 H    HW: 8W0 909 144 B
   Component: EPS_MLBEVO_ZF H08 0410
   Coding: 09000380008000
   ASAM Dataset: EV_EPSZFAU49X 003023
   ROD: EV_EPSZFAU49X_003.rod
   ROD: EV_BCM2HellaAU736_017_AU49.rod
   Subsystem 1 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0905
   Part No SW: 8W0 959 592 H    HW: 8W0 959 592 F
   Component: TSG BFS       009 0130
   Coding: 001DCB225E01000000011400
   Part No SW: 8W5 035 039 D    HW: 8W5 035 039
   Component: MU-P-LN-RW    035 1329
   Coding: 01940307FF0A000013110001000A00102F000DE601700900DE
   Subsystem 1 - Part No SW: V03 959 802 DJ    HW: -----------
   Component: ROW 2019/2020  --- 0079
   Subsystem 2 - Part No SW: 8W8 919 605     HW: 8W8 919 605
   Component: DU High AU49x  H32 0170
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8W0 919 614 T    HW: 8W0 919 614 T
   Component: ControlUnit_H  H30 0206
   Compact Disc Database:
   Component: Gracenote2  --- 4013
   Component: RVC Compact   H18 0250
   Coding: 0294030102002001400040
   ROD: EV_CamSysRVRVCPANAMLBEv_005_AU49.rod
   Part No SW: 8W8 959 107 D    HW: 8W8 959 107
   Component: HDSG-Modul    H13 0171
   Revision: --------    Serial number: 0000000000
   Coding: 0630
   Part No SW: 8W2 713 041 N    HW: 8W2 713 041 K
   Component: GSM-LL        H10 0077
   Revision: 0L0D5012    Serial number: 0000000000
   ROD: EV_GSMWaehlZFAU736.rod
   Part No SW: 8W0 959 595 H    HW: 8W0 959 595 F
   Component: TSG HFS       009 0130
   Coding: 000DC9220001000000001000
   Component: TSG HBFS      009 0130
   ROD: EV_DCU2RearPasseMAXHCONT_AU49.rod
End----------(Elapsed Time: 01:49, VBatt start/end: 13.1V/13.2V)-----------
OK, You may need to change the coding in Byte 22 to enable "remote_flashing_and_beep". This should be documented in the yellow "experimental" coding screen.
If that doesn't do the trick, please make an Adapation Channel map from your 46-CCM module so we can see what's going on there.
[Applications]
[Controller Channel Maps]
- Set Controller Address to 46
- Leave Login or security access blank.
- Select Function: Adaptations
- Select Output: CSV file.
[Go]
Post the resulting file here.
marble
Singapore
C?ID=291009
nope, the byte 22 edit doesnt work. :cry:
heres the channel maps
;SW:8W1-907-064-AC   HW:8W1-907-064-C ---  Central Conv.
;Component:BCM2 MLBevo   044 0529, Coding:01350000402010E0630980000C00080011024010804006502F0400004504803F001F0001030010
;EV_BCM2HellaAU736,017017,EV_BCM2HellaAU736_017_AU49.rod
;Tuesday,15,October,2019,13:14:44:04807
;VCDS Version: Release 19.6.2 (x64)  Data version: 20190930 DS308.0
IDE00001-MAS10843-Production mode-Deactivate interior lighting,not active ,3
IDE00001-MAS10851-Production mode-Deactivate engine start,not active ,3
IDE00001-MAS10853-Production mode-Deactivate sensor-controlled rear lid opening,not active ,3
IDE00001-MAS10854-Production mode-Deactivate central locking: function lock,not active ,3
IDE00001-MAS10855-Production mode-Deactivate ignition switch-off when vehicle has been left,not active ,3
IDE00001-MAS12009-Production mode-Deactivate lighting,not active ,3
IDE00001-MAS12010-Production mode-Deactivate automatic unlocking,not active ,3
IDE00001-MAS17290-Production mode-Suppress further signal sources for “Terminal 15 on”,not active ,3
IDE00820-Activating and deactivating all development messages,00 ,1
IDE01464-MAS01167-Rear window defogger-Actuation time,600 s,2
IDE01464-MAS01186-Rear window defogger-Shut-off temperature,35.0 °C,2
IDE04923-MAS08465-Turn signal control-Freeway flashing: flashing cycles,5 ,4
IDE04923-MAS08466-Turn signal control-Confirmation flashing unlocking central locking:flashing cycles,2 ,4
IDE04923-MAS08467-Turn signal control-Confirmation flashing locking central locking: flashing cycles,1 ,4
IDE04923-MAS10114-Turn signal control-Turn signal with relocking,On ,4
IDE04923-MAS10115-Turn signal control-Anti-theft blinkers by inter. door handle activ.,On ,4
IDE04923-MAS13291-Turn signal control-Motorway flashing cancel by counter tap,On ,4
IDE07279-Anti-theft warning system: monitoring diagnostics connection,On ,1
IDE07392-Terminal 15,Default ,1
IDE08221-MAS02444-Personalization settings key 1-Central locking,global opening ,3
IDE08221-MAS06456-Personalization settings key 1-Autolock,On ,3
IDE08221-MAS06457-Personalization settings key 1-autounlock,On ,3
IDE08221-MAS06696-Personalization settings key 1-Comfort opening sunroof,OFF ,3
IDE08221-MAS06697-Personalization settings key 1-Acoustic acknowledge signal,On ,3
IDE08221-MAS06698-Personalization settings key 1-Freeway flashing,On ,3
IDE08221-MAS06740-Personalization settings key 1-Release button in rear lid handle locked,OFF ,3
IDE08221-MAS06756-Personalization settings key 1-Window shade automatic,OFF ,3
IDE08221-MAS06880-Personalization settings key 1-Mirror fold-in (Audi),On ,3
IDE08221-MAS10221-Personalization settings key 1-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE08221-MAS10228-Personalization settings key 1-Comfort opening window: driver side,On ,3
IDE08221-MAS10229-Personalization settings key 1-Comfort opening window: frt. pass. side,On ,3
IDE08221-MAS10230-Personalization settings key 1-Comfort opening rear window: driver side,On ,3
IDE08221-MAS10231-Personalization settings key 1-Comfort opening rear window: frt. pass. side,On ,3
IDE08222-MAS02444-Personalization settings key 2-Central locking,global opening ,3
IDE08222-MAS06456-Personalization settings key 2-Autolock,On ,3
IDE08222-MAS06457-Personalization settings key 2-autounlock,On ,3
IDE08222-MAS06696-Personalization settings key 2-Comfort opening sunroof,OFF ,3
IDE08222-MAS06697-Personalization settings key 2-Acoustic acknowledge signal,On ,3
IDE08222-MAS06698-Personalization settings key 2-Freeway flashing,On ,3
IDE08222-MAS06740-Personalization settings key 2-Release button in rear lid handle locked,OFF ,3
IDE08222-MAS06756-Personalization settings key 2-Window shade automatic,OFF ,3
IDE08222-MAS06880-Personalization settings key 2-Mirror fold-in (Audi),On ,3
IDE08222-MAS10221-Personalization settings key 2-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE08222-MAS10228-Personalization settings key 2-Comfort opening window: driver side,OFF ,3
IDE08222-MAS10229-Personalization settings key 2-Comfort opening window: frt. pass. side,OFF ,3
IDE08222-MAS10230-Personalization settings key 2-Comfort opening rear window: driver side,OFF ,3
IDE08222-MAS10231-Personalization settings key 2-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08223-MAS02444-Personalization settings key 3-Central locking,global opening ,3
IDE08223-MAS06456-Personalization settings key 3-Autolock,On ,3
IDE08223-MAS06457-Personalization settings key 3-autounlock,On ,3
IDE08223-MAS06696-Personalization settings key 3-Comfort opening sunroof,OFF ,3
IDE08223-MAS06697-Personalization settings key 3-Acoustic acknowledge signal,On ,3
IDE08223-MAS06698-Personalization settings key 3-Freeway flashing,On ,3
IDE08223-MAS06740-Personalization settings key 3-Release button in rear lid handle locked,OFF ,3
IDE08223-MAS06756-Personalization settings key 3-Window shade automatic,OFF ,3
IDE08223-MAS06880-Personalization settings key 3-Mirror fold-in (Audi),OFF ,3
IDE08223-MAS10221-Personalization settings key 3-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE08223-MAS10228-Personalization settings key 3-Comfort opening window: driver side,OFF ,3
IDE08223-MAS10229-Personalization settings key 3-Comfort opening window: frt. pass. side,OFF ,3
IDE08223-MAS10230-Personalization settings key 3-Comfort opening rear window: driver side,OFF ,3
IDE08223-MAS10231-Personalization settings key 3-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08224-MAS02444-Personalization settings key 4-Central locking,global opening ,3
IDE08224-MAS06456-Personalization settings key 4-Autolock,On ,3
IDE08224-MAS06457-Personalization settings key 4-autounlock,On ,3
IDE08224-MAS06696-Personalization settings key 4-Comfort opening sunroof,OFF ,3
IDE08224-MAS06697-Personalization settings key 4-Acoustic acknowledge signal,On ,3
IDE08224-MAS06698-Personalization settings key 4-Freeway flashing,On ,3
IDE08224-MAS06740-Personalization settings key 4-Release button in rear lid handle locked,OFF ,3
IDE08224-MAS06756-Personalization settings key 4-Window shade automatic,OFF ,3
IDE08224-MAS06880-Personalization settings key 4-Mirror fold-in (Audi),OFF ,3
IDE08224-MAS10221-Personalization settings key 4-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE08224-MAS10228-Personalization settings key 4-Comfort opening window: driver side,OFF ,3
IDE08224-MAS10229-Personalization settings key 4-Comfort opening window: frt. pass. side,OFF ,3
IDE08224-MAS10230-Personalization settings key 4-Comfort opening rear window: driver side,OFF ,3
IDE08224-MAS10231-Personalization settings key 4-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08225-MAS02444-Personalization settings vehicle-Central locking,global opening ,3
IDE08225-MAS06456-Personalization settings vehicle-Autolock,On ,3
IDE08225-MAS06457-Personalization settings vehicle-autounlock,On ,3
IDE08225-MAS06696-Personalization settings vehicle-Comfort opening sunroof,OFF ,3
IDE08225-MAS06697-Personalization settings vehicle-Acoustic acknowledge signal,On ,3
IDE08225-MAS06698-Personalization settings vehicle-Freeway flashing,On ,3
IDE08225-MAS06740-Personalization settings vehicle-Release button in rear lid handle locked,OFF ,3
IDE08225-MAS06756-Personalization settings vehicle-Window shade automatic,OFF ,3
IDE08225-MAS06880-Personalization settings vehicle-Mirror fold-in (Audi),OFF ,3
IDE08225-MAS10221-Personalization settings vehicle-Rear lid unlocking through rear lid opening sensors,On ,3
IDE08225-MAS10228-Personalization settings vehicle-Comfort opening window: driver side,OFF ,3
IDE08225-MAS10229-Personalization settings vehicle-Comfort opening window: frt. pass. side,OFF ,3
IDE08225-MAS10230-Personalization settings vehicle-Comfort opening rear window: driver side,OFF ,3
IDE08225-MAS10231-Personalization settings vehicle-Comfort opening rear window: frt. pass. side,OFF ,3
IDE08225-MAS16238-Personalization settings vehicle-Keyless access authorization,On ,3
IDE08225-MAS20619-Personalization settings vehicle-Keyless access authorization: automatic opening,not active ,3
IDE08226-Use of personalization settings,Key ,1
IDE08398-Delay time alarm triggering,0 s,1
IDE08399-Delay time crash unlocking,2.5 s,1
IDE08400-Betätigungszeit Öffnen der Heckklappe mit Funkfernbedienung,800 ms,1
IDE09735-CU tailgate opener: sensor 1: threshold value 1,15 ,1
IDE09736-CU tailgate opener: sensor 1: threshold value 2,10 ,1
IDE09737-CU tailgate opener: sensor 1: threshold value 3,10 ,1
IDE09738-CU tailgate opener: sensor 1: threshold value 4,10 ,1
IDE09739-CU tailgate opener: sensor 1: threshold value 5,10 ,1
IDE09740-CU tailgate opener: sensor 2: threshold value 1,02 ,1
IDE09741-CU tailgate opener: sensor 2: threshold value 2,1F ,1
IDE09742-CU tailgate opener: sensor 2: threshold value 3,02 ,1
IDE09743-CU tailgate opener: sensor 2: threshold value 4,1F ,1
IDE09744-CU tailgate opener: sensor 2: threshold value 5,E0 ,1
IDE09745-CU tailgate opener: sensor 1: timer value 1,AA ,1
IDE09746-CU tailgate opener: sensor 1: timer value 2,00 ,1
IDE09747-CU tailgate opener: sensor 1: timer value 3,09 ,1
IDE09748-CU tailgate opener: sensor 1: timer value 4,E1 ,1
IDE09749-CU tailgate opener: sensor 1: timer value 5,00 ,1
IDE09750-CU tailgate opener: sensor 2: timer value 1,0B ,1
IDE09751-CU tailgate opener: sensor 2: timer value 2,AA ,1
IDE09752-CU tailgate opener: sensor 2: timer value 3,9E ,1
IDE09753-CU tailgate opener: sensor 2: timer value 4,CC ,1
IDE09754-CU tailgate opener: sensor 2: timer value 5,95 ,1
IDE09755-CU tailgate opener: sensor 1: burst length,10 ,1
IDE09756-CU tailgate opener: sensor 1: active screening,10 ,1
IDE09757-CU tailgate opener: sensor 2: burst length,02 ,1
IDE09758-CU tailgate opener: sensor 2: active screening,1F ,1
IDE09759-CU for tailgate opener: reset all counters,E0 ,1
IDE09760-CU for tailgate opener: check sum,AA ,1
IDE09829-CU tailgate opener: foot gestic recognition: timer value 1,02 ,1
IDE09830-CU tailgate opener: foot gestic recognition: timer value 2,1F ,1
IDE09831-CU for tailgate opener: play protection increments,06 ,1
IDE09832-CU for tailgate opener: play protection decrements,19 ,1
IDE09833-CU for tailgate opener: play protection threshold active,FF ,1
IDE09834-CU for tailgate opener: play protection threshold inactive,05 ,1
IDE09835-CU for tailgate opener: play protection decrement interval,3C ,1
IDE09836-CU tailgate opener: sensor 1: control parameter,10 ,1
IDE09837-CU tailgate opener: sensor 2: control parameter,10 ,1
IDE09838-CU tailgate opener: foot gestic recognition: evaluation,00 ,1
IDE09839-CU for tailgate opener: parameter set version,00 45 ,2
IDE10086-IDE02262-Personal settings of key 1: Part 2-synchronous mirror adjustment,OFF ,1
IDE10086-IDE03946-Personal settings of key 1: Part 2-Mirror dimming,OFF ,1
IDE10086-MAS05213-Personal settings of key 1: Part 2-Mirror heater,OFF ,1
IDE10086-MAS06870-Personal settings of key 1: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10086-MAS06881-Personal settings of key 1: Part 2-Mirror fold-in (VW),OFF ,1
IDE10087-IDE02262-Personal settings of key 2: Part 2-synchronous mirror adjustment,OFF ,1
IDE10087-IDE03946-Personal settings of key 2: Part 2-Mirror dimming,OFF ,1
IDE10087-MAS05213-Personal settings of key 2: Part 2-Mirror heater,OFF ,1
IDE10087-MAS06870-Personal settings of key 2: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10087-MAS06881-Personal settings of key 2: Part 2-Mirror fold-in (VW),OFF ,1
IDE10088-IDE02262-Personal settings of key 3: Part 2-synchronous mirror adjustment,OFF ,1
IDE10088-IDE03946-Personal settings of key 3: Part 2-Mirror dimming,OFF ,1
IDE10088-MAS05213-Personal settings of key 3: Part 2-Mirror heater,OFF ,1
IDE10088-MAS06870-Personal settings of key 3: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10088-MAS06881-Personal settings of key 3: Part 2-Mirror fold-in (VW),OFF ,1
IDE10089-IDE02262-Personal settings of key 4: Part 2-synchronous mirror adjustment,OFF ,1
IDE10089-IDE03946-Personal settings of key 4: Part 2-Mirror dimming,OFF ,1
IDE10089-MAS05213-Personal settings of key 4: Part 2-Mirror heater,OFF ,1
IDE10089-MAS06870-Personal settings of key 4: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10089-MAS06881-Personal settings of key 4: Part 2-Mirror fold-in (VW),OFF ,1
IDE10090-IDE02262-Personal settings of vehicle: Part 2-synchronous mirror adjustment,OFF ,1
IDE10090-IDE03946-Personal settings of vehicle: Part 2-Mirror dimming,OFF ,1
IDE10090-MAS05213-Personal settings of vehicle: Part 2-Mirror heater,OFF ,1
IDE10090-MAS06870-Personal settings of vehicle: Part 2-Mirror lowering in reverse travel,OFF ,1
IDE10090-MAS06881-Personal settings of vehicle: Part 2-Mirror fold-in (VW),OFF ,1
IDE10283-Key identification: transponder ID,FF FF FF FF ,4
IDE10318-Sunshade activation,cannot be activated ,1
IDE10347-Trip distance challenge,00 00 00 00 00 00 00 00 ,8
IDE10836-Enable code for vehicle positioning system,18477 ,2
IDE10858-Number of simultaneously adapting key,0 ,1
IDE10913-MAS10979-Setting the key data-Start page,00 00 ,3
IDE10913-MAS10980-Setting the key data-No. of pages,00 ,3
IDE10913-MAS11635-Setting the key data-Data security,encrypted ,3
IDE11476-Ignition lock: variant,Audi ,1
IDE11487-Trunk emergency release,OFF ,1
IDE11700-Parameter group 1,FF FF FF 80 00 00 00 00 00 00 0F 32 0A 05 80 0F 19 50 46 46 00 0A 02 14 3C 01 00 14 00 02 05 00 0A 14 B4 14 01 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 39 DE ,255
IDE11701-Parameter group 2,FF FF FF FF F0 00 00 00 00 00 00 00 1E 01 1E 0A 00 0A 03 00 00 00 1E 0A 3C 3C 01 04 00 01 03 00 00 00 01 50 96 01 01 02 FF 00 FF 00 00 5A 14 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1A E6 ,255
IDE11702-Parameter group 3,FF FF FF C0 00 00 00 00 00 00 0A 0C 14 16 14 16 02 00 0A 14 16 14 1E 14 3C 14 1E 0A FF FF FF 05 28 3C 00 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 1C 1B ,255
IDE11703-Parameter group 4,E0 00 00 00 00 00 00 00 00 00 7F FF 83 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0C AA ,255
IDE11704-Parameter group 5,E0 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B3 CA ,255
IDE11705-Parameter group 6,FF FF C0 00 00 00 00 00 00 00 F5 96 02 0A 64 02 01 00 96 06 96 06 96 06 96 06 14 00 0F 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 2B 44 ,255
IDE11706-Parameter group 7,FF FF FF FF FF E0 00 00 00 00 02 0A 32 3C 18 14 05 0A 1E 01 02 5A 14 14 0A 00 00 06 05 0F 14 00 5A 02 32 14 05 05 05 05 05 05 05 01 00 32 0A 05 1E 06 14 01 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 FF 2B ,255
IDE11707-Parameter group 8,FF FF FF FE 00 00 00 00 00 00 01 00 00 1E 00 05 32 00 00 01 07 00 07 00 00 02 01 01 04 00 14 1E 0A 02 0A 02 1E 64 1E 0A 3C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C0 0B ,255
IDE11708-Parameter group 9,80 00 00 00 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF F3 FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B6 9E ,255
IDE11709-Parameter group 10,FF E0 00 00 00 00 00 00 00 00 00 0A 00 0A 00 1C 00 3C 00 32 0A 05 05 32 05 0A 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 92 E4 ,255
IDE11798-Speed-dependent activation of the back window heater,activated ,1
IDE11935-MAS13456-Personalization-Automatic key assignment,activated ,1
IDE11935-MAS13457-Personalization-Status of personalization,activated ,1
IDE12303-MAS14243-Separation monitoring radio key to rear lid-Minimum opening angle of the rear lid for activation,3 %,6
IDE12303-MAS14244-Separation monitoring radio key to rear lid-Minimum opening angle of the rear lid to reverse,224 %,6
IDE12303-MAS14245-Separation monitoring radio key to rear lid-Lock vehicle after closing,OFF ,6
IDE12303-MAS14246-Separation monitoring radio key to rear lid-Monitoring time for rear lid restart,0 %,6
IDE12303-MAS14247-Separation monitoring radio key to rear lid-Monitoring time for rear lid closing,0 %,6
IDE12465-Rear lid opener control module: response in trailer mode,not activated ,2
IDE12481-MAS06700-Horn and flasher via smartphone app-Speed threshold,0 km/h,5
IDE12481-MAS14561-Horn and flasher via smartphone app-Division factor of horn frequency,0 ,5
IDE12481-MAS14562-Horn and flasher via smartphone app-Maximum execution duration,45 s,5
IDE12548-MAS14750-NFC communication: settings-Command category for single-sided NFC authentication,00 ,27
IDE12548-MAS14751-NFC communication: settings-Command for one-sided NFC authentication,10 ,27
IDE12548-MAS14752-NFC communication: settings-Parameter 1 for one-sided NFC authentication,00 ,27
IDE12548-MAS14753-NFC communication: settings-Parameter 2 for one-sided NFC authentication,00 ,27
IDE12548-MAS14754-NFC communication: settings-Command category for two-sided NFC authentication,00 ,27
IDE12548-MAS14755-NFC communication: settings-Command for two-sided NFC authentication,10 ,27
IDE12548-MAS14756-NFC communication: settings-Parameter 1 for two-sided NFC authentication,10 ,27
IDE12548-MAS14757-NFC communication: settings-Parameter 2 for two-sided NFC authentication,00 01 02 ,27
IDE12548-MAS14758-NFC communication: settings-Time point for NFC advance authentication,Last door closed ,27
IDE12548-MAS14761-NFC communication: settings-Block NFC device in the interior,not activated ,27
IDE12548-MAS14762-NFC communication: settings-NFC event search,activated ,27
IDE12548-MAS15378-NFC communication: settings-Command category to trigger an event,00 ,27
IDE12548-MAS15379-NFC communication: settings-Command to trigger an event,10 ,27
IDE12548-MAS15380-NFC communication: settings-Parameter 1 to trigger an event,20 ,27
IDE12548-MAS15381-NFC communication: settings-Parameter 2 to trigger an event,00 ,27
IDE12548-MAS15382-NFC communication: settings-Command category for vehicle data,00 ,27
IDE12548-MAS15383-NFC communication: settings-Command for vehicle data,10 ,27
IDE12548-MAS15384-NFC communication: settings-Parameter 1 for vehicle data,90 ,27
IDE12548-MAS15385-NFC communication: settings-Parameter 2 for vehicle data,01 ,27
IDE12548-MAS15386-NFC communication: settings-Command category for event data,00 ,27
IDE12548-MAS15387-NFC communication: settings-Command for event data,10 ,27
IDE12548-MAS15388-NFC communication: settings-Parameter 1 for event data,90 ,27
IDE12548-MAS15389-NFC communication: settings-Parameter 2 for event data,00 ,27
IDE12548-MAS16723-NFC communication: settings-Expected length of triggering event,00 ,27
IDE12548-MAS16724-NFC communication: settings-Expected length of vehicle data,00 ,27
IDE12548-MAS16725-NFC communication: settings-Expected length of event data,00 ,27
IDE12548-MAS18680-NFC communication: settings-Mobile device charger: duration of charge interruption,2540 ms,27
IDE12792-MAS02444-Personalization of user account 1-Central locking,global opening ,3
IDE12792-MAS06456-Personalization of user account 1-Autolock,On ,3
IDE12792-MAS06457-Personalization of user account 1-autounlock,On ,3
IDE12792-MAS06696-Personalization of user account 1-Comfort opening sunroof,OFF ,3
IDE12792-MAS06697-Personalization of user account 1-Acoustic acknowledge signal,On ,3
IDE12792-MAS06698-Personalization of user account 1-Freeway flashing,On ,3
IDE12792-MAS06740-Personalization of user account 1-Release button in rear lid handle locked,OFF ,3
IDE12792-MAS06756-Personalization of user account 1-Window shade automatic,OFF ,3
IDE12792-MAS06880-Personalization of user account 1-Mirror fold-in (Audi),OFF ,3
IDE12792-MAS10221-Personalization of user account 1-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12792-MAS10228-Personalization of user account 1-Comfort opening window: driver side,OFF ,3
IDE12792-MAS10229-Personalization of user account 1-Comfort opening window: frt. pass. side,OFF ,3
IDE12792-MAS10230-Personalization of user account 1-Comfort opening rear window: driver side,OFF ,3
IDE12792-MAS10231-Personalization of user account 1-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12792-MAS20789-Personalization of user account 1-Signature for tail light,0 ,3
IDE12793-IDE02262-Personalization of user account 1: part 2-synchronous mirror adjustment,OFF ,1
IDE12793-IDE03946-Personalization of user account 1: part 2-Mirror dimming,OFF ,1
IDE12793-MAS05213-Personalization of user account 1: part 2-Mirror heater,OFF ,1
IDE12793-MAS06870-Personalization of user account 1: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12793-MAS06881-Personalization of user account 1: part 2-Mirror fold-in (VW),OFF ,1
IDE12794-MAS02444-Personalization of user account 2-Central locking,global opening ,3
IDE12794-MAS06456-Personalization of user account 2-Autolock,On ,3
IDE12794-MAS06457-Personalization of user account 2-autounlock,On ,3
IDE12794-MAS06696-Personalization of user account 2-Comfort opening sunroof,OFF ,3
IDE12794-MAS06697-Personalization of user account 2-Acoustic acknowledge signal,On ,3
IDE12794-MAS06698-Personalization of user account 2-Freeway flashing,On ,3
IDE12794-MAS06740-Personalization of user account 2-Release button in rear lid handle locked,OFF ,3
IDE12794-MAS06756-Personalization of user account 2-Window shade automatic,OFF ,3
IDE12794-MAS06880-Personalization of user account 2-Mirror fold-in (Audi),OFF ,3
IDE12794-MAS10221-Personalization of user account 2-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12794-MAS10228-Personalization of user account 2-Comfort opening window: driver side,OFF ,3
IDE12794-MAS10229-Personalization of user account 2-Comfort opening window: frt. pass. side,OFF ,3
IDE12794-MAS10230-Personalization of user account 2-Comfort opening rear window: driver side,OFF ,3
IDE12794-MAS10231-Personalization of user account 2-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12794-MAS20789-Personalization of user account 2-Signature for tail light,0 ,3
IDE12795-IDE02262-Personalization of user account 2: part 2-synchronous mirror adjustment,OFF ,1
IDE12795-IDE03946-Personalization of user account 2: part 2-Mirror dimming,OFF ,1
IDE12795-MAS05213-Personalization of user account 2: part 2-Mirror heater,OFF ,1
IDE12795-MAS06870-Personalization of user account 2: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12795-MAS06881-Personalization of user account 2: part 2-Mirror fold-in (VW),OFF ,1
IDE12796-MAS02444-Personalization of user account 3-Central locking,global opening ,3
IDE12796-MAS06456-Personalization of user account 3-Autolock,On ,3
IDE12796-MAS06457-Personalization of user account 3-autounlock,On ,3
IDE12796-MAS06696-Personalization of user account 3-Comfort opening sunroof,OFF ,3
IDE12796-MAS06697-Personalization of user account 3-Acoustic acknowledge signal,On ,3
IDE12796-MAS06698-Personalization of user account 3-Freeway flashing,On ,3
IDE12796-MAS06740-Personalization of user account 3-Release button in rear lid handle locked,OFF ,3
IDE12796-MAS06756-Personalization of user account 3-Window shade automatic,OFF ,3
IDE12796-MAS06880-Personalization of user account 3-Mirror fold-in (Audi),OFF ,3
IDE12796-MAS10221-Personalization of user account 3-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12796-MAS10228-Personalization of user account 3-Comfort opening window: driver side,OFF ,3
IDE12796-MAS10229-Personalization of user account 3-Comfort opening window: frt. pass. side,OFF ,3
IDE12796-MAS10230-Personalization of user account 3-Comfort opening rear window: driver side,OFF ,3
IDE12796-MAS10231-Personalization of user account 3-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12796-MAS20789-Personalization of user account 3-Signature for tail light,0 ,3
IDE12797-IDE02262-Personalization of user account 3: part 2-synchronous mirror adjustment,OFF ,1
IDE12797-IDE03946-Personalization of user account 3: part 2-Mirror dimming,OFF ,1
IDE12797-MAS05213-Personalization of user account 3: part 2-Mirror heater,OFF ,1
IDE12797-MAS06870-Personalization of user account 3: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12797-MAS06881-Personalization of user account 3: part 2-Mirror fold-in (VW),OFF ,1
IDE12798-MAS02444-Personalization of user account 4-Central locking,global opening ,3
IDE12798-MAS06456-Personalization of user account 4-Autolock,On ,3
IDE12798-MAS06457-Personalization of user account 4-autounlock,On ,3
IDE12798-MAS06696-Personalization of user account 4-Comfort opening sunroof,OFF ,3
IDE12798-MAS06697-Personalization of user account 4-Acoustic acknowledge signal,On ,3
IDE12798-MAS06698-Personalization of user account 4-Freeway flashing,On ,3
IDE12798-MAS06740-Personalization of user account 4-Release button in rear lid handle locked,OFF ,3
IDE12798-MAS06756-Personalization of user account 4-Window shade automatic,OFF ,3
IDE12798-MAS06880-Personalization of user account 4-Mirror fold-in (Audi),OFF ,3
IDE12798-MAS10221-Personalization of user account 4-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12798-MAS10228-Personalization of user account 4-Comfort opening window: driver side,OFF ,3
IDE12798-MAS10229-Personalization of user account 4-Comfort opening window: frt. pass. side,OFF ,3
IDE12798-MAS10230-Personalization of user account 4-Comfort opening rear window: driver side,OFF ,3
IDE12798-MAS10231-Personalization of user account 4-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12798-MAS20789-Personalization of user account 4-Signature for tail light,0 ,3
IDE12799-IDE02262-Personalization of user account 4: part 2-synchronous mirror adjustment,OFF ,1
IDE12799-IDE03946-Personalization of user account 4: part 2-Mirror dimming,OFF ,1
IDE12799-MAS05213-Personalization of user account 4: part 2-Mirror heater,OFF ,1
IDE12799-MAS06870-Personalization of user account 4: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12799-MAS06881-Personalization of user account 4: part 2-Mirror fold-in (VW),OFF ,1
IDE12800-MAS02444-Personalization of user account 5-Central locking,global opening ,3
IDE12800-MAS06456-Personalization of user account 5-Autolock,On ,3
IDE12800-MAS06457-Personalization of user account 5-autounlock,On ,3
IDE12800-MAS06696-Personalization of user account 5-Comfort opening sunroof,OFF ,3
IDE12800-MAS06697-Personalization of user account 5-Acoustic acknowledge signal,On ,3
IDE12800-MAS06698-Personalization of user account 5-Freeway flashing,On ,3
IDE12800-MAS06740-Personalization of user account 5-Release button in rear lid handle locked,OFF ,3
IDE12800-MAS06756-Personalization of user account 5-Window shade automatic,OFF ,3
IDE12800-MAS06880-Personalization of user account 5-Mirror fold-in (Audi),OFF ,3
IDE12800-MAS10221-Personalization of user account 5-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12800-MAS10228-Personalization of user account 5-Comfort opening window: driver side,OFF ,3
IDE12800-MAS10229-Personalization of user account 5-Comfort opening window: frt. pass. side,OFF ,3
IDE12800-MAS10230-Personalization of user account 5-Comfort opening rear window: driver side,OFF ,3
IDE12800-MAS10231-Personalization of user account 5-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12800-MAS20789-Personalization of user account 5-Signature for tail light,0 ,3
IDE12801-IDE02262-Personalization of user account 5: part 2-synchronous mirror adjustment,OFF ,1
IDE12801-IDE03946-Personalization of user account 5: part 2-Mirror dimming,OFF ,1
IDE12801-MAS05213-Personalization of user account 5: part 2-Mirror heater,OFF ,1
IDE12801-MAS06870-Personalization of user account 5: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12801-MAS06881-Personalization of user account 5: part 2-Mirror fold-in (VW),OFF ,1
IDE12802-MAS02444-Personalization of user account 6-Central locking,global opening ,3
IDE12802-MAS06456-Personalization of user account 6-Autolock,On ,3
IDE12802-MAS06457-Personalization of user account 6-autounlock,On ,3
IDE12802-MAS06696-Personalization of user account 6-Comfort opening sunroof,OFF ,3
IDE12802-MAS06697-Personalization of user account 6-Acoustic acknowledge signal,On ,3
IDE12802-MAS06698-Personalization of user account 6-Freeway flashing,On ,3
IDE12802-MAS06740-Personalization of user account 6-Release button in rear lid handle locked,OFF ,3
IDE12802-MAS06756-Personalization of user account 6-Window shade automatic,OFF ,3
IDE12802-MAS06880-Personalization of user account 6-Mirror fold-in (Audi),OFF ,3
IDE12802-MAS10221-Personalization of user account 6-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12802-MAS10228-Personalization of user account 6-Comfort opening window: driver side,OFF ,3
IDE12802-MAS10229-Personalization of user account 6-Comfort opening window: frt. pass. side,OFF ,3
IDE12802-MAS10230-Personalization of user account 6-Comfort opening rear window: driver side,OFF ,3
IDE12802-MAS10231-Personalization of user account 6-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12802-MAS20789-Personalization of user account 6-Signature for tail light,0 ,3
IDE12803-IDE02262-Personalization of user account 6: part 2-synchronous mirror adjustment,OFF ,1
IDE12803-IDE03946-Personalization of user account 6: part 2-Mirror dimming,OFF ,1
IDE12803-MAS05213-Personalization of user account 6: part 2-Mirror heater,OFF ,1
IDE12803-MAS06870-Personalization of user account 6: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12803-MAS06881-Personalization of user account 6: part 2-Mirror fold-in (VW),OFF ,1
IDE12804-MAS02444-Personalization of user account 7-Central locking,global opening ,3
IDE12804-MAS06456-Personalization of user account 7-Autolock,On ,3
IDE12804-MAS06457-Personalization of user account 7-autounlock,On ,3
IDE12804-MAS06696-Personalization of user account 7-Comfort opening sunroof,OFF ,3
IDE12804-MAS06697-Personalization of user account 7-Acoustic acknowledge signal,On ,3
IDE12804-MAS06698-Personalization of user account 7-Freeway flashing,On ,3
IDE12804-MAS06740-Personalization of user account 7-Release button in rear lid handle locked,OFF ,3
IDE12804-MAS06756-Personalization of user account 7-Window shade automatic,OFF ,3
IDE12804-MAS06880-Personalization of user account 7-Mirror fold-in (Audi),OFF ,3
IDE12804-MAS10221-Personalization of user account 7-Rear lid unlocking through rear lid opening sensors,OFF ,3
IDE12804-MAS10228-Personalization of user account 7-Comfort opening window: driver side,OFF ,3
IDE12804-MAS10229-Personalization of user account 7-Comfort opening window: frt. pass. side,OFF ,3
IDE12804-MAS10230-Personalization of user account 7-Comfort opening rear window: driver side,OFF ,3
IDE12804-MAS10231-Personalization of user account 7-Comfort opening rear window: frt. pass. side,OFF ,3
IDE12804-MAS20789-Personalization of user account 7-Signature for tail light,0 ,3
IDE12805-IDE02262-Personalization of user account 7: part 2-synchronous mirror adjustment,OFF ,1
IDE12805-IDE03946-Personalization of user account 7: part 2-Mirror dimming,OFF ,1
IDE12805-MAS05213-Personalization of user account 7: part 2-Mirror heater,OFF ,1
IDE12805-MAS06870-Personalization of user account 7: part 2-Mirror lowering in reverse travel,OFF ,1
IDE12805-MAS06881-Personalization of user account 7: part 2-Mirror fold-in (VW),OFF ,1
IDE12808-Personalization of user account 1: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12809-Personalization of user account 2: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12810-Personalization of user account 3: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12811-Personalization of user account 4: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12812-Personalization of user account 5: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12813-Personalization of user account 6: name,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12814-Personalization of user account 7: name,47 61 73 74 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,66
IDE12815-MAS15187-User accounts for the NFC devices-User account of NFC device 1,0 ,8
IDE12815-MAS15188-User accounts for the NFC devices-User account of NFC device 2,0 ,8
IDE12815-MAS15189-User accounts for the NFC devices-User account of NFC device 3,0 ,8
IDE12815-MAS15190-User accounts for the NFC devices-User account of NFC device 4,0 ,8
IDE12815-MAS15191-User accounts for the NFC devices-User account of NFC device 5,0 ,8
IDE12815-MAS15192-User accounts for the NFC devices-User account of NFC device 6,0 ,8
IDE12815-MAS15193-User accounts for the NFC devices-User account of NFC device 7,0 ,8
IDE12815-MAS15194-User accounts for the NFC devices-User account of NFC device 8,0 ,8
IDE12815-MAS15195-User accounts for the NFC devices-User account of NFC device 9,0 ,8
IDE12815-MAS15196-User accounts for the NFC devices-User account of NFC device 10,0 ,8
IDE12815-MAS15197-User accounts for the NFC devices-User account of NFC device 11,0 ,8
IDE12815-MAS15198-User accounts for the NFC devices-User account of NFC device 12,0 ,8
IDE12815-MAS15199-User accounts for the NFC devices-User account of NFC device 13,0 ,8
IDE12815-MAS15200-User accounts for the NFC devices-User account of NFC device 14,0 ,8
IDE12815-MAS15201-User accounts for the NFC devices-User account of NFC device 15,0 ,8
IDE12815-MAS15202-User accounts for the NFC devices-User account of NFC device 16,0 ,8
IDE12938-MAS15390-NFC communication 2: settings-Command category for SELECT,00 ,22
IDE12938-MAS15391-NFC communication 2: settings-Command for SELECT,A4 ,22
IDE12938-MAS15392-NFC communication 2: settings-Parameter 1 for SELECT,04 ,22
IDE12938-MAS15393-NFC communication 2: settings-Parameter 2 for SELECT,00 ,22
IDE12938-MAS15394-NFC communication 2: settings-Utility data length for SELECT,0F ,22
IDE12938-MAS15395-NFC communication 2: settings-Application ID for SELECT,A0 00 00 07 02 00 00 00 00 00 00 01 00 00 01 00 ,22
IDE12938-MAS15396-NFC communication 2: settings-Expected length for SELECT,10 ,22
IDE13253-MAS16009-Convertible top convenience operation-Convenience closure with radio key,On ,2
IDE13253-MAS16010-Convertible top convenience operation-Convenience opening with lock cylinder,On ,2
IDE13253-MAS16011-Convertible top convenience operation-Convenience closing with exterior door handle touch sensor,On ,2
IDE13253-MAS16012-Convertible top convenience operation-Convenience opening with radio key,On ,2
IDE13253-MAS16013-Convertible top convenience operation-Convenient opening with lock cylinder,On ,2
IDE13254-MAS16014-Convenience opening: control points-Convenience opening of the window regulator with radio key,On ,2
IDE13254-MAS16015-Convenience opening: control points-Convenience opening of the window regulator with lock cylinder,On ,2
IDE13254-MAS16016-Convenience opening: control points-Convenience opening of the window regulator with window regulator button,On ,2
IDE13254-MAS16017-Convenience opening: control points-Convenience opening of the roof shade with the radio key,On ,2
IDE13254-MAS16018-Convenience opening: control points-Convenience opening of the roof shade with lock cylinder,On ,2
IDE13254-MAS16019-Convenience opening: control points-Convenience opening of the roof shade with window regulator button,On ,2
IDE13254-MAS16020-Convenience opening: control points-Comfort opening only for driver door,OFF ,2
IDE13254-MAS16029-Convenience opening: control points-Convenience opening of the sunroof with radio key,On ,2
IDE13254-MAS16030-Convenience opening: control points-Convenience opening of the sunroof with lock cylinder,On ,2
IDE13254-MAS16031-Convenience opening: control points-Convenience opening of the sun roof with window regulator button,On ,2
IDE13254-MAS16032-Convenience opening: control points-Convenience opening of rear sun roof with radio key,On ,2
IDE13254-MAS16033-Convenience opening: control points-Convenience opening of rear sun roof with lock cylinder,On ,2
IDE13254-MAS16034-Convenience opening: control points-Comfort opening of the rear sunroof with window regulator button,On ,2
IDE13255-MAS16021-Convenience closing: control points-Convenience closure of the window regulator with radio key,On ,2
IDE13255-MAS16022-Convenience closing: control points-Convenience closure of the window regulator with lock cylinder,On ,2
IDE13255-MAS16023-Convenience closing: control points-Convenience closure of the window regulator with window regulator button,On ,2
IDE13255-MAS16024-Convenience closing: control points-Convenience closure of window regulator with outside door handle sensor,On ,2
IDE13255-MAS16025-Convenience closing: control points-Convenience closing of the roof shade with the radio key,On ,2
IDE13255-MAS16026-Convenience closing: control points-Convenience closure of the roof shade with lock cylinder,On ,2
IDE13255-MAS16027-Convenience closing: control points-Convenience closure of the roof shade with window regulator button,On ,2
IDE13255-MAS16028-Convenience closing: control points-Convenience closure of roof shade with outside door handle,On ,2
IDE13255-MAS16035-Convenience closing: control points-Convenience closure of sun roof with radio key,On ,2
IDE13255-MAS16036-Convenience closing: control points-Convenience closing of the sunroof with lock cylinder,On ,2
IDE13255-MAS16037-Convenience closing: control points-Convenience closure of the sun roof with window regulator button,On ,2
IDE13255-MAS16038-Convenience closing: control points-Convenience closure of sunroof with outside door handle sensor,On ,2
IDE13255-MAS16039-Convenience closing: control points-Convenience closure of rear sun roof with radio key,On ,2
IDE13255-MAS16040-Convenience closing: control points-Convenience closure of rear sun roof with lock cylinder,On ,2
IDE13255-MAS16041-Convenience closing: control points-Convenience closure of the rear sun roof with window regulator button,On ,2
IDE13255-MAS16042-Convenience closing: control points-Convenience closure of rear sunroof with outside door handle sensor,On ,2
IDE14072-MAS17381-Central locking system actuation counter: configuration-Interface 1: counter 1,0 ,12
IDE14072-MAS17382-Central locking system actuation counter: configuration-Interface 2: counter 1,0 ,12
IDE14072-MAS17383-Central locking system actuation counter: configuration-Interface 3: counter 1,0 ,12
IDE14072-MAS17384-Central locking system actuation counter: configuration-Interface 1: counter 2,0 ,12
IDE14072-MAS17385-Central locking system actuation counter: configuration-Interface 2: counter 2,0 ,12
IDE14072-MAS17386-Central locking system actuation counter: configuration-Interface 3: counter 2,0 ,12
IDE14072-MAS17387-Central locking system actuation counter: configuration-Interface 1: counter 3,0 ,12
IDE14072-MAS17388-Central locking system actuation counter: configuration-Interface 2: counter 3,0 ,12
IDE14072-MAS17389-Central locking system actuation counter: configuration-Interface 3: counter 3,0 ,12
IDE14072-MAS17390-Central locking system actuation counter: configuration-Interface 1: counter 4,0 ,12
IDE14072-MAS17391-Central locking system actuation counter: configuration-Interface 2: counter 4,0 ,12
IDE14072-MAS17392-Central locking system actuation counter: configuration-Interface 3: counter 4,0 ,12
IDE14661-MAS18674-NFC communication 3: settings-Trigger event waiting time,0 ms,8
IDE14661-MAS18675-NFC communication 3: settings-Waiting time for sending event data,0 ms,8
IDE14661-MAS18676-NFC communication 3: settings-Waiting time for sending vehicle health data,300 ms,8
IDE14661-MAS18677-NFC communication 3: settings-Trigger NFC event,activated ,8
IDE14661-MAS18678-NFC communication 3: settings-Send NFC event data,activated ,8
IDE14661-MAS18679-NFC communication 3: settings-Send NFC vehicle health data,activated ,8
MAS13921-IDE00047-Control module rear lid opening: dataset-Parameter set version,0 ,37
MAS13921-IDE80001-Control module rear lid opening: dataset-Analysis 1,1 ,37
MAS13921-IDE80002-Control module rear lid opening: dataset-Analysis 2,1 ,37
MAS13921-IDE80003-Control module rear lid opening: dataset-Analysis 3,1 ,37
MAS13921-IDE80004-Control module rear lid opening: dataset-Analysis 4,0 ,37
MAS13921-IDE80005-Control module rear lid opening: dataset-Analysis 5,16 ,37
MAS13921-IDE80006-Control module rear lid opening: dataset-Analysis 6,16 ,37
MAS13921-IDE80007-Control module rear lid opening: dataset-Analysis 7,16 ,37
MAS13921-IDE80008-Control module rear lid opening: dataset-Analysis 8,16 ,37
MAS13921-IDE80009-Control module rear lid opening: dataset-Analysis 9,2 ,37
MAS13921-IDE80010-Control module rear lid opening: dataset-Analysis 10,31 ,37
MAS13921-IDE80011-Control module rear lid opening: dataset-Analysis 11,2 ,37
MAS13921-IDE80012-Control module rear lid opening: dataset-Analysis 12,31 ,37
MAS13921-IDE80013-Control module rear lid opening: dataset-Analysis 13,224 ,37
MAS13921-IDE80014-Control module rear lid opening: dataset-Analysis 14,10 ,37
MAS13921-IDE80015-Control module rear lid opening: dataset-Analysis 15,10 ,37
MAS13921-IDE80016-Control module rear lid opening: dataset-Analysis 16,0 ,37
MAS13921-IDE80017-Control module rear lid opening: dataset-Analysis 17,0 ,37
MAS13921-IDE80018-Control module rear lid opening: dataset-Analysis 18,9 ,37
MAS13921-IDE80019-Control module rear lid opening: dataset-Analysis 19,0 ,37
MAS13921-IDE80020-Control module rear lid opening: dataset-Analysis 20,active ,37
MAS13921-IDE80021-Control module rear lid opening: dataset-Analysis 21,not active ,37
MAS13921-IDE80022-Control module rear lid opening: dataset-Analysis 22,not active ,37
MAS13921-IDE80023-Control module rear lid opening: dataset-Analysis 23,Bottom ,37
MAS13921-IDE80024-Control module rear lid opening: dataset-Analysis 24,Dynamic ,37
MAS13921-IDE80025-Control module rear lid opening: dataset-Analysis 25,3 ,37
MAS13921-IDE80026-Control module rear lid opening: dataset-Analysis 26,not active ,37
MAS13921-IDE80027-Control module rear lid opening: dataset-Analysis 27,Dynamic ,37
MAS13921-IDE80028-Control module rear lid opening: dataset-Analysis 28,10 ,37
MAS13921-IDE80029-Control module rear lid opening: dataset-Analysis 29,6 ,37
MAS13921-IDE80030-Control module rear lid opening: dataset-Analysis 30,active ,37
MAS13921-IDE80031-Control module rear lid opening: dataset-Analysis 31,30 ,37
MAS13921-IDE80032-Control module rear lid opening: dataset-Analysis 32,2 ,37
MAS13921-IDE80033-Control module rear lid opening: dataset-Analysis 33,12 ,37
MAS13921-IDE80034-Control module rear lid opening: dataset-Analysis 34,4 ,37
MAS13921-IDE80035-Control module rear lid opening: dataset-Analysis 35,Do not reset ,37
MAS13921-IDE80036-Control module rear lid opening: dataset-Analysis 36,16 ,37
MAS13921-IDE80037-Control module rear lid opening: dataset-Analysis 37,16 ,37
MAS13921-IDE80038-Control module rear lid opening: dataset-Analysis 38,16 ,37
MAS13921-IDE80039-Control module rear lid opening: dataset-Analysis 39,16 ,37
MAS13921-IDE80040-Control module rear lid opening: dataset-Analysis 40,2 ,37
MAS13921-IDE80041-Control module rear lid opening: dataset-Analysis 41,31 ,37
MAS13921-IDE80042-Control module rear lid opening: dataset-Analysis 42,2 ,37
MAS13921-IDE80043-Control module rear lid opening: dataset-Analysis 43,31 ,37
MAS13921-IDE80044-Control module rear lid opening: dataset-Analysis 44,224 ,37
MAS13921-IDE80045-Control module rear lid opening: dataset-Analysis 45,10 ,37
MAS13921-IDE80046-Control module rear lid opening: dataset-Analysis 46,10 ,37
MAS13921-IDE80047-Control module rear lid opening: dataset-Analysis 47,0 ,37
MAS13921-IDE80048-Control module rear lid opening: dataset-Analysis 48,0 ,37
MAS13921-IDE80049-Control module rear lid opening: dataset-Analysis 49,0 ,37
MAS13921-IDE80050-Control module rear lid opening: dataset-Analysis 50,0 ,37
MAS13921-IDE80051-Control module rear lid opening: dataset-Analysis 51,6 ,37
MAS13921-IDE80052-Control module rear lid opening: dataset-Analysis 52,25 ,37
MAS13921-IDE80053-Control module rear lid opening: dataset-Analysis 53,255 ,37
MAS13921-IDE80054-Control module rear lid opening: dataset-Analysis 54,5 ,37
MAS13921-IDE80055-Control module rear lid opening: dataset-Analysis 55,60 ,37
MAS13921-IDE80056-Control module rear lid opening: dataset-Analysis 56,149 ,37
MAS13921-MAS01078-Control module rear lid opening: dataset-Vehicle type,0 ,37
MAS13921-MAS14087-Control module rear lid opening: dataset-time delay activation,not active ,37
MAS19655-MAS19656-Heckklappe öffnen durch Doppelbetätigung der Funkfernbedienung-Actuation time 1 for double-actuation,5100 ms,4
MAS19655-MAS19657-Heckklappe öffnen durch Doppelbetätigung der Funkfernbedienung-Actuation time 2 for double-actuation,5100 ms,4
MAS19655-MAS19658-Heckklappe öffnen durch Doppelbetätigung der Funkfernbedienung-Time window for double-actuation,1.40 s,4
ENG146368-ENG146489-central_locking_system-autolock_rear,On ,2
ENG146368-ENG146488-central_locking_system-beep_at_opening,On ,2
ENG146368-ENG146490-central_locking_system-global_unlocking_via_kessy_double_puls,OFF ,2
ENG146368-ENG146491-central_locking_system-unlocking_rear_via_vip_at_s_contact_active,OFF ,2
ENG146414-ffb_kessy_active_for_piloted_parking,Kessy_and_ffb_at_kl15_on_and_piloted_parking_event_active ,1
ENG146373-headlamp_range_adjustment,OFF ,1
ENG146406-ENG146575-Heated_front_window_lin_relais-Off_delay,0.50 s,14
ENG146406-ENG146574-Heated_front_window_lin_relais-On_delay,0.50 s,14
ENG146406-ENG146571-Heated_front_window_lin_relais-Threshold_driver_side_off,150 W,14
ENG146406-ENG146570-Heated_front_window_lin_relais-Threshold_driver_side_on,300 W,14
ENG146406-ENG146573-Heated_front_window_lin_relais-Threshold_passenger_side_off,350 W,14
ENG146406-ENG146572-Heated_front_window_lin_relais-Threshold_passenger_side_on,500 W,14
ENG146406-ENG146576-Heated_front_window_lin_relais-Two_Relais_installed,1 ,14
ENG146400-ENG146554-Heated_rear_window_with_extension-Default_activation_time,10 min,16
ENG146400-ENG155020-Heated_rear_window_with_extension-Delay_time_deactivate_heated_rear_window,25.50 ,16
ENG146400-ENG146546-Heated_rear_window_with_extension-Interval_1,5 min,16
ENG146400-ENG146547-Heated_rear_window_with_extension-Interval_2,7 min,16
ENG146400-ENG146548-Heated_rear_window_with_extension-Interval_3,15 min,16
ENG146400-ENG146549-Heated_rear_window_with_extension-Interval_4,20 min,16
ENG146400-ENG146550-Heated_rear_window_with_extension-Renewal_interval_1,0 min,16
ENG146400-ENG146551-Heated_rear_window_with_extension-Renewal_interval_2,3 min,16
ENG146400-ENG146552-Heated_rear_window_with_extension-Renewal_interval_3,5 min,16
ENG146400-ENG146553-Heated_rear_window_with_extension-Renewal_interval_4,0 min,16
ENG146400-ENG146555-Heated_rear_window_with_extension-Speed_theshold,50 ,16
ENG146400-ENG145114-Heated_rear_window_with_extension-Temperature_1,132 ,16
ENG146400-ENG145115-Heated_rear_window_with_extension-Temperature_2,124 ,16
ENG146400-ENG146545-Heated_rear_window_with_extension-Temperature_3,116 ,16
ENG146374-hella_debug_switch,00 00 ,2
ENG146372-ENG146515-horn_settings-number_of_acoustic_acknowlagement_signals_zv_close,2 ,2
ENG146372-ENG146514-horn_settings-number_of_acoustic_acknowlagement_signals_zv_open,0 ,2
ENG153896-ENG146539-Mobile_Key-idle_time_state_S1,60 ,4
ENG153896-ENG155141-Mobile_Key-idle_time_state_S2,20 ,4
ENG153896-ENG155142-Mobile_Key-idle_time_vtan_state_S1,60 ,4
ENG153896-ENG155143-Mobile_Key-idle_time_vtan_state_S2,20 ,4
ENG146397-ENG146535-mq_ewi_activation-ewi_mode,On ,4
ENG146397-ENG146534-mq_ewi_activation-ewi_trace,On ,4
ENG146397-ENG146536-mq_ewi_activation-ewi_trace_messages,FF FF FF ,4
ENG247341-Personalisation_2_0_ew,150 ms,5
ENG146405-ENG146480-Personalisation_ew-Delay_Time,0.40 s,8
ENG146405-ENG146558-Personalisation_ew-FSG_Setup2_Bit1,0 ,8
ENG146405-ENG146559-Personalisation_ew-FSG_Setup2_Bit2,0 ,8
ENG146405-ENG146560-Personalisation_ew-FSG_Setup2_Bit3,1 ,8
ENG146405-ENG146561-Personalisation_ew-FSG_Setup2_Bit4,0 ,8
ENG146405-ENG146562-Personalisation_ew-FSG_Setup2_Bit5,0 ,8
ENG146405-ENG146563-Personalisation_ew-FSG_Setup2_Bit6,1 ,8
ENG146405-ENG146564-Personalisation_ew-FSG_Setup2_Bit7,1 ,8
ENG146405-ENG146569-Personalisation_ew-Minimum_display_duration,1 ,8
ENG146405-ENG146566-Personalisation_ew-Number_of_accounts,7 ,8
ENG146405-ENG146577-Personalisation_ew-Prioritization_device,0 ,8
ENG146405-ENG146567-Personalisation_ew-Time_slot_driver_door_opening,0.30 s,8
ENG146405-ENG146565-Personalisation_ew-Time_slot_key_identification,5 ,8
ENG146405-ENG146568-Personalisation_ew-Timeout_drive_active,60 ,8
ENG146375-ENG146520-pwm_levels_hl_1-pwm_high_1,200 ,3
ENG146375-ENG146521-pwm_levels_hl_1-pwm_high_2,255 ,3
ENG146375-ENG146519-pwm_levels_hl_1-pwm_low,255 ,3
ENG146384-ENG146520-pwm_levels_hl_10-pwm_high_1,255 ,3
ENG146384-ENG146521-pwm_levels_hl_10-pwm_high_2,255 ,3
ENG146384-ENG146519-pwm_levels_hl_10-pwm_low,200 ,3
ENG146385-ENG146520-pwm_levels_hl_11-pwm_high_1,200 ,3
ENG146385-ENG146521-pwm_levels_hl_11-pwm_high_2,255 ,3
ENG146385-ENG146519-pwm_levels_hl_11-pwm_low,255 ,3
ENG146386-ENG146520-pwm_levels_hl_12-pwm_high_1,200 ,3
ENG146386-ENG146521-pwm_levels_hl_12-pwm_high_2,255 ,3
ENG146386-ENG146519-pwm_levels_hl_12-pwm_low,255 ,3
ENG146387-ENG146520-pwm_levels_hl_13-pwm_high_1,200 ,3
ENG146387-ENG146521-pwm_levels_hl_13-pwm_high_2,255 ,3
ENG146387-ENG146519-pwm_levels_hl_13-pwm_low,255 ,3
ENG146388-ENG146520-pwm_levels_hl_14-pwm_high_1,255 ,3
ENG146388-ENG146521-pwm_levels_hl_14-pwm_high_2,255 ,3
ENG146388-ENG146519-pwm_levels_hl_14-pwm_low,200 ,3
ENG146389-ENG146520-pwm_levels_hl_15-pwm_high_1,200 ,3
ENG146389-ENG146521-pwm_levels_hl_15-pwm_high_2,255 ,3
ENG146389-ENG146519-pwm_levels_hl_15-pwm_low,255 ,3
ENG146390-ENG146520-pwm_levels_hl_16-pwm_high_1,255 ,3
ENG146390-ENG146521-pwm_levels_hl_16-pwm_high_2,200 ,3
ENG146390-ENG146519-pwm_levels_hl_16-pwm_low,255 ,3
ENG146391-ENG146520-pwm_levels_hl_17-pwm_high_1,200 ,3
ENG146391-ENG146521-pwm_levels_hl_17-pwm_high_2,255 ,3
ENG146391-ENG146519-pwm_levels_hl_17-pwm_low,255 ,3
ENG146392-ENG146520-pwm_levels_hl_18-pwm_high_1,255 ,3
ENG146392-ENG146521-pwm_levels_hl_18-pwm_high_2,255 ,3
ENG146392-ENG146519-pwm_levels_hl_18-pwm_low,255 ,3
ENG146393-ENG146520-pwm_levels_hl_19-pwm_high_1,255 ,3
ENG146393-ENG146521-pwm_levels_hl_19-pwm_high_2,255 ,3
ENG146393-ENG146519-pwm_levels_hl_19-pwm_low,255 ,3
ENG146376-ENG146520-pwm_levels_hl_2-pwm_high_1,200 ,3
ENG146376-ENG146521-pwm_levels_hl_2-pwm_high_2,255 ,3
ENG146376-ENG146519-pwm_levels_hl_2-pwm_low,255 ,3
ENG146394-ENG146520-pwm_levels_hl_20-pwm_high_1,255 ,3
ENG146394-ENG146521-pwm_levels_hl_20-pwm_high_2,255 ,3
ENG146394-ENG146519-pwm_levels_hl_20-pwm_low,255 ,3
ENG146395-ENG146520-pwm_levels_hl_21-pwm_high_1,255 ,3
ENG146395-ENG146521-pwm_levels_hl_21-pwm_high_2,255 ,3
ENG146395-ENG146519-pwm_levels_hl_21-pwm_low,255 ,3
ENG146377-ENG146520-pwm_levels_hl_3-pwm_high_1,255 ,3
ENG146377-ENG146521-pwm_levels_hl_3-pwm_high_2,255 ,3
ENG146377-ENG146519-pwm_levels_hl_3-pwm_low,200 ,3
ENG146378-ENG146520-pwm_levels_hl_4-pwm_high_1,255 ,3
ENG146378-ENG146521-pwm_levels_hl_4-pwm_high_2,255 ,3
ENG146378-ENG146519-pwm_levels_hl_4-pwm_low,200 ,3
ENG146379-ENG146520-pwm_levels_hl_5-pwm_high_1,200 ,3
ENG146379-ENG146521-pwm_levels_hl_5-pwm_high_2,255 ,3
ENG146379-ENG146519-pwm_levels_hl_5-pwm_low,255 ,3
ENG146380-ENG146520-pwm_levels_hl_6-pwm_high_1,200 ,3
ENG146380-ENG146521-pwm_levels_hl_6-pwm_high_2,255 ,3
ENG146380-ENG146519-pwm_levels_hl_6-pwm_low,255 ,3
ENG146381-ENG146520-pwm_levels_hl_7-pwm_high_1,200 ,3
ENG146381-ENG146521-pwm_levels_hl_7-pwm_high_2,255 ,3
ENG146381-ENG146519-pwm_levels_hl_7-pwm_low,255 ,3
ENG146382-ENG146520-pwm_levels_hl_8-pwm_high_1,255 ,3
ENG146382-ENG146521-pwm_levels_hl_8-pwm_high_2,255 ,3
ENG146382-ENG146519-pwm_levels_hl_8-pwm_low,255 ,3
ENG146383-ENG146520-pwm_levels_hl_9-pwm_high_1,200 ,3
ENG146383-ENG146521-pwm_levels_hl_9-pwm_high_2,255 ,3
ENG146383-ENG146519-pwm_levels_hl_9-pwm_low,255 ,3
ENG146399-ENG146543-remote_functions-idle_time_bap_remote_beep,500 ,8
ENG146399-ENG146544-remote_functions-idle_time_state_S0,1 ,8
ENG146399-ENG146539-remote_functions-idle_time_state_S1,60 ,8
ENG146399-ENG146540-remote_functions-idle_time_state_S3,2000 ,8
ENG146399-ENG146537-remote_functions-Rear_lid_handle_release_button_activation_time,15 ,8
ENG146399-ENG146538-remote_functions-Rear_lid_handle_release_button_active,active ,8
ENG146399-ENG146541-remote_functions-remote_beep_activation_time_high,100 ,8
ENG146399-ENG146542-remote_functions-remote_beep_activation_time_low,900 ,8
ENG146403-ENG114991-RF_adjustment-channel_1,4E ,3
ENG146403-ENG114992-RF_adjustment-channel_2,50 ,3
ENG146403-ENG114993-RF_adjustment-channel_3,4C ,3
ENG146402-ENG114991-RF_calibration-channel_1,FF FF FF ,9
ENG146402-ENG114992-RF_calibration-channel_2,FF FF FF ,9
ENG146402-ENG114993-RF_calibration-channel_3,FF FF FF ,9
ENG129054-ENG144985-SERVICE_KEY-debounce_kilometer,15 km,9
ENG129054-ENG144693-SERVICE_KEY-Distance,20 km,9
ENG129054-ENG144983-SERVICE_KEY-hazard_warning_switch_delay_time,10 s,9
ENG129054-ENG144980-SERVICE_KEY-retry_request_obdc,3 ,9
ENG129054-ENG144979-SERVICE_KEY-timeout_request_obdc,30 s,9
ENG129054-ENG146532-SERVICE_KEY-write_cycles_per_key_and_day,20 ,9
ENG129054-ENG144984-SERVICE_KEY-write_data_delay_time,40 s,9
ENG129054-ENG144982-SERVICE_KEY-write_delay_speed,20 km/h,9
ENG129054-ENG144981-SERVICE_KEY-write_delay_time,20 s,9
ENG146371-ENG146510-sounder_settings-beeptime,60_ms ,2
ENG146371-ENG146511-sounder_settings-beeptime_closing_central_locking,single_beep ,2
ENG146371-ENG146513-sounder_settings-beeptime_opening_central_locking,no_beep ,2
ENG146371-ENG247388-sounder_settings-beeptime_reunlock,60_ms ,2
ENG146371-ENG146512-sounder_settings-sounder_sound,frequency_modulated ,2
ENG146364-ENG146516-Terminal_Control-deactivation_time_kl15,30 min,3
ENG146364-ENG146517-Terminal_Control-delay_time_leave_concept,200 ms,3
ENG146398-wiping_indicator,00010111  ,1
ENG146401-Write_key_content,17 00 01 0A 28 14 0F 14 FF 05 00 0A 32 FF FF FF 9E CC 10 10 10 10 02 1F 02 1F E0 AA 00 00 06 19 FF 05 3C 00 95 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 ,98
Elapsed Time: 01:46
Scratching head. I don't see any obvious reason why it wouldn't chirp (beep) then.
Is it possible that something isn't reporting as properly closed? The hood? The trunk? One of the doors? Because if the CCM thinks something isn't properly closed, it won't chirp.
NEtech
Denmark
C?ID=56995
Have you tried to setting this to "Beep"
ENG146371-ENG146513-sounder_settings-beeptime_opening_central_locking, no_beep
marble
Singapore
C?ID=291009
Nope, it's a new car, no error messages or bad sensor anything. The closest i manage to find a clue about is in the link in the first post. Couldnt be buying a different tool just for a chirp (assuming it works) hence i'm head scratching here.
Yep tried. I've been turning on and off various stuff, even tried hunting for B8's version which is "Theft alarm lock confirmation" but really no joy.
marble
Singapore
C?ID=291009
So any body can figure this part out?
*via VAG CAN Professional
Control Module 46
Access Permissions and Programming Matrix
Search for Horn Acknowledgment and set to "active"
Exit
South Molton, UK
In that link the poster does say that they have only worked on one MLB A4 (and I couldn't see a date when that was posted), given that VAG/Audi have been changing a lot lately it's quite possible that the instructions are not applicable to your new A5.
United States
I didn't spend a lot of time searching but I found this NAR 2019 A4 scan in our emails:
   Part No SW: 8W0 907 064 GC    HW: 8W0 907 064 DC
   Component: BCM2 MLBevo   025 0424
   Coding: 013400004FB00080650FA0002C01000203024000810026502F0400000B04803F001E0001000010
   Shop #: WSC 06335 790 00001
   ASAM Dataset: EV_BCM2HellaAU736 016016
   ROD: EV_BCM2HellaAU736_016_AU49.rod
   Subsystem 1 - Part No SW: 5Q0 951 177     HW: 5Q0 951 172
   [s]Serial number: removed[/s]
   Subsystem 2 - Part No SW: 5Q0 951 605 A    HW: 5Q0 951 605 A
   Subsystem 3 - Part No SW: 3AA 962 243 H    HW: 3AA 962 243 H
   Component: GEB.F.Heckoef  H16 0905
"beep" Adp results:
ENG146368-ENG146488-central_locking_system-beep_at_opening	OFF 	2
ENG146399-ENG146543-remote_functions-idle_time_bap_remote_beep	500	8
ENG146399-ENG146541-remote_functions-remote_beep_activation_time_high	100	8
ENG146399-ENG146542-remote_functions-remote_beep_activation_time_low	900	8
ENG146371-ENG146510-sounder_settings-beeptime	10_ms 	2
ENG146371-ENG146511-sounder_settings-beeptime_closing_central_locking	single_beep 	2
ENG146371-ENG146513-sounder_settings-beeptime_opening_central_locking	no_beep 	2
ENG146371-ENG247388-sounder_settings-beeptime_reunlock	60_ms 	2
I can't share the scan directly but .. I wonder if the lack-of that Alarm horn / Subsystem 2 is the problem?
marble, I would keep an eye out for B9 A5 scans and see if any with factory beep also have a LIN alarm horn slave module in their scans.
marble
Singapore
C?ID=291009
Thanks Dana, i think you might be onto something. I wonder how to retrofit that part. whatever i googled looks like it's buried deep in the engine bay.
"beep" Adp results:
