Hello guys ! Merry X-mas !!
I have a problem with an instrument cluster (maybe ? ) ,thats why I want your lights
The car is Ibiza 6L FR 20vt . The coolant needle goes up and down some times from 70 to 90 degrees. VCDS displays
16500 - Engine Coolant Temp. Sensor (G62)
P0116 - 35-00 - Implausible Signal
Readiness: 0010 1101
In engine module .Changing G62 didnt help at all. When DTC is present the needle will hop up and down. When I delete it , it goes normal ?!?!?! .After a test drive in the city everything ok , when driving in highways the needle starts 70-90.
While logging I noticed that in instruments cluster it displays 60-70 degrees but in engine module it displays 89-90 as it should..
I thought the signal is from the same sensor ? Maybe the Instument cluster is fried and gets the signal wrong so it displays 70 ?
Then why when deleting the DTC , instrument cluster works ok ??
We also swaped ECU just in case..
your lights pleaseeeeee thanks !
HAPPY NEW 2015 !!
HAPPY NEW 2015 !!
