05 Passat Timing chain tensioner
glkirk
C?ID=37343
Hi, and thanks for all your help in the past.
Come to find out-one of the nylon pads had come off the bottom of the cam timing chain tensioner.
This had allowed the chain to jump a tooth.
I replaced the pad and adjusted the timing marks.
All seemed to be well with not even having to clear any codes.
Well now, I get the "Check engine" light after 20 or 30 miles.
Does anyone think I should replace the tensioner?
Thanks!
Saturday,12,October,2019,08:01:56:08677
VIN: WVWRU63BX5P005880   License Plate:
Mileage: 217220km-134974mi   Repair Order:
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWRU63BX5P005880   Mileage: 217220km-134974miles
Address 01: Engine        Labels: 078-907-551-ATQ.lbl
   Part No: 3B0 907 551 DC
   Component: 2.8L V6/5V      G   0020
   Coding: 07551
   Shop #: WSC 00028
   VCID: 678B4783567FCA6F68D-5160
   WVWRU63BX5P005880     VWZ7Z0D9524430
16815 - Warm Up Catalyst; Bank 2
            P0431 - 35-00 - Efficiency Below Threshold
16825 - EVAP Emission Control Sys
            P0441 - 35-00 - Incorrect Flow
16725 - Camshaft Position Sensor (G40)
            P0341 - 35-10 - Implausible Signal - Intermittent
Readiness: 0000 0001
Address 02: Auto Trans        Labels: 01V-927-156.lbl
   Part No: 3B0 927 156 CC
   Component: AG5 01V 2.8l5V  USA 0404
   Coding: 0001104
   Shop #: WSC 00028 028 00001
   VCID: 698F41BB456BFC1F7E9-5160
Address 03: ABS Brakes        Labels: 4B0-614-517.lbl
   Part No: 4B0 614 517 G
   Component: ABS/ESP front       3428
   Coding: 04257
   Shop #: WSC 00028
   VCID: 25170D8BECF3187F9A1-51CE
   Part No: 3B1 907 044 J
   Component: CLIMATRONIC B5GP    0006
   Coding: 17200
   Shop #: WSC 00028
   VCID: 280904BF9BE10517A17-5160
   Part No: 1C0 909 605 C
   Component: 09 AIRBAG VW61 04   0003
   Coding: 12345
   Shop #: WSC 00028
   VCID: 2411108FE7C9E1778DF-513C
   Part No: 1J0 907 487 A
   Component: Lenkradelektronik   0005
   Coding: 00118
   Shop #: WSC 00028
   VCID: 2F3BEFA3BE0F522F60D-5160
Address 17: Instruments        Labels: 3B0-920-xx5-17.lbl
   Part No: 3B0 920 929 B
   Component: KOMBI+WEGFAHRSP VDO V04
   Coding: 15235
   Shop #: WSC 00222
   VCID: 26150A8791F5136793B-513C
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 00028
   VCID: 70B92CDF63B10DD7397-513C
Address 36: Seat Mem. Drvr        Labels: 3B1-959-760.lbl
   Part No: 3B1 959 760 E
   Component: °301
   Shop #: WSC 00000 065 00000
   VCID: 2F3BEFA3BB0F522F60D-513C
01008 - Note; Emergency OFF Switch is Active!
   Part No: 1C0 959 799 C
   Component: 09 Komfortgerát HLO 0004
   Coding: 00258
   Shop #: WSC 00028
   VCID: 372BD7C3465F9AEF38D-4B1E
   Subsystem 1 - Part No: 1C0959801
   Component: 09 Tõrsteuer.FS KLO 0202
   Subsystem 2 - Part No: 1C0959802A
   Component: 09 Tõrsteuer.BF KLO 0202
   Subsystem 3 - Part No: 1C0959811
   Component: 09 Tõrsteuer.HL KLO 0202
   Subsystem 4 - Part No: 1C0959812
   Component: 09 Tõrsteuer.HR KLO 0202
Address 56: Radio        Labels: 3B7-035-1xx-56.lbl
   Part No: 3B7 035 180 G
   Component:    Radio PM6        0016
   Coding: 04031
   Shop #: WSC 00028
End----(Elapsed Time: 04:01, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Address 01: DTCs cleared
Address 02: DTCs cleared
Address 03: DTCs cleared
Address 08: DTCs cleared
Address 15: DTCs cleared
Address 16: DTCs cleared
Address 17: DTCs cleared
Address 19: DTCs cleared
Address 36: DTCs cleared
Address 46: DTCs cleared
Address 56: DTCs cleared
Seems to be a continuation of this thread:
https://forums.ross-tech.com/showthread.php?19879
We generally frown on having multiple threads open regarding the same problem in the same car. Would you prefer I merge them, or close one of them, and if so, which one?
