Polybushes
maxx16v
C?ID=342531
hi
I have a lowered Caddy 2K 1.9tdi C20 2005 and would like to upgrade the front wishbone rear bushes to polyurethane rather than replace with stock VW parts
I am not sure if this is the same as a MK5 golf running gear setup
I need a size and if possible recommendation of where and who would be able to supply these in the UK...
All help appreciated
:D
NZDubNurd
New Zealand
C?ID=230482
They are the same as MK5 1K Golf and 1T Touran.
I've used Powerflex a lot and have had no issues myself.
If you want to really tighten up the front, go nuts: get the Anti-lift kit, which gives better traction (less wheel hop) and also more caster, makes the steering feel heavier and more solid.
In addition to that, I got the camber adjustable front lower arm bushes and the ECS subframe lock kits (which needs trimming to fit with the anti-lift kit). With standard bushes, the camber isn't adjustable as such - you have to slide the subframe left or right to make it even. With the adjustable bushes, you can adjust each side individually which probably helps a lot on a lowered Caddy.
My Touran is raised slightly, and the camber adjustment was brilliant.
