2012 A6 4G side assist and Engine timer fault
morski
Cheshire UK
C?ID=90186
Been fitting a new sub the other day and had the battery terminal on and off whilst doing it. So thought i'd clear some fault codes and am stuck with the 'P150 engine off timer performance' code which will not clear, and why its listed in the 08 HVAC module is unknown as ive seen the P150 code online and is usually listed in the 01 Engine module.
The 5F module is giving me a comms disruption which i thought was due to the MOST being disconnected but again wont clear.
The strange thing with the side assist is even though its a retrofit i did nearly 2 years ago its been working perfectly fine with no issues but after clearing the fault codes yesterday the fault suddenly appeared and will not clear. Whether its pure pot luck that i have a faulty lamp all of a sudden i dont know until i swap it with the other side
Any help with the codes please?
Friday,11,October,2019,16:51:36:00592
VIN: WAUZZZ4G7CN173219   License Plate: X9MBX
Mileage: 62368km-38753mi   Repair Order: Fitted Sub & clearde air susp coding
Chassis Type: 4G-AU57 (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 20 28 36 3B 3C 42 44 46 47
          52 53 55 56 5F 62 6C 6D 72 82 A9 C0
VIN: WAUZZZ4G7CN173219   Mileage: 62368km-38753miles
Address 01: Engine (J623-CGQB)       Labels: Redir Fail!
   Part No SW: 4G0 907 589 A    HW: 4G0 907 589
   Component: 3.0BTD EDC17  H21 0004
   Revision: 57H21---
   Coding: 122A4012052601020000
   Shop #: WSC 02391 785 00200
   ASAM Dataset: EV_ECM30BTD0114G0907589A 001005
   ROD: EV_ECM30BTD0114G0907589A.rod
   VCID: 323D188CE4AF44970F3-8066
   Part No SW: 4G0 927 158 AB    HW: 0BK 927 156 AM
   Component: 0BK 30RTDIRdW H16 1006
   Revision: --H16---
   VCID: 6E85CCFC301720772BB-803A
   Part No SW: 4G0 907 379 H    HW: 4G0 907 379 H
   Component: ESP PREMIUM   H09 0361
   Coding: 49A7870192E5E180DB00
   ASAM Dataset: EV_ESPPremiAU57X 004028
   VCID: 3635249C08C758B723B-8062
   Part No SW: 4H0 907 064 BN    HW: 4H0 907 064 BN
   Component: BCM2 2.0      H31 0333
   Coding: 01B93006000000000000
   Shop #: WSC 03273 003 1048576
   VCID: 76B5E49C48C718B7E3B-8022
   Serial number: 2312000080249013
   Part No SW: 4G0 820 043 CD    HW: 4G0 820 043 CD
   Serial number: 09111500041327
   Coding: 362209BA310000
   Shop #: WSC 01206 210 13345
   VCID: 6393ADC8EBD59D1FB45-8036
0276 - Engine Off Timer Performance
          P150A 00 [009] - -
                    Reset counter: 53
                    Mileage: 62368 km
                    Date: 2019.10.11
                    Time: 16:18:01
                    Voltage terminal 30: 13.46 V
                    Terminal 15 status: Terminal 15 on
0291 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [Sensor für Luftgüte: kein Signal / Kommunikation]
                    Reset counter: 53
                    Mileage: 62368 km
                    Date: 2019.10.11
                    Time: 16:18:01
                    Outside air temperature: 13.0 °C
   Part No SW: 4H0 907 063 CG    HW: 4H0 907 063
   Revision: 11012002    Serial number: 00000001674657
   Coding: 2907A01149748FE0178100C7000018005F9DC7080F000101000104546F00
   Shop #: WSC 02313 785 00200
   VCID: 6FBBD1F8379D297F20D-803A
   Subsystem 1 - Part No SW: 4G2 955 119     HW: 4G8 955 119 A  Labels: 1KX-955-119.CLB
   Component: WWS57X 120309  H35 0080
   Serial number:         120326084537
   Coding: 004DF7
   Component: RLS  H04 0003
   Serial number: 20151070
   Coding: 03512B
   Subsystem 3 - Part No SW: 4G0 941 531 H    HW: 4G0 941 531 H
   Component: E1 - LDS  H07 0044
   Serial number: 08 02 2011  00000393
   Subsystem 4 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A31 LED Mod1L  H03 0006
   Serial number: 00000029061200010224
   Coding: 110000
   Subsystem 5 - Part No SW: 4H0 907 472 B    HW: 4H0 907 472 B
   Component: A27 LED Mod1R  H03 0006
   Serial number: 00000030031100010004
   Coding: 110000
   Subsystem 6 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Component: AQ_Hum_Sensor  H03 0005
   Serial number: EA288B2800PAG0MUFU01
   Part No SW: 4H0 919 475 AA    HW: 4H0 919 475 AG
   Component: PARKHILFE ACC H01 0083
   Revision: 11001001    Serial number: 61061302604024
   Coding: A8E308
   ASAM Dataset: EV_EPHVA18AU57X0000 004009
   ROD: EV_EPHVA18AU57X0000_004.rod
   VCID: 71BFD78021293F8F369-8024
   Part No SW: 4H0 959 655 C    HW: 4H0 959 655 C
   Component: Airbag10.43   H43 0040
   Revision: --------    Serial number: 003JG008D7S8
   Coding: 30323436313330303537554A305234473053
   Serial number: 3575HRB405B1AP5SCHQ4
   Serial number: 3585HRB404R1BBH279UR
   Serial number: 3515JRB405F0UJCMJGKI
   Serial number: 3525JRB405D18E5E70ES
   Serial number: 3554VRB4061197FI89RJ
   Serial number: 3564VRB4061197FII8LN
   Part No SW: 4G0 953 568 A    HW: 4G0 953 568 A
   Component: Lenks.Modul   H05 0201
   Revision: 00000000    Serial number: 20120501000043
   Coding: 000035
   VCID: 30391284EA237687797-8064
   Subsystem 1 - Part No SW: 8U0 951 528 H    HW: 8U0 951 528 H
   Part No SW: 4G8 920 982 K    HW: 4G8 920 982 K
   Component: TDieGb        H79 0416
   Revision: 28460177    Serial number: 658140412596003
   Coding: 73AF11000B012600010000
   Shop #: WSC 00011 888 96745
   ASAM Dataset: EV_RBD4K 004045
   ROD: EV_RBD4K_AU57.rod
   VCID: 3C2136B436EB82E7D5F-8068
   Part No SW: 4G0 907 468 AB    HW: 4G0 907 468 AA
   Component: J533--Gateway H10 0028
   Revision: --------    Serial number: 00000000502826
   Coding: 00CD077D00
   ASAM Dataset: EV_GatewPkoUDS 001013
   VCID: 70B9D2842A233687397-8024
   Subsystem 1 - Part No SW: 8X0 915 181     HW: 8X0 915 181
   Component: J367-BDM  H07 0141
   Serial number: 00000000003790879227
   Voltage stabilizer:
   Subsystem 2 - Part No SW: 8K0 959 663 F    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 21011200000000000308
   Part No SW: 8K0 857 511 E    HW: 8K0 857 511 A
   Component: FLA           H04 0004
   Revision: AA001002
   Coding: 04028264747464545425363E
   VCID: 33331D881B354D9F045-8066
   Part No SW: 4G0 919 158 R    HW: 4G0 919 158 R
   Component: KLIMA FOND    H08 0112
   Serial number: 30111300040269
   Coding: 22
   VCID: 3E253CBC20F790F7FBB-806A
   Component: MEM-FS        H03 0153
   Revision: AA000000    Serial number: 00000010457256
   Coding: 00781B0000006001000001010101102030303232203232
   Shop #: WSC 02311 785 00200
   VCID: 77ABE9984FCD61BFF8D-8022
   Part No SW: 4G0 907 637 H    HW: 4G0 907 637 D
   Component: SARA 3D       H03 0056
   Revision: --------    Serial number: EJ1BPA7207MWN1
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 33331D881BB54D9F045-8066
   Part No SW: 4G0 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH02 0050
   Revision: 00H02000    Serial number: 6PZ 010 287-03
   Coding: 0001102
   Shop #: WSC 03654 128 28888
   VCID: 30391284E6237687797-8064
   Subsystem 1 - Part No: 4G0 907 568 D
   Component: J770  SWA Slave H02 0050
   Subsystem 2 - Serial number: 6PZ 010 287-23
   Subsystem 3 - Serial number: 5F09.02.1200H020003CF24763ÿ
   Subsystem 4 - Serial number: F24763ÿ
02853 - Warning Lamp for Lane Change Assistance (in left exterior mirror) (K233)
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 53
                    Date: 2012.01.01
   Part No SW: 4G8 959 793 D    HW: 4G8 959 793
   Component: TSG FA        H05 0212
   Coding: 011F1E205E01620002080012
   Shop #: WSC 06745 128 28888
   VCID: 41DF47405189EF0F869-8014
   Component: RCEPS         H35 0010
   Revision: 00001000    Serial number: 0008500146
   Coding: 101000010000
   ASAM Dataset: EV_RCEPS 009008
   ROD: EV_RCEPS_009.rod
   Revision: 00002001    Serial number: 0176199445
   Coding: 013F162220B93480C120098500010E470000000000000000000000000000
   Shop #: WSC 50394 001 104857
   Subsystem 1 - Part No: 4G0 951 177 A
   Component: Sensor, DWA  005 0002
   Subsystem 3 - Part No SW: 4G0 947 135 B    HW: 4G0 947 135
   Serial number: 0000000AP00020773168
   Revision: CJ007001    Serial number: 00000000043305
   VCID: 1D67DB308DB1EBEFC21-8048
   Part No SW: 4G8 959 792 D    HW: 4G8 959 792
   Component: TSG BF        H05 0212
   Coding: 011F1E205401620002080002
   VCID: 40D942445A83E607897-8014
   Part No SW: 4H0 907 801 E    HW: 4H0 907 801 A
   Component: EPB-4         H03 0012
   Revision: --------    Serial number: 00000000329638
   ROD: EV_ParkiBrake_VW51.rod
   VCID: 2A0D00ECCC7F0C57B73-807E
   Part No SW: 4H0 907 357 A    HW: 4H0 907 357 A
   Component: ....LWR12.... H02 0013
   Serial number: 120430-0004-084
   Coding: 1122A6601000A300
   ROD: EV_HeadlRegulBasic.rod
   VCID: 2C0106F4C68B126745F-8078
   Part No SW: 4G0 035 061 Q    HW: 4G0 035 061
   Component: Radio U DAB   H60 0150
   Revision: AB001007    Serial number: 109C 0F8018881
   Coding: 010103010000000001
   Shop #: WSC 06325 000 00000
   VCID: 2B0305E8C305155F4C5-807E
   Part No SW: 4G0 035 670 P    HW: 4G0 035 670 H
   Component: H-BNT-EU      H49 0939
   Revision: --------    Serial number: 190EU0C7502607
   Coding: 050101010103E7FF77088F3E00000003000001000100000202
   Subsystem 1 - Part No: 8R0 060 884 AH
   Component: EUR 2012  1308
   Subsystem 2 - Part No SW: 4G0 919 605 B    HW: 4G0 919 605 B
   Component: DU8 C7 SV  H42 0021
   Serial number: AUZ8ZDC9401C6WZ
   Subsystem 3 - Part No SW: 4G2 919 610 C    HW: 4G2 919 610 C
   Component: E380 BDT C7  H11 0204
   Serial number: 90349LE10002U
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
                    Reset counter: 53
                    Mileage: 62368 km
                    Date: 2019.10.11
                    Time: 16:35:45
                    Bin. Bits: 00000000 00001000
                    Bin. Bits: 00001000 00000000
                    Bin. Bits: 00000000 00000000
   Part No SW: 4G8 959 795 D    HW: 4G8 959 795
   Component: TSG HL        H03 0212
   Coding: 010F1C204001628202080002
   VCID: 43D34D484B95FD1F945-8016
   Part No SW: 4H0 907 428 D    HW: 7P6 907 441 F
   Component: TopView       H07 0330
   Revision: 11001001    Serial number: 82330JF0204757
   Coding: 0202000001000000000102000000
   ASAM Dataset: EV_CamerSysteTopViewAUDI 008027
   VCID: 2E050CFCF09760776BB-807A
9616786 - Surroundings Camera Front
          B127C F0 [009] - Calibration Failed
                    Reset counter: 50
                    Mileage: 62227 km
                    Date: 2019.08.24
                    Time: 18:59:05
                    Voltage terminal 30: 11.3 V
9616787 - Surroundings Camera Rear
          B127D F0 [009] - Calibration Failed
                    Reset counter: 50
                    Mileage: 62227 km
                    Date: 2019.08.24
                    Time: 18:59:05
9616788 - Surroundings Camera Left
          B127E F0 [009] - Calibration Failed
                    Reset counter: 50
                    Mileage: 62227 km
                    Date: 2019.08.24
                    Time: 18:59:05
9616789 - Surroundings Camera Right
          B127F F0 [009] - Calibration Failed
                    Reset counter: 50
                    Mileage: 62227 km
                    Date: 2019.08.24
                    Time: 18:59:05
10489856 - No Basic Setting
          B2010 00 [009] - -
          [TopView system not calibrated]
                    Reset counter: 50
                    Mileage: 62227 km
                    Date: 2019.08.24
                    Time: 18:59:05
   Part No SW: 4G9 959 107 C    HW: 4G9 959 107 B
   Component: HDSG-Modul    H05 0151
   Revision: 14005001    Serial number: 147500731
   Coding: 093205C010
   ROD: EV_HDSGAu571.rod
0114 - Load Space Cover
          B12EF 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 53
                    Mileage: 62368 km
                    Date: 2019.10.11
                    Time: 16:15:33
                    Voltage terminal 30: 13.57 V
   Component: TSG HR        H03 0212
Address 82: Heads Up Display (J898)       Labels:| 4G0-919-604.clb
   Part No SW: 4G0 919 604 A    HW: 4G0 919 604 A
   Component: HeadUpDisplay X19 0042
   Coding: A20000
   ASAM Dataset: EV_HUDContiC7 001020
   ROD: EV_HUDContiC7.rod
   VCID: 290FFFE0C979074FBE9-807C
   Part No SW: 4G0 907 159 A    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 120419200783
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: 2B0305E8C385155F4C5-807E
Address C0: Act. for Ext. Noise        Labels:
   VCID: 55F78310BC0173AFCA1-FFFE
   Note: Excessive Comm Errors
End----------(Elapsed Time: 02:27, VBatt start/end: 13.6V/13.6V)-----------
Address 08: DTCs cleared
morski
Cheshire UK
C?ID=90186
anyone have any input??
