VW Touran 2019 - unsupported vehicle
IgorDeLuxe
EU-Slovenia
C?ID=266900
Hi,
we received new VW Touran 1.5 TSI (150 hp).
I'm sending my full scan. Is this vehicle not compatible with HEX+CAN cable (upgraded to latest version)? Which interface is first one (cheapest) that would support this car? Can anything be done to use existing interface on this Tuaran?
Can someone please lookup what 2 error codes are on modules 09 and 5F?
Thank you.
Saturday,12,October,2019,11:07:10:18194
VCDS Version: 19.6.2.0 (x64)
VIN: WVGZZZ1TZLW007323   License Plate:
Chassis Type  1T (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 17 19 3C 42 44 4B 52 5F 6D 75 A5
          BB BC CF
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DPCA)       Labels: None
   Part No SW: 05E 906 018 BN    HW: 05E 907 309 H
   Component: R4 1.5l TFS   H20 9661
   Revision: 8AH20000
   Coding: 0125003223641D0830000000000000000000000000000000
   ASAM Dataset: EV_ECM15TFS01105E906018BN 003004
   ROD: N/A
   VCID: 72D2508EA5E833DFA1-8026
Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
No ASAM data for: "EV_ECM15TFS01105E906018BN" ()
Address 02: Auto Trans (J743)       Labels: None
   Part No SW: 0CW 300 050 A    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 1705
   Revision: 00005008    Serial number: CU501908316341
   ROD: N/A
   VCID: 335C958A9A727AD76A-8066
No ASAM data for: "EV_TCMDQ200021" ()
   Part No SW: 5Q0 614 517 FB    HW: 5Q0 614 517 BS
   Component: ESC           H82 0190
   Revision: 00000000    Serial number: 61679000000970
   Coding: 0CEA6AA030202373477A060260C62930560CC4E2600694753822F078D2A24A0B0000040212121212B235351919323200
   ROD: N/A
   VCID: 76DA6C9EC9802FFF8D-8022
No ASAM data for: "EV_Brake1UDSContiMK100IPB" ()
Address 05: Acc/Start Auth. (J518)       Labels:. 5Q0-959-435.clb
   Part No SW: 3Q0 959 435 N    HW: 3Q0 959 435 N
   Component: VWKESSYMQB    037 1307
   Revision: 00037000    Serial number: 0523826778
   Coding: 132C0C0723
   ROD: N/A
   VCID: 45B8DB52C4E6F467D4-8010
   Subsystem 1 - Part No SW: 3G0 962 243 C    HW: 3G0 962 243 C
   Serial number: 11923301
No ASAM data for: "EV_KessyHellaMQBAB" ()
Address 08: Auto HVAC (J255)       Labels:. 5G0-907-044.clb
   Part No SW: 5G0 907 044 EQ    HW: 5G0 907 044 EQ
   Component: Climatronic   H04 2202
   Revision: 00001K10
   Coding: 08020004200110011105100000101426
   ASAM Dataset: EV_ACClimaBHBVW37X 006150
   ROD: N/A
   VCID: 7AC278AEFD984B9FE9-802E
No ASAM data for: "EV_ACClimaBHBVW37X" ()
   Part No SW: 5Q0 937 086 CE    HW: 5Q0 937 086 BQ
   Component: BCM PQ37BOSCH 038 0303
   Revision: --------    Serial number: J53F17081900CV
   ASAM Dataset: EV_BodyContrModul1UDSBosc 020001
   ROD: N/A
   VCID: 7F3489BAE6BA6EB7DE-802A
   Subsystem 1 - Part No SW: 5TB 955 119 A    HW: 5TB 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    190715  043  0608
   Serial number:         190805182605
   Subsystem 2 - Part No SW: 5Q0 955 547 C    HW: 5Q0 955 547 C  Labels: 5Q0-955-547.CLB
   Component: RLHS  051  0206
   Serial number: S5Y19M08D26H18M22S42
   Coding: 0008DD
   Subsystem 4 - Part No SW: 5Q1 953 521 M    HW: 5Q1 953 569
   Component: Lenks.Modul  H03  0170
   Serial number: 0100170820190C102081
No ASAM data for: "EV_BodyContrModul1UDSBosc" ()
5642 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 49
                    Mileage: 44 km
                    Date: 2019.09.27
                    Time: 19:32:00
Address 10: Park/Steer Assist (J446)       Labels:. 5Q0-919-294.clb
   Part No SW: 5QA 919 294 G    HW: 5QA 919 294
   Component: PDC 8 Kanal   H08 0061
   Serial number: 000150058319241
   Coding: 0471155811
   ASAM Dataset: EV_EPHVA18AU3700000 009046
   ROD: N/A
   VCID: 5096FA060BA421CF77-8004
No ASAM data for: "EV_EPHVA18AU3700000" ()
Address 13: Auto Dist. Reg (J428)       Labels:. 3Q0-907-572.clb
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H05 0196
   Coding: 3204675219FFC428949C804D
   ASAM Dataset: EV_ACCBOSCHVW48X 001009
   ROD: N/A
   VCID: 3558AB92940664E744-8060
No ASAM data for: "EV_ACCBOSCHVW48X" ()
Address 15: Airbags (J234)       Labels:. 5Q0-959-655.clb
   Part No SW: 5Q0 959 655 BT    HW: 5Q0 959 655 BT
   Component: AirbagVW21    008 0403
   Serial number: 003FNR5LRFLS
   Coding: 98CCC0C00C0000005C5400CF004800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002164
   ROD: N/A
   VCID: 131C350AFA329AD70A-8046
   Subsystem 1 - Part No SW: -----------    HW: 480 000 209 19
   Serial number: 3570000000097C20DF3X
   Subsystem 2 - Part No SW: -----------    HW: 480 000 209 19
   Serial number: 35800000000D7C20DF3
   Subsystem 3 - Part No SW: -----------    HW: 480 410 209 19
   Component: SideSensor_Dr  003 0189
   Serial number: 351001A119A191F33F13
   Subsystem 4 - Part No SW: -----------    HW: 480 410 209 19
   Component: SideSensor_Pr  003 0189
   Serial number: 352001A119A1D544EC8H
   Subsystem 5 - Part No SW: -----------    HW: 480 402 708 19
   Component: FrontSensor_D  005 6149
   Serial number: 3550001BCF240023D831
   Subsystem 6 - Part No SW: -----------    HW: 480 403 008 19
   Component: PedP_Sensor_C  005 6149
   Serial number: 2300001BCF20D054BA03
   Subsystem 7 - Part No SW: -----------    HW: 480 001 708 19
   Serial number: I0M00000000D95146F3A
   Subsystem 8 - Part No SW: -----------    HW: 480 001 708 19
   Serial number: I0N000000002E015CE36
No ASAM data for: "EV_AirbaVW20SMEVW37X" ()
Address 17: Instruments (J285)       Labels:. 5G0-920-XXX-17.clb
   Part No SW: 5TA 920 740 D    HW: 5TA 920 740 D
   Component: KOMBI         203 6700
   Coding: 07A401086F88000801882A0B1401000800000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009069
   ROD: N/A
   VCID: 44BEC656CFDCCD6FC3-8010
No ASAM data for: "EV_DashBoardVDDMQBAB" ()
Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
   Part No SW: 3Q0 907 530 AC    HW: 3Q0 907 530 C
   Component: GW MQB High   521 5388
   Serial number: 18081910803356
   Coding: 030100047F0857002310025A180F00010001070000000000000000000000
   ROD: N/A
   VCID: 70D65A86ABE401CF57-8024
   Component: 5-00-14-00-04
   Subsystem 2 - Part No SW: 5NA 959 442 B    HW: 5NA 959 442 B
   Component: E221__MFL-TAT  H06 0025
   Serial number: 1971901323100090FJ2B
   Coding: 2C0000
   Serial number: 9330432405
No ASAM data for: "EV_GatewNF" ()
Address 3C: Lane Change (J769)       Labels:. 3Q0-907-566.clb
   Part No SW: 3Q0 907 566 G    HW: 3Q0 907 566
   Component: MRR1Rear      H25 0530
   Revision: --------
   Coding: 04C002
   ROD: N/A
   VCID: 3C4EBEB6B72CB5AFBB-8068
No ASAM data for: "EV_RearRadarS1BoschVW48X" ()
   Part No SW: 5Q0 959 593 K    HW: 5Q0 959 593 F
   Component: TSG FS002 0320
   Serial number: YE007SH601452
   Coding: 00319320D000040000001000
   ROD: N/A
   VCID: 49A0D762E8FE100730-801C
No ASAM data for: "EV_DCU2DriveSideMAXHKLO" ()
Address 44: Steering Assist (J500)       Labels:. 5Q0-910-143.clb
   Part No SW: 5Q0 910 143 C    HW: 5Q0 910 143
   Component: MQB_VWBS_GEN2 212 2211
   Serial number: 956030 00
   Coding: 0100001100400010
   ASAM Dataset: EV_SteerAssisVWBSMQBGen2 002119
   ROD: N/A
   VCID: 2B6C8DEA4242221722-807E
No ASAM data for: "EV_SteerAssisVWBSMQBGen2" ()
Address 4B: Multifunc. Module
Interface not compatible.
   Part No SW: 5Q0 959 592 K    HW: 5Q0 959 592 F
   Component: TSG BFS002 0320
   Serial number: YE007SG315963
   Coding: 00319120DC00040000001000
   ROD: N/A
   VCID: 48A6D266F3F4E90F2F-801C
No ASAM data for: "EV_DCU2PasseSideMAXHKLO" ()
Address 5F: Information Electr. (J794)       Labels:. 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 824 C    HW: 3Q0 035 824 C
   Component: MU-S--ER      724 0890
   Coding: 02730800FF0000004111000100080A001F0500D40120010002
   ROD: N/A
   VCID: 2D6883F27C562C273C-8078
   Subsystem 1 - Part No SW: 5G6 919 605 A    HW: 5G6 919 605 A
   Component: ABT_Std-2  H61 8214
   Serial number: VWZ6ZJW2450061
No ASAM data for: "EV_MUStd4CDELP" ()
6720 - ROD - Unknown Error Code
          - 00 [008]
                    Reset counter: 72
                    Mileage: 312 km
                    Date: 2019.10.05
                    Time: 13:05:13
Address 6D: Trunk Elect. (J605)       Labels:. 5Q0-959-107.clb
   Part No SW: 5Q0 959 107 S    HW: 5Q0 959 107 J
   Component: HDSG-Modul    H13 0271
   Revision: --------    Serial number: A2-C737-6291-8
   Coding: 0308
   ROD: N/A
No ASAM data for: "EV_DeckLidCONTIAU736" ()
Address 75: Telematics (J949)       Labels:. 5QE-035-285.clb
   Part No SW: 5NA 035 284 C    HW: 5NA 035 284 C
   Component: OCULowMQBLGE  H19 0825
   Revision: --------
   Coding: 02730801EA16180D3F1CBE000045400382E608
   ASAM Dataset: EV_OCULowMQBLGE 004049
   ROD: N/A
   VCID: 3D48B3B2AC36BCA78C-8068
No ASAM data for: "EV_OCULowMQBLGE" ()
Address A5: Frt Sens. Drv. Assist (R242)       Labels:. 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H12 0610
   Serial number: 23071915K11421
   Coding: 0003070800000401002200468140A90088000E30004000
   ROD: N/A
   VCID: 40B6CA46DBC4D14FE7-8014
No ASAM data for: "EV_MFKBoschMQBB" ()
Address BB: Door Rear Drv (J388)       Labels: None
   Part No SW: 5Q0 959 595 K    HW: 8W1 959 595 D
   Component: TSG HFS004 0320
   Serial number: YE007SGN3745D
   Coding: 002091200000040000001000
   ROD: N/A
   VCID: 4BACED6AE282021702-801E
No ASAM data for: "EV_DCU2RearDriveMAXHKLO" ()
Address BC: Door Rear Pass (J389)       Labels: None
   Component: TSG HBFS004 0320
   Serial number: YE007SHC06807
   ROD: N/A
No ASAM data for: "EV_DCU2RearPasseMAXHKLO" ()
Address CF: Lane Chge Asst 2
End-------------------------(Elapsed Time: 04:10)--------------------------
Spacewalker
Poland
C?ID=159607
It was say hmm.......over about a year ago
you need to use Hex NET or HEX V2
IgorDeLuxe
EU-Slovenia
C?ID=266900
I'm not "heavy" user. From time to time to check status of modules, make some adaptation to non-critical modules (like infotainment, climat, etc...) and that it is all. And to have chance to do this also on new car. :)
No need for bluetooth, wifi, etc... classic cable is ok.
diskoboy
Denmark
C?ID=50403
Would it be possible for you to post a complete log of all the adaptions channels from 09? :)
(I really need this for a small project :))
^^^ hmm...... hex09 DTC (and hex5F) DTC is intermittent and hasn't occurred again in the 15 x days between first registration on the CAN bus and the date of the auto-scan. Kind-of suggests that it might be prudent to reset all DTCs and re-poll the car (and post-up a new auto scan) - perhaps?
Doesn't solve the incompatibility problem with the VCDS cable - but might establish a more stable information base for further analysis -maybe?
