ECU Recoding from auto transmission to manual
dl724705
C?ID=383655
I swapped out the auto trans for a manual in my 2000 Jetta. All is good, car runs great; however, it has CEL related to auto trans codes.
VCDS-Lite Version: Release 1.2
Wednesday, 09 October 2019, 18:34:39:57286
Chassis Type: 9M - VW Jetta IV
Scan: 01,02,03,08,09,15,16,17,19,22,29,35,36,37,39,46,47,55,56,57,75,76
Address 01: Engine       Labels: Redir Fail!
   Controller: 06A 906 018 JM
   Component: 2.0l R4/2V  MOTR AT V01
   Coding: 00033
   Shop #: WSC 09250
   VCID: 769FBA1D41DF
Readiness: 0110 0101
Address 02: Auto Trans       Labels: 01M-927-733.LBL
   Controller: 01M 927 733 HM
   Component: AG4 Getriebe 01M    4604
   Coding: 00000
   VCID: 827756CD9D17
10 Faults Found:
00258 -  Solenoid Valve 1 (N88)
            36-00 -  Open Circuit
00260 -  Solenoid Valve 2 (N89)
00262 -  Solenoid Valve 3 (N90)
00264 -  Solenoid Valve 4 (N91)
00266 -  Solenoid Valve 5 (N92)
00270 -  Solenoid Valve 7 (N94)
00268 -  Solenoid Valve 6 (N93)
            36-10 -  Open Circuit - Intermittent
00293 -  Multi-function Switch (F125)
            25-00 -  Unknown Switch Condition
00281 -  Vehicle Speed Sensor (G68)
            03-00 -  No Signal
00297 -  Gearbox Speed Sensor (G38)
            03-00 -  No Signal
Address 03: ABS Brakes       Labels: 1J0-907-37x-ABS.LBL
   Controller: 1J0 907 379 P
   Component: ABS     20 IE CAN  0001
   Coding: 03504
   Shop #: WSC 00066
   VCID: 3E0F623D296F
Address 15: Airbags       Labels: 6Q0-909-605-VW5.LBL
   Controller: 6Q0 909 605 A
   Component: 09 AIRBAG VW5       0003
   Coding: 12345
   Shop #: WSC 00066
   VCID: 351D7D111C59
Address 17: Instruments       Labels: 1J0-920-xx0-17.LBL
   Controller: 1J0 920 900 K
   Component: A4-KOMBIINSTR. VDO V56
   Coding: 07242
   Shop #: WSC 00066
   VCID: 2A275E6DC5E7
   IMMO-IDENTNR: VWZ7Z0X1515416
Address 19: CAN Gateway       Labels: 6N0-909-901-19.LBL
   Controller: 6N0 909 901
   Coding: 00007
   Shop #: WSC 00066
   VCID: F0930C05A3BB
Address 35: Centr. Locks       Labels: 1C0-962-258-II.LBL
   Controller: 1C0 962 258 P
   Component: 0J Zentr.Verriegel. 0001
   Coding: 04096
   Shop #: WSC 00066
   VCID: 341B40151723
00953 -  Interior Light Time limit
            25-10 -  Unknown Switch Condition - Intermittent
End   --------------------------------------------------------------------------------------------------
I tried to change the engine coding from 00033 to 00031 using VCDS and I get:
18020 - engine control module incorrectly coded P1612 - 35-00
dieseldub
Bay Area, CA
C?ID=28764
First off, you need to physically unplug and remove the old transmission computer. Then you can also code the CAN gateway to no longer look for the transmission computer. Current coding being 00007 in address 19 CAN Gateway. Change it to 00006.
Then try to recode the engine computer and see what happens.
I agree with removing the TCU. In addition, the ECU might need a login in order to accept a coding change. Try 01283.
dl724705
C?ID=383655
Removing the TCU and recoding did it; no more CEL.
Thanks!
dl724705
C?ID=383655
Thanks!
After driving the car a spell, I get MAF and O2 sensor faults that I did not get before removing the TCM and recoding.
Autoscan before:
   Coding: 00033
   Shop #: WSC 09250
   VCID: 769FBA1D41DF
   Coding: 00000
   VCID: 827756CD9D17
10 Faults Found:
            03-00 -  No Signal
            03-00 -  No Signal
   Coding: 03504
   Shop #: WSC 00066
   VCID: 3E0F623D296F
   Coding: 12345
   Shop #: WSC 00066
   VCID: 351D7D111C59
   Coding: 07242
   Shop #: WSC 00066
   VCID: 2A275E6DC5E7
   Coding: 00007
   Shop #: WSC 00066
   VCID: F0930C05A3BB
   Coding: 04096
   Shop #: WSC 00066
   VCID: 341B40151723
And after:
Monday, 14 October 2019, 18:02:57:57286
Address 01: Engine       Labels: 06A-906-018-JM.LBL
   Component: 2.0l R4/2V  MOTR HS V01
   Coding: 00031
   Shop #: WSC 09250
   VCID: 769FBA1D41DF
16487 -  Mass Air Flow Sensor (G70): Signal too High
            P0103 - 35-00 -   -
16519 -  Oxygen (Lambda) Sensor B1 S1; Heating Circuit: Malfunction
            P0135 - 35-00 -   -
16518 -  Oxygen (Lambda) Sensor B1 S1: No Activity
            P0134 - 35-00 -   -
16496 -  Intake Air Temp. Sensor (G42): Signal too Low
            P0112 - 35-00 -   -
16523 -  Oxygen (Lambda) Sensor B1 S2: Response too Slow
            P0139 - 35-10 -   - - Intermittent
Readiness: 0010 0101
   Coding: 03504
   Shop #: WSC 00066
   VCID: 3E0F623D296F
   Coding: 12345
   Shop #: WSC 00066
   VCID: 351D7D111C59
   Coding: 07242
   Shop #: WSC 00066
   VCID: 2A275E6DC5E7
   Coding: 00006
   Shop #: WSC 00066
   VCID: F0930C05A3BB
   Coding: 04096
   Shop #: WSC 00066
   VCID: 341B40151723
00928 -  Locking Module for Central Locking; Front Driver Side (F220)
            54-10 -  Incorrectly Equipped - Intermittent
Is there something else that needs to be done?
Check connection(s) to front oxygen sensor?
Look at the MAF readings in MVB 003.2?
dl724705
C?ID=383655
Problem is the MAF connector is broken
Where can I get one?
United States
There's a VW part number on that connector. Give that number Google search and you should be able to locate the empty housing/connector easily. (You are looking for something like: 1J0 973 775 A)
If the gold plated terminals or weather tight seals on the wires are damaged VW sells those separately as well.
MartinsX
Riga, Latvia
C?ID=268515
Or go to junkyard with wire cutters in Your pocket ;)
dl724705
C?ID=383655
Order, received and installed the new connector and no more CEL.
Thanks!
