Golf mk7 retrofit PLA 3.0
alvin1001
Malaysia
C?ID=361413
Hi everyone,
i have upgraded my 8K ops sensor to 12k PLA3.0.
i have coded module 10(PLA), module 44(steering assist), module 17( instruments).
however im still having this error in my PLA module.
[Bremsensteuergerät - ESP_33 - kein Signal/keine Kommunikation]
OPS 360 works fine. but auto park is not functioning.
if i'm not mistaken i have to change ABS pump coding as well, but i'm not sure which bit and bytes i have to change.
Thank you in advance
Wednesday,09,October,2019,20:07:04:55008
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WVWZZZAUZEW259316   License Plate: GOLF GTI
Mileage: 6607km-4105mi   Repair Order:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 42 44 52 55 5F 65
          A5 A9
VIN: WVWZZZAUZEW259316   Mileage: 6607km-4105miles
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 C    HW: 06K 907 425 B
   Component: 2.0l TVS ST3  H13 0099
   Revision: --H13---
   Coding: 091D00324464050B3000
   ASAM Dataset: EV_ECM20TFS0205G0906259C 001005
   ROD: EV_ECM20TFS0205G0906259C.rod
   VCID: 2E100CF671C1A53F05-807A
Readiness: 1110 0001
   Part No SW: 0D9 300 043 T    HW: 02E 927 770 AQ
   Component: DQ250-6F TVS  H52 9699
   Revision: 05852204    Serial number: TFK01312100544
   Coding: 0018
   ROD: EV_TCMDQ250021.rod
   VCID: 2B1605E242D3D01722-807E
          P1734 00 [002] - -
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 635330000000C9
   Coding: 01FA93A134252975037A060181C9A980C92C94C0608195F7F84250884006
   VCID: 7CB4F6BEF73D87AFFB-8028
   Revision: 00021000    Serial number: 0322827289
   Coding: 030C0C
   VCID: 3A3830A6BD89799FA9-806E
   Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00120004100100001105004011101800
   VCID: 383C2AAE83856B8F5F-806C
   Air quality sensor:
   Part No SW: 5Q0 937 085 T    HW: 5Q0 937 085 T
   Component: BCM MQBAB HNA H16 0124
   Serial number: 00011400700350
   Coding: 03011B42424122FB49E44080B10C07281800000000000000000000000000
   ROD: EV_BCMBOSCH_012.rod
   VCID: 4AD86066ED69E91F39-801E
   Component: WWS    131215  042 0551
   Serial number:         131218213128
   Component: RLFS  024 0042
   Serial number: Y14M01D10H14M24S33S9
   Coding: 37E8DD
264452 - No Communications with Anti-Theft Sensor
          U10F4 00 [009] - -
          [Sensor-DWA->kein Signal/ Kommunikation]
                    Reset counter: 167
                    Mileage: 6607 km
                    Date: 2019.10.09
                    Time: 19:50:46
267012 - No Communications with Anti-Theft Siren / Alarm Horn
          U10F3 00 [009] - -
          [Sirene-DWA->kein Signal/Kommunikation]
                    Reset counter: 167
                    Mileage: 6607 km
                    Date: 2019.10.09
                    Time: 19:50:46
   Part No SW: 5QA 919 298 D    HW: 5QA 919 298 A
   Component: PLA 3.0 12KH07 0050
   Serial number: 000308417618093
   Coding: 0371161851
   Shop #: WSC 00046 123 12345
   ASAM Dataset: EV_EPHVA2CAU3700000 009041
   ROD: EV_EPHVA2CAU3700000.rod
   VCID: 51EA770A003FDAC778-8004
12656926 - Databus
                    Reset counter: 167
                    Mileage: 6607 km
                    Date: 2019.10.09
                    Time: 20:02:08
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 27121376510845
   Coding: 021C1700FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   VCID: 3620249689919DFF4D-8062
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H15 0115
   Serial number: 09121341350245
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 76A0E496C911DDFF8D-8022
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR02PY9E
   Coding: 98FCC0C0000000005C5400CF00C800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 7F4E01B2E62B9CB7DE-802A
   Belt Pretensioner left:
   Serial number: 34169677B10011471324
   Coding: 333135
   Belt Pretensioner right:
   Serial number: 34169676B07011470241
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 000 201 14
   Serial number: 35767000000804957E0W
   Subsystem 4 - Part No SW: -----------    HW: 480 000 201 14
   Serial number: 35867000000182817E0R
   Subsystem 5 - Part No SW: -----------    HW: 480 400 201 14
   Serial number: 3516502A912FAE31706E
   Subsystem 6 - Part No SW: -----------    HW: 480 402 012 13
   Serial number: 3526502A311FBE92228F
   Subsystem 7 - Part No SW: -----------    HW: 480 401 912 13
   Serial number: 3556502AD11FBE95310N
   Part No SW: 5Q0 953 507 EC    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 02011404400818
   Coding: 0C10
   ROD: EV_SMLSKLOMQB_010_VW37.rod
   VCID: 7BB6F5A2F2338097F2-802E
   Part No SW: 5G1 920 791 B    HW: 5G1 920 791 B
   Component: KOMBI         403 4191
   Coding: 27BD11987E94000E02887E070400000000000000
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2246
   Revision: --------    Serial number: 14051910003292
   Coding: 030100042B085900FF00027E9C0F00010001000100000000000000000000
   Shop #: WSC 00046 000 00000
   ROD: EV_GatewConti_013.rod
   VCID: 79BAEFAAF80FB287E0-802C
   Subsystem 2 - Part No SW: 5G0 959 442 N    HW: 5G0 959 442 N  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H06 0038
   Serial number: 27130001973530053492
   Coding: 2DFFFF
   Serial number: 7873132203
   Revision: 00000000    Serial number: 13000294093004
   Coding: DD00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 34241E9E9FED8FEF73-8060
   Serial number: 21121302090982
   Coding: 003F1320D001048000001000
   Shop #: WSC 39426 001 1048576
   VCID: 40CC424EDB55234FE7-8014
   Serial number: 00000000000001490259
   Coding: 1D0000
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 9303
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 3522239A949796E744-8060
   Serial number: 20121301100624
   Coding: 003F1120DE01048000801000
   VCID: 3FCE41B2A6AB5CB79E-806A
   Serial number: 00000000000001412506
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029603000B010200
   VCID: 3D323BBAACA74EA78C-8068
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 3Q0 035 866 C    HW: 3Q0 035 866 C
   Component: MU-S-N-CN     852 0870
   Coding: 02731012FF00000041150001001028001F0703D601200500C6
   Shop #: WSC 00078 790 00051
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 33261D829AE388D76A-8066
   Subsystem 1 - Part No SW: 5G6 919 605 F    HW: 5G6 919 605 F
   Component: ABT_Std-2_Nav  H52 8130
   Serial number: VWZ6ZJV3122165
   Subsystem 2 - Part No SW: 3G0 919 866 Q    HW: -----------
   Component: CHN 2015  --- 0630
          B201A 00 [009] - -
                    Reset counter: 167
                    Mileage: 6607 km
                    Date: 2019.10.09
                    Time: 19:50:47
                    Voltage terminal 30: 11.6 V
                    Status_Software_Version_Management-module_name: C
15360768 - Component Protection
          U1101 00 [009] - Active
          [Anti-theft protection - component protection active (0xEA6300)]
                    Reset counter: 167
                    Mileage: 6607 km
                    Date: 2019.10.09
                    Time: 19:50:47
                    Voltage terminal 30: 11.8 V
7170 - Function Restricted due to Missing Message(s)
          U1111 00 [009] - -
          [A/C system (0x02) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 167
                    Mileage: 6607 km
                    Date: 2019.10.09
                    Time: 19:50:50
                    BAP-BAP_Function_ID: 02
          U1111 00 [008] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 207
                    Mileage: 6607 km
                    Date: 2019.10.09
                    Time: 19:50:50
1637 - Interface for External Media
          U11B8 00 [009] - No Communications
          [USB - communication error]
                    Reset counter: 167
                    Mileage: 6607 km
                    Date: 2019.10.09
                    Time: 19:50:47
                    Interface for external media: status-Status: Open circuit
   Serial number: 40000000214041
   ROD: EV_RDKBERU30_006_VW37.rod
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 10000026169
   Coding: 0101010000020303000400000101010100
   ROD: EV_MFKBoschAU370.rod
2555904 - Databus
          [PSD_01_TO_FAILURE]
                    Reset counter: 167
                    Mileage: 6607 km
                    Date: 2019.10.09
                    Time: 20:03:34
                    Control Module temperature: 56 °C
                    Outside air temperature: 26.5 °C
                    Vehicle speed: 0.00 km/h
                    Voltage terminal 15: 11.7 V
                    Terminal 15 on: 108.9 s
   Component: SAS-GEN 2     H06 0013
   Serial number: 131128200368
   VCID: 6B96C5E28253101762-803E
End----(Elapsed Time: 01:25, VBatt start/end: 11.8V/11.8V. VIgn 11.9V)-----
myounus
Northwest UK
C?ID=321059
Hi
You need to activate 01 Engine byte3 bit 5, 03 ABS byte 26 to either 50 or F0.
downtime
Finland
C?ID=280813
Try this as your ABS coding :
01FA93A134252975037A060181C9A980C92C94C0608195F7B84250884006
Your byte 26 should be fine as you have ACC already. Byte 24 bit 5 & 6 have PLA coding.
