2016 Fabia 3 rear fog lamp coding
CDA
HC580512
Hi, I currently have a 2016 Skoda Fabia 3 in the workshop. The issue I have is the vehicle is left hand drive but requires a fog lamp on the O/S/R of the vehicle as the owner wishes to register the vehicle in the up. I have purchased and fitted a UK spec rear bulb holder but now need to code/adapt the vehicle to allow the fog lamp to work. Any help on which coding to change would be gratefully received. I have checked the long coding helper (09) Central electrics but I am unable to find anything there.
Mike@Gendan
Swansea, UK
C?ID=57030
Hi thanks for the reply but it appears I do not have permission to post attachments currently
You don't need to attach it. Just copy the complete text of the Auto-Scan output and paste it in here, ideally with [ code ] before it and [/ code ] after it (with the spaces in the code tags removed)
CDA
HC580512
Thursday,10,October,2019,10:51:15:51689
VCDS Version: 19.6.2.0 (x64)
VIN: TMBEB6NJ7GZ126270   License Plate: 98RD85
Mileage: 56509km-35113mi   Repair Order:
Chassis Type: NJ-SK26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: TMBEB6NJ7GZ126270   Mileage: 56509km-35113miles
Address 01: Engine (J623-CHYB)       Labels:. 04C-906-020-CHY.clb
   Part No SW: 04C 906 057 AB    HW: 04E 907 309 CB
   Component: R3 1.0l MPI   H20 2707
   Revision: 33H20000
   Coding: 01110052020405080000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM10MPI01104C906057AB 001003
   ROD: EV_ECM10MPI01104C906057AB.rod
   VCID: 65C5E93764A82F6734-8030
4101 - Maximum Engine Speed Exceeded: Engine Warranty VOID!
          P0219 00 [096] - -)
4261 - System Voltage
          P0562 00 [096] - Too Low
Address 03: ABS Brakes (J104)       Labels:. 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08507584151222
   Coding: 41F5247D492533C6091610700051822492CC9008000DCA098F00
   Shop #: WSC 13765 031 00000
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 3779737F8E846DF756-8062
Address 08: Auto HVAC (J301)       Labels:| 6C0-820-045.clb
   Part No SW: 6V0 820 045 A    HW: 6V0 820 045 A
   Component: AC Manuell    H01 0202
   Serial number:  1512041B-0540
   Coding: 100000001000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26.rod
   VCID: 306B48636BEABACF17-8064
Address 09: Cent. Elect. (J519)       Labels:| 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0086
   Serial number: 001588208904
   Coding: 0C0008404215405B43804000400703080000D800510A3500000000000000
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005.rod
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6V1 959 801 B    HW: 6V1 959 801 B
   Component: FHSG DRV  007 0001
   Serial number: 00000000000002800773
   Coding: 011200
8714 - Bulb for Left Fog Lamp
          B121F 15 [008] - Open or Short to Plus
                    Reset counter: 107
                    Mileage: 56509 km
                    Date: 2019.10.09
                    Time: 15:19:06
8970 - Bulb for Right Fog Lamp
          B1220 15 [008] - Open or Short to Plus
                    Reset counter: 107
                    Mileage: 56509 km
                    Date: 2019.10.09
                    Time: 15:19:06
Address 15: Airbags (J234)       Labels:| 6C0-959-655.clb
   Part No SW: 6C0 959 655 K    HW: 6C0 959 655 K
   Component: VW20Airbag743 002 0380
   Revision: --------    Serial number: 003TJ000R9CD
   Coding: 88CCC000000000005C5400CF000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 3B716F4FB2AC4997B2-806E
   Subsystem 1 - Part No SW: -----------    HW: 410 821 512 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00BB1DF141241BQ
   Subsystem 2 - Part No SW: -----------    HW: 410 821 512 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00A91DF1412435K
   Subsystem 3 - Part No SW: -----------    HW: 442 151 912 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00AF1E52A54F1CY
   Subsystem 4 - Part No SW: -----------    HW: 442 151 512 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A000A294A82A667F
   Part No SW: 6V0 920 740 A    HW: 6V0 920 740 A
   Component: KOMBI         205 1420
   Coding: 072401002180000801082A001000000000000000
   ROD: EV_DashBoardVDDMQBAB_SK25.rod
   VCID: 3361476F9AFC81D76A-8066
Address 19: CAN Gateway (J533)       Labels:| 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0086
   Revision: --------    Serial number: 001588208904
   Coding: 030100042F0A640000000000000000010001050000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_013_SK25.rod
   Subsystem 1 - Part No SW: 3V0 919 719 A    HW: 3V0 919 719 A
   Component: E221__MFL-PR6  H02 0150
   Serial number: 000000000A1951081215
   Subsystem 2 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 62348E55122821185237
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: CG1D0551
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW.rod
   VCID: 6DD59117BC5817277C-8038
Address 5F: Information Electr. (J794)       Labels:| 3V0-035-MIB-ENT2.clb
   Part No SW: 6V0 035 871 B    HW: 6V0 035 871 B
   Component: MU-E--ER      852 6490
   Serial number: 03121500012119
   Coding: 03620000BE0000001111000401000A002F0000C40000010000
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW26.rod
   VCID: 36677E7B898E94FF4D-8062
End-------------------------(Elapsed Time: 02:11)--------------------------
South Molton, UK
Have you checked whether the wiring is present to the rear light cluster(s)? When I looked on our previous Fabia (and on an Audi S3 I used to own) there was no wiring to the UK offside for a fog light.
It's probably a good idea to get the WD from erWin for this car ;)
