VW Caddy 2013, Lane Assist Install from 2018, issue with fault code
golfi_vend
Tartu, Estonia
C?ID=195131
Hi,
Did another Lane assist, pretty used to this by now. New windshield, wiring, cover etc.... .
Did also RLS, but that is another story.
I was able to code everything and everything works as supposed to. Lane Assist is OK, HBA is also OK, sign assist works partial because of RNS315 - waiting for DM. What I do not like is 1 fault code in A5-Camera that seems to be related ABS. Do You think if I put newer ABS it will send needed signal or I really need 7E0 ABS as used in 2016+ Caddys.
I think this Lane Assist camera was also used in Passat NMS which still had MK60EC1 ABS?
PS! If Dana/Sebastian/Niels reading, LCode helper seems to be missing coding description for Caddy.
EDIT: Odis doesn't have suggestions about this fault and doesn't create task for Test Plan.
Wednesday,09,October,2019,20:10:08:39429
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4508.4
Dealer/Shop Name: Tarfor OÜ
VIN: WV2ZZZ2KZDXxxxxxx   License Plate: CADDY LANE INSTALL
Mileage: 174110km-108186mi   Repair Order:
Chassis Type: 2K-VN35 (7N0)
Scan: 01 03 08 09 15 16 17 18 19 25 37 42 44 46 4C 4F 52 56 69 A5
VIN: WV2ZZZ2KZDXxxxxxx   Mileage: 174110km-108186miles
Address 01: Engine (J623-CAYD)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 PC    HW: 03L 907 425 C
   Component: 1,6l R4 CR td H43 8013
   Revision: --H43---    Serial number: 00000000000000
   Coding: 00114016032400080000
   Shop #: WSC 35110 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023PC 003009
   ROD: EV_ECM16TDI02103L906023PA.rod
   VCID: F6A09EF2495DB8FF33-80A2
Readiness: 1110 1000
   Part No SW: 1K0 907 379 BK    HW: 1K0 907 379 BK
   Revision: 00H31001
   Coding: 423C400D092703FA420B02E6901EC041300400
   Shop #: WSC 35110 377 08192
   VCID: FCB48CDA7F71E2AF45-80A8
   Part No SW: 5K0 907 044 GL    HW: 5K0 907 044 GL
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010004002
   ROD: EV_ClimaAutoBasis_VW32.rod
   VCID: FBB68FC6727FE5974C-80AE
   Part No SW: 5K0 937 085 R    HW: 5K0 937 085 R
   Component: BCM PQ35 B+   021 2068
   Revision: BB021001
   Coding: 411A0A3A80251A6B0888008A910000E407F172885223A960648020000040
   Shop #: WSC 63672 002 1048576
   VCID: C2C832225D15545F4F-8096
   Subsystem 1 - Part No: 1T1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer 12091  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 5K7 955 559 B  Labels: 5K7-955-559.CLB
   Component: RLS 080515 03  37  0059
   Coding: 0228DD
   Part No SW: 2H0 959 655 B    HW: 2H0 959 655 B
   Component: VW10Airbag01P H07 0013
   Revision: --------    Serial number: 003HN009XDCO
   Coding: 000000000000000000000000000000003150
   VCID: B32667E61AAFEDD7D4-80E6
   Serial number: 3495RRB405P1BBHA79ES
   Serial number: 3505RRB405N1BBHALGI0
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Revision: --------    Serial number:  90849LII000CO
   Coding: 1082160000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: F2A8A2E22535A4DF1F-80A6
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0255998
   Coding: 820000
   Part No SW: 2K0 920 875 L    HW: 2K0 920 875 L
   Component: KOMBI         H05 0705
   Coding: 181A01
   VCID: B83C50CA03C90E8FE1-80EC
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 C
   Component: Standheizer     044 4840
   Revision: 00044000    Serial number: 09024302000000
   Coding: 0031012
   Shop #: WSC 00999 444 64523
   VCID: B52259FEDCDBF3E7FA-80E0
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AJ
   Component: J533  Gateway H51 1682
   Revision:   H51       Serial number: 18011400F15339
   Coding: 357400
   Shop #: WSC 00015 115 00050
   VCID: FBB68FC67A7FE5974C-80AE
   Component: IMMO          H05 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: EA98BA820DE56C1FA7-80BE
   Part No SW: 3C0 035 279 N    HW: 3C0 035 279 N
   Component: RNS315-EU   H55 0319
   Serial number: VWZAZ2M5501773
   Coding: 000004110200130000029001
   ROD: EV_RNS315EUV2UDS.rod
   VCID: AE107692F18DC03FBB-80FA
   Subsystem 1 - Part No: 3AA 919 866 A
   Component: EUR_E_V8  0069
   Part No SW: 1T0 959 701 T    HW: 1T0 959 701 T
   Component: Tuer-SG         009 2109
   Coding: 0000048
   VCID: C8DC200ABB297E0F91-809C
   Part No: 1K0 909 144 R
   Component: EPS_ZFLS Kl. 140    3501
   Revision: 00H22000
   Shop #: WSC 00046 000 00000
   VCID: B93A55CEF0C317871E-80EC
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AJ
   Component: EZE_2         H51 1682
   Coding: 00000000
   VCID: EFAEAB963E078937F0-80BA
   Part No SW: 1T0 959 702 R    HW: 1T0 959 702 R
   Coding: 0000048
   VCID: C7DE2336B637717798-8092
   Revision: 3A001001    Serial number: 00008030287892
   Coding: 410D000100000000
   VCID: B02C68EAE3B9D6CFA9-80E4
   Part No SW: 3Q0 980 654 L    HW: 3Q0 980 654 A
   Component: MQB_B_MFK     H06 0610
   Serial number: 14091711P12027
   Coding: 0103040201000401002200018080880090000E00002000
   ROD: EV_MFKBoschMQBB_002_VW36.rod
   VCID: C0CC382A5B19464F59-8094
0033 - Databus
          [mBremse_8_BR8_Laengsbeschl_Qbit]
                    Reset counter: 25
                    Mileage: 174111 km
                    Date: 2019.10.09
                    Time: 00:25:09
                    Control Module temperature: 39 °C
                    Outside air temperature: 18.0 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 138.6 s
                    Voltage terminal 15: 11.6 V
                    mid: 02 DD
                    Status of camera: operational
                    Engine_Running_Info: 1
                    Software_Info_4: 0
                    Software_Info_3: 1
                    Software_Info_2: 6
                    Software_Info_1: 0
End----(Elapsed Time: 01:07, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
NEtech
Denmark
C?ID=56995
downtime
Finland
C?ID=280813
Have you researched is the ABS block sw upgradeable? If you upgrade to block to higher index?
golfi_vend
Tartu, Estonia
C?ID=195131
I know older software compatibility updates, but I have no idea about these ones.
Anyway official file is only for 0152 from 015x series.
Next one would be 0166 and from there 0174 and 0175. But I don't know if this results in brick or functioning ABS.
PS! 0164,0166,0172 and 0174 are all supported to flash 1K0907379CC 0175.
downtime
Finland
C?ID=280813
^ Probably too risky. 16x onwards looks to be H46 so different HW already.
Is there any functionality restrictions due to this error? It’s missing message and those usually don’t cause any bigger issues.
I cannot comment on the risk levels of creating a brick but I agree with downtime on the H46 topic. All of the scans we have with SW# 1K0 907 379 CC are: ESP MK60EC1 H46 0175
I also searched for Component: ESP MK60EC1 H__ 0175 (excluding H46 and the part number) but the results were identical. All SWL 0175s were also H46
golfi_vend
Tartu, Estonia
C?ID=195131
I've driven 10km since retrofitting, but one who knows me, knows that I dislike such messages and auto-scan has to be fault free. :)
I'll search the possibility of connecting 379CC ABS pump to test if it resolves this fault. Also the possibility to even code it in older vehicle.
downtime
Finland
C?ID=280813
I fully understand you. I’m the same, I just hate it if there’s errors in the memory :)
golfi_vend
Tartu, Estonia
C?ID=195131
Finally cleared.
I was suspecting the issue was with too old ABS. Bought newer abs, but didn't get to point of changing it. It's PITA with DPF in the way.
But as my cold idle was getting even worse i decided to investigate and was hoping not the worst with these engines. - But it was, 3rd conrod was bent.
After lowering the engine, it was the most convenient way to replace ABS on this car. But, the line thought some effort needs to be put into job. They were stuck..... But nothing little patience doesn't solve.
Many hours later, car with new conrod, ton of gaskets and new thermostat, engine is back in and now every fault is cleared. With MK60EC1 coding-magic I have also HHC and XDS now.
I might also update ABS SW due to those TPMS issues that I think were described in Dana's car thread.
Thursday,16,January,2020,22:33:48:39429
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4513.4
VIN: WV2ZZZ2KZDX   License Plate: MINU CADDY HILLHOLD TPMS XDS
Mileage: 181170km-112573mi   Repair Order:
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 4C 4F 52 5F 69 A5
VIN: WV2ZZZ2KZDX   Mileage: 181170km-112573miles
   VCID: F6A09EF2495DB8FF0D-80A2
Readiness: 0110 0000
   Part No SW: 1K0 907 379 BM    HW: 1K0 907 379 BM
   Component: ESP MK60EC1   H46 0164
   Revision: 00H46001
   Coding: 423C400D092703FA420B02E6901EC041A10C0032
   Shop #: WSC 00020 790 12345
   VCID: FEB086D2696DF0BF55-80AA
   Revision: 00001004
   Coding: 0010004002
   VCID: FBB68FC6727FE59772-80AE
   Revision: BB021001
   VCID: C2C832225D15545F71-8096
   Coding: 009795
   Coding: 0228DD
   VCID: B32667E61AAFEDD7EA-80E6
   Part No SW: 5K0 953 501 CS    HW: 5K0 953 569 AL
   Component: LENKS.MODUL   016 0162
   Revision: FF010042    Serial number: 20141113201093
   Coding: 308A240000
   ASAM Dataset: EV_SMLSNGVOLWS A01004
   ROD: EV_SMLSNGVOLWS.rod
   VCID: FDB281DE6C6BEBA74C-80A8
   Coding: 820000
   Part No SW: 2K5 920 886 E    HW: 2K5 920 886 E
   Component: KOMBI         H04 2010
   Coding: 110A010000
   Shop #: WSC 65498 595 77785
   VCID: B83C50CA03C90E8FDF-80EC
   Coding: 0031012
   VCID: B52259FEDCDBF3E7C4-80E0
   Coding: 357400
   VCID: FBB68FC67A7FE59772-80AE
   Component: IMMO          H04 2010
   VCID: EA98BA820DE56C1F99-80BE
   Coding: 0000048
   VCID: C8DC200ABB297E0FAF-809C
   Revision: 00H22000
   VCID: B93A55CEF0C3178720-80EC
   Coding: 00000000
   VCID: EFAEAB963E078937CE-80BA
   Coding: 0000048
   VCID: C7DE2336B6377177A6-8092
   Part No SW: 5C0 035 680 G    HW: 5C0 035 680 G
   Component: MU-S-ND-ER    H41 0472
   Serial number: VWZAZ2U1626823
   Coding: 06330701BE0000001111000100090A001F010004002001008E
   ROD: EV_MUStd4CTSAT_SK26.rod
   VCID: A50289BEA47B836774-80F0
   Subsystem 1 - Part No SW: 5NA 919 866 AG    HW: -----------
   Component: ECE AS 2020  --- 1310
   VCID: B02C68EAE3B9D6CF97-80E4
   Coding: 0103040201000401002213018080880090000E00002000
   VCID: C0CC382A5B19464F67-8094
End----------(Elapsed Time: 01:03, VBatt start/end: 13.9V/13.9V)-----------
downtime
Finland
C?ID=280813
Looks good! Good to hear that now everything works as it should.
golfi_vend
Tartu, Estonia
C?ID=195131
Due current events in the world, I also had some more time on my hands.
Finally updated ABS to latest version. Although I didn't have any issues, there are TPI-s that resolve some of them.
1K0907379BM 0164 -> 1K0907379CC Software 0175
1K0907379BS 0166 -> 1K0907379CC Software 0175
1K0907379BR 0172 -> 1K0907379CC Software 0175
1K0907379CB 0174 -> 1K0907379CC Software 0175
Sign Assist is also resolved, which I had issues with. Seems like Caddy dataset doesn't enable SignAssist in Baltic region as I checked pricelist for all these countries and none of them have this option. Also while I traveled to Germany with this car during Christmas last year, it worked fine there, but kept giving error of being limited once I got back. Loaded Touran dataset and seems to work OK now.
Also different is SWCM which I "borrowed back" for my Golf. :)
Thursday,09,April,2020,20:14:08:63851
VCDS Version: 20.4.0.1 (x64)  HEX-NET2 CB: 0.4523.4
Dealer/Shop Name: LeVWFreaks.eu
VIN: WV2ZZZ2KZDX   License Plate: CADDY ABS FLASH
Mileage: 185410km-115208mi   Repair Order:
VIN: WV2ZZZ2KZDX   Mileage: 185410km-115208miles
   ROD: EV_ECM16TDI02103L906023B_003.rod
   VCID: 76BE8D905848AB0B79E-8022
Readiness: 0110 1000
   Part No SW: 1K0 907 379 CC    HW: 1K0 907 379 CC
   Component: ESP MK60EC1   H46 0175
   Revision: 00H46001
   Shop #: WSC 00046 123 12345
   VCID: 75BC8A9C45CEA013704-8020
   Revision: 00001004
   Coding: 0010004002
   VCID: 7BA89CA4636AF663060-802E
   Revision: BB021001
   VCID: 42D62140448047AB056-8016
   Coding: 009795
   Coding: 0228DD
   ROD: EV_AirbaVW10BPAVN750.rod
   VCID: 333874840BBAFE239E0-8066
   Part No SW: 5K0 953 501 CH    HW: 5K0 953 569 L
   Revision: FF010041    Serial number: 20120601101792
   Coding: 308A240000
   Shop #: WSC 00020 999 12345
   VCID: 72B6B1803420B72B556-8026
   Coding: 820000
   Coding: 110A010000
   ROD: EV_Kombi_UDS_VDD_RM09_005_VW31.rod
   VCID: 382243A812DC1D7BAB2-806C
   Coding: 0031012
   VCID: 353C4A9C094EE013B04-8060
   Coding: 357400
   VCID: 7BA89CA463EAF663060-802E
   VCID: 6A86A9E01CF07FEBED6-803E
   Coding: 0000048
   VCID: 48C233686EBC6DFBDB2-801C
   Revision: 00H22000
   VCID: 392446AC2556047354C-806C
   Coding: 00000000
   VCID: 6FB0B8F427929AC3BA8-803A
   Coding: 0000048
   VCID: 47C0305463A26283D28-8012
   Component: MU-S-ND-ER    H41 0475
   Coding: 06330701BE0000001111000100090A001F0100C4002001008E
   ROD: EV_MUStd4CTSAT_VW32.rod
   VCID: 251C9ADCB56E9093004-8070
   VCID: 30327B88FA2CC53BE32-8064
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| User\3Q0-980-65X-A5.lbl
   ROD: EV_MFKBoschMQBB_002.rod
   VCID: 40D22B484A0C55BB132-8014
End----------(Elapsed Time: 01:06, VBatt start/end: 13.5V/13.2V)-----------
fernando60
Italy
C?ID=302168
Hi a question but how did you manage to update the ABS? because I wanted to change the ABS for sid assist but here in Italy nobody wants to change it if there is the possibility to update mine I would be very happy
