2005 Audi A6 C6: After coding euro tails -> fuel lid failure
corrado-correr
C?ID=50225
Hi guys,
First time poster, long time Ross-Tech user. Till now, I had never come across a problem that didnt already have a solution here. So, thanks for that!
I have a US-spec 2005 A6 Sedan. The car originally came with SAE spec LED taillights. I've sense changed them out with OEM euro LED tail lights.
I want to code the new tail lights to blink the turn signal independent of the brake lights. I can and have successful done this with VCDS by subtracting 4096 (SAE Rear Lights) from the Central Convenience module coding.
Unfortunately when i do this there is an additional undesired affect, now the fuel cap door pops open every time i unlock the car. I only want my fuel door to open when i press the button on the driver door.
There's an option in VCDS for "+4194304 = Fuel Lid Unlock via Driver Door Button" but when i try to add this I get an error that the codding is not accepted.
FYI, I found this thread: Link. In it this guy says...
No. 20: Fuel tank flap control
When the bit is set the fuel tank flap is unlocked via a button in the driver's door (USA vehicles). When the bit is not set the fuel tank flap is locked and unlocked via the central locking.
YZ Note
The fuel tank flap control is only codeable as from control unit software version 0120. If software version 0120 is not yet installed in the control unit, select Fuel tank flap lock/release via central locking.
This probably means I have the older sw and will not be able to code the euro tail lights as i want them without the funky fuel lid behavior.
My question is: does anyone have any experience with alternate coding I can try? Is there an alternate WSC?
So far I've tried:
-4096 SAE Rear Lights (PR-A8U) --> fuel lid failure
-4096 SAE Rear Lights (PR-A8U) and -131072 Highline (LED Rear Lights) --> fuel lid failure
-4096 SAE Rear Lights (PR-A8U) and +4194304 Fuel Lid Unlock via Driver Door Button --> coding not accepted.
Here are a few links to threads on similar topics but without a solution, or a solution that doesn't work for me.
https://forums.ross-tech.com/showthread.php?9927-05-Audi-A6-aftermarket-led-tail-lights-retrofit
https://forums.ross-tech.com/showthread.php?5591-A6-4F-full-LED-Tail-Light-retrofit
Here is my full auto scan:
Tuesday,08,October,2019,19:58:16:00426
VCDS Version: 19.6.2.0 (x64)
VIN: WAUDG74F55N056396   License Plate: 0KYZ06
Mileage: 230820km-143424mi   Repair Order:
Chassis Type: 4F (4F0)
Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 42 46 47 4F 52 53 55 56
          61 62 72 76 77
VIN: WAUDG74F55N056396   Mileage: 230820km-143424miles
Address 01: Engine (AUK)       Labels:. 06E-910-559-BKH.clb
   Part No SW: 4F2 910 559 B    HW: 4F1 907 559 A
   Component: 3.2l V6 FSI         0030
   Revision: --H15---    Serial number:
   Coding: 0000000000000000
   Shop #: WSC 02116 444 64487
   VCID: 2B5553708A049A1722-807E
               P1653 - 008 -  - Intermittent
                    Fault Frequency: 40
                    Mileage: 227753 km
                    Date: 2019.08.02
                    Time: 16:08:57
                    RPM: 736 /min
                    Mass Air / Rev.: 130.8 mg/str
                    Temperature: 94.5°C
                        Idle
                    Load: 16.5 %
000773 - Cylinder 5
               P0305 - 007 - Misfire Detected - Intermittent
                    Fault Status: 00000010
                    Reset counter: 6
                    Mileage: 229688 km
                    Date: 2019.09.02
                    Time: 10:42:35
                    RPM: 864 /min
                    Mass Air / Rev.: 179.9 mg/str
                    Temperature: 31.5°C
                        Idle
                    Time: 51.2 s
   Part No SW: 4F1 910 156 H    HW: 09L 927 156
   Component: AG6 09L 3.2 FSI USA 0020
   Revision: --H01---    Serial number:        0055481
   Coding: 0001002
   Shop #: WSC 02335 785 00200
   VCID: 2959A97880F88807D0-807C
Address 03: ABS Brakes        Labels: 4F0-910-517.clb
   Part No SW: 4F0 910 517 E    HW: 4F0 614 517 A
   Component: ESP8 quattro    H03 0010
   Coding: 0004511
   VCID: 2643A24491E6A77FFD-8072
                    Fault Status: 01101000
                    Reset counter: 136
                    Mileage: 230824 km
                    Date: 2019.10.08
                    Time: 19:56:09
                    Hex Value: 0x0280
                    Hex Value: 0x4082
                    Hex Value: 0x0000
                    Hex Value: 0x0095
                    Hex Value: 0x00FF
   Part No SW: 4F0 910 852     HW: 4F0 905 852 B
   Component: FBSAUDIC6 ELV   H31 0220
   Revision: 31050601    Serial number: 10601100628238
   Coding: 0000011
   Shop #: WSC 02116 444 82885
   VCID: 63C5FB50A2541257DA-8036
   Subsystem 1 - Part No: 4F0 910 132 L
   Component: FBSAUDIC6 EZS   H05 0020
   Subsystem 2 - Part No: 4F0 910 220 A
   Component: FBSAUDIC6 IDG   H35 0040
Address 07: Control Head        Labels: 4F0-910-7xx-07-H.clb
   Part No SW: 4F0 910 729 B    HW: 4E0 035 729
   Component: Interfacebox    H43 0750
   Revision: 00000000    Serial number: 360IL047505640
   Coding: 0000003
   VCID: 285FAC7C9BF2B10FCF-807C
   Component: Bedienteil MMIC6H01 0060
   Subsystem 2 - Serial number: 00000000582836
   Subsystem 3 - Serial number: 0114.11.060000000100011362ÿ
   Subsystem 4 - Serial number: 011362ÿ
Address 08: Auto HVAC        Labels: 4F0-910-043.clb
   Part No SW: 4F0 910 043     HW: 4F1 820 043 J
   Component: KLIMABETAETIGUNGH11 0110
   Revision: 00000023    Serial number: 00000000065527
   Coding: 0524326
   VCID: 5BB5C3B09A242A9792-800E
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 136
                    Mileage: 230824 km
                    Date: 2019.10.08
                    Time: 19:56:14
                    Temperature: 21.0°C
   Part No SW: 4F0 910 279     HW: 4F0 907 279
   Component: ILM Fahrer      H14 0080
   Coding: 0013123
   VCID: 66C3E2445166677F3D-8032
   Subsystem 1 - Part No: 4F1 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiC6  H05 0150
   Coding: 00062736
   Shop #: WSC 02335
   Subsystem 2 - Part No: 4E0 910 557   Labels: 8K0-955-559.CLB
   Component: REGENLICHTSENSORH10 0050
   Coding: 00141886
   Shop #: WSC 02335
   Part No SW: 4E0 910 111 D    HW: 4E0 035 111 A
   Component: CD-Changer      H44 0340
   Revision: 00000000    Serial number: AUZ5ZBD6018178
   VCID: 1A3B86B4D59E139F49-804E
Address 15: Airbags        Labels: 4F0-910-655-8R.clb
   Part No SW: 4F0 910 655 B    HW: 4F0 959 655 A
   Component: 56 AIRBAG AUDI8RH28 0310
   Revision: 09H28000    Serial number: 00359D072YB+
   Coding: 0013622
   Shop #: WSC 22102 444 84485
   Subsystem 1 - Part No: 4F0 910 339
   Component: BF-Gewichtsens. 002 0040
   Subsystem 2 - Serial number: 6332CSME051E5E639
   Subsystem 3 - Serial number: 6342CSME05624C61+
   Subsystem 4 - Serial number: 6351HSME043A094C9
   Subsystem 5 - Serial number: 6361HSME042D4C205
   Subsystem 6 - Serial number: 6371VSME041E131DK
   Subsystem 7 - Serial number: 6381VSME0420052FC
   Part No SW: 4F0 910 549     HW: 4F0 953 549 A
   Component: Lenksäulenmodul H07 0230
   Revision: 00H07000    Serial number: 90025042590240
   Coding: 0002021
   Component: Lenkradmodul    H05 0080
Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
   Part No SW: 4F0 910 900 A    HW: 4F0 920 950 M
   Component: KOMBIINSTR. M73 H09 0460
   Revision: 00200000    Serial number: 4I21290A4
   Coding: 0067203
   Shop #: WSC 16732 002 1048576
   VCID: 1E338AA4C9B67FBFB5-804A
Address 19: CAN Gateway        Labels:. 4F0-910-468.clb
   Part No SW: 4F0 910 468 A    HW: 4F0 907 468 B
   Component: Gateway         H09 0030
   Revision: 09          Serial number: 08008049250162
   Coding: ECFE73C41B1104
   VCID: 275DAF4096ECBE77C6-8072
Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 793 B
   Component: TSG FA          H10 0020
   Revision: 00000000    Serial number: 7W%
   Coding: 0035435
Address 46: Central Conv.        Labels:. 4F0-910-289.lbl
   Part No SW: 4F0 910 289 E    HW: 4F0 907 289 E
   Component: Komfortgeraet   H14 0090
   Revision: 00900014    Serial number: 01001051570000
   Coding: 0424125
   VCID: 2C57506C8F0A9D2F2B-8078
   Component: LIN BACKUP HORN H02 1301
                    Fault Status: 01101100
                    Reset counter: 136
                    Mileage: 192381 km
                    Date: 2015.11.23
                    Time: 12:54:01
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 136
                    Mileage: 210896 km
                    Date: 2004.06.03
                    Time: 12:04:40
Address 47: Sound System        Labels: 4F0-910-223-BO.lbl
   Part No SW: 4F5 910 223 B    HW: 4F5 035 223 C
   Component: DSP-High C6     H14 0220
   Revision: PROD_01     Serial number: 00000000200040
   Coding: 0000016
   VCID: 224BBE54FDCE5B5F91-8076
   Part No SW: 4F0 910 280     HW: 4F0 907 280 A
   Component: ILM Beifahrer   H09 0050
   Revision:             Serial number: 00000000035314
   Coding: 0001114
   VCID: 5EB3CAA489363FBFF5-800A
Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
   Part No SW: 4F0 910 793 B    HW: 4F0 959 792 B
   Component: TSG BF          H10 0020
   Revision: 00000000    Serial number: d%
   Coding: 0035435
Address 53: Parking Brake        Labels: 4F0-910-801.clb
   Part No SW: 4F0 910 801 D    HW: 4F0 907 801 B
   Component: EPB  CEFC0090   H05 0090
   Revision: --H05---
   Coding: 0005021
   VCID: 2149B158F8C8404788-8074
02432 - Supply Voltage for Left Parking Brake Motor (V282)
            011 - Open Circuit - MIL ON
                    Fault Status: 11101011
                    Reset counter: 188
                    Mileage: 214976 km
                    Date: 2018.12.02
                    Time: 21:02:28
                    Voltage: 12.42 V
                    Count: 116
   Part No SW: 4F0 910 357 A    HW: 4F0 907 357 A
   Component: AFS 1           H03 0010
   Coding: 0000016
   Shop #: WSC 02325 785 00200
   VCID: 2447B84CE7DA556FE3-8070
   Subsystem 1 - Part No: NOSUBSYSTEM
   Component: AFS-Modul links
   Subsystem 2 - Part No: NOSUBSYSTEM
   Component: AFS-Modul rechts
02071 - Local Databus
                    Fault Status: 11100100
                    Reset counter: 136
                    Mileage: 230824 km
                    Date: 2019.10.08
                    Time: 19:56:11
   Part No SW: 4E0 910 541 C    HW: 4F0 035 541
   Component: TUNER EU/US/RDW H41 0290
   Revision: 00000000    Serial number: 352JT047565163
   Coding: 0000002
   VCID: 204FB45CF3C2494F87-8074
Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
   Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
   Component: ENERGIEMANAGER  H11 0490
   Revision: 00000000    Serial number: 00000000059937
   Shop #: WSC 02116 444 53299
   VCID: 2345BB50E2D452579A-8076
   Subsystem 1 - Part No: 4F0 915 105 C
   Component: von VA0  2410020536
   Coding: 344630393135313035432056413032343130303230353336
   Shop #: WSC 00000 384 00290
Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 795
   Component: TSG HL          H09 0010
   Coding: 0035370
   VCID: 69D9E9784078480710-803C
Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
   Part No SW: 4F0 910 795     HW: 4F0 959 794
   Component: TSG HR          H09 0010
   Coding: 0035370
   Part No SW: 4F0 910 283     HW: 4F0 919 283
   Component: Parkhilfe 4-Kan H09 0020
   Revision: --.--.--    Serial number: 11730427402512
   Coding: 0001206
   VCID: 61C9F158B8480047C8-8034
   Part No SW: 4F0 910 336 H    HW: 4E0 862 335
   Component: Handyvorb2      H10 1130
   Revision: 00000000    Serial number: 00000007502533
   Coding: 0010900
End-------------------------(Elapsed Time: 02:21)--------------------------
United States
The factory condition scan, or clip of 46 with the factory coding, may shed light on this but the SWL of that module is 0090 so the rejected coding may be normal per your source.
Coding: 0424125
Providing they aren't all zeros the WSC, Importer and Equipment numbers don't matter.
I located a Canadian market 4F25NL Audi A6 Quattro 3,2 Sedan with PR-Code 8SL Taillight assemblies with diodes (LED) (for NAR) and that 46 module was:
> Coding: 0423997
If you haven't already done so I would try that exact value. If it resolves your fuel door problem but creates new issues related to the new tails please include the factory value in your next reply.
corrado-correr
C?ID=50225
Thanks for the reply Dana.
I tried Coding 0423997, but that just removes the comfort functions with remote. Coding 0423997 - 4096 SAE Rear Lights (PR-A8U) gets the tail lights working like I want but the fuel lid still opens when the car is unlocked every time like before.
My WSC, Importer and Equipment numbers are non-zero, I have them set to: 02335 785 00200.
Is there any other place in Adaptions where the Fuel Lid Unlock via Driver Door Button can be added?
I know (for example) on the B7 on channel 61 there are these options:
+1 = Rear Mechanical Window Regulators (PR-4R5) installed
+2 = Footwell Lights (PR-QQ1) installed
+4 = Fuel Tank Lid/Flap Release Button (PR-4K2/4K8) installed
In the C6 channel 61 is only window open/close comfort options.
