The teardrop wiping on my front wiper irritates me so I found the option in the Central Electric Module to make the "Teardrop Wiping For Front Wiper Inactive". I have this tickbox checked. I also have a tickbox for "Tear Wiping Active" unchecked. The changes were saved it was effective for the first two or three times I used the windscreen washer and then it returned to normal giving me the teardrop wipe. Why can't i disable this permanently?
I have a similar issue with the Stop/Start, another piece of technology I would really like to disable but so far it keeps coming back. In the Engine module I have "Start/Stop Function Active" unchecked but it still operates. How do I permanently turn it off?
Also, pretty much every time i carry out an autoscan it comes up with some fault or other, but they differ all the time and I have no issues with the car, the attached scan being a good example. Should these random fault codes bother me?
Many thanks
Adam
Thursday,03,October,2019,13:04:22:45944
VIN: WAUZZZ4G8CN165114 License Plate:
Mileage: 137976km-85734mi Repair Order:
Chassis Type: 4G-AU57 (4G5)
Scan: 01 03 05 08 09 10 15 16 17 19 3B 42 44 46 52 53 56 5F 62 69
72
VIN: WAUZZZ4G8CN165114 Mileage: 137976km-85734miles
Address 01: Engine (J623-CLAB) Labels:. 059-907-401-V2.clb
Part No SW: 4G0 907 311 D HW: 4G0 907 401
Component: 3.0TDI EDC17 H37 0003
Revision: 53H37---
Coding: 12194012052401020000
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ECM30TDI0114G0907311D 001007
ROD: EV_ECM30TDI0114G0907311D.rod
VCID: 2412E429EE50C8A78DF-8070
Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 H HW: 4G0 907 379 H
Component: ESP PREMIUM H09 0361
Coding: 07A08701E005E1808B00
ASAM Dataset: EV_ESPPremiAU57X 004028
VCID: 36362E6148CC4A3723B-8062
Part No SW: 4H0 907 064 BG HW: 4H0 907 064 BG
Component: BCM2 2.0 H31 0333
Coding: 03993006000000000000
VCID: 6FB8DB0577963BFF20D-803A
Serial number: 2312000061223016
Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 H HW: 4G0 820 043 H
Component: KLIMA 2 ZONEN H10 0064
Serial number: 16041200040477
Coding: 3622000820
ASAM Dataset: EV_AirCondiBasisUDS 002040
ROD: EV_AirCondiBasisUDS_002.rod
Part No SW: 4H0 907 063 BJ HW: 4H0 907 063 B
Component: BCM1 2.0 H12 0111
Revision: 13012002 Serial number: 00000001278715
Coding: 69080011C034AF600405008300005F5F0F9D860827080101000004402000
VCID: 71BCDD7D61A22D0F369-8024
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 120309 H35 0080
Serial number: 120317110303
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 20136956
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 HW: 4G0 941 531
Component: E1 - LDS H07 0044
Serial number: 04 04 2012 00000709
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H03 0002
Serial number: 43788226000000000001
Reset counter: 18
Mileage: 137867 km
Date: 2019.10.01
Time: 18:48:00
Address 10: Park/Steer Assist (J446) Labels:| 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 Q HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0060
Revision: 11001001 Serial number: 55901209300226
Coding: 090207
ASAM Dataset: EV_EPHVA18AU57X0000 004005
ROD: EV_EPHVA18AU57X0000_004.rod
VCID: 40DA48B91A08F487897-8014
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H43 0040
Revision: -------- Serial number: 003JG007Y8JK
Coding: 30323436313330303537554A305234473053
Serial number: 3575HRB406718NQOG0N+
Serial number: 3585HRB406918NQO39EV
Serial number: 3515JRB40104UHL8E9OV
Serial number: 3525JRB405H184CO3GD7
Serial number: 3554VRB400M4UHPKGP5$
Serial number: 3564VRB400M4UHPKIHA$
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20120413001477
Coding: 000015
VCID: 303A1879AA286407797-8064
Subsystem 1 - Part No SW: 4G0 951 528 D HW: 4G0 951 528 D
Component: E221 - MFL H09 0009
Part No SW: 4G8 920 982 K HW: 4G8 920 982 K
Component: TDieGb H79 0416
Revision: 28460177 Serial number: 658030412596020
Coding: 33A4100003012600010000
ASAM Dataset: EV_RBD4K 004045
ROD: EV_RBD4K_AU57.rod
VCID: 3C223C4976E09067D5F-8068
Part No SW: 4G5 907 468 A HW: 4G5 907 468
Component: J533--Gateway H10 0028
Revision: -------- Serial number: 00000000457606
Coding: 00CD077D00
ASAM Dataset: EV_GatewPkoUDS 001013
VCID: 333017755BBE5F1F045-8066
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790807976
Voltage stabilizer:
Subsystem 2 - Part No SW: 8K0 959 663 D HW: 8K0 959 663
Component: J532_DCDCStab H23 0021
Serial number: 14011200000000000029
Part No SW: 4G0 907 637 HW: 4G0 907 637
Component: SARA 3D H02 0009
Revision: -------- Serial number: EJ1BPA32021L0N0
ASAM Dataset: EV_SARA 009017
ROD: EV_SARA_009.rod
VCID: 6B80CF15430EC7DF0C5-803E
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011C16204001620002080002
VCID: 42DE42B11484E6979F3-8016
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0026467717
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009.rod
VCID: 323E1271A4A456170F3-8066
Revision: 00002001 Serial number: 0174000125
Coding: 013B062220B9044083200904000104000000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 41DC4DBD1182FD8F869-8014
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000316200
ROD: EV_ParkiBrake_VW51.rod
VCID: 2A0E0A118C741ED7B73-807E
Part No SW: 4G0 035 056 E HW: 4G0 035 056
Component: Radio U STD H60 0093
Revision: AB001007 Serial number: 230DQ0C7556510
Coding: 010003020100000001
VCID: 2310E735EBDECF9FF45-8076
Part No SW: 4G0 035 670 H HW: 4G0 035 670 H
Component: H-BNT-EU H49 0526
Revision: -------- Serial number: 190DM0C7501016
Coding: 050101010003A1ED05008B3E00000003000001000000000000
VCID: 280AF01992F82CC7A17-807C
Subsystem 1 - Part No: 8R0 060 884 DF
Component: EUR 2016 2204
Subsystem 2 - Part No SW: 4G0 919 605 B HW: 4G0 919 605 B
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDC94017AAC
Subsystem 3 - Part No SW: 4G2 919 710 C HW: 4G2 919 710 C
Component: E380 BDT C7 H11 0204
Serial number: 90349LD500108
Subsystem 4 - Part No: 8R0 060 961 C
Component: CD-Database 3638
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010814204001620002080002
VCID: 44D244A90E90E8A7ADF-8010
Address 69: Trailer (J345) Labels:. 4G8-907-383-V1.clb
Part No SW: 4G8 907 383 HW: 4G8 907 383
Component: Towbar module H07 0100
Coding: 0100000100000000
Component: TSG HR H04 0212
End----------(Elapsed Time: 01:59, VBatt start/end: 12.2V/12.1V)-----------
Adam
