2015 audi RS3 park break fault
PARandrew
Swansea, UK
C?ID=301543
Hi I have a customer who has replaced the rear break pads himself. However he did not disable the park break with the computer.This has lead to the system losing all of the coding. If anyone can advise me on how to rectify this problem, I would be greatfull.
Wednesday,09,October,2019,11:57:57:35902
VIN: WUAZZZ8VXGA902986   License Plate:
Chassis Type: 8V-AU37 (5Q0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 42 44 52 55 5F BB BC
VIN: WUAZZZ8VXGA902986   Mileage: 91092km-56601miles
Address 01: Engine (------CZGB)       Labels:. 07K-907-309-V1.clb
   Part No SW: 8V0 907 404     HW: 07K 907 309 C
   Component: 2.5l R5/4V TF H52 0003
   Revision: NKH52---
   Coding: 12250032252601032600
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM25TFS0118V0907404 001004
   ROD: EV_ECM25TFS0118V0907404.rod
   VCID: 76B6EF9D084FFE57E3B-8022
17158 - Databus
          U1123 00 [047] - Received Error Message
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:25:51
                    Engine speed: 0.00 /min
                    Coolant temperature: 73 °C
                    Intake air temperature: 45 °C
                    Voltage terminal 30: 11.920 V
                    Drivetrain coordinator: brake fault status-Bits 0-7: 5
                    Acceleration: 0.000 m/s²
          U0428 00 [032] - -
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:24:31
                    Coolant temperature: 74 °C
                    Intake air temperature: 44 °C
                    Voltage terminal 30: 12.060 V
                    Engine status: COENG_READY
4716 - No Communications with Parking Brake Control Module
          U0128 00 [047] - -
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:24:31
                    selected gear-Bits 0-7: 0
4651 - Implausible Data Received from ESP Control Module
          U0416 00 [047] - -
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:24:31
Readiness: 0010 0001
   Part No SW: 0DL 300 011 D    HW: 0BH 927 711 F
   Component: GSG DQ500     H10 5201
   Revision: 00H10V01
   VCID: 290CF4E18971E1AFBE9-807C
10685 - Databus
          U1121 00 [047] - Missing Message
                    Fault Frequency: 15
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:24:32
                    Clutch: primary stat: New
                    selected gear: GANG_R
                    Driving position: P
                    Engine torque: -40 Nm
                    Control Module temperature: 31 °C
                    Accelerator position: 18.4 %
                    DTC memory status: 73
   Part No SW: 8V0 907 379     HW: 8V0 907 379
   Component: ESC           H42 0020
   Revision: 00000000    Serial number: 62635000000208
   Coding: 000000000000000000000000000000000000000000000000000000
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 061003
   ROD: EV_Brake1UDSContiMK100IPB_061.rod
   VCID: 015C8C415181C9EFC69-8054
17 Faults Found:
0195 - Control module not coded
          U1013 00 [137] - -
          [ECU marked as Not Configured because vehicle ID is invalid]
                    Reset counter: 188
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:26:35
          C1017 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 188
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:26:35
          C1079 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 188
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:26:35
0279 - Brake Pressure Sensor 1
          C107A 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 188
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:26:35
0295 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 188
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:26:35
0297 - Steering Angle Sensor
          B1168 F2 [008] - Not Initialized
                    Reset counter: 228
                    Date: 2019.10.06
                    Time: 09:16:20
8279 - Engine Control Module Incorrectly Coded
          P1612 00 [137] - -
                    Reset counter: 190
                    Date: 2019.10.06
                    Time: 09:16:20
8280 - Engine Control Module Incorrectly Coded
          P1612 00 [137] - -
                    Reset counter: 190
                    Date: 2019.10.06
                    Time: 09:16:20
8290 - Coding Not Possible
          U10BC 00 [137] - -
          [FCAN: Unplausible VIN number]
                    Reset counter: 188
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:16:25
8292 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [FCAN: 4 wheel driven is not coded but Allrad_03 message is received]
                    Fault Frequency: 11
                    Reset counter: 190
                    Date: 2019.10.06
                    Time: 09:16:20
8306 - Databus
          U1122 00 [137] - Implausible Message
                    Reset counter: 188
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:16:25
8308 - Control Module Incorrectly Coded
          U1014 00 [009] - -
          [FCAN: StartStop not coded but MO_StartStopp_Status not equal 0]
                    Reset counter: 190
                    Date: 2019.10.06
                    Time: 09:16:20
8311 - Control Module Incorrectly Coded
          U1014 00 [137] - -
          [FCAN: Damper not coded but Fahrwerk_01 message received]
                    Fault Frequency: 11
                    Reset counter: 190
                    Date: 2019.10.06
                    Time: 09:16:20
8314 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [009] - -
          [FCAN: Coding of ESP and TSK does not fit together]
                    Fault Frequency: 12
                    Reset counter: 190
                    Date: 2019.10.06
                    Time: 09:16:20
32848 - Control Module for Electric Parking Brake
          C10E2 F1 [137] - Switches/Motors Detected
                    Reset counter: 188
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:26:35
32901 - Right Parking Brake Motor Voltage Supply
          C100E 13 [009] - Electrical Malfunction
                    Reset counter: 188
                    Date: 2019.10.06
                    Time: 09:16:20
32951 - Control Module for Electronic Parking Brake
          C10E2 54 [137] - Missing Calibration / Basic Setting
                    Reset counter: 188
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:26:35
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000749403
   Coding: 03100005000000001000000000001000
   VCID: 333016895BBDAB7F045-8066
   Serial number: AAD88DC7000000000001
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061527400523
   Coding: 07041C46C24106FD03844004B31C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 094C946169B181AF9E9-805C
   Subsystem 1 - Part No SW: 8V2 955 119 A    HW: 8V2 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 150830  042 0580
   Serial number:         150920123355
   Coding: 0A47F7
   Serial number: 20724112
   Coding: 00006C
   Serial number: 11 07 2015  00001011
   Serial number: 000000000ZY152360L58
   Serial number: 00000000000063823734
262912 - Sensor for Anti-Theft Alarm System
          B1330 F5 [009] - Alert Emergency Activation Stage 1
                    Reset counter: 187
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 00:01:00
   Revision: --------    Serial number: 39391526803845
   Coding: 0010050011
   VCID: 43D046490B1D1BFF945-8016
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 188
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:18:00
13637426 - Databus
                    Reset counter: 188
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:18:00
Address 14: Susp. Elect. (J250)       Labels: 8V0-907-376.clb
   Part No SW: 8V0 907 376 E    HW: 8V0 907 376 E
   Component: DAEMPFUNGS-SG H09 0072
   Serial number:       250915031
   ASAM Dataset: EV_AudiMagneRide 002003
   ROD: EV_AudiMagneRide.rod
10522629 - Databus
          [init value steer angle]
                    Reset counter: 228
                    COM: 07 0F 06 B2 00 00 03 43 00 00
                    Voltage terminal 30: 12.1 V
                    Terminal 15 status via CAN: Terminal 15 on
                    Steering angle: Not available
                    Steering rate: 0 rad/s
                    AMR state: 0
                    Damping adjustment indicator lamp: OFF
                    ESP automatic engagement: not activated
                    Fall-back level: 00 00 90 20
10522630 - Databus
          [old value steer angle]
                    Reset counter: 228
                    AMR state: 0
10526728 - Databus
          [standing time not available]
                    Reset counter: 227
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 00:01:17
                    COM: 07 00 06 B2 00 00 13 D3 00 00
                    Voltage terminal 30: 11.9 V
                    AMR state: 6
                    Damping adjustment indicator lamp: On
                    Time since terminal 15 off: Not available
                    Outside air temperature via CAN: 12.5 °C
                    ESP automatic engagement: activated
                    Fall-back level: 00 01 D0 20
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    012 0361
   Serial number: 003M2R14KH8I
   Coding: 98CCC000008000005C5400CA00C800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 4BC06E69234DD3BF6C5-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 000 110 15
   Serial number: 357670000002F4FCB618
   Subsystem 2 - Part No SW: -----------    HW: 480 000 110 15
   Serial number: 35867000000EE4FCB61K
   Subsystem 3 - Part No SW: -----------    HW: 480 403 009 15
   Serial number: 3516502A71CF2D74F13Q
   Subsystem 4 - Part No SW: -----------    HW: 480 403 009 15
   Serial number: 3526502A51CF2DA1E2BX
   Subsystem 5 - Part No SW: -----------    HW: 480 400 109 15
   Serial number: 3556502B71CF2D82336N
          B13BC F2 [137] - No function
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:25:11
   Part No SW: 8V0 953 521 EH    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0110
   Revision: --------    Serial number: 29091508490869
   Coding: A418
   ROD: EV_SMLSKLOMQB_010_AU37.rod
   VCID: 045285554E93DCC7EDF-8050
   Part No SW: 8V0 920 971 N    HW: 8V0 920 971 N
   Component: KOMBI         H02 6420
   Coding: 27AD080A3B8026000104EA001000000000000000
   Shop #: WSC 06029 002 104857
   VCID: 48CA5165323B38A7417-801C
16776967 - Databus
          [EPB_02 keine Kommunikation]
                    Reset counter: 187
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 15:19:32
16776973 - Databus
          [RKA_01 keine Kommunikation]
                    Reset counter: 187
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 15:19:32
9456128 - Engine Control Module (ECM) not authorized
          B104A 00 [009] - -
                    Fault Frequency: 9
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 00:01:12
9634288 - Transmission Control Module
          B1301 F0 [009] - Not Authorized
                    Fault Frequency: 9
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 00:01:12
   Part No SW: 5Q0 907 530 AF    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1224
   Revision: --------    Serial number: 0003962416
   Coding: 030100043F0860005B000268B80B00000001010000000000000000000000
   ROD: EV_GatewLear_013.rod
   VCID: 75B4E8911549F54FEA1-8020
   Subsystem 2 - Part No SW: 8U0 951 528 C    HW: 8U0 951 528 C
   Serial number: 22 09 2015  B0058434
   Subsystem 3 - Part No SW: 8S0 915 181     HW: 8S0 915 181
   Component: J367-BDMHella  H10 9052
   Serial number: 4077867803
   Part No SW: 0CQ 907 554 C    HW: 0CQ 525 130
   Component: Haldex4Motion H52 7754
   Serial number: HA1-00007.08.15
   Coding: 0601
   VCID: 45D45851052925CFBA1-8010
17505 - Databus
          [Bremsensteuergerät - TO -- EPB_01]
                    Fault Frequency: 11
                    Reset counter: 190
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 09:22:53
   Serial number: 220915BIL05115
   Coding: 005D8A204001040000001002
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8103
   VCID: 392C24A179D1512FCE9-806C
19204 - Databus
          [ESP_02 Botschaft - SNA_Check]
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 15:19:42
                    Motor status: 00
                    Supply voltage: 12.00 V
                    Temperature: 25.0 °C
                    KFC: 4B
                    KFA: 00 04
                    Environmental conditions: 21
                    uioUdNotFilt_xdu16: 12.17 V
                    uAdSensI_SwitchedKl30_xdu16: 12.16 V
                    ASC_CTRL_GET_ILWS_ERR_FLAGS: 00
12289 - Supply voltage
          [Abschaltung wegen zu niedriger Versorgungsspannung Abschaltung aufgrund von Unterspannung (<5.5V für 3ms: KL50=0]
                    Motor status: 00
                    Supply voltage: 6.75 V
                    Temperature: 15.0 °C
                    KFC: 30
                    KFA: 00 01
                    uioUdNotFilt_xdu16: 5.11 V
                    uAdSensI_SwitchedKl30_xdu16: 5.11 V
26885 - Comfort limitation
          C10D7 00 [008] - -
          [Speicherinkonsistenz im Errorhandler]
                    Motor status: 00
                    Supply voltage: 0.00 V
                    Temperature: 80.0 °C
                    KFC: 69
                    KFA: 00 05
   Serial number: 110915BIA07923
   Coding: 005D82204001040000001002
   VCID: 42DE434D140712F79F3-8016
   Component: AFS-ECU       H01 0110
   Coding: 01A600002B200200
   Shop #: WSC 59998 002 1048576
   ROD: EV_HeadlRegulAFSMQBMLB.rod
   VCID: 3FD84AB967F57F1FF0D-806A
   Subsystem 1 - Part No SW: 7PP 941 472 K    HW: 7PP 941 472 K  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H07 7570
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
Address 5F: Information Electr. (J794)       Labels:| 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 874 C    HW: 8V0 035 874 B
   Component: MU-S-ND-ER    042 0461
   Serial number: A7F00210150709
   Coding: 017303010000000021111102000A00002F0006260100010006
   Shop #: WSC 06029 002 1048576
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 3C223DB576E36407D5F-8068
   Subsystem 1 - Part No SW: 8V0 919 866 C    HW: -----------
   Component:  ECE 2015  --- 0045
   Subsystem 2 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30DQX9
   Multimedia Operating Unit:
   Subsystem 3 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: C1000001081500020149
          U1111 00 [009] - -
          [Tire pressure monitoring (0x07) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 187
                    Mileage: 91092 km
                    Date: 2019.10.06
                    Time: 00:01:18
                    Voltage terminal 30: 11.8 V
                    BAP-BAP_Function_ID: 02
   Serial number: 050915BI405025
   Coding: 004D82204001040000001002
   Serial number: 050915BI405022
End----(Elapsed Time: 01:27, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Mike@Gendan
Swansea, UK
C?ID=57030
From a search for scans of RS3s with the same part number ECU, I found this:
999CF08DAA9915AC4097096BC398B20EC4990F55A80290C34D7023
May not be the exact options but hopefully should be a start!
I'm pretty sure MK100IPB modules have pieces of the VIN obfuscated and embedded in them, similar to the way that MK60EC1 modules do, so I don't think one can just copy the code from another car, even if the equipment and configuration of the car is identical.
Mike@Gendan
Swansea, UK
C?ID=57030
Well that's a bit of a bummer :(
Reflash job at a dealer?
