2005.5 A4 B7 Avant Quattro Automatic TiP - Cranks but wont start died while driving.
   #21
PnwQuattro
Oregon, USA
C?ID=382634
Sorry it took me a few days to get back to this. Between work and school and a sick wife Ive been short on time the last few nights.
So I think my battery is about to bite the dust I couldnt keep it above 12v long enough to reflash the stock tune. It failed many many times but I finally got it tonight with it on jumper cables from another car.
I dont know where to find the N276 in the blocks I think it was 117
The g28 is reading the RPMS with crank
G40 i couldnt find.
New scan before crank (after reflash to stock)
Monday,14,October,2019,18:00:24:43608
VIN: WAUKF68E05A438025   License Plate:
          67 69 75 76 77
VIN: WAUKF68E05A438025   Mileage: 180260km-112008miles
   Part No SW: 8E0 910 115 B    HW: 8E0 907 115 C
   Component: 2.0l R4/4V TFSI     0130
   Revision: --H02---    Serial number:
   Coding: 010C010A190F0120
   Shop #: WSC 00191 264 15243
   VCID: 2019E785B6C94687E97-8074
Readiness: 0110 0101
   Part No SW: 8E1 910 156 A    HW: 09L 927 156
   Component: AG6 09L 2,0TFSI USA 0020
   Revision: --H01---    Serial number:        0078784
   Coding: 0000002
   Shop #: WSC 06325 000 00000
   VCID: 2517F691A9EBA3AF9A1-8070
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
                    Fault Status: 00110000
                    Mileage: 180260 km
                    (no units): 30.0
                    (no units): 60.0
                    Temperature: 14.0°C
                    T.B. Angle: 0.0°
18258 - Powertrain Data Bus
            P1850 - 000 - Missing Message from ECU - Intermittent
                    Mileage: 180260 km
18289 - Powertrain Data Bus: Missing Message
            P1881 - 001 - Acceleration Request - Intermittent
                    Fault Status: 00110001
                    Mileage: 180260 km
   Part No SW: 8E0 910 517 C    HW: 8E0 614 517 BB
   Component: ESP8 quattro    H04 0180
   Coding: 0004528
   VCID: 270BFC99D3E7B1BFA8D-8072
                    Fault Frequency: 12
                    Hex Value: 0x0000
                    Hex Value: 0x0722
                    Hex Value: 0x00FF
                    Hex Value: 0xFF96
                    Hex Value: 0x00FF
                    Fault Status: 00101011
                    Reset counter: 14
                    Hex Value: 0x3D40
                    Hex Value: 0x4006
                    Hex Value: 0x00FF
                    Hex Value: 0xFFAB
                    Hex Value: 0x00FF
                    Fault Frequency: 35
                    Hex Value: 0x0000
                    Hex Value: 0x4222
                    Hex Value: 0x00FF
                    Hex Value: 0xFF93
                    Hex Value: 0x00FF
18265 - Load Signal
                    Hex Value: 0x0000
                    Hex Value: 0x6222
                    Hex Value: 0x00FF
                    Hex Value: 0xFF9D
                    Hex Value: 0x00FF
   Part No: 8E0 820 043 AM
   Component:   A4 Klimaautomat   2728
   Coding: 00000
   Shop #: WSC 26130
   VCID: 6C81C3B50F9152E705F-5160
            27-00 - Implausible Signal
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  USA 0304
   Coding: 11023
   Shop #: WSC 65536
   VCID: 3B2330E93A7F055FDC5-4B00
01494 - Bulb for Parking Lamps; Left (M1)
            30-00 - Open or Short to Plus
01498 - Bulb for Parking Lamps; Right (M3)
Address 0F: Digital Radio        Labels: 8E0-035-593-XM.lbl
   Part No SW: 8E0 035 593 E    HW:
   Component: SDAR XM
   Revision:             Serial number: AUZ4Z7D5019110
   VCID: 2B0300A9CF2F95DF4C5-5184
02788 - Internal Communications Error
   Part No SW: 8E0 959 655 H    HW: 8E0 959 655 H
   Component:    Airbag 9.41  H10 3230
   Revision: 91H10323    Serial number: 0036N0001LKV
   Coding: 0032607
   VCID: 3C2133F53A610267D5F-8068
   Subsystem 1 - Part No: 8E0 910 339 B
   Component: BF-Gewichtsens. 02  0070
   Serial number: 6332DRB4011C4714D
   Coding: 00032607
   Subsystem 2 - Serial number: 6342DRB4011CD19AV
   Subsystem 3 - Serial number: 6352ARB4003BDBEA1
   Subsystem 4 - Serial number: 6362ARB4003BEA83W
   Subsystem 5 - Serial number: 63729RB400366A89P
   Subsystem 6 - Serial number: 63829RB400366AD0M
01794 - Control Module - Incorrect Chassis (VIN) Number
                    Reset counter: 99
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0601
   Coding: 02042
   Shop #: WSC 06325
   VCID: 41DF420158936F8F869-4B00
   Part No SW: 8E0 920 981 N    HW: 8E0 920 981 N
   Component: KOMBI+WFS 4     H12 0040
   Revision: 0040        Serial number: 00000000000000
   Coding: 0021261
   Shop #: WSC 26130 444 84535
   VCID: 38292FE50E492E47317-5184
   Coding: 0021261
Address 36: Seat Mem. Drvr        Labels: 8E0-959-760.lbl
   Part No: 8E0 959 760
   Component: Sitzmemory R2 F     0305
   Coding: 00002
   VCID: 71BFD2C12883BF0F369-4B3C
            79-00 - Please Check Fault Codes
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8E0 035 192 E    HW: 8E0 035 192 E
   Component: RNS-E US        H52 0020
   Revision:      02S    Serial number: AUZBZ7D0000558
   Coding: 0309137
   Shop #: WSC 26027 444 53511
   VCID: 2615F19DD4CDA8B793B-5184
                    Reset counter: 34
                    Date: 2017.07.12
                    Time: 18:41:47
                    Voltage: 12.70 V
                    Reset counter: 34
                    Date: 2017.07.12
                    Time: 17:46:53
                    Voltage: 12.70 V
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
   Part No: 8E0 959 433 BT
   Component: Komfortgerát T7B    3132
   Coding: 12092
   Shop #: WSC 06325
   VCID: 04518B150701BAA7EDF-4B00
   Subsystem 1 - Part No: 8E1959801G
   Component: Tõrsteuer.FS BRM 1406
   Subsystem 2 - Part No: 8E1959802G
   Component: Tõrsteuer.BF BRM 1406
   Component: Tõrsteuer.HL BRM 1406
   Subsystem 4 - Part No: 8E0959802E
   Component: Tõrsteuer.HR BRM 1406
12 Faults Found:
00962 - Alarm via. Tilt Sensor
            35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
            35-00 - -
01369 - Alarm triggered by Hood Switch
            35-00 - -
01374 - Alarm triggered by Terminal 15
            35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
            35-00 - -
01574 - Alarm triggered by Door Contact Switch; Rear Right
            35-00 - -
01573 - Alarm triggered by Door Contact Switch; Rear Left
            35-00 - -
00956 - Key 2
            35-10 - - - Intermittent
            62-10 - No or Incorrect Adjustment - Intermittent
01705 - Selection Switch for Mirror-Adjust (E48)
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Coding: 0000019
   Shop #: WSC 26131 444 92477
   VCID: 2615F19DD4EDA8B793B-8072
   Subsystem 1 - Part No: 8E0 941 329 A
   Component: AFS-Modul links H05 0030
   Subsystem 2 - Part No: 8E0 941 329 A
   Component: AFS-Modul rechtsH01 0020
                    Fault Frequency: 9
                    Reset counter: 39
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0309137
                    Reset counter: 34
                    Date: 2017.07.12
                    Time: 18:41:47
                    Voltage: 12.70 V
                    Reset counter: 34
                    Date: 2017.07.12
                    Time: 17:46:53
                    Voltage: 12.70 V
                    Mileage: 655350 km
                    Count: 65535
                    Clock: 255:255
End----------(Elapsed Time: 04:45, VBatt start/end: 13.2V/13.2V)-----------
Scan after crank (stock tune)
Monday,14,October,2019,18:23:16:43608
          67 69 75 76 77
   Coding: 0000002
18265 - Load Signal
                    Mileage: 180260 km
                    (no units): 30.0
                    (no units): 60.0
                    Temperature: 14.0°C
                    T.B. Angle: 0.0°
                    Mileage: 180260 km
                    Mileage: 180260 km
   Coding: 0004528
                    Fault Frequency: 12
                    Hex Value: 0x0000
                    Hex Value: 0x0722
                    Hex Value: 0x00FF
                    Hex Value: 0xFF96
                    Hex Value: 0x00FF
                    Reset counter: 14
                    Hex Value: 0x3D40
                    Hex Value: 0x4006
                    Hex Value: 0x00FF
                    Hex Value: 0xFFAB
                    Hex Value: 0x00FF
                    Fault Frequency: 39
                    Hex Value: 0x0000
                    Hex Value: 0x4222
                    Hex Value: 0x00FF
                    Hex Value: 0xFF93
                    Hex Value: 0x00FF
18265 - Load Signal
                    Hex Value: 0x0000
                    Hex Value: 0x6222
                    Hex Value: 0x00FF
                    Hex Value: 0xFF9D
                    Hex Value: 0x00FF
   Coding: 00000
   Shop #: WSC 26130
   Coding: 11023
   Shop #: WSC 65536
   Component: SDAR XM
   VCID: 2B0300A9CF2F95DF4C5-5160
   Coding: 0032607
   Coding: 00032607
                    Reset counter: 99
   Coding: 02042
   Shop #: WSC 06325
   Coding: 0021261
   Coding: 0021261
   Coding: 00002
   Coding: 0309137
   VCID: 2615F19DD4CDA8B793B-5160
                    Reset counter: 34
                    Date: 2017.07.12
                    Time: 18:41:47
                    Voltage: 12.70 V
                    Reset counter: 34
                    Date: 2017.07.12
                    Time: 17:46:53
                    Voltage: 11.00 V
                    Mileage: 655350 km
                    Count: 2512
                    Clock: 01:04
   Coding: 12092
   Shop #: WSC 06325
12 Faults Found:
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
            35-00 - -
00956 - Key 2
   Coding: 0000019
                    Fault Frequency: 9
                    Reset counter: 35
   Coding: 0309137
                    Reset counter: 34
                    Date: 2017.07.12
                    Time: 18:41:47
                    Voltage: 12.70 V
                    Reset counter: 34
                    Date: 2017.07.12
                    Time: 17:46:53
                    Voltage: 11.00 V
                    Mileage: 655350 km
                    Count: 2512
                    Clock: 01:04
End----------(Elapsed Time: 04:47, VBatt start/end: 12.4V/12.3V)-----------
   #22
NostraJackAss
What about fuses/fuel pump PSI and mechanicals of HPP output with gauge's?
You did say it ran when sprayed.
Sorry to hear about your wife, hope she feels better, I know this dilemma myself!
   #23
PnwQuattro
Oregon, USA
C?ID=382634
I need the RTFB bro I cant figure out how to check pressure at the rail. I know its fuel and I know the LP FP is running. Seems odd that the pump doesnt run when the door opens any more but I can still hear it running when I try to turn the car over.
I know the rail pressures are silly high like excess of 1kpsi right?
I signed up with ErWin and downloaded everything I could find for my car. I found the fuel injection and timing book im gonna dive into that tonight.
PnwQuattro
Oregon, USA
C?ID=382634
Im stuck. Can't figure out what to check next.
Recap-
Car cranks no start
car starts on fuel spray so it's lack of fuel.
Lpfp is running
Fuel filter is brand new.
Hpfp is brand new but I have not checked for pressure after the hpfp.
Can someone tell me how to check out the function of the hpfp?
I don't know what block it is or what that block value should be.
Is there a place to hook up a pressure test rig to the rail or pump?
Is there any other reason why it would crank and not start?
I read on another post that a coolant temp sensor or crank position sensor could cause a no start but I can not confirm.
I got a new battery today and will put it in tonight. Is there something I need to do when I replace the battery?
   #27
Jef
HQ
MVB groups 103 and 106 should have fuel pressure readings. What are those pressures during cranking?
PnwQuattro
Oregon, USA
C?ID=382634
Did you subscribe to Erwin yet and download + print to PDF to follow the trouble tree?
I did subscribe and I downloaded everything that came up when I searched my VIN. I didnt see a "trouble tree" anywhere . I did get a few hundred pages so maybe I missed that . Is that its own document ? A service of erwin? is it inside a certain manual?
   #29
PnwQuattro
Oregon, USA
C?ID=382634
Screenshot key "on"
Screenshot while cranking
   #30
Seems to me that 103.1 is the low-pressure feed and should be at least 2.8 bar.
106.1 should be the rail pressure after the high pressure pump, and 1.3 bar is no pressure at all there.
Bad transfer pump? Just a guess.
NostraJackAss
or
Depends on what IS, IS, & is lift pump returning fuel to tank by faulty fuel filter or installed ass backward from induced FOD?
Jef
HQ
I'm away from my access to technical information, but i suspect your might be able to hit the lift pump with direct battery power. If so, then give that a try and see if you gawd awfulz low fuel pressure gets better. Fuel flilter issues? Is the fuel line up to the engine bay in good condition? No kinks from a floor jack?
So some dummy got dropped off at terminal F and needed to be at gate A10. Got some steps in this morning.
   #33
PnwQuattro
Oregon, USA
C?ID=382634
So I figured it out. I really hate to admit it but in the interest of closing the issue on the forum and in the hopes that it will help someone in the future here goes...
It was the fuel level gauge that got me. Tank was bone dry gauge read half tank. Not sure how to fix that issue yet but the car is running.
Thank you all for trying to help me resolve this issue. I guess the takeaway from this episode is always start with the basics.
   #34
NostraJackAss
Yeah fuel in the tank is a good start.......... :p
You are not alone, it happens even to poor schmucks like me!
I guess "IS" was GAS!
I had a CIS 16V Scirocco about 10 years ago & that when the consumer dropped off he said the tank was filled before drop off and the gauge indeed read as such.
The car was dropped off in July/Aug and it was hot, so hot!, that because the fuel gap was loose, it all literally evaporated an entire full tank!
When I was done installing the engine a month later, it would start and die and it had fuel PSI, so I commenced testing other stuff in fuel distributor and all it was, was no FUEL IN TANK!
Never omit basics and never accept PSI for Fuel volume present!
I'll say it again "VOLUME" you must have it or you are not going anyplace.
BRAKE FLUID/OIL/COOLANT/FUEL..........FLUID MECHANICS
   #35
PnwQuattro
Oregon, USA
C?ID=382634
That makes me wonder.. did someone siphon off her tank while it sat outside the shop overnights or something. Hard to believe a whole tank evaporated but then again I never leave a gas cap open for that long.
Thinking back to my trouble shoot process. I can see where I went wrong but I can also see where I was fooled by the gauge. Taking that reading for granted is now on my list of no no's . When I sprayed it and it fired I should have started with the tank and moved forward. I skipped the tank because the pump was running and the gauge read fine. I never let my car get much past a half tank so I never realized that just below half was empty. I never should've assumed it was ECU related and started fucking around with all that shit.
My thought process when LPF Pump (new) -> Filter (new)-> HPF pump (new)-> Fuses (check) relays (check)------fuck it must be the ECU.
Ill never truly forgive myself but at least I learned a lesson and now have a VCDS. My wife has a 16 tiguan so itll get used more and more here in the future.
NostraJackAss
That was someone doing something underhanded or you just met the results of what happens when you blend gasoline with ethanol & because it's a corrosive!
   #37
Jef
HQ
Well, at least it wasn't a missing fuse. :eek:
And it isn't like any one of us would of guessed that (wonky fuel gauge) off the top of our collective heads. You may feel silly, but don't knock success when you stumble upon it.... all of us have done something like this.... many times.
