Skoda Octavia 2009 L&K 2.0TDI ABS coding missing/deleted
markthespark
C?ID=380519
I'm wondering if it is possible to re-install the coding for an ABS module that has been wiped leaving the code section full of zeros, the unit was working fine until i mistakenly plugged a different instrument module in and the result is the ABS module has lost its coding, I have returned to the original instrument cluster (one problem at a time) any help would be really appreciated, i've included a scan.
Monday,07,October,2019,11:14:45:37288
VIN: TMBAE61Z092066779   License Plate: PF09FFG
Mileage: 63510km-39463mi   Repair Order: 1st test
Chassis Type: 1Z-SK35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 36 42 44 46 52 55 56 62 72
          77
VIN: TMBAE61Z092066779   Mileage: 63510km-39463miles
25-Immobilizer -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 021 TC    HW: 03G 906 021 AN
   Component: R4 2,0L EDC G000SG  2048
   Revision: --H11---    Serial number:
   Coding: 0000072
   Shop #: WSC 73430 790 00999
   VCID: 73B3DF1197BC321FC45-8026
005659 - Glowplug for Cylinder 2 (Q11)
               P161B - 000 - Open Circuit
                    Mileage: 63517 km
                    Date: 2014.02.27
                    Time: 00:00:26
                    RPM: 840 /min
                    Voltage: 14.21 V
                    Bin. Bits: 00001100
                    Temperature: 12.6°C
                    Bin. Bits: 10110000
   Part No SW: 1K0 907 379 AE    HW: 1K0 907 379 AE
   Component: ESP MK60EC1   H35 0106
   Revision: 00H35001
   Coding: 000000000000000000000000000000000000
   VCID: 75B7E10995C82C2FEA1-8020
00003 - Control Module
                    Fault Status: 01100101
                    Reset counter: 88
                    Mileage: 63516 km
                    Date: 2014.02.20
                    Time: 00:28:12
                    Count: 16391
                    Count: 8192
                    Count: 143
                    Count: 42240
                    Reset counter: 88
                    Mileage: 63516 km
                    Date: 2014.02.20
                    Time: 00:28:12
                    Count: 16391
                    Count: 8192
                    Count: 195
                    Count: 42240
   Part No SW: 3T0 907 044 AC    HW: 3T0 907 044 AC
   Component: Climatronic   122 0203
   Revision: 00003001
   Coding: 0100000000
   ASAM Dataset: EV_Climatronic A01001
   ROD: EV_ClimaAutoBasis_SK35.rod
   VCID: 73B3DF119B3C321FC45-8026
13701456 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Steuergerät im Schalttafeleinsatz - kein Signal/Kommunikation]
                    Reset counter: 128
   Part No SW: 1K0 937 087 D    HW: 1K0 937 087 D
   Component: BCM PQ35  H   103 0537
   Revision: 00103 AB
   Coding: 48180AB8F841B1C04008008011001124017000AE626D85605C0440000000
   VCID: 323D1A1524267B170F3-8066
   Subsystem 1 - Part No: 1Z2 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer 21040  22  0601
   Coding: 00D7B7
   Component: RLS 150509 05  54  0402
   Coding: 0730ED
   Subsystem 3 - Part No: 1Z0 951 171
   Component: Innenraumuebe  008 5101
   Subsystem 4 - Part No: 1K8 951 605
   Component: LIN BACKUP HO  H09 9002
Address 10: Park/Steer Assist (J446)       Labels:. 1Z0-919-475-V1.clb
   Part No SW: 1Z0 919 475     HW: 1Z0 919 475
   Component: PARKHILFE 4K  H06 0004
   Revision: --------    Serial number: 66640912820298
   VCID: 7EA5FE25A0FE6F77BBB-802A
   Component: Q8 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD2DCFGL
   Coding: 0020792
   VCID: 3D273929E178B46FE21-8068
   Subsystem 1 - Serial number: 6332MSME473417568
   Subsystem 2 - Serial number: 6342MSME47425658D
   Subsystem 3 - Serial number: 6351HSME00286216Z
   Subsystem 4 - Serial number: 6361HSME002E27485
   Part No SW: 1K0 953 549 CF    HW: 1K0 953 549 CF
   Component: J0527           055 0111
   Coding: 0000732
   VCID: 78A9E83D8EDA5147F17-802C
   Subsystem 1 - Part No: 3T0 959 537   Labels: 3C8-959-537.CLB
   Component: E221__MFL-URO   H07 0011
   Coding: 00000130
   Part No SW: 1Z0 920 943 D    HW: 1Z0 920 943 D
   Component: KOMBI         H21 0109
   Coding: 410F00
   Shop #: WSC 73430 031 00999
   ROD: EV_Kombi_UDS_VDD_RM09_004_SK34.rod
   VCID: 3A2D3235FCD68357C73-806E
   Part No SW: 1K0 907 530 S    HW: 1K0 907 951
   Component: J533__Gateway   H16 0210
   Revision:   H16       Serial number: 3400K0951202D5
   Coding: E9A1FF06000612001303
   VCID: 372B2B01C3449E3F38D-8062
                    Reset counter: 88
                    Mileage: 63515 km
                    Date: 2014.02.20
                    Time: 18:23:26
                    Reset counter: 128
   Component: IMMO          H21 0109
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Part No SW: 5N0 035 342 B    HW: 5N0 035 342 B
   Component: SG EXT.PLAYER H13 0084
   Revision: A1001003    Serial number: 7667421721
   VCID: 2615F64518EE17B793B-8072
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1102
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F3B13613B1456FF60D-807A
   Part No SW: 1T0 959 701 AA    HW: 1T0 959 701 AA
   Component: Tuer-SG         009 2108
   Coding: 0005118
   VCID: 76B5E60584CE2737E3B-8022
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H15000
   Part No SW: 1T0 959 702 S    HW: 1T0 959 702 S
   Coding: 0005118
   VCID: 48C958FDBEBAE1C7417-801C
   Component: AFS-Steuergeraet    0142
   Coding: 1507610
   VCID: 34311C0DD23275271DF-8060
   Coding: 00000023
   Subsystem 2 - Part No: 7L6 941 329 B  Labels: 3D0-941-329.CLB
   Coding: 00000023
   Part No SW: 1Z0 035 156 F    HW: 1Z0 035 156 F
   Component: BOLERO        008 0053
   Revision: 0A001001    Serial number: SKZ1Z3I8158712
   Coding: 090004000001
   VCID: 35372109D5486C2F2A1-8060
                    Reset counter: 88
                    Mileage: 63515 km
                    Date: 2014.02.20
                    Time: 18:31:57
   Part No SW: 5K0 959 703 A    HW: 5K0 959 703 A
   Coding: 0000144
   Shop #: WSC 73430 790 1012551
   VCID: 323D1A1528267B170F3-8066
   Part No SW: 5K0 959 704 A    HW: 5K0 959 704 A
   Coding: 0000144
   VCID: 33331F11D73C721F045-8066
Address 77: Telephone
End----(Elapsed Time: 01:15, VBatt start/end: 11.9V/11.9V. VIgn 11.7V)-----
langers2k
C?ID=224085
At a guess, the stock coding was probably similar to:
133B401C09280000C81202EB902200823400
However, based on the capabilities of the module I'd use one of these:
133B401C09280000C81202EB902200823500 (adds hill hold control)
133B401C09280000C81202EB902200823508 (adds hill hold control and XDS)
markthespark
C?ID=380519
Thank you very much for your help so far, I entered the codes you have given me and the first code you suggested (add hill control) has been accepted by the module, the flashng ABS and ESP lights have stopped on the instrument cluster but there is a message of ESP fault and a solid ESP light on the cluster, the second code you suggested apparently is "out of range" i wondered if
I have done something wrong? (real newbie) Ive included another scan with the new ABS code.
Friday,11,October,2019,14:13:05:37288
VIN: TMBAE61Z092066779   License Plate: PF09 FFG
Mileage: 63510km-39463mi   Repair Order: scan 2
          77
   Coding: 0000072
                    Fault Status: 01110000
                    Mileage: 63517 km
                    Date: 2014.02.27
                    Time: 00:00:26
                    RPM: 840 /min
                    Voltage: 14.21 V
                    Bin. Bits: 00001100
                    Temperature: 12.6°C
                    Bin. Bits: 10110000
   Revision: 00H35001
   Coding: 133B401C09280000C81202EB902200823500
                    Reset counter: 88
                    Mileage: 63516 km
                    Date: 2014.02.20
                    Time: 00:28:12
                    Count: 16391
                    Count: 8192
                    Count: 195
                    Count: 42240
                    Reset counter: 88
                    Mileage: 63516 km
                    Date: 2014.02.20
                    Time: 00:28:12
                    Count: 16391
                    Count: 8192
                    Count: 143
                    Count: 42240
                    Reset counter: 88
                    Date: 2014.03.03
                    Time: 03:21:24
                    Count: 7
                    Count: 12288
                    Count: 212
                    Count: 41728
   Revision: 00003001
   Coding: 0100000000
          U1111 00 [008] - -
                    Reset counter: 128
   Revision: 00103 AB
   Coding: 00D7B7
   Coding: 0730ED
   Coding: 0020792
   Coding: 0000732
   Coding: 00000130
   Coding: 410F00
                    Reset counter: 88
                    Mileage: 63515 km
                    Date: 2014.02.20
                    Time: 18:23:26
                    Reset counter: 128
   Coding: 0005118
   Revision: 00H15000
   Coding: 0005118
   Coding: 1507610
   Coding: 00000023
   Coding: 00000023
                    Reset counter: 88
                    Mileage: 63515 km
                    Date: 2014.02.20
                    Time: 18:31:57
   Coding: 0000144
   Coding: 0000144
End----(Elapsed Time: 01:15, VBatt start/end: 11.8V/11.8V. VIgn 11.7V)-----
