VW Touran module error
daniel.b
Europe
C?ID=318819
I am asking for help in resolving the problem in VW Touran 2005r. 2.0 TDI
The handbrake icon is constantly lit in the car and a sound signal is triggered. The sensor and wires have been checked.
There is an error in the instrument cluster:
00003 - Control Module
014 - Defective
Can the above mentioned error indicate damage and therefore is the handbrake icon still displayed?
Saturday,05,October,2019,15:09:15:07292
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4441.4
VIN: WVGZZZ1TZ6W061351   License Plate:
Chassis Type: 1T (1K0)
Scan: 01 02 03 08 09 15 16 17 18 19 25 37 42 44 46 47 52 55 56 62
          72 76 77
VIN: WVGZZZ1TZ6W061351   Mileage: 229860km-142828miles
Address 01: Engine        Labels: 03G-906-016-BKD.clb
   Part No SW: 03G 906 016 HK    HW: 028 101 225 1
   Component: R4 2,0L EDC G000AG  7000
   Revision: 12345678    Serial number: VWZ7Z0E2749338
   Coding: 0000078
   Shop #: WSC 01324 785 00200
   VCID: F3A6809E92A9D4D250-80A6
   Part No SW: 02E 300 042 G    HW: 02E 927 770 AE
   Component: GSG DSG         070 0918
   Revision: 04507000    Serial number: 00000509020616
   VCID: 977E940EA69158F28C-80C2
Address 03: ABS Brakes        Labels:. 1K0-614-517-MK60AT.clb
   Part No SW: 1K0 614 517 R    HW: 1K0 614 517 R
   Component: ESP FRONT MK60-AT   0103
   Revision: 00T12001
   Coding: 0037574
   Shop #: WSC 11111 785 00200
   VCID: B620798AC15B81FAB7-80E2
   Part No: 1K0 907 044 BC
   Component: ClimatronicPQ35 066 0606
   VCID: E99AE2F6C0651E02EA-80BC
            000 -  -  - Intermittent
00229 - Refrigerant Pressure
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Revision: 00H37000    Serial number: 00000005114674
   Coding: 038B8F210104100000120C000000000000097F075C
   VCID: AB1658FE0A19CC12D8-80FE
   Subsystem 1 - Part No: 1T0 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW358  012  0401
   Coding: 00065493
   Shop #: WSC 01324
00156 - Control Circuit for Windshield Washer Pump
            006 - Short to Plus - Intermittent
                    Fault Status: 00100110
                    Reset counter: 28
                    Mileage: 229766 km
                    Voltage: 14.30 V
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 C    HW: 1T0 909 605 C
   Component: 02 AIRBAG VW62 0506 1500
   Revision: 09025000    Serial number: 0038BD0F57N%
   Coding: 0012338
   VCID: B5227E86DC5D8AE2BE-80E0
   Part No SW: 1K0 953 549 AG    HW: 1K0 953 549 AG
   Component: J0527           034 0070
   Coding: 0012022
   VCID: F7BEB48E86D1B8F26C-80A2
   Component: E0221           002 0030
   Part No: 1T0 920 872 A
   Coding: 0007101
   VCID: B228459A2D339DDA9B-80E6
            014 - Defective
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 1K0 815 007 AP
   Component: Standheizer     020 3602
   Revision: 00020000    Serial number: 09011559000000
   Coding: 0001112
   VCID: F2A8859AEDB3DDDA5B-80A6
01415 - Recirculating Pump (V55)
                    Fault Status: 00101010
                    Reset counter: 31
                    Mileage: 229869 km
                    Time: 15:04:43
                        Ctrl. Pause
                    Temperature: 76.0°C
                    Temperature: 76.0°C
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001059080F6F
   Coding: 7F3F17CA078002
   VCID: AA185DFA05E3D51A23-80FE
   Component: IMMO            VDD 1212
Address 37: Navigation        Labels: 1K0-919-887-MFD2.lbl
   Part No: 1K0 919 887 F
   Component:      Navigation     0012
   Coding: 0000101
   VCID: BC346BA2FF775BAA41-80E8
            014 - Defective
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX2.lbl
   Part No: 1T0 959 701 C
   Component: Tuer-SG         024 2401
   Coding: 0000244
   VCID: B73E748EC65178F2AC-80E2
   Part No: 1K1 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   Part No SW: 1K0 959 433 AR    HW: 1K0 959 433 AR
   Component: 01 KSG PQ35 G2  010 0101
   Revision: 00010000    Serial number: 00000000000000
   Coding: 009002085103087F2D06840560084F01E0A500
   VCID: 804CDF52D31FFF4A5D-80D4
00956 - Key 2
                    Fault Status: 00100101
                    Reset counter: 15
                    Mileage: 229493 km
Address 47: Sound System        Labels: 3C0-035-456.clb
   Part No: 1T0 035 456
   Component: 08K Audioverst.     0003
   Revision: 00001000    Serial number: 00000000002281
   VCID: EC949BE2CF970B2A91-80B8
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX2.lbl
   Part No: 1T0 959 702 C
   Coding: 0000244
   VCID: B83C77B2CB4F778AA5-80EC
   Part No: 1T0 907 357
   Coding: 0000001
   VCID: F4A4838297A7D3EA49-80A0
Address 56: Radio        Labels:
   VCID: D5E2DE062C1DAAE25E-FFFE
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 06 0214
   Coding: 0000048
   VCID: AF2E4CEE3E01B032F4-80FA
00937 - Switch for Electric Window; Rear Left (E52)
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Coding: 0000048
   VCID: B02C4F92233FAFCAED-80E4
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 02 Einparkhilfe     0101
   VCID: AD1256E6340DC222C6-80F8
Address 77: Telephone        Labels: 1K0-035-729-UNI.lbl
   Part No: 1K0 035 729 E
   Component: CIB PAH  HW 202 SW  0308
   Coding: 0000364
End----------(Elapsed Time: 01:54, VBatt start/end: 12.4V/12.3V)-----------
Jef
HQ
The parking brake (F9) is a simple open/closed switch from the instrument cluster's T36/6 to ground. Is that electrical path to factory design?
014 - Defective
95% of the time, that means said control module is in fact... defective and could be the root issue. Before you swap it out, you need to verify the powers/grounds for the instrument cluster are to factory design, that they can carry electrical load. I've seen plenty of "defective" modules that were caused by rotting terminals, poor grounds and other type issues.
