ABS coding Passat B6
Joe2k
Verified VCDS-User
Romania
C?ID=327551
Hello guys , we try to repair a passat b6 ABS module . The original module has lost communication , so no matter what we tried we coudln't get it to communicate with DIAG . Replaced the unit with the same number on it , and now .. we can't code it ! Please help !
Monday,07,October,2019,13:04:25:40571
VCDS Version: 19.6.0.2 (x64)  HEX-V2 CB: 0.4505.4
VIN: WVWZZZ3CZ9E070185   License Plate:
Mileage: 258370km-160543mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 55 56 62 72 77
VIN: WVWZZZ3CZ9E070185   Mileage: 258370km-160543miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 BL    HW: 03L 907 309
   Component: R4 2.0l TDI G000SG  9977
   Revision: 13H01---    Serial number: VWZCZ000000000
   Coding: 0000072
   Shop #: WSC 18432 807 600232
   VCID: 70B92DB896AAF4373A1-8024
               U1017 - 000 -
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 12:49:27
                    Voltage: 11.25 V
                    Bin. Bits: 11001010
                    Bin. Bits: 00000000
                    (no units): 0.0
               U1017 - 000 -  - MIL ON
                    Fault Status: 11100000
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 12:49:32
                    Voltage: 11.70 V
                    Torque: 219.0 Nm
                    Hex Value: 0xFF00
                    Bin. Bits: 11001010
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --025---    Serial number: 00000795393370
   Coding: 0003368
   Shop #: WSC 00028 028 00001
   VCID: 629D57F0484656A7BC5-8036
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 12:57:06
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00011111
                    Count: 150
                    Hex Value: 0x0000
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 12:57:06
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 12:57:06
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 12:57:06
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 12:57:06
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 12:57:06
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 DA    HW: 3C0 907 044 DA
   Component: ClimatronicPQ46 132 0811
   Revision: 00132023    Serial number: 00000000000000
   VCID: 639352F4575C5FAFB73-8036
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 12:57:07
   Revision: 00H54000    Serial number: 00000008898702
   Coding: E38A8F0700041A00470A00000F000000000B5D435C000120000000000000
   Shop #: WSC 05124 000 00000
   VCID: 3333E2B4A73C8F2F073-8066
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 040908 003  0205
   Coding: 00046997
   Shop #: WSC 05124
   Component: RLS     071008 054  0402
   Coding: 00208936
   Shop #: WSC 05124
   Component: J234__005 VW10 HI   1815
   Revision: 19013000    Serial number: 0039DPKNMWDV
   Coding: 0012341
   Shop #: WSC 05311 000 00000
   VCID: 3B23CA948F6C476FDF3-806E
   Subsystem 1 - Serial number: 6333FTS651252268
   Subsystem 2 - Serial number: 6343FTS615222568
   Subsystem 3 - Serial number: 6353ETS61497VVNJ
   Subsystem 4 - Serial number: 6363ETS6BEH3VVNR
   Part No SW: 3C0 953 549 AD    HW: 3C0 953 549 AD
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C9953507BA
   Coding: 0000014
   VCID: 6E8533C08C9EE2C728D-803A
   Part No SW: 3C0 920 871 E    HW: 3C0 920 871 E
   Component: KOMBIINSTRUMENT VD1 2416
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007105
   Shop #: WSC 11111 111 11111
   VCID: 26150BE064EEEA8790D-8072
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 L    HW: 3C0 907 951
   Component: J533__Gateway   H13 0152
   Revision:   H13       Serial number: 3300P08A01038E
   Coding: F9817F06000602002002
   VCID: 2A0DFFD070F6CEE7B45-807E
   Part No SW: 3C0 959 433 R    HW: 3C0 959 433 R
   Component:    IMMO         042 0383
   Shop #: WSC 45091 001 1048576
   VCID: 392FD09C8550757FCDF-806C
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1517
   Revision: 72009005    Serial number: 00000644488909
   Coding: 0000181
   VCID: 6FBB2EC48B94EBCF23B-803A
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.082 0401
   Revision: 1AH02234    Serial number: 00080810126902
   Coding: 0000258
   VCID: 3635DBA0B44E9A0720D-8062
   Component:    KSG PQ46 ELV 042 0472
   Coding: 0091020051030E763004941570084F0E707C01
   Shop #: WSC 33691 001 1048576
   Component: LIN BACKUP HORN H08 9001
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1517
   Revision: 72009005    Serial number: 00000507488911
   Coding: 0000180
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000153118
   Coding: 0000056
   VCID: 280905D86EFAFCF7A21-807C
                    Fault Status: 11111101
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 12:57:06
                    Voltage: 11.60 V
                    Count: 71
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Component: AFS-Steuergeraet    0133
   Coding: 2311169
   VCID: 3431E1A8A23288171E9-8060
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  012 0029
   Revision: 00000000    Serial number: VWZ1Z2H5799455
   Coding: 0500040004
   Shop #: WSC 05314 000 00000
   VCID: 65974CEC5568219F597-8030
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000626788
   Coding: 0000144
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000641877
   Coding: 0000144
   VCID: 71BF28BC9DA0FD3F35F-8024
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730     HW: 1K8 035 730
   Component: Telefon       H06 3100
   Revision: 00006000    Serial number: 20387920056910
   Coding: 011100
   VCID: 66954BE0A86E2A8750D-8032
End----(Elapsed Time: 01:20, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
NEtech
Denmark
C?ID=56995
As far I can see, Coding should be: 0000274
After coding see wiki here
Joe2k
Verified VCDS-User
Romania
C?ID=327551
Hello , tried , request out of range ..
NEtech
Denmark
C?ID=56995
Try this before coding.
[Options]
[User Interface and Identification]
write numbers for wsc, importer, device no.
For example 12345 123 23456
[Save]
[Close VCDS]
Start VCDS
Joe2k
Verified VCDS-User
Romania
C?ID=327551
No luck , but stupid thing i tried ,.,the coding was 0010000 i substract tpms and said coding accepted but now its looking for AWD . no AWD on this car...
Monday,07,October,2019,15:08:06:40571
Control Module Part Number: 3C0 614 109 AF    HW: 3C0 614 109 AF
  Component and/or Version: J104    C4 440 V2   0015
           Software Coding: 0007952
            Work Shop Code: WSC 00028 028 00001
9 Faults Found:
01324 - Control Module for All Wheel Drive (J492)
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:06:26
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00000000
                    Count: 222
                    Hex Value: 0x0000
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:06:26
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00000000
                    Count: 227
                    Hex Value: 0x0000
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:06:26
                    Hex Value: 0x0000
                    Voltage: 12.00 V
                    Bin. Bits: 00000000
                    Count: 149
                    Hex Value: 0x0000
03201 - Adaptation Overboost
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:06:26
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:06:26
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:06:26
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:06:26
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:06:26
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:06:26
Joe2k
Verified VCDS-User
Romania
C?ID=327551
Also another combo working but another fault insted of AWD ...
Monday,07,October,2019,15:35:09:40571
VCDS Version: Release 19.6.0 (x64) Running on Windows 7 x64
           Software Coding: 0000269
            Work Shop Code: WSC 05311 000 00000
                      VCID: 629D57F0494656A7BC5-8036
Fault Codes have been Erased
8 Faults Found:
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:33:37
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 199
                    Hex Value: 0x0000
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:33:37
                    Hex Value: 0x0000
                    Voltage: 11.75 V
                    Bin. Bits: 00011111
                    Count: 149
                    Hex Value: 0x0000
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:33:37
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:33:37
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:33:37
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:33:37
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:33:37
                    Reset counter: 7
                    Mileage: 258379 km
                    Date: 2019.10.07
                    Time: 15:33:37
Joe2k
Verified VCDS-User
Romania
C?ID=327551
Can someone guide me where can i get the coding ? There is no dealer in 100km radius ...
