Retrofitting LED headlights to 2019 SportWagen S 4motion
Doccutter
C?ID=71879
Hello all,
First time poster, long-time TDI VAG-COM user. I suspect this question has already been asked, but I couldn't find an answer. So I have a base-model Golf SportWagen 4motion, and I'm trying to fit adaptive LED headlights. I know I would obviously need to fit the headlights themselves, and also the rear level sensor. Do we know what other items I might need to make this work? I found the sensor and the cabling here, but it's for a mk7, not a mk7.5 like I have, so I'm not sure it's identical:
https://www.carsystems.eu/vw-auto-leveling-kit-sensor-retrofit-vw-golf-7-5g0-bi-xenon,id1340.html
Can anyone provide me with some guidance of where to go from here? Someone (I didn't get permission to use her name) at Ross-tech was so helpful today, and she explained that I might run into some problems with component protection, do folks know if I'll need to get specially programmed modules to avoid that problem?
Thanks all for your help!
I suspect the leveling module may be different for a 2018+ US car.
I figured that I might need some new modules in the car, I took a scan of the car with my old cable, and came up with this:
Part No SW: 5Q0 937 087 BA HW: 5Q0 937 087 BA
Component: BCM PQ37BOSCH 036 0265
Address 19: CAN Gateway (J533) Labels:. 3Q0-907-530-V1.clb
Part No SW: 3Q0 907 530 AA HW: 3Q0 907 530 C
Component: GW MQB High 521 5366
Address 5F: Information Electr. (J794) Labels:. 5G0-035-MIB-ENT2.clb
Part No SW: 5G6 035 868 HW: 5G6 035 868
Component: MU-E--ER 695 8742
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 5Q4 959 392 M HW: 5Q4 959 392 F
Component: TSG BFS 006 0247
Doccutter
C?ID=71879
Hah! Yeah, I figured that was OK... So the sensor is I think the same, and the wiring as well, right? I figured the module was either different, or incorporated in the new BCM...
OEMplusCC
C?ID=160054
I dont know exactly what is required for your sportwagon but here are some general notes I'm aware of.
7 years ago I retrofitted OEM bi-xenon headlights onto my VW CC. The system contained
Rear level sender
Front level sender(only if car was 4motion V6)
Headlight Control Module
Actual headlights with modules
Cables + Connectors
I'm also playing with an idea to retrofit LED adaptive headlights on my wife's 2019 MQB Tiguan which should be similar setup as your sportwagen.
VW did not really change their setup
Two headlights with control modules
Headlight module
Level Sender
Connectors and wires
As far as I know the headlight module should not be on the Component Protection list. But, it is the best to obtain a used module instead of a brand new module. As far as I know VCDS is not able to provision new modules, so to keep it simple try to find used module. VCDS should be able to change coding and change adaptations if needed.
Compare auto-scan from a sportwagen which came with LED headlights. Plus obtain modules adaptations
Buy one day subscription to erwin https://erwin.vw.com/erwin/showHome.do and download all wiring for the sportwagen
Play "whats the difference" game between auto-scans, adaptations and wiring for few days
Sorry not exactly the info you are looking for but I at least it points you in a good direction.
PS: Also make sure your other modules are compatible. Years ago VW used to install same modules to all trim levels so retrofits were much easier. However they have lot more module variants on the MQB platform which are limited to certain features.
Doccutter
C?ID=71879
Thanks OEM Plus. I was wondering about the BCMs being shared between vehicles. It seems like maybe the suffix shows the difference between trim levels? Mine is a "BA" suffix, and I'm not sure if that's the same across models or if it's a low-line unit. The CANBUS gateway says MQB-HIGH, so I'm assuming that's the same among the models. I suppose what I really need is someone with a 2019 SportWagen SE (which came with the lights) to do a scan. Maybe I'll see if anyone on Vortex has one? Our local dealer doesn't have any SE trim models, it's all Tiguans now, so I don't think I can ask them. As far as I can tell, seems like folks are saying for mk7, there's only rear level sensors. I think you're absolutely right about the used vs new question, but I think the headlights themselves can be new, or perhaps since they have modules built in they have to be used as well?
OEMplusCC
C?ID=160054
People on vortex are usually helpful in providing auto-scans. If you can get auto-scan from sportwagen along with adaptation maps that would be the best.
Also check out reference scans thread here on vortex for auto-scans and adaptations.
I'm not sure if headlights need to be used or not. I always just had used headlights because they are the cheapest, got off wrecked vehicles. Brand new headlights from VW are ridiculously expense.
Doccutter
C?ID=71879
Looks like the BCM is identical between a sportwagen S and an Alltrack SEL with lights. The ECU and CANBUS gateway are different, and there's another module which looks like the AFS leveling controller module, which reads the sensor on the rear shock. So here's the question, do I need to replace the ECU, or since the BCM module is the same, then the modules are basically plug and play?
Mine:
[COLOR=#a52a2a]Address 09: Cent. Elect. (J519)       Labels:. 5Q0-937-08X-V2.clb
   Revision: --------    Serial number:
   Shop #: WSC 00066 790 00249
   ASAM Dataset: EV_BodyContrModul1UDSBosc 019001
   ROD: N/A
   VCID: 7BF5E856F2C41F97F2-802E
   Subsystem 1 - Part No SW: 5G1 955 119 A    HW: 5G1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS    190405  043 0551
   Subsystem 2 - Part No SW: 5Q0 955 559 C    HW: 5Q0 955 559 C  Labels: 5Q0-955-547.CLB
   Component: RLS  051 0205
   Coding: 0008DD
   Subsystem 3 - Part No SW: 5Q1 953 521     HW: 5Q1 953 569
   Component: Lenks.Modul  H03 0170
   Serial number:[/COLOR]
The Alltrack SEL
[COLOR=#008000]Address 09: Cent. Elect. (J519) Labels:. 5Q0-937-08X-V2.clb
Coding: 00000000000000000000000000000000000000000000000000 0000000000
Shop #: WSC 00066 790 00248
ROD: EV_BCMBOSCH_019_VW37.rod
VCID: 7BA3F60F436EBCDF9C5-802F
Component: WWS 180708 043 0551
Component: RLHS 052 0107
Coding: 00A8DD
Steering Column Switch:
Subsystem 4 - Part No SW: 5Q1 953 521 M HW: 5Q1 953 569
Serial number: [/COLOR]
Mine (Sportwagen S)
[COLOR=#a52a2a]Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
   Coding: 0101000830085900FA0000081C0F00000001070000000000000000000000
   Shop #: WSC 00066 790 00166
   ROD: N/A
   VCID: 6ED3D102B1B67A3F45-803A
   Component: 0-00-0d-00-04
   Subsystem 2 - Part No SW: 5G0 959 442 AA    HW: 5G0 959 442 AA  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H18 0052
   Coding: 28FFFF[/COLOR]
Alltrack SEL
[COLOR=#008000]Address 19: CAN Gateway (J533)       Labels:. 3Q0-907-530-V1.clb
   Serial number: 25051900842052
   ROD: N/A
 Coding: 28FFFF[/color]
I think this is the AFS module:
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V2.clb
Part No SW: 3Q0 907 338 C HW: 3Q0 907 338 C
Component: FCM MQB Low 002 0342
Serial number: 26091800840553
Coding: 000000050900211200110F0103000000000000000000000000 0000000000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_MultiModulContiVW48X 002004
ROD: EV_MultiModulContiVW48X_002_VW37.rod
VCID: 3537203725CAAAAF2A1-8061
I doubt the ECU matters to this.
My guess is you need to add the (J745) and do some tweaking in the BCM. Get an Adaptation map from a BCM from a car that came from the factory with the lights you're trying to retrofit.
Doccutter
C?ID=71879
Thanks Uwe! I’ll ask the same person for the adaptation.
Doccutter
C?ID=71879
So the parts list is coming together. Seems like I need the below items to make this work. Now here's a question. Do the halogen lights and the LEDs use the same plug and number of pins, or do I need to make an adaptor to make the pins work?
Level Sensor - Volkswagen (5Q0-512-521-G)
168.00
Wiring for VW Auto Leveling - VW Golf 7 5G0 - Bi Xenon
https://www.carsystems.eu/wiring-for-vw-auto-leveling-vw-golf-7-5g0-bi-xenon,id1277.html
115 Euro
AFS Control UNIT 3Q0 907 338 C (Attaches to BCM)
180.36 NEW, prefer used
https://www.1stvwparts.com/oem-parts/volkswagen-ecu-3q0907338c
Headlights with controllers (New or Used)
That should be it, right? Then the coding process needs to happen, but we may be talking less than 1000USD if using used parts.
