Engine fault codes
msi_kindy
Oman
C?ID=378252
I have run an auto scan on my Jetta 2012 2.0 engine and i got the following codes.
Friday,04,October,2019,00:47:23:45039
VIN: WVWSV1AJ3DM219511   License Plate: 15142 R
Mileage: 183840km-114232mi   Repair Order:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 42 46 4F 52 56 62 72 77
VIN: WVWSV1AJ3DM219511   Mileage: 183840km-114232miles
Address 01: Engine (CBP)       Labels: 06G-906-055-CBP.clb
   Part No SW: 06G 906 055 N    HW: 06G 906 055 B
   Component: 2,0L 85KW       G01 1308
   Revision: T5H06---    Serial number:
   Coding: 0001015
   Shop #: WSC 00015 752 179759
   VCID: 34311C4D723191571DF-8060
               P0300 - 000 -  - Intermittent
                    Mileage: 183777 km
                    Date: 2014.02.23
                    Time: 17:31:01
                    RPM: 2343 /min
                    Load: 85.8 %
                    Speed: 17.0 km/h
                    Temperature: 94.0°C
                    Temperature: 55.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
000769 - Cylinder 1
               P0301 - 000 - Misfire Detected - Intermittent
                    Mileage: 183777 km
                    Date: 2014.02.23
                    Time: 17:31:01
                    RPM: 2343 /min
                    Load: 85.8 %
                    Speed: 17.0 km/h
                    Temperature: 94.0°C
                    Temperature: 55.0°C
                    Voltage: 13.843 V
please help.
NostraJackAss
When is last time a tune up was done with plugs and filters + oil change?
Did you swap coil pack to isolate and see if fault moves?
msi_kindy
Oman
C?ID=378252
Yes, but where should i start. It seems that they are a lot of things that may cause the same issue.
msi_kindy
Oman
C?ID=378252
I do regular oil change every 10,000 km. I never did a tune up of any system in my engine. The fault is intermittent and difficult to catch.
Yes, there are many things that can cause a misfire.
If it were mine, the first thing I would do is pull the coils and spark plugs and inspect both. If the spark plugs have never been replaced, then at 180,000+ km, chances are they need to be replaced.
msi_kindy
Oman
C?ID=378252
Yesterday I took my car to a workshop and he suggested cleaning the injectors. the injectors and throttle were cleaned. The tech said that he has to clear the codes before starting the engine. The engine performance was better in general and I never had the intermittent misfire.
I run the auto scan again this morning and I found several other codes which were not appearing previously, can this be because he rest the fault codes.
Saturday,05,October,2019,14:34:13:45039
Mileage: 184030km-114350mi   Repair Order:
VIN: WVWSV1AJ3DM219511   Mileage: 184030km-114350miles
   Coding: 0001015
   Part No SW: 09G 927 750 LE    HW: 09G 927 750 LE
   Component: AQ 250 6F           2329
   Revision: 00H97000    Serial number:
   Coding: 0000328
   VCID: 7F5B03610BF7820FB0D-802A
Address 03: ABS Brakes        Labels:. 1K0-907-379-MK70M.clb
   Part No SW: 1K0 907 379 AK    HW: 1K0 907 379 AK
   Component: MK70 M MASR         0106
   Revision: 00H35001
   Coding: 0020849
   Shop #: WSC 00066 790 00185
   VCID: 7BA3F7711FEF9E2F9C5-802E
   Part No SW: 3AA 907 044 AF    HW: 3AA 907 044 AF
   Component: Climatronic   H03 0303
   Revision: 00001K02
   Coding: 0010002002
   Shop #: WSC 00066 000 00119
   VCID: 74B1DC4D3E31D157DDF-8020
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0068
   Revision: BC021001
   Coding: 00000A3A802DE3C0408800801000812403010088508089605C8000000040
   Shop #: WSC 00066 000 00000
   VCID: 3E253E65407D4B07FBB-806A
   Subsystem 1 - Part No: 1K8 951 171
00984 - Left Tail Light (M4)
                    Fault Status: 00101010
                    Fault Frequency: 147
                    Reset counter: 245
                    Mileage: 175705 km
                    Date: 2013.11.07
                    Time: 08:43:42
                    Voltage: 14.15 V
Address 10: Park/Steer Assist (J446)       Labels:| 1Q0-919-475.clb
   Part No SW: 5C6 919 475     HW: 7E0 919 475 A
   Component: PARKHILFE 8K  H10 0005
   Revision: --------    Serial number: 84091214200734
   Coding: 108101
   ASAM Dataset: EV_EPHVA18VW3610000 001003
   ROD: EV_EPHVA18VW3610000.rod
   VCID: 71BFD5594123E47F369-8024
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Component: AirbagVW10    013 0613
   Serial number: 003G6M054NPI
   Coding: 00003242
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 323D1A5584A59F670F3-8066
   Serial number: 3572MSME1E75556FZZZ8
   Serial number: 3582MSME2F174267ZZZ
   Serial number: 3516KSME63734D1DZZZ$
   Serial number: 3526KSME65132F1DZZZ-
   Part No SW: 1K5 953 507 T    HW: 5K0 953 549 B
   Revision: --------    Serial number:  90440LG2000M2
   Coding: 0882140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 42DD4A9534052FE79F3-8016
   Component: E221__MFL-TAS  H09 0013
   Serial number: 0422858
   Coding: 820000
   Part No SW: 5C6 920 872     HW: 5C6 920 872
   Component: KOMBI         H07 0705
   Coding: 671B00
   VCID: 6A8DC2356CF517A7773-803E
   Part No SW: 7N0 907 530 T    HW: 7N0 907 530 K
   Component: J533  Gateway H40 1632
   Revision:   H40       Serial number: 13081203290010
   Coding: 351002
   VCID: 41DF4599318334FF869-8014
   Component: IMMO          H07 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   Component: TUER-SG FT    002 0515
   Revision: 13110009    Serial number: 0005297904
   Coding: 0000B5
   Shop #: WSC 01383 790 50316
   VCID: 5BE397F1B3AF7E2FFC5-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1508
   Serial number: 00000006995713
   Coding: 000090
67074 - Motors for Central Locking
          B122B 01 [009] - Electrical Failure
                    Fault Frequency: 93
                    Reset counter: 204
                    Mileage: 166870 km
                    Date: 2019.03.25
                    Time: 19:36:54
67330 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Reset counter: 245
                    Mileage: 166870 km
                    Date: 2019.03.25
                    Time: 19:36:55
   Part No SW: 7N0 907 532     HW: 7N0 907 530 K
   Component: EZE_2         H40 1632
   Coding: 01030100
   VCID: 6FBBD3215797F28F20D-803A
   Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Serial number:     WRH00060NZY
   Coding: 180000
   Component: TUER-SG BT    002 0515
   Revision: 15110009    Serial number: 0005285626
   Coding: 0000B4
   VCID: 5CE194EDB6A17917F5F-8008
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704 B    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1508
   Serial number: 00000006998721
   Coding: 000090
Address 56: Radio (J0503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 5K0 035 190 B    HW: 5K0 035 190 B
   Component: Radio RCD510  005 0234
   Revision: 00000001    Serial number: VWZ1Z3M7249582
   Coding: 05000400040006
   VCID: 2411EC0DCED101D78DF-8070
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Revision: 1B001001    Serial number: 00007662926645
   Coding: 0A01000000010101
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 392F2D7959D36C3FCE9-806C
End----------(Elapsed Time: 01:17, VBatt start/end: 12.5V/12.6V)-----------
I doubt it. Your Gateway through that both 09 and 42 had fault codes in the first (partial) scan you posted. However, I cannot say whether they are identical because you did not post a complete scan at that time.
msi_kindy
Oman
C?ID=378252
What does the address 03 code mean?
You mean the fault code at 03-ABS? That's just a "sympathy code"; the ABS telling you it's aware that the ECU had a fault. Since the ECU no longer does, you should be able to clear that.
msi_kindy
Oman
C?ID=378252
I run the scan today and i still have misfire in my engine. I had my spark plugs replaced but the issue still not solved.
the details of the scan are as below.
Friday,06,March,2020,22:16:15:45039
VCDS Version: 19.6.2.2  HEX-V2 CB: 0.4508.4
Mileage: 197790km-122901mi   Repair Order: 06-03-2020
VIN: WVWSV1AJ3DM219511   Mileage: 197790km-122901miles
   Coding: 0001015
   VCID: 34311C4D723191571DD-8060
   Coding: 0000328
   VCID: 7F5B03610BF7820FB0F-802A
   Revision: 00H35001
   Coding: 0020849
   VCID: 7BA3F7711FEF9E2F9C7-802E
   Revision: 00001K02
   Coding: 0010002002
   VCID: 74B1DC4D3E31D157DDD-8020
   Revision: BC021001
   VCID: 3E253E65407D4B07FB9-806A
01259 - Fuel Pump Relay (J17)
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 3
                    Mileage: 195141 km
                    Date: 2014.07.01
                    Time: 00:00:05
                        Term 15 Off
                    Voltage: 12.60 V
   Coding: 108101
   VCID: 71BFD5594123E47F36B-8024
   Coding: 00003242
   VCID: 323D1A5584A59F670F1-8066
   Coding: 0882140000
   VCID: 42DD4A9534052FE79F1-8016
   Coding: 820000
   Coding: 671B00
   VCID: 6A8DC2356CF517A7771-803E
   Coding: 351002
   VCID: 41DF4599318334FF86B-8014
   Coding: 0000B5
   VCID: 5BE397F1B3AF7E2FFC7-800E
   Slave Driver:
   Coding: 000090
                    Fault Frequency: 117
                    Reset counter: 16
                    Mileage: 166870 km
                    Date: 2019.03.26
                    Time: 19:36:54
                    Reset counter: 126
                    Mileage: 166870 km
                    Date: 2019.03.26
                    Time: 19:36:55
   Coding: 01030100
   VCID: 6FBBD3215797F28F20F-803A
   Coding: 180000
   Coding: 0000B4
   VCID: 5CE194EDB6A17917F5D-8008
   Slave Passenger:
   Coding: 000090
   VCID: 2411EC0DCED101D78DD-8070
   VCID: 392F2D7959D36C3FCEB-806C
End----(Elapsed Time: 01:16, VBatt start/end: 12.4V/12.4V. VIgn 0.0V)------
msi_kindy
Oman
C?ID=378252
I have also replaced the J17 relay but it did not help.
NostraJackAss
You are not showing fault codes for a misfire now or is this a new recent scan, when was last reported misfire?
Did you check intake for leaks or injector for cylinder number 1, in addition a compression check to compare cylinders?
msi_kindy
Oman
C?ID=378252
There was no recorded faults for missfire. However, the engine still have missfire especially when it is cool. I have replaced my spark plugs and had my injectors cleaned and checked.
How do i check the cylinder compression? Can that be done by HEX-V2 ross tech cable?
vwtech
Verified Coal Cracker
Wilkes-Barre, PA
C?ID=7573
I would think you should monitor miss fire in ECU measuring blocks and watch what cyl. are misfiring.
If spark plugs where done then change the plug wires and or coil pack. With good stuff not cheap junk.
All this is a good basic tune up. That fails them go deeper to compression.
Good Luck
