Replacing a haldex controller, gen 5
Amsa303
Sweden
hex7386-0141e7-e0c7d4-901e42-unjahh-57e6
am about to replace my faulty haldex gen 5 controller and was wondering what the coding procedure is.
I can not longer access my haldex controller as it's not responding. MOdule 19 can gateway is reporting a fault 01324, No signal/communication with the awd control module.
I've however found an old autoscan of the car and the question is if it's just a simple matter of copying the code 0201 of old module and coding the new one to the same code?
Old part number is 0AY907554F and the new one is 0AY907554L
Autoscan
 Wednesday,04,July,2018,22:10:14:51156
VCDS Version: 18.2.1.2 (x64)
VIN: WAUZZZ8X6FB001294   License Plate:
Mileage: 37270km-23158mi   Repair Order:
Chassis Type: 8X-AU21 (8U0)
Scan: 01 03 08 09 10 14 15 16 17 19 22 25 42 44 46 52 55 5F 62 72
          A9
VIN: WAUZZZ8X6FB001294   Mileage: 37270km-23158miles
Address 01: Engine (J623-CWZA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 8X0 906 259     HW: 06K 907 425 B
   Revision: --H13---
   Coding: 0A1900322426010B0002
   Shop #: WSC 00046 412 00000
   ASAM Dataset: EV_ECM20TFS0208X0906259 001006
   ROD: EV_ECM20TFS_AU21.rod
   VCID: 7F08993FE63AA8BC5E-802A
23651 - Heater Support Pump
          P16C6 00 [032] - Running Dry
16803 - Implausible Data Received from Instrument Panel Control Module
          U0423 00 [032] - -
   Part No SW: 6C0 907 379 A    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0002
   Serial number: 08502182140302
   Coding: 34DF708B8D2333C14916307200552C0EB1CC920C0013E2090F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100015
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 2D5493777CD6EA2CBC-8078
Address 08: Auto HVAC (J255)       Labels:* Redir Fail!
   Part No SW: 8XA 820 043     HW: 8XA 820 043
   Component: Klima 1 Zone  H01 0010
   Serial number: 00000000261150
   Coding: 6403080890
   ASAM Dataset: EV_AirCondiFrontAU210 007002
   ROD: EV_AirCondiFrontAU210_007.rod
   VCID: 020E10CB95C8C55431-8056
   Part No SW: 8X0 907 063 R    HW: 8X0 907 063 R
   Component: BCM PQ35  M   113 0811
   Revision: AD113811
   Coding: 06000A2CA805E3C0201843E02104084C53F7630A21EF5D22E408878700C5
   Shop #: WSC 00046 000 00000
   VCID: 4B90FDEFEA02C41C82-801E
   Subsystem 1 - Part No SW: 8U0 955 559 B    HW: 8U0 955 559 B  Labels: 8U0-955-559.CLB
   Serial number: 22432198
   Coding: 02005D
   Subsystem 2 - Part No: 8X0 951 177
   Component: DWA-Sensor H0  H01 0020
Address 10: Park/Steer Assist (J446)       Labels:| 8X0-919-475.clb
   Part No SW: 8X0 919 475 Q    HW: 8X0 919 475
   Component: PARKHILFE 4K  H03 0070
   Revision: 11001001    Serial number: 37061408601625
   Coding: 000007
   ASAM Dataset: EV_EPHVA14AU21X0000 003006
   ROD: EV_EPHVA14AU21X0000_003.rod
   VCID: 54A2E6933F3C9BE4D3-8000
Address 14: Susp. Elect. (J250)       Labels:. 6C0-907-359.clb
   Part No SW: 6C0 907 359     HW: 6C0 907 359
   Component: DAEMPFUNGS-SG H04 0007
   Serial number: 01041402000002
   Coding: 82
   ASAM Dataset: EV_SwitcDampeContiTemic 001004
   ROD: EV_SwitcDampeContiTemic.rod
   VCID: 6ADE586B8DB83D1499-803E
   Part No SW: 8XA 959 655     HW: 8XA 959 655
   Component: Airbag10.41   H07 0011
   Revision: --------    Serial number: 003NV0001EA$
   Coding: 30323236303230313835554A304C38584153
   ASAM Dataset: EV_Airba1041BPAAU210 001018
   ROD: EV_Airba1041BPAAU210.rod
   VCID: 183A52A3E3547F84FF-804C
   Serial number: 3554VRB404V2G2O828V3
   Serial number: 3575HRB405N2AO0A3HQR
   Serial number: 3585HRB400250QOUBHT9
   Rear Impact Crash Sensor:
   Serial number: 3515ZRB400Q50RN8SHNX
   Part No SW: 8X0 953 521 D    HW: 5K0 953 569 AE
   Revision: FF010018    Serial number: 20140402200262
   Coding: 1084204000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 3D74A337ACB67AAC0C-8068
   Subsystem 1 - Part No SW: 8U0 951 528 G    HW: 8U0 951 528 G
   Part No SW: 8XA 920 930 C    HW: 8XA 920 930 C
   Component: KOMBI_MEDIUM  H06 0450
   Coding: 13CE01
   ASAM Dataset: EV_Kombi_UDS_VDD_AU10 A04399
   VCID: 4B90FDEFE202C41C82-801E
   Part No SW: 8U0 907 468 Q    HW: 8U0 907 468 G
   Component: GAT 4CAN 1L M H13 0063
   Revision: 1P120037    Serial number: 3741P143300071
   Coding: FBCF1059000100010253
   VCID: 50AAEA830324E7C4F7-8004
   Component: J367-BDM  H07 0190
   Serial number: 31064G41184121925167
   Subsystem 2 - Part No SW: 8K0 959 663 D    HW: 8K0 959 663
   Component: J532_DCDCStab  H23 0021
   Serial number: 140107000000000004E7
   Part No SW: 0AY 907 554 F    HW: 0AY 907 554 F
   Component: Haldex4Motion H52 7521
   Serial number: HA1-00028.02.14
   Coding: 0201
   VCID: 4E96F4FB1110F134E5-801A
   Component: IMMO          H06 0450
   Coding: 000002
   ROD: EV_Immo_UDS_VDD_AU10.rod
   Part No SW: 8X0 959 793 K    HW: 8X0 959 793 K
   Component: TSG FA        H10 0415
   Coding: 011E02200000000000
   VCID: 55A41B973CC682EC24-8000
Address 44: Steering Assist (J792)       Labels:| 6Rx-909-144-V2.clb
   Part No SW: 6R1 909 144 R    HW: 6R1 909 144 E
   Component: EPS_TRW_ALow  311 3111
   Serial number: CE420741
   Coding: 0017
   ASAM Dataset: EV_SteerAssisUDSTRW 011021
   ROD: EV_SteerAssisUDSTRW_011.rod
   VCID: 4686CCDBF96039745D-8012
   Part No SW: 8X0 959 792 K    HW: 8X0 959 792 K
   Component: TSG BF        H10 0415
   VCID: 54A2E693373C9BE4D3-8000
   Part No SW: 8X0 907 357 E    HW: 8X0 907 357 B
   Component: ****LWR12**** H02 0010
   Serial number: 140221-0002-219
   Coding: 11B3AC1010022500
   ROD: EV_HeadlRegulBasic.rod
   VCID: 4482D6D3CF5C0B6443-8010
   Part No SW: 8XA 035 182     HW: 8XA 035 182
   Component: RMC Cnct Plus H55 0812
   Coding: 0100040200C053470023020103010000010000
   VCID: 040216D387DCCB6403-8050
   Subsystem 1 - Part No SW: 8X0 919 603 B    HW: 8X0 919 603 B
   Component: DU6 Basic  H43 0084
   Serial number: 9462D30E2766794
   Part No SW: 8X0 959 795 D    HW: 8X0 959 795 D
   Component: TSG HL        H07 0415
   Coding: 010802200000000000
   Component: TSG HR        H07 0415
   Part No SW: 8X0 907 159 C    HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 140325202117
   VCID: 428ED0CBD548055471-8016
End-------------------------(Elapsed Time: 03:28)--------------------------
DrPeter
16.4905° S, 151.7375° W
....the question is if it's just a simple matter of copying the code 0201 of old module and coding the new one to the same code?
- Thanks for posting your question, make sure you register your VCDS tool, so you can become a verified user here.
Yes, use the same coding of the old/original J492 controller [0201] and you should have no issues as this controller does not appear to have "Component Protection". However, I can not confirm you will not receive a Parameterization fault code, like "No End of Line Programing". If so the controller will need to go on-line with Audi to clear codes.
Note: The Factory repair information, says the J492-All Wheel Drive Control Module should be replaced with the N373-Haldex Clutch Control Valve.
For example:
Hope this helps,
drpeter
Amsa303
Sweden
Thank you for the clarification drpeter.
I'll also check into geting verified, still new to this forum so i'm running around like a blind hen over here :)
I've replaced the haldex controller and it read out al OK by vcds. It's old 0505 coding was replaced by my original string 0201 without any issues and all output tests worked out fine, aswell as a testdrive.
BUT, now i'm getting a 16652 error from the controller, see autoscan
 Monday,07,October,2019,10:03:05:51156
VCDS Version: 19.6.2.0 (x64)
          A9
VIN: WAUZZZ8X6FB001294   Mileage: 42860km-26631miles
   Revision: --H13---
   ROD: EV_ECM20TFS0208X0906259.rod
   VCID: 7F08993FE63AA8B7DE-802A
Readiness: 0010 0001
   VCID: 2D5493777CD6EA273C-8078
   Coding: 6403080890
   VCID: 020E10CB95C8C55FB1-8056
   Coding: 080007
   Shop #: WSC 00046 412 12345
   VCID: 54A2E6933F3C9BEF53-8000
Address 14: Susp. Elect. (J250)       Labels: 6C0-907-359.clb
   Coding: 82
   VCID: 6ADE586B8DB83D1F19-803E
   VCID: 183A52A3E3547F8F7F-804C
   Coding: 1084204000
   VCID: 3D74A337ACB67AA78C-8068
   Coding: 13DE01
   VCID: 4B90FDEFE202C41702-801E
   VCID: 50AAEA830324E7CF77-8004
   Part No SW: 0AY 907 554 L    HW: 0CQ 525 130 A
   Component: Haldex4Motion H53 7620
   Serial number: HA1-00018.09.15
   Coding: 0201
   Shop #: WSC 02737 790 50316
16652 - Databus
                    Reset counter: 191
                    Mileage: 42864 km
                    Date: 2019.10.07
                    Time: 09:54:51
   Coding: 000002
   VCID: 55A41B973CC682E7A4-8000
   Coding: 0017
   VCID: 4686CCDBF960397FDD-8012
Address 46: Central Conv.
   Coding: 011E02200C00000000
   Shop #: WSC 00046 123 12345
   VCID: 54A2E693373C9BEF53-8000
   VCID: 4482D6D3CF5C0B6FC3-8010
   VCID: 040216D387DCCB6F83-8050
   VCID: 428ED0CBD548055FF1-8016
End-------------------------(Elapsed Time: 03:44)--------------------------
What i also noticed while swapping the controller is that the new one had pins/contacts on all pins except nr 8 and my old one was missing pin 5 and 6 aswel las pin 8
open
Are you sure that the "new" one:
is an appropriate replacement for the old one?
The hardware part numbers are very different.
Viking
C?ID=151455
You swapped out an 0AY controller for an 0CQ one. I think that would be a problem as they're different hardware.
Amsa303
Sweden
Hmm, never noticed that.
Why does it come up as a 0CQ controller when the part number written on the controller itself is a
0AY907554L?
I was just assuming that it was a newer revision of my original controller as the part numbers were the same apart from the last letter.
Viking
C?ID=151455
Are you confusing software versions with hardware versions?
Amsa303
Sweden
Now i'm confused :) Isn't the number written on the part the hardware number?
OLD module
"NEW" Module
No, that's the software number.
downtime
Finland
C?ID=280813
Also good hint is the H number. Old module is H52, new one is H53 so new one is different HW revision.
I hope you have return policy for the controller.
Amsa303
Sweden
Hi guys
I've managed to trrace an used controller with the same HW number, part number, software code etc. and replaced it.
Everything works fine mechanicly and car drives on all 4 wheels BUT the darn fault code persists.
Anyone knows why?
And how to get rid of it?
posting an autoscan below, never mind all the faults for low battery. the car has been sitting in the garage for few weeks and hasn't been driven.
 Sunday,17,November,2019,12:55:29:51156
Mileage: 43170km-26824mi   Repair Order:
          A9
VIN: WAUZZZ8X6FB001294   Mileage: 43170km-26824miles
   Revision: --H13---
0606 - Tire Pressure Warning
          C102D 00 [008] - -
                    Reset counter: 246
                    Mileage: 43139 km
                    Date: 2019.10.26
                    Time: 16:46:41
   Coding: 6403080890
   Revision: AD113811
   Coding: 06000A2CE805E3C0205843E0200408C453F7630A21AF5D22E408878700C5
   VCID: 4B90FDEFEA02C41702-801E
   Coding: 02005D
                    Reset counter: 209
                    Mileage: 43176 km
                    Date: 2019.11.17
                    Time: 12:49:56
                    Voltage: 11.35 V
                        Term 50 On
   Coding: 080007
   Coding: 82
   Coding: 1084204000
   Coding: 13DE01
                    Reset counter: 209
                    Mileage: 43176 km
                    Date: 2019.11.10
                    Time: 03:38:01
                    Bin. Bits:    00000
                    Voltage: 12.00 V
                    Count: 19
   Serial number: HA1-00007.06.14
   Coding: 0201
   Shop #: WSC 12345 123 61029
   VCID: 4E96F4FB1110F13F65-801A
16652 - Databus
                    Fault Frequency: 24
                    Reset counter: 209
                    Mileage: 43081 km
                    Date: 2019.10.22
                    Time: 17:31:27
   Coding: 000002
   Coding: 0017
End-------------------------(Elapsed Time: 03:53)--------------------------
downtime
Finland
C?ID=280813
Getting a newer HEX V2 interface would reveal where that missing message is coming from. Older interface cannot give the extended dtc info.
I think it is a missing message from the transmission. Except that this car appears to be a manual.
Have you got a scan from when the old Haldex was still in the car?
Amsa303
Sweden
Hi uwe.
That's a pretty good guess actually as my audi s1 is a manual and the replacement unit comes of a q3 with dsg/tiptronic.
My original autoscan with the old haldex unit is included in the first post of this topic.
If this is the case, ahould i be bothered or just leave it be as everything seem to be working anyway.
Or is there a simple fix?
Perhaps I am blind, but I do not see it there.
Amsa303
Sweden
Here's the autoscan from when the car was working with it's original haldex controller
          A9
   Revision: --H13---
          U0423 00 [032] - -
   Coding: 6403080890
   Revision: AD113811
   Coding: 02005D
   Coding: 000007
   Coding: 82
   Coding: 1084204000
   Coding: 13CE01
   Coding: 0201
   Coding: 000002
   Coding: 0017
OK, that really is all the same except for the serial number. At this point, I'm out of ideas and the only suggestion I have is to try what darkchina811 suggested in post #15.
golfi_vend
Tartu, Estonia
C?ID=195131
A software update is in place too. Way too common to have issues due to SW and not actual Pump/Module....
SVM/ActionCode: 3929
threepot
C?ID=207547
Just to add to this. There is a byte in the EEPROM, if it is set to 00 it is Manual, if it is 01 it means the controller looks for the Transmission control unit.
If you look at measuring blocks 125, under the TRANS block, a manual one always reports back yes to coms, even though there is no Transmission module.
While an Automatic/DGS programmed Haldex module will only report yes if the module is actually present, if it is missing it reports negative, and gives you the 16652 code.
So you can fit a manual one to an auto/DSG, but not the other way round.
There is no external way to my knowledge to edit the EEPROM data byte without desoldering/editing/refitting the EEPROM, and you have to know where the byte is too. It is not documented anywhere. I can do this though if required. And if anyone comes up with a way of reading out the EEPROM data, and rewriting it over OBD/CAN, then i'm all ears as I've spend a few hundred hours trying to figure that out.
