esp front mk 60
bjkandre
Norway
C?ID=210865
Hi
oblem with esp front mk 60..so no i have removed the whole esp mk 60 and replaced it..The light is still on and i cant erase the light..and when i se in the scan log it have become many faults on the esp.Is there anyone that know how to erase and remove the faults on esp front??Cant do it the normal way.
Wednesday,07,January,2015,15:27:14:45374
VCDS Version: 14.10.0.0 (x64)
Data version: 20141022
VIN: WVGZZZ1TZ5W013138   License Plate:
Mileage: 214960km-133569mi   Repair Order:
Chassis Type: 1T (1K0)
Scan: 01 02 03 08 09 15 16 17 18 19 25 42 44 46 52 55 56 62 69 72
VIN: WVGZZZ1TZ5W013138   Mileage: 214960km-133569miles
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 DK    HW: 028 101 194 6
   Component: R4 1,9L EDC G000AG  6247
   Revision: 12345678    Serial number: VWZ7Z0D0029025
   Coding: 0000078
   Shop #: WSC 01324 785 00200
   VCID: 6FEDDDF97E2C3259861-803A
   Part No SW: 02E 300 041 R    HW: 02E 927 770 AD
   Component: GSG DSG         041 0812
   Revision: 00004010    Serial number: 00000405250202
   VCID: 2149EBC1F878D429405-8074
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021190
   VCID: 3A7B3CAD75EEA7F161F-806F
00493 - ESP-Sensor Unit (G419)
   Part No: 1K0 907 044 L
   Component: ClimatronicPQ35 061 0201
   VCID: 306F1E85A3926DA1DFB-8065
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 T    HW: 1K0 937 049 T*
   Component: Bordnetz-SG 1.0 H30 0704
   Revision: 00030000    Serial number: 00000000821478
   Coding: 0B8B8F020004200000120C000000000000
   VCID: 408F4E451332FD212FB-8015
   Subsystem 1 - Part No: 1T0 955 119 C  Labels: 1KX-955-119.CLB
   Component: Wischer VW358  012  0401
   Coding: 00065493
01064 - Terminal 58d; Interior Dimming
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 B    HW: 1T0 909 605 B
   Component: 02 AIRBAG VW62 0506 1400
   Revision: 07023000    Serial number: 0037SD07T225
   Coding: 0012338
   VCID: 34671295578A5181BB3-8061
   Part No SW: 1K0 953 549 AM    HW: 1K0 953 549 AM
   Component: J0527           032 0070
   Coding: 0010042
   Shop #: WSC 00220 218 55170
   VCID: 7DF1F7B1244050C904D-8028
   Part No: 1T0 920 861 A
   Component: KOMBIINSTRUMENT VDD 0714
   Coding: 0007103
   Shop #: WSC 00011 888 96745
   Part No: 1K0 815 071 H
   Component: Zuheizer        031 1312
   Revision:        A    Serial number: 09010046
   Coding: 0000011
   Shop #: WSC 00690 218 178596
   VCID: 2A5B0CED854E177111F-807F
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 C    HW: 1K0 907 951
   Component: Gateway         H08 0080
   Revision: 08          Serial number: 2600104519027B
   Coding: 7F3F5340078002
   VCID: 275DF5D9965C2A190E1-8072
   Component: IMMO            VDD 0714
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0157
   Coding: 0000116
   VCID: 74E7D295170A11817B3-8021
   Part No: 1K1 909 144 G
   Component: EPS_ZFLS Kl.0       1401
   VCID: 2F6D1DF9BEAC7259C61-807A
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 C
   Component:    KSG              0201
   Coding: 00E802087F2D8404084F0100
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Coding: 0000116
   VCID: 75E1EF911C7008894CD-8020
   Part No: 1T0 907 357
   Component: Dynamische LWR      0002
   Coding: 0000001
   Part No: 1K0 035 186 J
   Component: Radio BNO           0016
   Coding: 0040400
   VCID: 2D5107F1B4A00049F4D-8078
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN1.lbl
   Part No: 1K0 959 703 B
   Component: Tuersteuergeraet 06 0214
   Coding: 0000048
Address 69: Trailer
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN1.lbl
   Part No: 1K0 959 704 B
   Coding: 0000048
End-------------------------(Elapsed Time: 01:56)--------------------------
Do you have a scan from before you replaced it?
Where did you get the replacement module? Is it the correct one?
bjkandre
Norway
C?ID=210865
Hi
Had some trouble with sending the post..i bought the item used from a dealer.And it was working..i Checked the item up with my car from vw.part number on the other car.and reg number.and my car and that car had identical part numbers.I think that i maibe have to go in too the different fault codes and erase it??i have only had a full scan and then clear all dtc or dts?? And the fault code was still there..I was srating up my webasto..and then i had to set in a number and then it was working..If someone knows wat i can doo???
Its the adress 03..
Sunday,30,November,2014,16:24:40:45374
Mileage: 213140km-132439mi   Repair Order:
VIN: WVGZZZ1TZ5W013138   Mileage: 213140km-132439miles
   Coding: 0000078
            P1847 - 000 -
   Component: ESP FRONT MK60      0103
   Coding: 0021190
   Coding: 00065493
   Coding: 0012338
   Coding: 0010042
   Coding: 0007103
   Coding: 0000011
                    Fault Frequency: 19
                    Reset counter: 181
                    Mileage: 200974 km
                    Time: 16:21:38
00664 - Fuel gauge
                    Fault Frequency: 16
                    Reset counter: 90
                    Mileage: 212981 km
                    Time: 17:59:26
01410 - Heater Over-Temp
            000 -  -  - Intermittent
                    Reset counter: 217
                    Mileage: 185813 km
                    Time: 06:25:58
                        Ctrl. Pause
                    Temperature: 148.0°C
                    Temperature: 7.0°C
02251 - Heater Unit Locked
                    Reset counter: 217
                    Mileage: 185813 km
                    Time: 06:25:58
01411 - Temperature Sensor (G18)
                    Fault Status: 00100111
                    Fault Frequency: 255
                    Reset counter: 231
                    Mileage: 204405 km
                    Time: 23:17:19
                        Malfunction
                    Temperature: 205.0°C
                    Temperature: 43.0°C
   Coding: 0000116
   Component:    KSG              0201
   Coding: 0000116
   Coding: 0000001
   Coding: 0040400
   Coding: 0000048
Address 69: Trailer
   Coding: 0000048
End-------------------------(Elapsed Time: 01:53)--------------------------
Spacewalker
Poland
C?ID=159607
G419 is a DuoSensor located under glove box , near Passenger Airbag switch
this is a separate sensor, If replacement pump cant see it , seems pump is faulty (your old one havent see that problem)
of course you can try replaced it (easier to replace it then whole ABS) , but I will look also for each wire ABS <-> Duo Sensor
but 1st - try do that adaptations
bjkandre
Norway
C?ID=210865
i have replaced the whole abs unit.?it`s the abs module that i have changed erlier and it`s after that the 5 faults came on adress 03.how can i erase fault codes??? step by step..I have sendt some things here erlier and then people told me that the pump ++ was broken on some other things..i went in on the spesific module on the computer program and got a step by step way to erase the fault..and everything works perfektly now.I have tried to clear more faults and now there are 3 faults instead of 5 faults.. the faults that are back is
Jetta 97
Dallas (McKinney) ,TX ,USA
C?ID=81680
I do not think you are getting this.
ESP sensor is separate unit from ABS unit.So replacing ABS unit will not fix ESP sensor code.
Other codes will be clear when you do adaption what UWE post it. .
