Audi a4 2013
Tunnel
Italy
C?ID=65533
hello, i have audi a4 in my garage vin WAUZZZ8K8DA234004,my customer changed POWER STEERING ECU with used one,now i have dtc actived C10AC07-C10AD29-C10ACF0,can i solve with vcds?thanks.
Tunnel
Italy
C?ID=65533
Thursday,03,October,2019,15:34:55:40494
VCDS Version: 19.6.2.0 (x64)  HEX-NET CB: 0.4508.4
VIN: WAUZZZ8K8DA234004   License Plate:
Mileage: 218240km-135608mi   Repair Order:
Chassis Type: 8K-AU48 (8R0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 44 46 52 53 56 62 72
VIN: WAUZZZ8K8DA234004   Mileage: 218240km-135608miles
44-Steering Assist -- Status: Malfunction 1010
Address 01: Engine (J623-CJCA)       Labels:. 03L-906-018-CGL.clb
   Part No SW: 03L 906 018 HT    HW: 03L 906 018 JL
   Component: R4 2,0L EDC   H25 3110
   Revision: 45H25---
   Coding: 12034012230401080000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM20TDI01103L906018HT 003006
   ROD: EV_ECM20TDI01103L906018HT.rod
   VCID: 034678CE8A8B3657BA-8056
18735 - Steering Effort Control Module
          U0130 00 [032] - No Communications
                    Mileage: 218247 km
                    Date: 2019.10.02
                    Time: 17:14:22
                    Engine speed: 0.00 /min
                    Coolant temperature: 60 °C
                    Intake air temperature: 48 °C
                    Voltage terminal 30: 12.240 V
Address 02: Auto Trans (J217)       Labels:| 0AW-927-156.clb
   Part No SW: 8K9 927 155 A    HW: 0AW 927 156 K
   Component: 0AW 20TDI RdW H05 0001
   Revision: --H05---    Serial number: 0000001025
   Coding: 000002
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMVL381 A02432
   ROD: EV_TCMVL381.rod
   VCID: 3A38C52ABDC1B79FA9-806E
   Part No SW: 8K0 907 379 CG    HW: 8K0 907 379 CG
   Component: ESP8 front    H09 0100
   Coding: 171544
   VCID: 004C77C2939D2D4FA7-8054
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 2
                    Mileage: 218247 km
                    Date: 2019.10.02
                    Time: 17:35:13
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x000A
                    Hex Value: 0xC095
                    Hex Value: 0x0000
                    Reset counter: 2
                    Mileage: 218247 km
                    Date: 2019.10.02
                    Time: 18:20:39
                    Hex Value: 0x0000
                    Hex Value: 0x07A2
                    Hex Value: 0x0010
                    Hex Value: 0x1095
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GC    HW: 8K0 907 064 FC
   Component: BCM2 2.0      H12 0633
   Coding: 01A24040000000000000
   VCID: 77BE1C1EC6536AF796-8022
   Subsystem 1 - Part No SW: 8K0 959 754 H    HW: 8K0 959 754 H
   Serial number: 0813000039822011
   Part No SW: 8K1 820 043 AG    HW: 8K1 820 043 AG
   Component: KLIMA 1 ZONE  H02 0122
   Revision: A1000000    Serial number: 01050420130256
   Coding: 342002E000
   VCID: 6D923E76B40FD0277C-8038
   Part No SW: 8K0 907 063 DD    HW: 8K0 907 063 DD
   Revision: 04016001    Serial number: 00000581886102
   Coding: 29000030803400C00081000300001F1F001C460826080401000004004001020000000020000000
   VCID: 74A42B12D72501EFB3-8020
   Subsystem 1 - Part No SW: 8K1 955 119 B    HW: 8K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: MITSUBA130912  H18 0461
   Serial number: 12091207003610
   Coding: 004577
   Subsystem 2 - Part No SW: 8K0 941 531 AR    HW: 8K0 941 531 AR
   Component: E1 - LDS  H03 0031
   Serial number: 00000000002203135369
   Subsystem 3 - Part No SW: 4G0 907 658 A    HW: 4G0 907 658 A
   Component: Humidity_Sens  H03 0002
   Serial number: 7F6880A6000000000001
   Subsystem 4 - Part No SW: 8U0 955 559     HW: 8U0 955 559
   Component: G355_FeuchteS  H07 0002
   Serial number: 20330410
                    Fault Status: 01101100
                    Reset counter: 253
                    Mileage: 218024 km
                    Date: 2019.09.25
                    Time: 19:41:49
   Part No SW: 8K0 959 655 N    HW: 8K0 959 655 N
   Serial number: 003KFD999E6C
   Coding: 30514435363030303030554A304C384B3053
   Shop #: WSC 00765 002 1048576
   VCID: 48DCAFE2F32DD50F2F-801C
   Serial number: 6334MSME7B062645E
   Serial number: 6344MSME7B03122DD
   Serial number: 6352QSME202F117CH
   Serial number: 6362QSME4C2F0678W
   Serial number: 63732SME252F5740$
   Serial number: 63832SME735A47250
   Part No SW: 8R0 953 568 Q    HW: 8R0 953 568 Q
   Component: Lenks.Modul   H02 0171
   Revision: 00000000    Serial number: 20130403001553
   Coding: 000013
   VCID: 4FEE84FE1E4302376E-801A
   Part No SW: 8K0 920 901 F    HW: 8K0 920 901 F
   Component: KOMBIINSTR.   H09 0556
   Revision: 00500000    Serial number: UVF79PM3E
   Coding: 1386100002010008040000
   VCID: 2E10F97A79896B3F05-807A
                    Reset counter: 42
                    Mileage: 218247 km
                    Date: 2019.10.02
                    Time: 17:14:23
   Part No SW: 8R0 907 468 L    HW: 8R0 907 468 A
   Component: GW-BEM 5CAN   H11 0056
   Revision: 1V080027    Serial number: 2741V1332084C6
   Coding: 80CF07FF00
   VCID: 48DCAFE2FB2DD50F2F-801C
   Serial number: 9332400203
   Subsystem 2 - Part No SW: 8K0 959 663 B    HW: 8K0 959 663 B
   Serial number: 13085000918011200410
                    Reset counter: 42
                    Mileage: 218247 km
                    Date: 2019.10.02
                    Time: 17:14:23
                    Bin. Bits:    10111
                    Voltage: 12.20 V
                    Count: 6
                    Bin. Bits:    10000
                    Time: 25.40 s
   Component: TSG FA        H02 0508
   Revision:             Serial number: 0000054839207
   Coding: 011002205C00410001
   Part No SW: 8K0 909 144 J    HW: 8K0 909 144 B
   Component: RCEPS         H41 0509
   Revision: 00001000    Serial number: 0021120637
   Coding: 100000010001
   Shop #: WSC 06334 123 12345
   ASAM Dataset: EV_RCEPSAU48X 008016
   ROD: EV_RCEPSAU48X_008.rod
   VCID: 383CDF2283CDA58F5F-806C
5258760 - Steering
          C10AC 07 [137] - Mechanical Failure
          [Einfriergefahr der Lenkung]
                    Mileage: 217981 km
                    Date: 2019.09.02
                    Time: 20:50:25
                    Write only channel
7341600 - Position Sensor for Motor
          C10AD 29 [137] - Signal Implausible
          [Unplausible Werte vom Resolver (Warnung)]
                    Reset counter: 2
                    Mileage: 218247 km
                    Date: 2019.10.02
                    Time: 19:00:36
                    Write only channel
7341570 - Position Sensor for Motor
          [Unplausible Werte vom Resolver (beherrschbarer Fehler)]
                    Mileage: 217981 km
                    Date: 2019.09.02
                    Time: 20:49:31
                    Write only channel
5258753 - Steering End Stops Not Learned
          C10AC F0 [137] - Unknown Error Elaboration
          [Lenkungsendanschläge nicht angelernt]
                    Fault Frequency: 11
                    Reset counter: 8
                    Mileage: 218247 km
                    Date: 2019.10.02
                    Time: 19:00:36
                    Write only channel
   Revision: 00002001    Serial number: 0303807813
   Coding: 0100062020B90080812002368000000F
02615 - Fuel Tank Cap; Lock
            009 - Open or Short to Ground
                    Fault Status: 01101001
                    Reset counter: 252
                    Mileage: 218008 km
                    Date: 2019.09.11
                    Time: 12:17:47
02616 - Fuel Tank Cap; Unlock
                    Reset counter: 252
                    Mileage: 218008 km
                    Date: 2019.09.11
                    Time: 12:18:19
   Component: TSG BF        H02 0508
   Revision:             Serial number: 0000056016776
   Coding: 011002205E00410001
   VCID: 4ED099FA19490B3F65-801A
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 00000001280447
   ROD: EV_ParkiBrake_AU48.rod
Address 56: Radio (J503)       Labels:. 8Tx-035-1xx-56.clb
   Part No SW: 8R1 035 186 N    HW: 8R1 035 186 N
   Component: Concert3      H09 0470
   Revision: 00000003    Serial number: AUZ5Z6N2086828
   Coding: 0500048004020500015A071000
   Shop #: WSC 13334 002 1048576
   VCID: 40CCB7C2D31DED4FE7-8014
   Subsystem 1 - Part No SW: 8T0 919 603 G    HW: 8T0 919 603 G
   Component: Display
   Component: TSG HL        H01 0506
   Revision:             Serial number: 0000056059993
   Coding: 010002204000210001
   VCID: 46C0A1DAF139C37FDD-8012
   Component: TSG HR        H01 0506
   Revision:             Serial number: 0000056051048
End----------(Elapsed Time: 01:16, VBatt start/end: 12.1V/12.1V)-----------
I do not think you can solve faults like "Mechanical Failure" and "Signal Implausible" with VCDS.
Tunnel
Italy
C?ID=65533
hello,thanks for reply,i tried also with odis online but nothing.
downtime
Finland
C?ID=280813
Uwe, you never know:rolleyes:
Tunnel
Italy
C?ID=65533
Wednesday,04,September,2019,19:14:39:40494
Mileage: 218250km-135614mi   Repair Order:
VIN: WAUZZZ8K8DA234004   Mileage: 218250km-135614miles
33-Flux Capacitor -- Status: Malfunction 0010
   Revision: 45H25---
   Coding: 000002
   Coding: 171544
   Coding: 342002E000
   Coding: 004577
   Coding: 000013
   Coding: 80CF07FF00
   Component: RCEPS         H41 0507
   VCID: 3424EB129FA541EF73-8060
                    Reset counter: 2
                    Mileage: 218250 km
                    Date: 2019.10.07
                    Time: 20:12:19
                    Write only channel
   Component: Display
End----------(Elapsed Time: 01:13, VBatt start/end: 14.0V/14.0V)-----------
only one dtc in power steering.
