Golf 7 R Variant USA - Discovery Pro MIB2. HELP!!!
SerCaddy
Pirate
Ukraine
Hello!
I had a problem with Discovery Pro MIB 2 after installing RDKS.:плач:
After coding blocks 03, 17, 19, 5F and adapting to 5F, errors appeared:
- voice control inactive (non-responsive);
- Apple CarPlay does not connect the phone;
- error on recognition of road signs.
Guys help out. I need your help.
I spread admaps of blocks
VIN: 3VWCA7AU5GM506755 License plate: 123456
Mileage: Work Order Number: 123456
Gateway equipment list: 5Q0 907 530 AF
01- Engine Electronics - Status: OK 0000
02- Gearbox Electronics - Status: OK 0000
03- Brake Electronics - Status: OK 0000
05- Authorization system for access and starting the engine - Status: OK 0000
08- Heater and climate electronics - Status: contains faults 0010
09- Onboard supply control unit - Status: OK 0000
10- Parking Assistant 2 - Status: OK 0000
13- Adaptive Cruise Control - Status: OK 0000
15- Airbags - Status: OK 0000
16- Steering Column Electronics - Status: Malfunction 0010
17- Instrument cluster - Status: contains faults 0010
19- Data Bus Diagnostic Interface - Status: Contains Fault 0010
2B- Steering column lock - Status: OK 0000
3C- Lane change assistant - Status: OK 0000
42- Electronic equipment of the driver's door - Status: OK 0000
44- Power Steering - Status: OK 0000
47- Speaker System - Status: OK 0000
52- Electronics, front passenger door - Status: OK 0000
5F- Electronic Information System 1 - Status: contains faults 0010
65- Tire Pressure Monitoring System - Status: OK 0000
75- Emergency Call and Communication Module - Status: OK 0000
A5- Front Auxiliary Sensor for Driver - Status: OK 0000
03-ABS
SW: 3Q0-907-379-AB HW: 3Q0-907-379-G --- Brake electronics --- SA: 20103
Component: ESC H42 0723, Encoding: 04FA6AA124200972007E020581C82520562490004081A4B21663F0024007
EV_Brake1UDSContiMK100IPB, 034036, EV_Brake1UDSContiMK100IPB_034_VW37.odx
Tuesday, 01, October, 2019,13: 21: 39: 10463
Software Version: 19.6.0 Protocol Type: Troubleshooting
IDE00001-Production Mode, not active, 3
IDE00252-Vacuum brake pump, 5, 1
IDE00820-Activation and deactivation of all messages, 0, 1
IDE01763-Reg. brightness, incl. ,one
IDE02332-Disable Production Mode, Deactivation, 3
IDE03493-Status of the driver's door, incl. ,one
IDE03659-Mode Roller stand, Manual activation: possible, 1
IDE04456-Drying Brake Discs, Medium, 1
IDE04508-Hydraulic Brake Booster, 8, 1
IDE04643-Overpressure in the brake system, including ,one
IDE04645-IDE05287-Electromechanical parking brake-Automatic application of the parking brake, incl. , 2
IDE04645-MAS05667-Electromechanical parking brake-Detecting driver presence by brake pedal, not activated, 2
IDE04765-Reverse Taxi Steering, Strong, 1
IDE04774-Vehicle and trailer stabilization, incl. ,one
IDE04871-Dynamic Start-up Assistant, Early, 1
IDE04939-Tire Pressure Monitoring Indicator, 0, 1
IDE04944-Evaluation of the position of the brake pedal, incl. ,one
IDE04949-A system of regulating engine torque on wheel slip, incl. ,one
IDE04951-Increase braking force, 4, 1
IDE04952-Increased Braking Force: Adaptive Cruise Control, 3, 1
IDE05055-Hydraulic Brake Assistant, Normal, 1
IDE05057-Brake system: pre-filling, including ,one
IDE05161-Maintaining directional stability while driving in a straight line, incl. ,one
IDE05263-Protection function AUTO HOLD, not activated, 1
IDE05264-Slope limit value for AUTO HOLD: reduced force, 0%, 1
IDE05265-Slope limit value for AUTO HOLD: full force, 10%, 1
IDE05286-Extended Electronic Differential Lock, Standard, 1
IDE05337-Reducing wobble when starting off, - Strong, 1
IDE05337-MAS02653-Decrease in wobble when starting-Torque limiter, Deactivated, 1
IDE05711-Automatic. apply the parking brake: when the engine stalls, turn on. ,one
IDE06137-IDE04772-Control of work indication lamps-Control lamp in the electromech key. parking brake, 7, 2
IDE06137-IDE05333-Control of the operation indicator lamps-Operation indicator lamp in the AUTO HOLD key, 7, 2
IDE06139-AUTO HOLD: roll detection, incl. ,one
IDE06425-Mode Roller Stand: Functions, not activated, 1
IDE06505-Electromechanical parking brake: acceleration level, 6, 1
IDE07006-Tire Pressure Monitoring Indicator: Tire Selection, 0, 1
IDE07565-ABS in the lower speed range, incl. ,one
IDE07848-Braking performance levels, incl. ,one
MAS00122-Electronic Stability Program, not activated, 1
MAS00970-Manufacturer serial number, incl. ,one
MAS01180-AUTO HOLD: operational status, last setting, 1
MAS01299-Offroad, 0, 1
MAS02080-XCP Calibration Protocol, not activated, 1
MAS02138-Lift assist, normal, 1
MAS02666-Poll seat belt lock, incl. ,one
MAS08145-Lifting Assistant: Ascent Threshold, 6%, 1
MAS09008-MAS00988-Validation-Reverse, incl. , 3
MAS09008-MAS09009-Validation-Neutral sensor, incl. , 3
MAS09008-MAS10668-Validation-Clutch stroke, incl. , 3
ENG118148-Developer_Function_1,0, 1
ENG130301-Developer_Function_121, not activated, 1
ENG122844-ENG101574-dimming_characteristic_1-X1,0, 12
ENG122844-ENG99557-dimming_characteristic_1-X2,50, 12
ENG122844-ENG102140-dimming_characteristic_1-X3,220, 12
ENG122844-ENG102936-dimming_characteristic_1-X4,6, 12
ENG122844-ENG103548-dimming_characteristic_1-X5,8, 12
ENG122844-ENG113992-dimming_characteristic_1-X6,80, 12
ENG122844-ENG99777-dimming_characteristic_1-Y1,10, 12
ENG122844-ENG100480-dimming_characteristic_1-Y2,100, 12
ENG122844-ENG100773-dimming_characteristic_1-Y3,253, 12
ENG122844-ENG100631-dimming_characteristic_1-Y4,6, 12
ENG122844-ENG102174-dimming_characteristic_1-Y5,12, 12
ENG122844-ENG113993-dimming_characteristic_1-Y6,100, 12
ENG122845-ENG101574-dimming_characteristic_2-X1,0, 12
ENG122845-ENG99557-dimming_characteristic_2-X2,50, 12
ENG122845-ENG102140-dimming_characteristic_2-X3,220, 12
ENG122845-ENG102936-dimming_characteristic_2-X4,6, 12
ENG122845-ENG103548-dimming_characteristic_2-X5,8, 12
ENG122845-ENG113992-dimming_characteristic_2-X6,80,12
ENG122845-ENG99777-dimming_characteristic_2-Y1,10, 12
ENG122845-ENG100480-dimming_characteristic_2-Y2,100, 12
ENG122845-ENG100773-dimming_characteristic_2-Y3,253, 12
ENG122845-ENG100631-dimming_characteristic_2-Y4,6, 12
ENG122845-ENG102174-dimming_characteristic_2-Y5,12, 12
ENG122845-ENG113993-dimming_characteristic_2-Y6,100, 12
Time Spent: 00:22
17-Instrument cluster
SW: 5G1-920-751 HW: 5G1-920-751 --- Instrument cluster --- SA: 20103
Component: KOMBI 303 5290, Encoding: 07AD129A649C840810897E2F5000000000000000
EV_DashBoardJCIMQBAB, 009003, EV_DashBoardJCIMQBAB_009_VW37.odx
Tuesday, 01, October, 2019,13: 23: 40: 10463
IDE00295-Oil temperature display, incl. ,one
IDE00301-Mileage, 15227 km, 3
IDE00342-WIV: reset counter for extended maintenance intervals, no warning, 1
IDE00343-Language option, Russian, 1
IDE00345-MAS00234-Reset multi-function display 3-RESET / OK key of multi-function display, manual reset: not possible, 3
IDE00345-MAS05463-Reset multifunction display 3-Refuel recognition: gasoline / diesel, Reset multifunction display 3, 3
IDE00345-MAS05464-Reset multifunction display 3-Recognition refueling: gas, Reset multifunction display 3, 3
IDE00499-Correction of indications of an expense and a power reserve, 100%, 1
IDE00500-Hour, 13 H, 1
IDE00501-Minute, 23 min, 1
IDE00502-Year, 2019 yr, 2
IDE00503-Month, 10 mon, 1
IDE00504-Day, 1 d, 1
IDE00510-WIV: mileage after inspection service, 5400 km, 3
IDE00511-WIV: time after inspection service, 72 d, 2
IDE00512-WIV: Minimum Mileage / Inspection Service, 15,000 km, 2
IDE00513-WIV: Maximum Mileage / Inspection Service, 30,000 km, 2
IDE00514-WIV: max. interval value between inspection services, 730 d, 2
IDE00515-WIV: oil quality, poor oil quality, 1
IDE00517-WIV: soot fraction, 10,300 km, 2
IDE00518-WIV: Heat Load, 4200 km, 2
IDE00711-Tachograph, not installed. ,one
IDE00819-The counter of daily run, 988 d, 2
IDE00820-Activation and deactivation of all messages, not active, 1
IDE00827-WIV: minimum time interval between inspectors. services, 365 d, 2
IDE01153-SIA: maximum mileage for TO, 15,000 km, 2
IDE01154-SIA: maximum time to maintenance, 365 d, 2
IDE02489-Display, Version 2, 1
IDE02818-IDE02689-Fuel Tank Sensor Calibration Deviation - Full Fuel Tank Sensor Calibration, -12.8 l, 5
IDE02818-MAS02376-Fuel Tank Sensor Calibration Deviation-Sensor Deviation 1, -12.8 l, 5
IDE02818-MAS02377-Fuel Tank Sensor Calibration Deviation-Sensor Deviation 2.12.7 l, 5
IDE02818-MAS02378-Fuel Tank Sensor Calibration Deviation-Sensor Deviation 3.12.7 l, 5
IDE02818-MAS02379-Fuel Tank Sensor Calibration Deviation-Sensor Deviation 4.12.7 l, 5
IDE03329-Drive mode for calculating the remaining power reserve, 7.0 l / 100km, 2
IDE03346-IDE00301-Customized units-Mileage, km, 3
IDE03346-MAS01230-Customized units-Date, dd_mm_yy, 3
IDE03346-MAS01456-Customized units-Speed, km per hour, 3
IDE03346-MAS02201-Configured units-Temperature, between 95 ° C and 105 ° C, 3
IDE03346-MAS02957-Customized Units-Time, 24 h, 3
IDE03346-MAS03032-Customized Units-Volume, l, 3
IDE03346-MAS03034-Customized Units-Pressure, bar, 3
IDE03346-MAS05637-Customized units-Operating range consumption: CNG (compressed natural gas), kg per 100 km, 3
IDE03346-MAS05638-Customized Units-Gas mileage / diz. fuel / LPG (liquefied petroleum gas), l per 100 km, 3
IDE03346-MAS13665-Customized units-Trailer weight / Vertical load on the towing vehicle, Kilogram (kg), 3
IDE03348-MAS01456-Overspeed Warning-Speed, 170, 2
IDE03348-MAS01561-Speeding Warning - Unit, km per hour, 2
IDE03348-Speeding Warning-, not active, 2
IDE03349-FIX: max. mileage to the next. installed Inspection Service mileage, 30,000 km, 2
IDE03350-FIX: max. term until next installed by time inspector. service, 730 d, 2
IDE03351-FIX: mileage with max. last install. official service mileage, 5400 km, 2
IDE03352-FIX: mileage with max. last install. by time inspection service, 72 d, 2
IDE03372-A source for clock synchronization, GPS, 1
IDE03568-ENG119828-Settings Service Key-p_deactivate_SK_Function, incl. ,5
IDE03568-ENG99943-Settings Service Key-p_forcewrite_qual_time, 10 s, 5
IDE03568-ENG119827-Settings Service Key-p_main_switch_Basic, incl. ,5
IDE03568-ENG102414-Settings Service Key-p_main_switch_keyless, incl. ,5
IDE03568-ENG102611-Settings Service Key-p_write_delay_speed, 20 km / h, 5
IDE03568-ENG103545-Settings Service Key-p_write_delay_time, 40 s, 5
IDE03568-ENG104099-Settings Service Key-p_write_distance, 20 km, 5
IDE03867-Disable seat belt warning, No, 1
IDE05930-Warning of MOT in days, 30 d, 1
IDE05931-FIX: value of zeroing for the next insp.service in the head. from the run, 30,000 km, 2
IDE05932-FIX: value of zeroing for the next insp.service in the head. from time to 365 d, 2
IDE06588-Message Ignition active: squib, Driver's door, 1
IDE07221-Disable Cylinders, No display, 1
MAS03555-Lap Counter, Display, 1
MAS03685-Digital Speedometer, Display, 1
ENG117917-BAP_Debug_Mode_Release, not_released, 1
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1, OFF, 20
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10, OFF, 20
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11, OFF, 20
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12, OFF, 20
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13, OFF, 20
ENG119877-ENG98447-Configuration of Development CAN-Messages-Блок 14,OFF ,20
ENG119877-ENG98448-Configuration of Development CAN-Messages-Блок 15,OFF ,20
ENG119877-ENG98404-Configuration of Development CAN-Messages-Блок 16,OFF ,20
ENG119877-ENG98449-Configuration of Development CAN-Messages-Блок 17,OFF ,20
ENG119877-ENG98450-Configuration of Development CAN-Messages-Блок 18,OFF ,20
ENG119877-ENG98451-Configuration of Development CAN-Messages-Блок 19,OFF ,20
ENG119877-ENG98452-Configuration of Development CAN-Messages-Блок 2,OFF ,20
ENG119877-ENG98405-Configuration of Development CAN-Messages-Блок 20,OFF ,20
ENG119877-ENG98453-Configuration of Development CAN-Messages-Блок 21,OFF ,20
ENG119877-ENG98406-Configuration of Development CAN-Messages-Блок 22,OFF ,20
ENG119877-ENG98454-Configuration of Development CAN-Messages-Блок 23,OFF ,20
ENG119877-ENG98455-Configuration of Development CAN-Messages-Блок 24,OFF ,20
ENG119877-ENG98456-Configuration of Development CAN-Messages-Блок 25,OFF ,20
ENG119877-ENG98407-Configuration of Development CAN-Messages-Блок 26,OFF ,20
ENG119877-ENG98457-Configuration of Development CAN-Messages-Блок 27,OFF ,20
ENG119877-ENG98458-Configuration of Development CAN-Messages-Блок 28,OFF ,20
ENG119877-ENG98459-Configuration of Development CAN-Messages-Блок 29,OFF ,20
ENG119877-ENG98408-Configuration of Development CAN-Messages-Блок 3,OFF ,20
ENG119877-ENG98409-Configuration of Development CAN-Messages-Блок 30,OFF ,20
ENG119877-ENG125180-Configuration of Development CAN-Messages-Блок 31,OFF ,20
ENG119877-ENG125181-Configuration of Development CAN-Messages-Блок 32,OFF ,20
ENG119877-ENG125182-Configuration of Development CAN-Messages-Блок 33,OFF ,20
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF ,20
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF ,20
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF ,20
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF ,20
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF ,20
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF ,20
ENG119877-ENG98410-Configuration of Development CAN-Messages-Блок 4,OFF ,20
ENG119877-ENG98460-Configuration of Development CAN-Messages-Блок 5,OFF ,20
ENG119877-ENG98461-Configuration of Development CAN-Messages-Блок 6,OFF ,20
ENG119877-ENG98462-Configuration of Development CAN-Messages-Блок 7,OFF ,20
ENG119877-ENG98411-Configuration of Development CAN-Messages-Блок 8,OFF ,20
ENG119877-ENG98463-Configuration of Development CAN-Messages-Блок 9,OFF ,20
ENG119875-defuel_threshold,45 l,1
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32 ,12
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66 ,12
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96 ,12
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC ,12
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00 ,12
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00 ,12
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00 ,12
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,05 ,12
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,14 ,12
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,32 ,12
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64 ,12
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,96 ,12
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,02 ,12
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,02 ,12
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,0E ,12
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1E ,12
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,32 ,12
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00 ,12
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A ,12
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,32 ,12
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64 ,12
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC ,12
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD ,12
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,02 ,12
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,02 ,12
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,06 ,12
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,10 ,12
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,55 ,12
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64 ,12
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00 ,12
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A ,12
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32 ,12
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64 ,12
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96 ,12
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD ,12
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05 ,12
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05 ,12
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C ,12
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17 ,12
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32 ,12
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64 ,12
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 96 ,20
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,01 2C ,20
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 08 ,20
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 32 ,20
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 96 ,20
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00 ,12
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A ,12
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,32 ,12
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64 ,12
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,96 ,12
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD ,12
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01 ,12
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01 ,12
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,07 ,12
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0A ,12
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,1E ,12
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64 ,12
ENG125906-ENG126933-Illumination_algorithm-Pointer_illumination_algorithm,terminal_58xd_log_bus_parkinglight ,1
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,auto_lowbeam_foglight ,1
ENG119882-init_fuel_algorithm,Нет ,1
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,2.0 °C,16
ENG119876-Service_Key_Clear_All_Counter,Нет ,1
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,0.00 s,18
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,0 s,18
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,0 s,18
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 s,18
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,0 s,18
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,0 s,18
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,0 s,18
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,0 s,18
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,0 s,18
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,0 s,18
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,0 s,18
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,0 s,18
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.00 s,18
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,244 ,18
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.15 s,18
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 s,18
ENG109442-ENG100026-time_parameter_display-tDDWUP,1.55 s,18
09-Onboard supply control unit
SW: 5Q0-937-087-AA HW: 5Q0-937-087-AA --- Onboard supply control unit --- SA: 31347
Component: BCM PQ37BOSCH 028 0162, Encoding: 0351184640C182F969E4400001140700180A0000000000000000000000000000
EV_BodyContrModul1UDSBosc, 015002, EV_BCMBOSCH_015.odx
Tuesday, 01, October, 2019,13: 29: 33: 10463
IDE00001-ENG99061-Production Mode-Access Control, not active, 3
IDE00001-ENG115730-Production Mode-Aussenbeleuchtung, not active, 3
IDE00001-ENG116710-Production Mode-Frontwischer deaktivieren, not active, 3
IDE00001-ENG112304-Production Mode-Heckwischer, not active, 3
IDE00001-ENG98647-Production Mode-Interior Lighting, not active, 3
IDE00001-ENG115729-Production Mode-Scheinwerferreinigung, not active, 3
IDE00001-ENG115731-Production Mode-Virtuel_pedal, not active, 3
IDE00002-Transportation mode, act. ,one
IDE01268-ENG115835-Windshield Wiper-Adaptives Nachwischen bei SRA, not active, 12
IDE01268-ENG116609-Windshield Wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung, 0, 12
IDE01268-ENG115836-Windshield Wiper-Frontwischer Notlaufprogramm, act. ,12
IDE01268-ENG116614-Windshield Wiper-Frontwischer Referenzlauf, act. ,12
IDE01268-ENG133394-Windshield Wiper-Frontwischer_Abtauposition, not active, 12
IDE01268-ENG116617-Windshield Wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung, act. ,12
IDE01268-ENG116615-Windshield Wiper-Menuesteuerung Frontwischer, not active, 12
IDE01268-ENG115771-Windshield Wiper-Regensensor aktivieren, Deactivation, 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel, not active, 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit, 0 ms, 12
IDE01268-ENG115768-Windshield Wiper-SRA Nachwaschzeit, 0 ms, 12
IDE01268-ENG116611-Windshield Wiper-SRA Pausenzeit, 0 ms, 12
IDE01268-ENG116610-Windshield Wiper-SRA Verzoegerungszeit, 0 ms, 12
IDE01268-ENG115766-Windshield Wiper-SRA Waschzeit, 0 ms, 12
IDE01268-ENG133393-Windshield Wiper-Tippendes_Frontwaschen, not active, 12
IDE01268-ENG116616-Windshield Wiper-Tippwischen mit erhoehter Wischfrequenz, act. ,12
IDE01268-ENG116618-Windshield Wiper-Traenenwischen Front Status, act. ,12
IDE01268-ENG115770-Windshield Wiper-Variable Regensensoraktivierung, not active, 12
IDE01268-ENG126844-Windshield Wiper-Washer_Tipwiping_Variant, 0, 12
IDE01268-ENG116613-Windshield Wiper-Wischer abparken bei Oeffnen der Motorhaube, not active, 12
IDE01268-ENG116612-Windshield Wiper-Wischer stop bei KL15 aus, not active, 12
IDE01268-ENG122185-Windshield Wiper-Wischer Stopp bei Oeffnen der Motorhaube, not active, 12
IDE01550-Service position, 170.49 °, 2
IDE02152-Production Quality, 2000 ms, 4
IDE02269-MAS04382-Response signals-Light confirmation when locking, Slowdown, 4
IDE02269-ENG116666-Response Signals-Akustische Rueckmeldung entriegeln, not active, 4
IDE02269-ENG116669-Response signals-Akustische Rueckmeldung global, act. ,4
IDE02269-ENG116670-Response signals-Akustische Rueckmeldung Signalhorn, act. ,4
IDE02269-ENG116667-Response signals-Akustische Rueckmeldung verriegeln, act. ,4
IDE02269-ENG122187-Response signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn, Short ,4
IDE02269-ENG122188-Response signals-Menuesteuerung akustische Rueckmeldung, act. ,four
IDE02269-ENG122995-Response Signals-Optische Rueckmeldung 3.Bremsleuchte, not active, 4
IDE02269-ENG116668-Response signals-Optische Rueckmeldung Komfortschliessen, act. ,four
IDE02269-ENG133344-Response Signals-Quittierton bei zweitem ZV-AUF-Befehl, not active, 4
IDE02269-ENG133345-Response Signals-Quittierton bei zweitem ZV-ZU-Befehl, not active, 4
IDE02332-Disable production mode, 0, 3
IDE02711-ENG116690-Rear wiper-Automatisches Heckwischen, not active, 8
IDE02711-ENG133397-Rear wiper-Einzelansteuerung Heckintervallwischen, not active, 8
IDE02711-ENG133395-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1.0 s, 8
IDE02711-ENG133396-Rear wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2.0.0 s, 8
IDE02711-ENG114947-Rear wiper-Heckwischer Weiterlauf, act. ,8
IDE02711-ENG116692-Rear wiper-Kein automatisches Abparken, not active, 8
IDE02711-ENG114946-Rear wiper-Komfortwischen Heck, act. ,8
IDE02711-ENG116695-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1.5 s, 8
IDE02711-ENG116696-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2.3 s, 8
IDE02711-ENG116694-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik, 7 s, 8
IDE02711-ENG116693-Rear wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall, 7 s, 8
IDE02711-ENG116689-Rear wiper-Menuesteuerung Komfortwischen HW, act. ,8
IDE02711-ENG116691-Rear wiper-Traenenwischen Heck, act. ,8
IDE02957-ENG115822-Aesthetic Lighting-Defaultwert Ambienteprofil Fussraum, 80%, 8
IDE02957-ENG116685-Aesthetic lighting-Defaultwert Ambienteprofil Tuer, 80%, 8
IDE02957-ENG115823-Aesthetic Lighting-Defaultwert Ambienteprofil Vorn, 80%, 8
IDE02957-ENG115824-Aesthetic lighting-Innenlichtinszenierung, not enabled, 8
IDE02957-ENG116687-Aesthetic lighting-Tuerinnengriff mit Tuertafel, not installed. ,8
IDE02957-ENG116686-Aesthetic lighting-Tuerinnengriffbeleuchtung mit I-Tafel, not installed. ,8
IDE03638-IDE04231-System of static adaptive lighting-Steering angle: deviation, -63.75 °, 14
IDE03638-ENG116677-Static Adaptive Lighting System-Abdimmgeschwindigkeit, 50.00% / s, 14
IDE03638-ENG116673-Static Adaptive Lighting System-bei Rueckwaertsfahrt, both sides, 14
IDE03638-ENG116675-Static Adaptive Lighting System-Lower Speed ​​Threshold, 0.00 km / h, 14
IDE03638-ENG116682-Static Adaptive Lighting System-Maximaltemperatur, 100.00 ° C, 14
IDE03638-ENG116679-Static adaptive lighting system-obere Grenztemperatur, 95.00 ° C, 14
IDE03638-ENG116681-Static Adaptive Lighting System-Oberer Lenkradwinkel, 120 °, 14
IDE03638-ENG116680-Static Adaptive Lighting System-untere Grenztemperatur, 80.00 ° C, 14
IDE03638-ENG116678-Static Adaptive Lighting System-Unterer Lenkradwinkel, 180 °, 14
IDE03638-ENG116676-Static Adaptive Lighting System-Upper Speed ​​Threshold, 40.00 km / h, 14
IDE03638-ENG116674-Static Adaptive Lighting System-Vorschrift, ECE R119, 14
IDE04923-ENG133379-Turn Signal Management-Abbruch Komfortblinken, act. ,8
IDE04923-ENG116590-Turn Signal Management-Blinkkontrolleuchte fuer Anhaenger, separte, 8
IDE04923-ENG115774-Control of turn signals-Komfortblinken, act. ,8
IDE04923-ENG116587-Turn Signal Management-Komfortblinken Blinkzyklen, 4, 8
IDE04923-ENG116589-Turn Signal Management-Signalprioritaet fuer Blinker, MFG, 8
IDE04923-ENG116588-Turn Signal Management-Sonderfunktionen, not enabled, 8
IDE04923-ENG115818-Turn Signal Management-Warnblinken bei Verdeckentriegelung, not active, 8
IDE04923-ENG115819-Turn Signal Management-Warnblinktastersuchbeleuchtung Aktivierung, always an act. ,8
IDE04923-ENG115821-Turn Signal Management-Warnblinktastersuchbeleuchtung Faktor, 0.10, 8
IDE04923-ENG115820-Turn Signal Management-Warnblinktastersuchbeleuchtung Grundwert, 10.00%, 8
IDE04924-ENG116705-Drive light and side lights-Allwetterlicht Ausschaltgrenze, 350 km / h, 14
IDE04924-ENG116704-Drive light and side lights-Allwetterlicht Einschaltgrenze, 350 km / h, 14
IDE04924-ENG115858-Riding light and side lights-Kontrollleuchte fuer Begrenzungslicht, integriert in Suchbeleuchtung, 14
IDE04924-ENG115861-Light for driving and side lights-Lichthupe bei Zuendung aus moeglich, act. ,fourteen
IDE04924-ENG115862-Riding light and side lights-Lichtwarnungsverhalten, klemmenabhaengig, 14
IDE04924-ENG115863-Driving light and side lights-Menueeinstellung CHO LHO, Menuesteuerung Zeit aktivieren, 14
IDE04924-ENG115782-Drive light and side lights-Nebelschlusslicht Warngeschwindigkeit, 0 km / h, 14
IDE04924-ENG115859-Driving light and side lights-Parklicht ueber LSS aktiviert, not active, 14
IDE04924-ENG115831-Driving light and side lights-Schlusslicht mit Bremslichtfunktion, not active, 14
IDE04924-ENG126816-Light for driving and side lights-Standlicht aus, act. ,fourteen
IDE04924-ENG115829-Riding light and side lights-Standlichtreduzierung mit beidseitigem Parklicht, not active, 14
IDE04924-ENG122200-Riding light and side lights-Warnung Fahrt mit Standlicht, not active, 14
IDE04924-ENG115860-Drive light and side lights-Zahl der aktiven Scheinwerfer auf 2 limitieren, in Betrieb lassen, 14
IDE04924-ENG115830-Driving light and side lights-Zeitwert Einschaltzeit Abbiegelicht, 15 min, 14
IDE04926-ENG115656-Comfort Lighting-Coming Home Leuchten, Dipped, 8
IDE04926-ENG116601-Comfort Lighting-Coming Home Verbaustatus, automatic, 8
IDE04926-ENG116604-Comfort lighting-Coming-home Einschaltereignis, Driver's door, 8
IDE04926-ENG116608-Comfortable lighting-Helligkeitsschwelle Forward-Messung, 46400 lx, 8
IDE04926-ENG116605-Comfortable lighting-Helligkeitsschwelle Infrarot-Messung, 12 lx, 8
IDE04926-ENG115657-Comfortable lighting-Leaving-Home Verbausstatus, Enabled, 8
IDE04926-ENG116603-Comfortable lighting-Menueeinstellung Cominghome, 10 s, 8
IDE04926-ENG116607-Comfortable lighting-Menueeinstellung Leaving-home Zeit per BAP, 10 s, 8
IDE04926-ENG116602-Comfortable lighting-Menuesteuerung Coming Home Werkseinstellung, act. ,8
IDE04926-ENG116606-Comfortable lighting-Menuesteuerung Leaving-home Freischaltung per BAP, act. ,8
IDE04927-IDE01446-Glass heating-Windshield heating: operating time, 240 s, 8
IDE04927-ENG126847-Glass heating-Abschalttemperatur fuer Frontscheibenheizung, 35.00 ° C, 8
IDE04927-ENG126846-Glass heating-Abschalttemperatur fuer Heckscheibenheizung, 35.00 ° C, 8
IDE04927-ENG126845-Glass heating-FSH Automatik, act. ,8
IDE04927-ENG115736-Glass heating-Heckscheibenheizung Zeitwert, 920 s, 8
IDE04927-ENG116620-Glass heating-Temperaturabhaengige Einschaltzeit FSH, act. ,8
IDE04927-ENG116619-Glass heating-Temperaturabhaengige Einschaltzeit HSH, act. ,8
IDE04928-ENG115867-Security system-Akustischer Alarm Signalhorn, act. ,four
IDE04928-ENG115864-Security system-Alarmsignal, frequency modulated, 4
IDE04928-ENG115865-Security System-DWA Alarmverzoegerung, not active, 4
IDE04928-ENG115812-Security System-DWA Camper Modus, not active, 4
IDE04928-ENG115866-Security System-Sirenen Alarmzahl, 1 Alarm, 4
IDE04928-ENG126842-Security system-Ueberwachung Innenentriegelungshebel, not active, 4
IDE04928-ENG115868-Security system-Verzoegerung Panikalarm, keine verzoegerung, 4
IDE05142-ENG116628-Access Control-Autolock Autounlock wirkt auf Heck, act. ,8
IDE05142-ENG116621-Access control-automatisches Entriegeln, act. ,8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit, act. ,8
IDE05142-ENG116706-Access Control-Autounlock NAR, act. ,8
IDE05142-ENG116632-Access Control-Bewusstes Safe mit 2. Betaetigung der FFB, not active, 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung, act. ,8
IDE05142-ENG133387-Access control-Deaktivierung_Laderaumschliessung_extern, not active, 8
IDE05142-ENG125653-Access Control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster, act. ,8
IDE05142-ENG115759-Access Control-Direkter Auswurf des Heckdeckels, act. ,8
IDE05142-ENG115722-Access control-Electric shutter luggage compartment shutter, not active, 8
IDE05142-ENG126839-Access Control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang, not active, 8
IDE05142-ENG126837-Access Control-Entsafen mit autorisierte Klemme 15 Ein, not active, 8
IDE05142-ENG116707-Access Control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster, not active, 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein, act. ,8
IDE05142-ENG116622-Access Control-Geschwindigkeitsabhaengige Tankdeckelverriegelung, not active, 8
IDE05142-ENG116627-Access Control-Heckdeckel-Bedienstellen nachCrash temporaer sperren, act. ,8
IDE05142-ENG133386-Access Control-Heckfreigabe_Ohne_Verzoegerung, not active, 8
IDE05142-ENG133388-Access Control-LS_Taster_Togglefunktion, not active, 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung, act. ,8
IDE05142-ENG116634-Access Control-Menuesteuerung ZV Autolock-Unlock, adjustable, 8
IDE05142-ENG137162-Access Control-Mindestbetaetigung_HDF_Innentaster, 0.00 s, 8
IDE05142-ENG115761-Access Control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt, not active, 8
IDE05142-ENG115755-Access Control-Notschlie? Funktion, act. ,8
IDE05142-ENG133389-Access Control-Nutzfahrzeug_Schliessung, not active, 8
IDE05142-ENG116626-Access Control-Oeffnung Heckdeckel bei Wiederentriegelung, not active, 8
IDE05142-ENG116631-Access Control-Schliessung der Schiebetuer bei geoeffneter Tankklappe, not active, 8
IDE05142-ENG125652-Access Control-Servoheck Schlossansteuerung, always, 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden, always, 8
IDE05142-ENG115758-Access Control-Valet Parking, not active, 8
IDE05142-ENG126840-Access Control-Vorrastenhaenger_Freigabe, not active, 8
IDE05142-ENG116630-Access Control-Wiederholte Heckansteuerung beim Schliessen FT oder BT, not active, 8
IDE05142-ENG116625-Access Control-Wiederoeffnung Elektrische-Schiebetuer, not active, 8
IDE05142-ENG133390-Access Control-Wiederverriegelung_Laderaum, Freigabe_Softtouch, 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel, act. ,8
IDE05142-ENG116629-Access Control-ZV Heck nur direkt auswerfen, not active, 8
IDE05142-ENG116623-Access Control-ZV Tuerentriegelung, Einzeltuerentriegelung, 8
IDE05142-ENG116635-Access Control-ZV-Entriegelung nach Seitencrash, not active, 8
IDE05143-MAS02985-Saving Parameters-Value, 130, 5
IDE05143-MAS04381-Saving parameters-Parameter Address, FE 00 00, 5
IDE05144-Parameter Address: Read, FE 00 00, 3
IDE05145-ENG115874-Lantern Configuration-BAP Bitposition 0.34, 560
IDE05145-ENG115893-Lantern Configuration-BAP Bitposition 1,3E, 560
IDE05145-ENG116063-Lantern Configuration-BAP Bitposition 10.00, 560
IDE05145-ENG116082-Lantern Configuration-BAP Bitposition 11.00, 560
IDE05145-ENG116101-Lantern Configuration-BAP Bitposition 12.38, 560
IDE05145-ENG116120-Lantern Configuration-BAP Bitposition 13.42, 560
IDE05145-ENG116139-Lantern Configuration-BAP Bitposition 14.00, 560
IDE05145-ENG116158-Lantern Configuration-BAP Bitposition 15.00560
IDE05145-ENG116177-Lantern Configuration-BAP Bitposition 16.00, 560
IDE05145-ENG116196-Lantern Configuration-BAP Bitposition 17.00, 560
IDE05145-ENG116215-Lantern Configuration-BAP Bitposition 18.08, 560
IDE05145-ENG116234-Lantern Configuration-BAP Bitposition 19.18, 560
IDE05145-ENG115911-Lantern Configuration-BAP Bitposition 2.00, 560
IDE05145-ENG116253-Lantern Configuration-BAP Bitposition 20.10, 560
IDE05145-ENG116272-Lantern Configuration-BAP Bitposition 21.20, 560
IDE05145-ENG116291-Lantern Configuration-BAP Bitposition 22.29, 560
IDE05145-ENG116310-Lantern Configuration-BAP Bitposition 23.0A, 560
IDE05145-ENG116329-Lantern Configuration-BAP Bitposition 24.1A, 560
IDE05145-ENG116348-Lantern Configuration-BAP Bitposition 25.28, 560
IDE05145-ENG116367-Lantern Configuration-BAP Bitposition 26.0C, 560
IDE05145-ENG116386-Lantern Configuration-BAP Bitposition 27.00, 560
IDE05145-ENG116405-Lantern Configuration-BAP Bitposition 28.0B, 560
IDE05145-ENG116424-Lantern Configuration-BAP Bitposition 29.1B, 560
IDE05145-ENG115930-Lantern Configuration-BAP Bitposition 3.00, 560
IDE05145-ENG116443-Lantern Configuration-BAP Bitposition 30.00, 560
IDE05145-ENG116462-Lantern Configuration-BAP Bitposition 31.00, 560
IDE05145-ENG116481-Lantern Configuration-BAP Bitposition 32.00, 560
IDE05145-ENG116500-Lantern Configuration-BAP Bitposition 33.00, 560
IDE05145-ENG116519-Lantern Configuration-BAP Bitposition 34.00, 560
IDE05145-ENG115949-Lantern Configuration-BAP Bitposition 4.48, 560
IDE05145-ENG115968-Lantern Configuration-BAP Bitposition 5.4C, 560
IDE05145-ENG115987-Lantern Configuration-BAP Bitposition 6.36, 560
IDE05145-ENG116006-Lantern Configuration-BAP Bitposition 7.40, 560
IDE05145-ENG116025-Lantern Configuration-BAP Bitposition 8.37, 560
IDE05145-ENG116044-Lantern Configuration-BAP Bitposition 9.41, 560
IDE05145-ENG115883-Lantern Configuration-Dimming Direction CD 0, maximize, 560
IDE05145-ENG115902-Lantern Configuration-Dimming Direction CD 1, maximize, 560
IDE05145-ENG116072-Lantern Configuration-Dimming Direction CD 10, maximize, 560
IDE05145-ENG116091-Lantern Configuration-Dimming Direction CD 11, maximize, 560
IDE05145-ENG116110-Lantern Configuration-Dimming Direction CD 12, maximize, 560
IDE05145-ENG116129-Lantern Configuration-Dimming Direction CD 13, maximize, 560
IDE05145-ENG116148-Lantern Configuration-Dimming Direction CD 14, maximize, 560
IDE05145-ENG116167-Lantern Configuration-Dimming Direction CD 15, maximize, 560
IDE05145-ENG116186-Lantern Configuration-Dimming Direction CD 16, maximize, 560
IDE05145-ENG116205-Lantern Configuration-Dimming Direction CD 17, maximize, 560
IDE05145-ENG116224-Lantern Configuration-Dimming Direction CD 18, maximize, 560
IDE05145-ENG116243-Lantern Configuration-Dimming Direction CD 19, maximize, 560
IDE05145-ENG115920-Lantern Configuration-Dimming Direction CD 2, maximize, 560
IDE05145-ENG116262-Lantern Configuration-Dimming Direction CD 20, maximize, 560
IDE05145-ENG116281-Lantern Configuration-Dimming Direction CD 21, maximize, 560
IDE05145-ENG116300-Lantern Configuration-Dimming Direction CD 22, maximize, 560
IDE05145-ENG116319-Lantern Configuration-Dimming Direction CD 23, maximize, 560
IDE05145-ENG116338-Lantern Configuration-Dimming Direction CD 24, maximize, 560
IDE05145-ENG116357-Lantern Configuration-Dimming Direction CD 25, maximize, 560
IDE05145-ENG116376-Lantern Configuration-Dimming Direction CD 26, maximize, 560
IDE05145-ENG116395-Lantern Configuration-Dimming Direction CD 27, maximize, 560
IDE05145-ENG116414-Lantern Configuration-Dimming Direction CD 28, maximize, 560
IDE05145-ENG116433-Lantern Configuration-Dimming Direction CD 29, maximize, 560
IDE05145-ENG115939-Lantern Configuration-Dimming Direction CD 3, maximize, 560
IDE05145-ENG116452-Lantern Configuration-Dimming Direction CD 30, maximize, 560
IDE05145-ENG116471-Lantern Configuration-Dimming Direction CD 31, maximize, 560
IDE05145-ENG116490-Lantern Configuration-Dimming Direction CD 32, maximize, 560
IDE05145-ENG116509-Lantern Configuration-Dimming Direction CD 33, maximize, 560
IDE05145-ENG116528-Lantern Configuration-Dimming Direction CD 34, maximize, 560
IDE05145-ENG115958-Lantern Configuration-Dimming Direction CD 4, minimize, 560
IDE05145-ENG115977-Lantern Configuration-Dimming Direction CD 5, minimize, 560
IDE05145-ENG115996-Lantern Configuration-Dimming Direction CD 6, maximize, 560
IDE05145-ENG116015-Lantern Configuration-Dimming Direction CD 7, maximize, 560
IDE05145-ENG116034-Lantern Configuration-Dimming Direction CD 8, maximize, 560
IDE05145-ENG116053-Lantern Configuration-Dimming Direction CD 9, maximize, 560
IDE05145-ENG115887-Lantern Configuration-Dimming Direction EF 0, maximize, 560
IDE05145-ENG115906-Lantern Configuration-Dimming Direction EF 1, maximize, 560
IDE05145-ENG116076-Lantern Configuration-Dimming Direction EF 10, maximize, 560
IDE05145-ENG116095-Lantern Configuration-Dimming Direction EF 11, maximize, 560
IDE05145-ENG116114-Lantern Configuration-Dimming Direction EF 12, maximize, 560
IDE05145-ENG116133-Configuration of lights -Dimming Direction EF 13, maximize, 560
IDE05145-ENG116152-Lantern Configuration-Dimming Direction EF 14, maximize, 560
IDE05145-ENG116171-Lantern Configuration-Dimming Direction EF 15, maximize, 560
IDE05145-ENG116190-Lantern Configuration-Dimming Direction EF 16, maximize, 560
IDE05145-ENG116209-Lantern Configuration-Dimming Direction EF 17, maximize, 560
IDE05145-ENG116228-Lantern Configuration-Dimming Direction EF 18, maximize, 560
IDE05145-ENG116247-Lantern Configuration-Dimming Direction EF 19, maximize, 560
IDE05145-ENG115924-Lantern Configuration-Dimming Direction EF 2, maximize, 560
IDE05145-ENG116266-Lantern Configuration-Dimming Direction EF 20, maximize, 560
IDE05145-ENG116285-Lantern Configuration-Dimming Direction EF 21, maximize, 560
IDE05145-ENG116304-Lantern Configuration-Dimming Direction EF 22, maximize, 560
IDE05145-ENG116323-Lantern Configuration-Dimming Direction EF 23, maximize, 560
IDE05145-ENG116342-Lantern Configuration-Dimming Direction EF 24, maximize, 560
IDE05145-ENG116361-Lantern Configuration-Dimming Direction EF 25, maximize, 560
IDE05145-ENG116380-Lantern Configuration-Dimming Direction EF 26, maximize, 560
IDE05145-ENG116399-Lantern Configuration-Dimming Direction EF 27, maximize, 560
IDE05145-ENG116418-Lantern Configuration-Dimming Direction EF 28, maximize, 560
IDE05145-ENG116437-Lantern Configuration-Dimming Direction EF 29, maximize, 560
IDE05145-ENG115943-Lantern Configuration-Dimming Direction EF 3, maximize, 560
IDE05145-ENG116456-Lantern Configuration-Dimming Direction EF 30, maximize, 560
IDE05145-ENG116475-Lantern Configuration-Dimming Direction EF 31, maximize, 560
IDE05145-ENG116494-Lantern Configuration-Dimming Direction EF 32, maximize, 560
IDE05145-ENG116513-Lantern Configuration-Dimming Direction EF 33, maximize, 560
IDE05145-ENG116532-Lantern Configuration-Dimming Direction EF 34, maximize, 560
IDE05145-ENG115962-Lantern Configuration-Dimming Direction EF 4, maximize, 560
IDE05145-ENG115981-Lantern Configuration-Dimming Direction EF 5, maximize, 560
IDE05145-ENG116000-Lantern Configuration-Dimming Direction EF 6, maximize, 560
IDE05145-ENG116019-Lantern Configuration-Dimming Direction EF 7, maximize, 560
IDE05145-ENG116038-Lantern Configuration-Dimming Direction EF 8, maximize, 560
IDE05145-ENG116057-Lantern Configuration-Dimming Direction EF 9, maximize, 560
IDE05145-ENG115891-Lantern Configuration-Dimming Direction GH 0, maximize, 560
IDE05145-ENG115909-Lantern Configuration-Dimming Direction GH 1, maximize, 560
IDE05145-ENG116080-Lantern Configuration-Dimming Direction GH 10, maximize, 560
IDE05145-ENG116099-Lantern Configuration-Dimming Direction GH 11, maximize, 560
IDE05145-ENG116118-Lantern Configuration-Dimming Direction GH 12, maximize, 560
IDE05145-ENG116137-Lantern Configuration-Dimming Direction GH 13, maximize, 560
IDE05145-ENG116156-Lantern Configuration-Dimming Direction GH 14, maximize, 560
IDE05145-ENG116175-Lantern Configuration-Dimming Direction GH 15, maximize, 560
IDE05145-ENG116194-Lantern Configuration-Dimming Direction GH 16, maximize, 560
IDE05145-ENG116213-Lantern Configuration-Dimming Direction GH 17, maximize, 560
IDE05145-ENG116232-Lantern Configuration-Dimming Direction GH 18, maximize, 560
IDE05145-ENG116251-Lantern Configuration-Dimming Direction GH 19, maximize, 560
IDE05145-ENG115928-Lantern Configuration-Dimming Direction GH 2, maximize, 560
IDE05145-ENG116270-Lantern Configuration-Dimming Direction GH 20, maximize, 560
IDE05145-ENG116289-Lantern Configuration-Dimming Direction GH 21, maximize, 560
IDE05145-ENG116308-Lantern Configuration-Dimming Direction GH 22, maximize, 560
IDE05145-ENG116327-Lantern Configuration-Dimming Direction GH 23, maximize, 560
IDE05145-ENG116346-Lantern Configuration-Dimming Direction GH 24, maximize, 560
IDE05145-ENG116365-Lantern Configuration-Dimming Direction GH 25, maximize, 560
IDE05145-ENG116384-Lantern Configuration-Dimming Direction GH 26, maximize, 560
IDE05145-ENG116403-Lantern Configuration-Dimming Direction GH 27, maximize, 560
IDE05145-ENG116422-Lantern Configuration-Dimming Direction GH 28, maximize, 560
IDE05145-ENG116441-Lantern Configuration-Dimming Direction GH 29, maximize, 560
IDE05145-ENG115947-Lantern Configuration-Dimming Direction GH 3, maximize, 560
IDE05145-ENG116460-Lantern Configuration-Dimming Direction GH 30, maximize, 560
IDE05145-ENG116479-Lantern Configuration-Dimming Direction GH 31, maximize, 560
IDE05145-ENG116498-Lantern Configuration-Dimming Direction GH 32, maximize, 560
IDE05145-ENG116517-Lantern Configuration-Dimming Direction GH 33, maximize, 560
IDE05145-ENG116536-Lantern Configuration-Dimming Direction GH 34, maximize, 560
IDE05145-ENG115966-Lantern Configuration-Dimming Direction GH 4, minimize, 560
IDE05145-ENG115985-Lantern Configuration-Dimming Direction GH 5, minimize, 560
IDE05145-ENG116004-Lantern Configuration-Dimming Direction GH 6, maximize, 560
IDE05145-ENG116023-Lantern Configuration-Dimming Direction GH 7, maximize, 560
IDE05145-ENG116042-Lantern Configuration-Dimming DirectionGH 8, maximize, 560
IDE05145-ENG116061-Lantern Configuration-Dimming Direction GH 9, maximize, 560
IDE05145-ENG115878-Lantern Configuration-Dimmwert AB 0,100, 560
IDE05145-ENG115897-Lantern Configuration-Dimmwert AB 1,100, 560
IDE05145-ENG116067-Lantern Configuration-Dimmwert AB 10.0, 560
IDE05145-ENG116086-Lantern Configuration-Dimmwert AB 11.0, 560
IDE05145-ENG116105-Lantern Configuration-Dimmwert AB 12,100, 560
IDE05145-ENG116124-Lantern Configuration-Dimmwert AB 13,100, 560
IDE05145-ENG116143-Lantern Configuration-Dimmwert AB 14.0, 560
IDE05145-ENG116162-Lantern Configuration-Dimmwert AB 15.0, 560
IDE05145-ENG116181-Lantern Configuration-Dimmwert AB 16.0, 560
IDE05145-ENG116200-Lantern Configuration-Dimmwert AB 17.0, 560
IDE05145-ENG116219-Lantern Configuration-Dimmwert AB 18,100, 560
IDE05145-ENG116238-Lantern Configuration-Dimmwert AB 19,100, 560
IDE05145-ENG115915-Lantern Configuration-Dimmwert AB 2,100, 560
IDE05145-ENG116257-Lantern Configuration-Dimmwert AB 20,100, 560
IDE05145-ENG116276-Lantern Configuration-Dimmwert AB 21,100, 560
IDE05145-ENG116295-Lantern Configuration-Dimmwert AB 22,100, 560
IDE05145-ENG116314-Lantern Configuration-Dimmwert AB 23.25, 560
IDE05145-ENG116333-Lantern Configuration-Dimmwert AB 24.25, 560
IDE05145-ENG116352-Lantern Configuration-Dimmwert AB 25,127, 560
IDE05145-ENG116371-Lantern Configuration-Dimmwert AB 26,100, 560
IDE05145-ENG116390-Lantern Configuration-Dimmwert AB 27.0, 560
IDE05145-ENG116409-Lantern Configuration-Dimmwert AB 28,100, 560
IDE05145-ENG116428-Lantern Configuration-Dimmwert AB 29,100, 560
IDE05145-ENG115934-Lantern Configuration-Dimmwert AB 3,100, 560
IDE05145-ENG116447-Lantern Configuration-Dimmwert AB 30,100, 560
IDE05145-ENG116466-Lantern Configuration-Dimmwert AB 31.0, 560
IDE05145-ENG116485-Lantern Configuration-Dimmwert AB 32.0, 560
IDE05145-ENG116504-Lantern Configuration-Dimmwert AB 33.0, 560
IDE05145-ENG116523-Lantern Configuration-Dimmwert AB 34.0, 560
IDE05145-ENG115953-Lantern Configuration-Dimmwert AB 4,100, 560
IDE05145-ENG115972-Lantern Configuration-Dimmwert AB 5,100, 560
IDE05145-ENG115991-Lantern Configuration-Dimmwert AB 6,100, 560
IDE05145-ENG116010-Lantern Configuration-Dimmwert AB 7,100, 560
IDE05145-ENG116029-Lantern Configuration-Dimmwert AB 8,100, 560
IDE05145-ENG116048-Lantern Configuration-Dimmwert AB 9,100, 560
IDE05145-ENG115882-Lantern Configuration-Dimmwert CD 0,0, 560
IDE05145-ENG115901-Flashlight Configuration-Dimmwert CD 1.0, 560
IDE05145-ENG116071-Lantern Configuration-Dimmwert CD 10.0, 560
IDE05145-ENG116090-Lantern Configuration-Dimmwert CD 11.0, 560
IDE05145-ENG116109-Lantern Configuration-Dimmwert CD 12.0, 560
IDE05145-ENG116128-Lantern Configuration-Dimmwert CD 13.0, 560
IDE05145-ENG116147-Lantern Configuration-Dimmwert CD 14.0, 560
IDE05145-ENG116166-Lantern Configuration-Dimmwert CD 15.0, 560
IDE05145-ENG116185-Lantern Configuration-Dimmwert CD 16.0, 560
IDE05145-ENG116204-Lantern Configuration-Dimmwert CD 17.0, 560
IDE05145-ENG116223-Lantern Configuration-Dimmwert CD 18.0, 560
IDE05145-ENG116242-Lantern Configuration-Dimmwert CD 19.0, 560
IDE05145-ENG115919-Lantern Configuration-Dimmwert CD 2.0, 560
IDE05145-ENG116261-Lantern Configuration-Dimmwert CD 20.25, 560
IDE05145-ENG116280-Lantern Configuration-Dimmwert CD 21.25, 560
IDE05145-ENG116299-Lantern Configuration-Dimmwert CD 22,100, 560
IDE05145-ENG116318-Lantern Configuration-Dimmwert CD 23,100, 560
IDE05145-ENG116337-Lantern Configuration-Dimmwert CD 24,100, 560
IDE05145-ENG116356-Lantern Configuration-Dimmwert CD 25.0, 560
IDE05145-ENG116375-Lantern Configuration-Dimmwert CD 26.0, 560
IDE05145-ENG116394-Lantern Configuration-Dimmwert CD 27,100, 560
IDE05145-ENG116413-Lantern Configuration-Dimmwert CD 28.0, 560
IDE05145-ENG116432-Lantern Configuration-Dimmwert CD 29.0, 560
IDE05145-ENG115938-Lantern Configuration-Dimmwert CD 3.0, 560
IDE05145-ENG116451-Lantern Configuration-Dimmwert CD 30.0, 560
IDE05145-ENG116470-Lantern Configuration-Dimmwert CD 31.0, 560
IDE05145-ENG116489-Lantern Configuration-Dimmwert CD 32.0, 560
IDE05145-ENG116508-Lantern Configuration-Dimmwert CD 33.0, 560
IDE05145-ENG116527-Lantern Configuration-Dimmwert CD 34.0, 560
IDE05145-ENG115957-Lantern Configuration-Dimmwert CD 4.0, 560
IDE05145-ENG115976-Lantern Configuration-Dimmwert CD 5.0, 560
IDE05145-ENG115995-Flashlight Configuration-Dimmwert CD 6.0, 560
IDE05145-ENG116014-Lantern Configuration-Dimmwert CD 7.0, 560
IDE05145-ENG116033-Lantern Configuration-Dimmwert CD 8.0, 560
IDE05145-ENG116052-Lantern Configuration-Dimmwert CD 9.0, 560
IDE05145-ENG115886-Lantern Configuration-Dimmwert EF 0,0, 560
IDE05145-ENG115905-Lantern Configuration-Dimmwert EF 1.0, 560
IDE05145-ENG116075-Lantern Configuration-Dimmwert EF 10.0, 560
IDE05145-ENG116094-Lantern Configuration-Dimmwert EF 11.0, 560
IDE05145-ENG116113-Lantern Configuration-Dimmwert EF 12.0, 560
IDE05145-ENG116132-Lantern Configuration-Dimmwert EF 13.0, 560
IDE05145-ENG116151-Lantern Configuration-Dimmwert EF 14.0, 560
IDE05145-ENG116170-Lantern Configuration-Dimmwert EF 15.0, 560
IDE05145-ENG116189-Lantern Configuration-Dimmwert EF 16.0, 560
IDE05145-ENG116208-Lantern Configuration-Dimmwert EF 17.0, 560
IDE05145-ENG116227-Lantern Configuration-Dimmwert EF 18.0, 560
IDE05145-ENG116246-Lantern Configuration-Dimmwert EF 19.0, 560
IDE05145-ENG115923-Lantern Configuration-Dimmwert EF 2.0, 560
IDE05145-ENG116265-Lantern Configuration-Dimmwert EF 20.0, 560
IDE05145-ENG116284-Lantern Configuration-Dimmwert EF 21.0, 560
IDE05145-ENG116303-Lantern Configuration-Dimmwert EF 22.0, 560
IDE05145-ENG116322-Lantern Configuration-Dimmwert EF 23.0, 560
IDE05145-ENG116341-Lantern Configuration-Dimmwert EF 24.0, 560
IDE05145-ENG116360-Lantern Configuration-Dimmwert EF 25.0, 560
IDE05145-ENG116379-Lantern Configuration-Dimmwert EF 26.0, 560
IDE05145-ENG116398-Lantern Configuration-Dimmwert EF 27.0, 560
IDE05145-ENG116417-Lantern Configuration-Dimmwert EF 28.0, 560
IDE05145-ENG116436-Lantern Configuration-Dimmwert EF 29.0, 560
IDE05145-ENG115942-Lantern Configuration-Dimmwert EF 3.0, 560
IDE05145-ENG116455-Lantern Configuration-Dimmwert EF 30.0, 560
IDE05145-ENG116474-Lantern Configuration-Dimmwert EF 31.0, 560
IDE05145-ENG116493-Lantern Configuration-Dimmwert EF 32.0, 560
IDE05145-ENG116512-Lantern Configuration-Dimmwert EF 33.0, 560
IDE05145-ENG116531-Lantern Configuration-Dimmwert EF 34.0, 560
IDE05145-ENG115961-Lantern Configuration-Dimmwert EF 4.31, 560
IDE05145-ENG115980-Lantern Configuration-Dimmwert EF 5.31, 560
IDE05145-ENG115999-Lantern Configuration-Dimmwert EF 6.0, 560
IDE05145-ENG116018-Lantern Configuration-Dimmwert EF 7.0, 560
IDE05145-ENG116037-Lantern Configuration-Dimmwert EF 8.0, 560
IDE05145-ENG116056-Lantern Configuration-Dimmwert EF 9.0, 560
IDE05145-ENG115890-Lantern Configuration-Dimmwert GH 0,0, 560
IDE05145-ENG115908-Lantern Configuration-Dimmwert GH 1.0, 560
IDE05145-ENG116079-Lantern Configuration-Dimmwert GH 10.0, 560
IDE05145-ENG116098-Lantern Configuration-Dimmwert GH 11.0, 560
IDE05145-ENG116117-Lantern Configuration-Dimmwert GH 12.0, 560
IDE05145-ENG116136-Lantern Configuration-Dimmwert GH 13.0, 560
IDE05145-ENG116155-Lantern Configuration-Dimmwert GH 14.0, 560
IDE05145-ENG116174-Lantern Configuration-Dimmwert GH 15.0, 560
IDE05145-ENG116193-Lantern Configuration-Dimmwert GH 16.0, 560
IDE05145-ENG116212-Lantern Configuration-Dimmwert GH 17.0, 560
IDE05145-ENG116231-Lantern Configuration-Dimmwert GH 18.0, 560
IDE05145-ENG116250-Lantern Configuration-Dimmwert GH 19.0, 560
IDE05145-ENG115927-Lantern Configuration-Dimmwert GH 2.0, 560
IDE05145-ENG116269-Lantern Configuration-Dimmwert GH 20.0, 560
IDE05145-ENG116288-Lantern Configuration-Dimmwert GH 21.0, 560
IDE05145-ENG116307-Lantern Configuration-Dimmwert GH 22.0, 560
IDE05145-ENG116326-Lantern Configuration-Dimmwert GH 23.0, 560
IDE05145-ENG116345-Lantern Configuration-Dimmwert GH 24.0, 560
IDE05145-ENG116364-Lantern Configuration-Dimmwert GH 25.0, 560
IDE05145-ENG116383-Lantern Configuration-Dimmwert GH 26.0, 560
IDE05145-ENG116402-Lantern Configuration-Dimmwert GH 27.0, 560
IDE05145-ENG116421-Lantern Configuration-Dimmwert GH 28.0, 560
IDE05145-ENG116440-Lantern Configuration-Dimmwert GH 29.0, 560
IDE05145-ENG115946-Lantern Configuration-Dimmwert GH 3.0, 560
IDE05145-ENG116459-Lantern Configuration-Dimmwert GH 30.0, 560
IDE05145-ENG116478-Lantern Configuration-Dimmwert GH 31.0, 560
IDE05145-ENG116497-Lantern Configuration-Dimmwert GH 32.0, 560
IDE05145-ENG116516-Lantern Configuration-Dimmwert GH 33.0, 560
IDE05145-ENG116535-Lantern Configuration-Dimmwert GH 34.0, 560
IDE05145-ENG115965-Lantern Configuration-Dimmwert GH 4.0, 560
IDE05145-ENG115984-Lantern Configuration-Dimmwert GH 5.0, 560
IDE05145-ENG116003-Lantern Configuration-Dimmwert GH 6.0, 560
IDE05145-ENG116022-Lantern Configuration-Dimmwert GH 7.0, 560
IDE05145-ENG116041-Lantern Configuration-Dimmwert GH 8.0, 560
IDE05145-ENG116060-Lantern Configuration-Dimmwert GH 9.0, 560
IDE05145-ENG115875-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 0.14, 560
IDE05145-ENG115894-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 1.15, 560
IDE05145-ENG116064-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 10.00, 560
IDE05145-ENG116083-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 11.00, 560
IDE05145-ENG116102-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 12.22, 560
IDE05145-ENG116121-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 13.23, 560
IDE05145-ENG116140-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 14.00, 560
IDE05145-ENG116159-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 15.00, 560
IDE05145-ENG116178-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 16.00, 560
IDE05145-ENG116197-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 17.00, 560
IDE05145-ENG116216-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 18.16, 560
IDE05145-ENG116235-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 19.18, 560
IDE05145-ENG115912-Configuration fOnarey-Fehlerort mittleres Byte DTC-DFCC 2.45, 560
IDE05145-ENG116254-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 20.39, 560
IDE05145-ENG116273-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 21.3A, 560
IDE05145-ENG116292-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 22,2C, 560
IDE05145-ENG116311-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 23.29, 560
IDE05145-ENG116330-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 24.2A, 560
IDE05145-ENG116349-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 25.30, 560
IDE05145-ENG116368-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 26,2E, 560
IDE05145-ENG116387-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 27.00, 560
IDE05145-ENG116406-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 28.31, 560
IDE05145-ENG116425-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 29.32, 560
IDE05145-ENG115931-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 3.46, 560
IDE05145-ENG116444-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 30.02, 560
IDE05145-ENG116463-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 31.00, 560
IDE05145-ENG116482-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 32.00, 560
IDE05145-ENG116501-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 33.00, 560
IDE05145-ENG116520-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 34.00, 560
IDE05145-ENG115950-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 4.43, 560
IDE05145-ENG115969-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 5.44, 560
IDE05145-ENG115988-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 6.1A, 560
IDE05145-ENG116007-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 7.1B, 560
IDE05145-ENG116026-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 8.1C, 560
IDE05145-ENG116045-Lantern Configuration-Fehlerort mittleres Byte DTC-DFCC 9.1D, 560
IDE05145-ENG115873-Lantern Configuration-Lasttyp 0.12 - Blinkleuchten, 560
IDE05145-ENG115892-Lantern Configuration-Lasttyp 1.12 - Blinkleuchten, 560
IDE05145-ENG116062-Lantern Configuration-Lasttyp 10, not active, 560
IDE05145-ENG116081-Lantern Configuration-Lasttyp 11, not active, 560
IDE05145-ENG116100-Lantern Configuration-Lasttyp 12.10 - allgemeine Scheinwerfer, 560
IDE05145-ENG116119-Lantern Configuration-Lasttyp 13.10 - allgemeine Scheinwerfer, 560
IDE05145-ENG116138-Lantern Configuration-Lasttyp 14, not active, 560
IDE05145-ENG116157-Lantern Configuration-Lasttyp 15, not active, 560
IDE05145-ENG116176-Lantern Configuration-Lasttyp 16, not active, 560
IDE05145-ENG116195-Lantern Configuration-Lasttyp 17, not active, 560
IDE05145-ENG116214-Lantern Configuration-Lasttyp 18.12 - Blinkleuchten, 560
IDE05145-ENG116233-Lantern Configuration-Lasttyp 19.12 - Blinkleuchten, 560
IDE05145-ENG115910-Flashlight Configuration-Lasttyp 2.8 - allgemeine Gl? Hlampe 12W, 560
IDE05145-ENG116252-Lantern Configuration-Lasttyp 20.13 - Bremsleuchten, 560
IDE05145-ENG116271-Lantern Configuration-Lasttyp 21.13 - Bremsleuchten, 560
IDE05145-ENG116290-Lantern Configuration-Lasttyp 22.42 - LED dritte Bremsleuchte, 560
IDE05145-ENG116309-Lantern configuration-Lasttyp 23.9 - allgemeine Gl? Hlampe 27W: auch H15, 560
IDE05145-ENG116328-Lantern configuration-Lasttyp 24.9 - allgemeine Gl? Hlampe 27W: auch H15, 560
IDE05145-ENG116347-Lantern configuration-Lasttyp 25.43 - allgemeine LED, 560
IDE05145-ENG116366-Lantern configuration-Lasttyp 26.9 - allgemeine Gl? Hlampe 27W: auch H15, 560
IDE05145-ENG116385-Lantern Configuration-Lasttyp 27, not active, 560
IDE05145-ENG116404-Lantern configuration-Lasttyp 28.9 - allgemeine Gl? Hlampe 27W: auch H15, 560
IDE05145-ENG116423-Lantern configuration-Lasttyp 29.9 - allgemeine Gl? Hlampe 27W: auch H15, 560
IDE05145-ENG115929-Lantern configuration-Lasttyp 3.8 - allgemeine Gl? Hlampe 12W, 560
IDE05145-ENG116442-Lantern Configuration-Lasttyp 30.36 - LED Kleinleistung, 560
IDE05145-ENG116461-Lantern Configuration-Lasttyp 31, not active, 560
IDE05145-ENG116480-Lantern Configuration-Lasttyp 32, not active, 560
IDE05145-ENG116499-Lantern Configuration-Lasttyp 33, not active, 560
IDE05145-ENG116518-Lantern Configuration-Lasttyp 34, not active, 560
IDE05145-ENG115948-Lantern configuration-Lasttyp 4.9 - allgemeine Gl? Hlampe 27W: auch H15, 560
IDE05145-ENG115967-Lantern configuration-Lasttyp 5.9 - allgemeine Gl? Hlampe 27W: auch H15, 560
IDE05145-ENG115986-Lantern Configuration-Lasttyp 6.11 - Abblendlicht, 560
IDE05145-ENG116005-Lantern Configuration-Lasttyp 7.11 - Abblendlicht, 560
IDE05145-ENG116024-Lantern Configuration-Lasttyp 8.10 - allgemeine Scheinwerfer, 560
IDE05145-ENG116043-Lantern Configuration-Lasttyp 9.10 - allgemeine Scheinwerfer, 560
IDE05145-ENG115879-Lantern configuration-Lichtansteuerung HD AB 0, always, 560
IDE05145-ENG115898-Lantern Configuration-Lichtansteuerung HD AB 1, always, 560
IDE05145-ENG116068-Lantern configuration-Lichtansteuerung HD AB 10, always, 560
IDE05145-ENG116087-Lantern Configuration-Lichtansteuerung HD AB 11 always 560
IDE05145-ENG116106-Lantern configuration-Lichtansteuerung HD AB 12, always, 560
IDE05145-ENG116125-Lantern configuration-Lichtansteuerung HD AB 13, always, 560
IDE05145-ENG116144-Lantern configuration-Lichtansteuerung HD AB 14, always, 560
IDE05145-ENG116163-Lantern Configuration-Lichtansteuerung HD AB 15, always, 560
IDE05145-ENG116182-Lantern configuration-Lichtansteuerung HD AB 16, always, 560
IDE05145-ENG116201-Lantern configuration-Lichtansteuerung HD AB 17, always, 560
IDE05145-ENG116220-Lantern configuration-Lichtansteuerung HD AB 18, always, 560
IDE05145-ENG116239-Lantern configuration-Lichtansteuerung HD AB 19, always, 560
IDE05145-ENG115916-Lantern configuration-Lichtansteuerung HD AB 2, always, 560
IDE05145-ENG116258-Lantern configuration-Lichtansteuerung HD AB 20, always, 560
IDE05145-ENG116277-Lantern configuration-Lichtansteuerung HD AB 21, always, 560
IDE05145-ENG116296-Lantern configuration-Lichtansteuerung HD AB 22, always, 560
IDE05145-ENG116315-Lantern configuration-Lichtansteuerung HD AB 23, always, 560
IDE05145-ENG116334-Lantern Configuration-Lichtansteuerung HD AB 24, always, 560
IDE05145-ENG116353-Lantern Configuration-Lichtansteuerung HD AB 25, always, 560
IDE05145-ENG116372-Lantern Configuration-Lichtansteuerung HD AB 26, only_if_closed, 560
IDE05145-ENG116391-Lantern configuration-Lichtansteuerung HD AB 27, always, 560
IDE05145-ENG116410-Lantern configuration-Lichtansteuerung HD AB 28, always, 560
IDE05145-ENG116430-Lantern configuration-Lichtansteuerung HD AB 29, always, 560
IDE05145-ENG115935-Lantern configuration-Lichtansteuerung HD AB 3, always, 560
IDE05145-ENG116448-Lantern configuration-Lichtansteuerung HD AB 30, always, 560
IDE05145-ENG116467-Lantern configuration-Lichtansteuerung HD AB 31, always, 560
IDE05145-ENG116486-Lantern Configuration-Lichtansteuerung HD AB 32, always, 560
IDE05145-ENG116505-Lantern configuration-Lichtansteuerung HD AB 33, always, 560
IDE05145-ENG116524-Lantern configuration-Lichtansteuerung HD AB 34, always, 560
IDE05145-ENG115954-Lantern Configuration-Lichtansteuerung HD AB 4, always, 560
IDE05145-ENG115973-Lantern configuration-Lichtansteuerung HD AB 5, always, 560
IDE05145-ENG115992-Lantern configuration-Lichtansteuerung HD AB 6, always, 560
IDE05145-ENG116011-Lantern configuration-Lichtansteuerung HD AB 7, always, 560
IDE05145-ENG116030-Lantern configuration-Lichtansteuerung HD AB 8, always, 560
IDE05145-ENG116049-Lantern configuration-Lichtansteuerung HD AB 9, always, 560
IDE05145-ENG116199-Lantern Configuration-Lichtfunktion B 17.0, 560
IDE05145-ENG116126-Lantern Configuration-Lichtfunktion C 13.0, 560
IDE05145-ENG115876-Lantern Configuration-Lichtfunktion A 0.2, 560
IDE05145-ENG115895-Lantern Configuration-Lichtfunktion A 1.4, 560
IDE05145-ENG116065-Lantern Configuration-Lichtfunktion A 10.0, 560
IDE05145-ENG116084-Lantern Configuration-Lichtfunktion A 11.0, 560
IDE05145-ENG116103-Lantern Configuration-Lichtfunktion A 12.18, 560
IDE05145-ENG116122-Lantern Configuration-Lichtfunktion A 13.19, 560
IDE05145-ENG116141-Lantern Configuration-Lichtfunktion A 14.0, 560
IDE05145-ENG116160-Lantern Configuration-Lichtfunktion A 15.0, 560
IDE05145-ENG116179-Lantern Configuration-Lichtfunktion A 16.0, 560
IDE05145-ENG116198-Lantern Configuration-Lichtfunktion A 17.0, 560
IDE05145-ENG116217-Lantern Configuration-Lichtfunktion A 18.2, 560
IDE05145-ENG116236-Lantern Configuration-Lichtfunktion A 19,4, 560
IDE05145-ENG115913-Lantern Configuration-Lichtfunktion A 2.8, 560
IDE05145-ENG116255-Lantern Configuration-Lichtfunktion A 20.24, 560
IDE05145-ENG116274-Lantern Configuration-Lichtfunktion A 21.24, 560
IDE05145-ENG116293-Lantern Configuration-Lichtfunktion A 22.24, 560
IDE05145-ENG116312-Lantern Configuration-Lichtfunktion A 23.8, 560
IDE05145-ENG116331-Lantern Configuration-Lichtfunktion A 24.8, 560
IDE05145-ENG116350-Lantern Configuration-Lichtfunktion A 25.8, 560
IDE05145-ENG116369-Lantern Configuration-Lichtfunktion A 26.27, 560
IDE05145-ENG116388-Lantern Configuration-Lichtfunktion A 27.0, 560
IDE05145-ENG116407-Lantern Configuration-Lichtfunktion A 28.25, 560
IDE05145-ENG116426-Lantern Configuration-Lichtfunktion A 29.25, 560
IDE05145-ENG115932-Lantern Configuration-Lichtfunktion A 3.8, 560
IDE05145-ENG116445-Lantern Configuration-Lichtfunktion A 30.43, 560
IDE05145-ENG116464-Lantern Configuration-Lichtfunktion A 31.0, 560
IDE05145-ENG116483-Lantern Configuration-Lichtfunktion A 32.0, 560
IDE05145-ENG116502-Lantern Configuration-Lichtfunktion A 33.0, 560
IDE05145-ENG116521-Lantern Configuration-Lichtfunktion A 34.0, 560
IDE05145-ENG115951-Lantern Configuration-Lichtfunktion A 4.20, 560
IDE05145-ENG115970-Lantern Configuration-Lichtfunktion A 5.20, 560
IDE05145-ENG115989-Lantern Configuration-Lichtfunktion A 6.11, 560
IDE05145-ENG116008-Lantern Configuration-Lichtfunktion A 7,12,560
IDE05145-ENG116027-Lantern Configuration-Lichtfunktion A 8.13, 560
IDE05145-ENG116046-Lantern configuration-Lichtfunktion A 9.14, 560
IDE05145-ENG115877-Lantern Configuration-Lichtfunktion B 0.0, 560
IDE05145-ENG115896-Lantern Configuration-Lichtfunktion B 1.0, 560
IDE05145-ENG116066-Lantern Configuration-Lichtfunktion B 10.0, 560
IDE05145-ENG116085-Lantern Configuration-Lichtfunktion B 11.0, 560
IDE05145-ENG116104-Lantern Configuration-Lichtfunktion B 12.22, 560
IDE05145-ENG116123-Lantern Configuration-Lichtfunktion B 13.23, 560
IDE05145-ENG116142-Lantern Configuration-Lichtfunktion B 14.0, 560
IDE05145-ENG116161-Lantern Configuration-Lichtfunktion B 15.0, 560
IDE05145-ENG116180-Lantern Configuration-Lichtfunktion B 16.0, 560
IDE05145-ENG116218-Lantern Configuration-Lichtfunktion B 18.0, 560
IDE05145-ENG116237-Lantern Configuration-Lichtfunktion B 19.0, 560
IDE05145-ENG115914-Lantern Configuration-Lichtfunktion B 2.0, 560
IDE05145-ENG116256-Lantern Configuration-Lichtfunktion B 20.33, 560
IDE05145-ENG116275-Lantern Configuration-Lichtfunktion B 21.33, 560
IDE05145-ENG116294-Lantern Configuration-Lichtfunktion B 22.0, 560
IDE05145-ENG116313-Lantern Configuration-Lichtfunktion B 23.0, 560
IDE05145-ENG116332-Lantern Configuration-Lichtfunktion B 24.0, 560
IDE05145-ENG116351-Lantern Configuration-Lichtfunktion B 25.0, 560
IDE05145-ENG116370-Lantern Configuration-Lichtfunktion B 26.0, 560
IDE05145-ENG116389-Lantern Configuration-Lichtfunktion B 27.0, 560
IDE05145-ENG116408-Lantern Configuration-Lichtfunktion B 28.0, 560
IDE05145-ENG116427-Lantern Configuration-Lichtfunktion B 29.0, 560
IDE05145-ENG115933-Lantern Configuration-Lichtfunktion B 3.0, 560
IDE05145-ENG116446-Lantern Configuration-Lichtfunktion B 30.0, 560
IDE05145-ENG116465-Lantern Configuration-Lichtfunktion B 31.0, 560
IDE05145-ENG116484-Lantern Configuration-Lichtfunktion B 32.0, 560
IDE05145-ENG116503-Lantern Configuration-Lichtfunktion B 33.0, 560
IDE05145-ENG116522-Lantern Configuration-Lichtfunktion B 34.0, 560
IDE05145-ENG115952-Lantern Configuration-Lichtfunktion B 4.0, 560
IDE05145-ENG115971-Lantern Configuration-Lichtfunktion B 5.0, 560
IDE05145-ENG115990-Lantern Configuration-Lichtfunktion B 6.0, 560
IDE05145-ENG116009-Lantern Configuration-Lichtfunktion B 7.0, 560
IDE05145-ENG116028-Lantern Configuration-Lichtfunktion B 8.15, 560
IDE05145-ENG116047-Lantern Configuration-Lichtfunktion B 9.15, 560
IDE05145-ENG115880-Lantern Configuration-Lichtfunktion C 0,0, 560
IDE05145-ENG115899-Lantern Configuration-Lichtfunktion C 1.0, 560
IDE05145-ENG116069-Lantern Configuration-Lichtfunktion C 10.0, 560
IDE05145-ENG116088-Lantern Configuration-Lichtfunktion C 11.0, 560
IDE05145-ENG116107-Lantern Configuration-Lichtfunktion C 12.0, 560
IDE05145-ENG116145-Lantern Configuration-Lichtfunktion C 14.0, 560
IDE05145-ENG116164-Lantern Configuration-Lichtfunktion C 15.0, 560
IDE05145-ENG116183-Lantern Configuration-Lichtfunktion C 16.0, 560
IDE05145-ENG116202-Lantern Configuration-Lichtfunktion C 17.0, 560
IDE05145-ENG116221-Lantern Configuration-Lichtfunktion C 18.0, 560
IDE05145-ENG116240-Lantern Configuration-Lichtfunktion C 19.0, 560
IDE05145-ENG115917-Lantern Configuration-Lichtfunktion C 2.0, 560
IDE05145-ENG116259-Lantern Configuration-Lichtfunktion C 20.8, 560
IDE05145-ENG116278-Lantern Configuration-Lichtfunktion C 21.8, 560
IDE05145-ENG116297-Lantern Configuration-Lichtfunktion C 22.33, 560
IDE05145-ENG116316-Lantern Configuration-Lichtfunktion C 23.24, 560
IDE05145-ENG116335-Lantern Configuration-Lichtfunktion C 24.24, 560
IDE05145-ENG116354-Lantern Configuration-Lichtfunktion C 25.0, 560
IDE05145-ENG116373-Lantern Configuration-Lichtfunktion C 26.0, 560
IDE05145-ENG116392-Lantern Configuration-Lichtfunktion C 27.0, 560
IDE05145-ENG116411-Lantern Configuration-Lichtfunktion C 28.0, 560
IDE05145-ENG116429-Lantern Configuration-Lichtfunktion C 29.0, 560
IDE05145-ENG115936-Lantern Configuration-Lichtfunktion C 3.0, 560
IDE05145-ENG116449-Lantern Configuration-Lichtfunktion C 30.0, 560
IDE05145-ENG116468-Lantern Configuration-Lichtfunktion C 31.0, 560
IDE05145-ENG116487-Lantern Configuration-Lichtfunktion C 32.0, 560
IDE05145-ENG116506-Lantern Configuration-Lichtfunktion C 33.0, 560
IDE05145-ENG116525-Lantern Configuration-Lichtfunktion C 34.0, 560
IDE05145-ENG115955-Lantern Configuration-Lichtfunktion C 4.0, 560
IDE05145-ENG115974-Lantern Configuration-Lichtfunktion C 5.0, 560
IDE05145-ENG115993-Lantern Configuration-Lichtfunktion C 6.0, 560
IDE05145-ENG116012-Lantern Configuration-Lichtfunktion C 7.0, 560
IDE05145-ENG116031-Lantern Configuration-Lichtfunktion C 8.0, 560
IDE05145-ENG116050-Lantern Configuration-Lichtfunktion C 9.0, 560
IDE05145-ENG115881-Lantern Configuration-Lichtfunktion D 0,0, 560
IDE05145-ENG115900-Lantern Configuration-Lichtfunktion D 1.0, 560
IDE05145-ENG116070-Lantern Configuration-Lichtfunktion D 10.0, 560
IDE05145-ENG116089-Lantern Configuration-Lichtfunktion D 11.0, 560
IDE05145-ENG116108-Lantern Configuration-Lichtfunktion D 12.0, 560
IDE05145-ENG116127-Lantern Configuration-Lichtfunktion D 13.0, 560
IDE05145-ENG116146-Lantern Configuration-Lichtfunktion D 14.0, 560
IDE05145-ENG116165-ConfigLanterns-Lichtfunktion D 15.0, 560
IDE05145-ENG116184-Lantern Configuration-Lichtfunktion D 16.0, 560
IDE05145-ENG116203-Lantern Configuration-Lichtfunktion D 17.0, 560
IDE05145-ENG116222-Lantern Configuration-Lichtfunktion D 18.0, 560
IDE05145-ENG116241-Lantern Configuration-Lichtfunktion D 19.0, 560
IDE05145-ENG115918-Lantern Configuration-Lichtfunktion D 2.0, 560
IDE05145-ENG116260-Lantern Configuration-Lichtfunktion D 20.0, 560
IDE05145-ENG116279-Lantern Configuration-Lichtfunktion D 21.0, 560
IDE05145-ENG116298-Lantern Configuration-Lichtfunktion D 22.0, 560
IDE05145-ENG116317-Lantern Configuration-Lichtfunktion D 23.0, 560
IDE05145-ENG116336-Lantern Configuration-Lichtfunktion D 24.0, 560
IDE05145-ENG116355-Lantern Configuration-Lichtfunktion D 25.0, 560
IDE05145-ENG116374-Lantern Configuration-Lichtfunktion D 26.0, 560
IDE05145-ENG116393-Lantern Configuration-Lichtfunktion D 27.24, 560
IDE05145-ENG116412-Lantern Configuration-Lichtfunktion D 28.0, 560
IDE05145-ENG116431-Lantern Configuration-Lichtfunktion D 29.0, 560
IDE05145-ENG115937-Lantern Configuration-Lichtfunktion D 3.0, 560
IDE05145-ENG116450-Lantern Configuration-Lichtfunktion D 30.0, 560
IDE05145-ENG116469-Lantern Configuration-Lichtfunktion D 31.0, 560
IDE05145-ENG116488-Lantern Configuration-Lichtfunktion D 32.0, 560
IDE05145-ENG116507-Lantern Configuration-Lichtfunktion D 33.0, 560
IDE05145-ENG116526-Lantern Configuration-Lichtfunktion D 34.0, 560
IDE05145-ENG115956-Lantern Configuration-Lichtfunktion D 4.0, 560
IDE05145-ENG115975-Lantern Configuration-Lichtfunktion D 5.0, 560
IDE05145-ENG115994-Lantern Configuration-Lichtfunktion D 6.0, 560
IDE05145-ENG116013-Lantern Configuration-Lichtfunktion D 7.0, 560
IDE05145-ENG116032-Lantern Configuration-Lichtfunktion D 8.0, 560
IDE05145-ENG116051-Lantern Configuration-Lichtfunktion D 9.0, 560
IDE05145-ENG115884-Lantern Configuration-Lichtfunktion E 0,0, 560
IDE05145-ENG115903-Lantern Configuration-Lichtfunktion E 1.0, 560
IDE05145-ENG116073-Lantern Configuration-Lichtfunktion E 10.0, 560
IDE05145-ENG116092-Lantern Configuration-Lichtfunktion E 11.0, 560
IDE05145-ENG116111-Lantern Configuration-Lichtfunktion E 12.0, 560
IDE05145-ENG116130-Lantern Configuration-Lichtfunktion E 13.0, 560
IDE05145-ENG116149-Lantern Configuration-Lichtfunktion E 14.0, 560
IDE05145-ENG116168-Lantern Configuration-Lichtfunktion E 15.0, 560
IDE05145-ENG116187-Lantern Configuration-Lichtfunktion E 16.0, 560
IDE05145-ENG116206-Lantern Configuration-Lichtfunktion E 17.0, 560
IDE05145-ENG116225-Lantern Configuration-Lichtfunktion E 18.0, 560
IDE05145-ENG116244-Lantern Configuration-Lichtfunktion E 19.0, 560
IDE05145-ENG115921-Lantern Configuration-Lichtfunktion E 2.0, 560
IDE05145-ENG116263-Lantern Configuration-Lichtfunktion E 20.0, 560
IDE05145-ENG116282-Lantern Configuration-Lichtfunktion E 21.0, 560
IDE05145-ENG116301-Lantern Configuration-Lichtfunktion E 22.0, 560
IDE05145-ENG116320-Lantern Configuration-Lichtfunktion E 23.0, 560
IDE05145-ENG116339-Lantern Configuration-Lichtfunktion E 24.0, 560
IDE05145-ENG116358-Lantern Configuration-Lichtfunktion E 25.0, 560
IDE05145-ENG116377-Lantern Configuration-Lichtfunktion E 26.0, 560
IDE05145-ENG116396-Lantern Configuration-Lichtfunktion E 27.0, 560
IDE05145-ENG116415-Lantern Configuration-Lichtfunktion E 28.0, 560
IDE05145-ENG116434-Lantern Configuration-Lichtfunktion E 29.0, 560
IDE05145-ENG115940-Lantern Configuration-Lichtfunktion E 3.0, 560
IDE05145-ENG116453-Lantern Configuration-Lichtfunktion E 30.0, 560
IDE05145-ENG116472-Lantern Configuration-Lichtfunktion E 31.0, 560
IDE05145-ENG116491-Lantern Configuration-Lichtfunktion E 32.0, 560
IDE05145-ENG116510-Lantern Configuration-Lichtfunktion E 33.0, 560
IDE05145-ENG116529-Lantern Configuration-Lichtfunktion E 34.0, 560
IDE05145-ENG115959-Lantern Configuration-Lichtfunktion E 4.8, 560
IDE05145-ENG115978-Lantern Configuration-Lichtfunktion E 5.8, 560
IDE05145-ENG115997-Lantern Configuration-Lichtfunktion E 6.0, 560
IDE05145-ENG116016-Lantern Configuration-Lichtfunktion E 7.0, 560
IDE05145-ENG116035-Lantern Configuration-Lichtfunktion E 8.0, 560
IDE05145-ENG116054-Lantern Configuration-Lichtfunktion E 9.0, 560
IDE05145-ENG115885-Lantern Configuration-Lichtfunktion F 0,0, 560
IDE05145-ENG115904-Lantern Configuration-Lichtfunktion F 1.0, 560
IDE05145-ENG116074-Lantern Configuration-Lichtfunktion F 10.0, 560
IDE05145-ENG116093-Lantern Configuration-Lichtfunktion F 11.0, 560
IDE05145-ENG116112-Lantern Configuration-Lichtfunktion F 12.0, 560
IDE05145-ENG116131-Lantern Configuration-Lichtfunktion F 13.0, 560
IDE05145-ENG116150-Lantern Configuration-Lichtfunktion F 14.0, 560
IDE05145-ENG116169-Lantern Configuration-Lichtfunktion F 15.0, 560
IDE05145-ENG116188-Lantern Configuration-Lichtfunktion F 16.0, 560
IDE05145-ENG116207-Lantern Configuration-Lichtfunktion F 17.0, 560
IDE05145-ENG116226-Lantern Configuration-Lichtfunktion F 18.0, 560
IDE05145-ENG116245-Lantern Configuration-Lichtfunktion F 19.0, 560
IDE05145-ENG115922-Lantern Configuration-Lichtfunktion F 2.0, 560
IDE05145-ENG116264-Lantern Configuration-Lichtfunktion F 20.0, 560
IDE05145-ENG116283-Lantern Configuration-Lichtfunktion F 21.0, 560
IDE05145-ENG116302-Lantern Configuration-Lichtfunktion F 22.0, 560
IDE05145-ENG116321-Lantern Configuration-Lichtfunktion F 23.0, 560
IDE05145-ENG116340-Lantern Configuration-Lichtfunktion F 24.0, 560
IDE05145-ENG116359-Lantern Configuration-Lichtfunktion F 25.0, 560
IDE05145-ENG116378-Lantern Configuration-Lichtfunktion F 26.0, 560
IDE05145-ENG116397-Lantern Configuration-Lichtfunktion F 27.0, 560
IDE05145-ENG116416-Lantern Configuration-Lichtfunktion F 28.0, 560
IDE05145-ENG116435-Lantern Configuration-Lichtfunktion F 29.0, 560
IDE05145-ENG116454-Lantern Configuration-Lichtfunktion F 30.0, 560
IDE05145-ENG116473-Lantern Configuration-Lichtfunktion F 31.0, 560
IDE05145-ENG116492-Lantern Configuration-Lichtfunktion F 32.0, 560
IDE05145-ENG116511-Lantern Configuration-Lichtfunktion F 33.0, 560
IDE05145-ENG116530-Lantern Configuration-Lichtfunktion F 34.0, 560
IDE05145-ENG115960-Lantern Configuration-Lichtfunktion F 4.0, 560
IDE05145-ENG115998-Lantern Configuration-Lichtfunktion F 6.0, 560
IDE05145-ENG116017-Lantern Configuration-Lichtfunktion F 7.0, 560
IDE05145-ENG116036-Lantern Configuration-Lichtfunktion F 8.0, 560
IDE05145-ENG116055-Lantern Configuration-Lichtfunktion F 9.0, 560
IDE05145-ENG115941-Lantern Configuration-Lichtfunktion F3.0, 560
IDE05145-ENG115979-Lantern Configuration-Lichtfunktion F5,0, 560
IDE05145-ENG115888-Lantern Configuration-Lichtfunktion G 0,0, 560
IDE05145-ENG115907-Lantern Configuration-Lichtfunktion G 1.0, 560
IDE05145-ENG116077-Lantern Configuration-Lichtfunktion G 10.0, 560
IDE05145-ENG116096-Lantern Configuration-Lichtfunktion G 11.0, 560
IDE05145-ENG116115-Lantern Configuration-Lichtfunktion G 12.0, 560
IDE05145-ENG116134-Lantern Configuration-Lichtfunktion G 13.0, 560
IDE05145-ENG116153-Lantern Configuration-Lichtfunktion G 14.0, 560
IDE05145-ENG116172-Lantern Configuration-Lichtfunktion G 15.0, 560
IDE05145-ENG116191-Lantern Configuration-Lichtfunktion G 16.0, 560
IDE05145-ENG116210-Lantern Configuration-Lichtfunktion G 17.0, 560
IDE05145-ENG116229-Lantern Configuration-Lichtfunktion G 18.0, 560
IDE05145-ENG116248-Lantern Configuration-Lichtfunktion G 19.0, 560
IDE05145-ENG115925-Lantern Configuration-Lichtfunktion G 2.0, 560
IDE05145-ENG116267-Lantern Configuration-Lichtfunktion G 20.0, 560
IDE05145-ENG116286-Lantern Configuration-Lichtfunktion G 21.0, 560
IDE05145-ENG116305-Lantern Configuration-Lichtfunktion G 22.0, 560
IDE05145-ENG116324-Lantern Configuration-Lichtfunktion G 23.0, 560
IDE05145-ENG116343-Lantern Configuration-Lichtfunktion G 24.0, 560
IDE05145-ENG116362-Lantern Configuration-Lichtfunktion G 25.0, 560
IDE05145-ENG116381-Lantern Configuration-Lichtfunktion G 26.0, 560
IDE05145-ENG116400-Lantern Configuration-Lichtfunktion G 27.0, 560
IDE05145-ENG116419-Lantern Configuration-Lichtfunktion G 28.0, 560
IDE05145-ENG116438-Lantern Configuration-Lichtfunktion G 29.0, 560
IDE05145-ENG115944-Lantern Configuration-Lichtfunktion G 3.0, 560
IDE05145-ENG116457-Lantern Configuration-Lichtfunktion G 30.0, 560
IDE05145-ENG116476-Lantern Configuration-Lichtfunktion G 31.0, 560
IDE05145-ENG116495-Lantern Configuration-Lichtfunktion G 32.0, 560
IDE05145-ENG116514-Lantern Configuration-Lichtfunktion G 33.0, 560
IDE05145-ENG116533-Lantern Configuration-Lichtfunktion G 34.0, 560
IDE05145-ENG115963-Lantern Configuration-Lichtfunktion G 4.11, 560
IDE05145-ENG115982-Lantern Configuration-Lichtfunktion G 5.12, 560
IDE05145-ENG116001-Lantern Configuration-Lichtfunktion G 6.0, 560
IDE05145-ENG116020-Lantern Configuration-Lichtfunktion G 7.0, 560
IDE05145-ENG116039-Lantern Configuration-Lichtfunktion G 8.0, 560
IDE05145-ENG116058-Lantern Configuration-Lichtfunktion G 9.0, 560
IDE05145-ENG115889-Lantern Configuration-Lichtfunktion H 0,0, 560
IDE05145-ENG116549-Lantern Configuration-Lichtfunktion H 1.0, 560
IDE05145-ENG116078-Lantern Configuration-Lichtfunktion H 10.0, 560
IDE05145-ENG116097-Lantern Configuration-Lichtfunktion H 11.0, 560
IDE05145-ENG116116-Lantern Configuration-Lichtfunktion H 12.0, 560
IDE05145-ENG116135-Lantern Configuration-Lichtfunktion H 13.0, 560
IDE05145-ENG116154-Lantern Configuration-Lichtfunktion H 14.0, 560
IDE05145-ENG116173-Lantern Configuration-Lichtfunktion H 15.0, 560
IDE05145-ENG116192-Lantern Configuration-Lichtfunktion H 16.0, 560
IDE05145-ENG116211-Lantern Configuration-Lichtfunktion H 17.0, 560
IDE05145-ENG116230-Lantern Configuration-Lichtfunktion H 18.0, 560
IDE05145-ENG116249-Lantern Configuration-Lichtfunktion H 19.0, 560
IDE05145-ENG115926-Lantern Configuration-Lichtfunktion H 2.0, 560
IDE05145-ENG116268-Lantern Configuration-Lichtfunktion H 20.0, 560
IDE05145-ENG116287-Lantern Configuration-Lichtfunktion H 21.0, 560
IDE05145-ENG116306-Lantern Configuration-Lichtfunktion H 22.0, 560
IDE05145-ENG116325-Lantern Configuration-Lichtfunktion H 23.0, 560
IDE05145-ENG1164-Lantern Configuration-Lichtfunktion H 24.0, 560
IDE05145-ENG116363-Lantern Configuration-Lichtfunktion H 25.0, 560
IDE05145-ENG116382-Lantern Configuration-Lichtfunktion H 26.0, 560
IDE05145-ENG116401-Lantern Configuration-Lichtfunktion H 27.0, 560
IDE05145-ENG116420-Lantern Configuration-Lichtfunktion H 28.0, 560
IDE05145-ENG116439-Lantern Configuration-Lichtfunktion H 29.0, 560
IDE05145-ENG115945-Lantern Configuration-Lichtfunktion H 3.0, 560
IDE05145-ENG116458-Lantern Configuration-Lichtfunktion H 30.0, 560
IDE05145-ENG116477-Lantern Configuration-Lichtfunktion H 31.0, 560
IDE05145-ENG116496-Lantern Configuration-Lichtfunktion H 32.0, 560
IDE05145-ENG116515-Lantern Configuration-Lichtfunktion H 33.0, 560
IDE05145-ENG116534-Lantern Configuration-Lichtfunktion H 34.0, 560
IDE05145-ENG115964-Lantern Configuration-Lichtfunktion H 4.0, 560
IDE05145-ENG115983-Lantern Configuration-Lichtfunktion H 5.0, 560
IDE05145-ENG116002-Lantern Configuration-Lichtfunktion H 6.0, 560
IDE05145-ENG116021-Lantern Configuration-Lichtfunktion H 7.0, 560
IDE05145-ENG116040-Lantern Configuration-Lichtfunktion H 8.0, 560
IDE05145-ENG116059-Lantern Configuration-Lichtfunktion H 9.0, 560
IDE05145-ENG154438-Lantern Configuration-Reserved 0,0, 560
IDE05145-ENG99841-Lantern Configuration-Reserved 1.0, 560
IDE05145-ENG154357-Lantern Configuration-Reserved 10.0, 560
IDE05145-ENG154352-Lantern Configuration-Reserved 11.0, 560
IDE05145-ENG154182-Lantern Configuration-Reserved 12.0, 560
IDE05145-ENG154265-Lantern Configuration-Reserved 13.0, 560
IDE05145-ENG154334-Lantern Configuration-Reserved 14.0, 560
IDE05145-ENG154340-Lantern Configuration-Reserved 15.0, 560
IDE05145-ENG154204-Lantern Configuration-Reserved 16.0, 560
IDE05145-ENG154344-Lantern Configuration-Reserved 17.0, 560
IDE05145-ENG154195-Lantern Configuration-Reserved 18.0, 560
IDE05145-ENG154190-Lantern Configuration-Reserved 19.0, 560
IDE05145-ENG99862-Lantern Configuration-Reserved 2.0, 560
IDE05145-ENG154300-Lantern Configuration-Reserved 20.0, 560
IDE05145-ENG154439-Lantern Configuration-Reserved 21.0, 560
IDE05145-ENG154440-Lantern Configuration-Reserved 22.0, 560
IDE05145-ENG154441-Lantern Configuration-Reserved 23.0, 560
IDE05145-ENG154442-Lantern Configuration-Reserved 24.0, 560
IDE05145-ENG154443-Lantern Configuration-Reserved 25.0, 560
IDE05145-ENG154444-Lantern Configuration-Reserved 26.0, 560
IDE05145-ENG154445-Lantern Configuration-Reserved 27.0, 560
IDE05145-ENG154446-Lantern Configuration-Reserved 28.0, 560
IDE05145-ENG154447-Lantern Configuration-Reserved 29.0, 560
IDE05145-ENG101107-Lantern Configuration-Reserved 3.00, 560
IDE05145-ENG154448-Lantern Configuration-Reserved 30.0, 560
IDE05145-ENG154449-Lantern Configuration-Reserved 31.0, 560
IDE05145-ENG154450-Lantern Configuration-Reserved 32.0, 560
IDE05145-ENG154451-Lantern Configuration-Reserved 33.0, 560
IDE05145-ENG154452-Lantern Configuration-Reserved 34.0, 560
IDE05145-ENG154267-Lantern Configuration-Reserved 4.0, 560
IDE05145-ENG154291-Lantern Configuration-Reserved 5.0, 560
IDE05145-ENG154239-Lantern Configuration-Reserved 6.0, 560
IDE05145-ENG154308-Lantern Configuration-Reserved 7.0, 560
IDE05145-ENG154184-Lantern Configuration-Reserved 8.0, 560
IDE05145-ENG154255-Lantern Configuration-Reserved 9.0, 560
IDE06089-ENG116683-Correspondence of the consumed current to the seat heating level-Sitzheizung Filterkonstante fuer Waermefluss, 1 s, 24
IDE06089-ENG116684-Correspondence of the consumed current to the seat heating level-Sitzheizung Regeltemperaturkorrektur bei Waermefluss, 0.00 ° C, 24
IDE06089-ENG115738-Correspondence of the consumed current to the heating level of the seat-Sitzheizung Stufe 1 obere Schaltschwelle, 22.50 ° C, 24
IDE06089-ENG115737-Correspondence of the consumed current to the seat heating level-Sitzheizung Stufe 1 untere Schaltschwelle, 21.50 ° C, 24
IDE06089-ENG115740-Correspondence of the consumed current to the seat heating level-Sitzheizung Stufe 2 obere Schaltschwelle, 22.50 ° C, 24
IDE06089-ENG115739-Correspondence of the consumed current to the seat heating level-Sitzheizung Stufe 2 untere Schaltschwelle, 21.50 ° C, 24
IDE06089-ENG115742-Correspondence of the consumed current to the seat heating level-Sitzheizung Stufe 3 obere Schaltschwelle, 36.00 ° C, 24
IDE06089-ENG115741-Correspondence of the consumed current to the seat heating level-Sitzheizung Stufe 3 untere Schaltschwelle, 34.00 ° C, 24
IDE06089-ENG115744-Correspondence of the consumed current to the seat heating level-Sitzheizung Stufe 4 obere Schaltschwelle, 36.00 ° C, 24
IDE06089-ENG115743-Correspondence of the consumed current to the seat heating level-Sitzheizung Stufe 4 untere Schaltschwelle, 34.00 ° C, 24
IDE06089-ENG115746-Correspondence of the consumed current to the seat heating level-Sitzheizung Stufe 5 obere Schaltschwelle, 50.00 ° C, 24
IDE06089-ENG115745-Correspondence of the consumed current to the seat heating level-Sitzheizung Stufe 5 untere Schaltschwelle, 49.00 ° C, 24
IDE06089-ENG115748-Correspondence of the consumed current to the seat heating level-Sitzheizung Stufe 6 obere Schaltschwelle, 50.00 ° C, 24
IDE06089-ENG115747-Compliance Consumableth current seat heating level - Sitzheizung Stufe 6 untere Schaltschwelle, 49.00 ° C, 24
IDE06096-ENG116596-Interior Lighting-Innenlicht bei offenem Heckdeckel einschalten, act. ,8
IDE06096-ENG116597-Interior Lighting-KL30G ohne PWM, not active, 8
IDE06096-ENG116598-Interior Lighting-KL58 Einschalten mit Rampe, act. ,8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten, not active, 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung, act. ,8
IDE06096-ENG115631-Interior Lighting-Suchbeleuchtung Festwert, 100%, 8
IDE06425-Mode Roller Stand: Functions, not active, 1
IDE06507-MAS13125-The keys on the center console-Function keys 1, start stop, 8
IDE06507-MAS13129-The keys on the center console-Function keys 2, Closing the cargo compartment, 8
IDE06507-MAS13132-Keys on the center console-Function keys 3, Travel program, 8
IDE06507-MAS13135-The keys on the center console-Function keys 4, Heated steering wheel, 8
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag, Daytime running lights, 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht, not active, 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht, not active, 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich, act. ,four
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten, act. ,four
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO, act. ,four
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht, not active, 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte, not active, 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge, act. ,four
IDE07356-Position in the intermittent mode of operation, 31.49 °, 2
IDE07470-ENG116719-Glow of the side lights after switching off-Bedingungen zur Beendigung des Standlichtnachlaufs, abschalten nach der Nachlaufzeit, 12
IDE07470-ENG133381-Illumination of parking lights after switching off-Bedingungen zur Parklichtbegrenzung, begrenzen auf Mindestverf? Gbarkeit, 12
IDE07470-ENG133380-Glow of side lights after switching off-Bedingungen zur Standlichtbegrenzung, begrenzen auf Mindestverf? Gbarkeit, 12
IDE07470-ENG133382-Illumination of the position lights after switching off - Faktor fuer Verf? Gbarkeitstimer, Faktor fuer x5 Minuten, 12
IDE07470-ENG116720-Glow of marker lights after switching off-Standlicht-Nachlaufzeit, 30 min, 12
IDE07470-ENG133383-Glow of side lights after switching off-Standlicht-Verf? Gbarkeit, 6 s, 12
IDE08542-IDE02021-Access control 2-Comfortable closing, act. ,8
IDE08542-IDE02022-Access control 2-Comfortable opening, act. ,8
IDE08542-ENG128459-Access Control 2-easycloselight_aktiv, not active, 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen, act. ,8
IDE08542-ENG116664-Access Control 2-Fahrertuerbedienung Fensterheber schliessen, not active, 8
IDE08542-ENG116662-Access Control 2-FH SAD Kl15Aus Freigabezeit, 600 s, 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus, act. ,8
IDE08542-ENG122993-Access Control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen, not active, 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen, act. ,8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen, act. ,8
IDE08542-ENG116658-Access Control 2-Funk Spiegelanklappen, not active, 8
IDE08542-ENG116665-Access Control 2-Funk Spiegelanklappung Modus, by convenience operation via remote control key, 8
IDE08542-ENG116653-Access Control 2-Kessy Komfort oeffnen, not active, 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen, act. ,8
IDE08542-ENG116655-Access Control 2-Kessy Komfortbedienung Reichweitenbegrenzung, not active, 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global, act. ,8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer, not active, 8
IDE08542-ENG116660-Access Control 2-Menuesteuerung Funk Spiegel anklappen, act. ,8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar, adjustable, 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen, act. ,8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung, act. ,8
IDE08542-ENG116659-Access Control 2-Menuesteuerung synchrone Spiegelverstellung, not active, 8
IDE08542-ENG125654-Access Control 2-Nachsaven_nach_Verdecklauf, not active, 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel, act. ,8
IDE08542-ENG125656-Access Control 2-Regenschliessen_art, Permanent, 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus, act. ,8
IDE08542-ENG125657-Access Control 2-Remote_Unlock_Lock, Via ZV-Absicherung Light, 8
IDE08542-ENG116647-Access Control 2-SAD Comfort effnen, act. , 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen, act. , 8
IDE08542-ENG116661-Access Control 2-SAD PreCrash Konturschliessen, not active, 8
IDE08542-ENG116645-Access Control 2-SAD Richtung Komfortoeffnen, Open, 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen, not active, 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen, not active, 8
IDE08542-ENG126610-Access Control 2-Signalisierung_Spiegelanklappung, Act. , 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt, act. , 8
IDE08542-ENG133411-Access Control 2-Spiegelanklappen_bei_Wiederverriegelung, not active, 8
IDE08542-ENG116656-Access Control 2-Spiegelverstellung Synchron, not active, 8
IDE08542-ENG115869-Access Control 2-Virtuelles_Pedal, not active, 8
IDE08542-ENG126611-Access Control 2-virtuelles_pedal_HMI_einstellbar, not active, 8
IDE08786-ENG116640-AFL Zeitverzoegerung Auxiliary Lighting Functions, 2000 ms, 8
IDE08786-ENG115723-Auxiliary lighting functions-Assistenzfahrlicht bei Regen, Act. , 8
IDE08786-ENG130581-Auxiliary lighting functions-Fahrlicht_Hinweis_mehrfach, not active, 8
IDE08786-ENG126818-Auxiliary lighting functions-Fahrlichtwarnung_Hinweis_Konfig, kein_Hinweis, 8
IDE08786-ENG116639-Auxiliary Lighting Functions-Fernlichtassistent Reset, not active, 8
IDE08786-ENG116638-Auxiliary Lighting Functions-Fernlichtassistent Zeitverzoegerungswert, 0 ms, 8
IDE08786-ENG115724-Auxiliary lighting functions-Lichtsensorempfindlichkeit, sensitive, 8
IDE08786-ENG126628-Auxiliary Lighting Functions-LS_Error_Ausgabe, not active, 8
IDE08786-ENG116637-Auxiliary lighting functions-Menuesteuerung Fernlichtassistent, available, 8
IDE08786-ENG116641-Auxiliary lighting functions-Menuesteuerung Fernlichtassistent Werkseinstellung, available, 8
IDE08786-ENG116636-Auxiliary Lighting Functions-Notbremsanzeige NBA, Act. , 8
IDE08786-ENG126817-Auxiliary lighting functions-Umfeldleuchte als Manoevrierleuchte, not active, 8
IDE08787-ENG115810-Additional Features-Klemmenfehler auf CAN ausgeben, act. , 2
IDE08787-ENG101416-Advanced Features-Reserved_1, not active, 2
IDE08787-ENG99458-Advanced Features-Reserved_2, not active, 2
IDE08787-ENG115809-Additional Features-Signalhorn ohne KL15, Act. , 2
IDE08787-ENG116672-Additional Features-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren, not active, 2
IDE08787-ENG116671-Additional Features-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT, not active, 2
IDE08788-ENG122212-Dynamic flashing mode-ABBA_Blinken, not active, 4
IDE08788-ENG121966-Dynamic Blink Mode-Blinking in Accident, Act. , 4
IDE08788-ENG122207-Dynamic flashing mode-DWA_Alarm_Blinken, not active, 4
IDE08788-ENG122206-Dynamic flashing mode-DWA_Schaerfungsquittung, not active, 4
IDE08788-ENG126819-Dynamic blink mode-Emergency_alert_blinken, not active, 4
IDE08788-ENG122208-Dynamic blink mode-Multi_kollisions_Blinken, not active, 4
IDE08788-ENG122209-Dynamic Blink Mode-Notwarn_blinken_NBA_Phase_2, Act. , 4
IDE08788-ENG121967-Dynamic Blink Mode-Panic Blink, not active, 4
IDE08788-ENG122211-Dynamic flashing mode-Richtungs_blinken_links, not active, 4
IDE08788-ENG122210-Dynamic blink mode-Richtungs_blinken_rechts, not active, 4
IDE08788-ENG122201-Dynamic blink mode-Schluessel_Anlern_Blinken, not active, 4
IDE08788-ENG121968-Dynamic flashing mode-Taxi alarm flashing, not active, 4
IDE08788-ENG126629-Dynamic Blink Mode-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken, not active, 4
IDE08788-ENG122202-Dynamic flashing mode-UGDO_ Anlern_Blinken, not active, 4
IDE08788-ENG122214-Dynamic flashing mode-Warnblinken_Zuendung_AUS, not active, 4
IDE08788-ENG122213-Dynamic flashing mode-Warnblinken_Zuendung_EIN, not active, 4
IDE08788-ENG122204-Dynamic flashing mode-ZV_Blinken_auf, not active, 4
IDE08788-ENG122203-Dynamic blink mode-ZV_Blinken_zu, not active, 4
IDE09731-ENG125014-2nd generation interior lighting-Aufloesung Dimmzeit, 0.10 s, 20
IDE09731-ENG125024-2nd Generation Interior Lighting-BAP Farbwert Farbe 1.0, 20
IDE09731-ENG125025-2nd Generation Interior Lighting-BAP Farbwert Farbe 2.0, 20
IDE09731-ENG125026-2nd Generation Interior Lighting-BAP Farbwert Farbe 3.0, 20
IDE09731-ENG126827-2nd Generation Interior Lighting-Blauwert Farbe 1,225, 20
IDE09731-ENG126830-2nd Generation Interior Lighting-Blauwert Farbe 2,225, 20
IDE09731-ENG126833-Lighting 2nd Generation Lounge-Blauwert Farbe 3,225, 20
IDE09731-ENG125018-2nd generation salon lighting-Cockpitbeleuchtung mehrfarbig, not active, 20
IDE09731-ENG125021-Lighting of the 2nd generation salon-Dachbeleuchtung mehrfarbig, not active, 20
IDE09731-ENG125028-2nd generation salon lighting-Defaultwert Ambienteprofil Dach, 80%, 20
IDE09731-ENG125029-Illuminated 2nd Generation Salon-Defaultwert Ambienteprofil Farbe, 0, 20
IDE09731-ENG125027-2nd Generation Interior Lighting-Defaultwert Ambienteprofil Mittelkonsole, 80%, 20
IDE09731-ENG125641-2nd Generation Interior Lighting-Farbausgabe Cockpitbeleuchtung nicht berechnen, act. ,twenty
IDE09731-ENG125644-2nd Generation Interior Lighting-Farbausgabe Dachbeleuchtung nicht berechnen, act. ,twenty
IDE09731-ENG125640-Interior lighting 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen, act. ,twenty
IDE09731-ENG125642-2nd generation interior lighting-Farbausgabe Lautsprecherbeleuchtung nicht berechnen, act. ,twenty
IDE09731-ENG125643-Interior lighting 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen, act. ,twenty
IDE09731-ENG125645-Interior lighting 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen, act. ,twenty
IDE09731-ENG125639-Interior lighting 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen, act. ,twenty
IDE09731-ENG126826-Interior Lighting 2nd Generation-Gruenwert Farbe 1,225, 20
IDE09731-ENG126829-Interior Lighting 2nd Generation-Gruenwert Farbe 2,225, 20
IDE09731-ENG126832-Interior lighting 2nd generation-Gruenwert Farbe 3.225, 20
IDE09731-ENG125634-2nd generation interior lighting-Helligkeit Cockpitbeleuchtung nicht berechnen, act. ,twenty
IDE09731-ENG125637-2nd Generation Interior Lighting-Helligkeit Dachbeleuchtung nicht berechnen, act. ,twenty
IDE09731-ENG125633-2nd Generation Interior Lighting-Helligkeit Instrumententafelbeleuchtung nicht berechnen, act. ,twenty
IDE09731-ENG125635-2nd Generation Interior Lighting-Helligkeit Lautsprecherbeleuchtung nicht berechnen, act. ,twenty
IDE09731-ENG125636-Interior lighting 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen, act. ,twenty
IDE09731-ENG125638-Interior lighting 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen, act. ,twenty
IDE09731-ENG126824-2nd Generation Interior Lighting-Helligkeit Tuertafelbeleuchtung nicht berechnen, not active, 20
IDE09731-ENG125017-2nd Generation Interior Lighting-Instrumententafelbeleuchtung mehrfarbig, not active, 20
IDE09731-ENG125019-2nd Gen Interior Lighting-Lautsprecherbeleuchtung mehrfarbig, not active, 20
IDE09731-ENG125020-Interior lighting 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig, not active, 20
IDE09731-ENG125023-2nd generation interior lighting-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren, not active, 20
IDE09731-ENG125022-Interior lighting 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig, not active, 20
IDE09731-ENG126825-2nd Gen Interior Lighting-Rotwert Farbe 1,225, 20
IDE09731-ENG126828-Interior Lighting 2nd Generation-Rotwert Farbe 2.225, 20
IDE09731-ENG126831-Interior Lighting 2nd Generation-Rotwert Farbe 3.225, 20
IDE09731-ENG125016-Interior Light 2nd Generation-Tuertafelbeleuchtung mehrfarbig, not active, 20
IDE09731-ENG125015-2nd Gen Interior Lighting-weicher Farbwechsel, not active, 20
IDE09732-ENG133384-Interior Lighting: Lantern Configuration-Ambient_Farbliste_HMI, not active, 2
IDE09732-ENG115870-Interior lighting: configuration of lights-Ambiente_Applikationsleisten_in_Instrumententafel, not installed. , 2
IDE09732-ENG115871-Interior lighting: configuration of lights-Ambiente_Applikationsleisten_in_Tuertafel, installed. , 2
IDE09732-ENG115872-Interior lighting: configuration of lights-Ambiente_Lautsprecher, not installed. , 2
IDE09732-ENG126836-Interior Lighting: Lantern Configuration-Ambientemenue mit alle Zonen, not active, 2
IDE09732-ENG126835-Interior Lighting: Lantern Configuration-Ambientemenue mit globalem aus, not active, 2
IDE09732-ENG125646-Interior lighting: configuration of lights-Cockpitbeleuchtung, not installed. , 2
IDE09732-ENG125648-Interior lighting: configuration of lights-Dachbeleuchtung, not installed. , 2
IDE09732-ENG125651-Interior lighting: configuration of lights-Farbwahl ueber Fahrprofil, not installed. , 2
IDE09732-ENG125650-Interior lighting: configuration of lights-Farbwahl ueber HMI, not installed. , 2
IDE09732-ENG114629-Interior lighting: configuration of lights-Highlighting the space for the legs, set. , 2
IDE09732-ENG133385-Interior Lighting: Lantern Configuration-Frei_Farbwahl_ueber_HMI, not active, 2
IDE09732-ENG126834-Interior Lighting: Lantern Configuration-LIN-Dachkonsole lokal aktivierbar, not active, 2
IDE09732-ENG125647-Interior lighting: configuration of lights-Mittelkonsolenbeleuchtung, not installed. , 2
IDE09732-ENG125649-Interior lighting: configuration of lights-Panoramaschiebedachbeleuchtung, not installed. , 2
IDE09761-ENG126617-Seat Fan Feature-Level_1_Lehne, 30%, 12
IDE09761-ENG126616-Seat Fan Feature-Level_1_Sitz, 25%, 12
IDE09761-ENG126619-Seat Fan Feature-Level_2_Lehne, 30%, 12
IDE09761-ENG126618-Seat Fan Feature-Level_2_Sitz, 25%, 12
IDE09761-ENG126621-Seat Fan Feature-Level_3_Lehne, 58%, 12
IDE09761-ENG126620-Seat Fan Feature-Level_3_Sitz, 53%, 12
IDE09761-ENG126623-Seat Fan Feature-Level_4_Lehne, 58%, 12
IDE09761-ENG126622-Seat Fan Feature-Level_4_Sitz, 53%, 12
IDE09761-ENG126625-Seat Fan Feature-Level_5_Lehne, 85%, 12
IDE09761-ENG126624-Seat Fan Feature-Level_5_Sitz, 80%, 12
IDE09761-ENG126627-Seat Fan Feature-Level_6_Lehne, 85%, 12
IDE09761-ENG126626-Seat Fan Feature-Level_6_Sitz, 80%, 12
IDE10298-Variable brush starting position 1.7.49 °, 2
IDE10299-Variable brush starting position 2.29.49 °, 2
IDE11477-ENG128587-Interior lighting: parameters-p_adaption_kundenwunsch_cockpit, 64, 256
IDE11477-ENG128619-Interior lighting: parameters-p_adaption_kundenwunsch_dach, 64, 256
IDE11477-ENG128539-Interior lighting: parameters-p_adaption_kundenwunsch_fussraum, 14, 256
IDE11477-ENG128571-Interior lighting: parameters-p_adaption_kundenwunsch_itafel, 64, 256
IDE11477-ENG128555-Interior lighting: parameters-p_adaption_kundenwunsch_lautsprecher, 64, 256
IDE11477-ENG128603-Interior lighting: parameters-p_adaption_kundenwunsch_miko, 64, 256
IDE11477-ENG128635-Interior lighting: parameters-p_adaption_kundenwunsch_psd, 64, 256
IDE11477-ENG128523-Interior lighting: parameters-p_adaption_kundenwunsch_tuer, 3C, 256
IDE11477-ENG128659-Interior lighting: parameters-p_ambientelicht_verbauinformation_HMI, 00, 256
IDE11477-ENG128660-Interior lighting: parameters-p_ambientelicht_verbauinformation_HMI_2,00, 256
IDE11477-ENG128661-Interior lighting: parameters-p_ambientelicht_verbauinformation_HMI_3,00, 256
IDE11477-ENG128662-Interior lighting: parameters-p_ambientelicht_verbauinformation_HMI_4,00, 256
IDE11477-ENG128655-Interior lighting: parameters-p_ambienteumfang_mehrfarbig_HMI, 00, 256
IDE11477-ENG128656-Interior lighting: parameters-p_ambienteumfang_mehrfarbig_HMI_2,00, 256
IDE11477-ENG128657-Interior lighting: parameters-p_ambienteumfang_mehrfarbig_HMI_3,00, 256
IDE11477-ENG128658-Interior lighting: parameters-p_ambienteumfang_mehrfarbig_HMI_4,00, 256
IDE11477-ENG128652-Interior lighting: parameters-p_dimmfaktor_farbwechsel_ab, 01, 256
IDE11477-ENG128651-Interior lighting: parameters-p_dimmfaktor_farbwechsel_auf, 01, 256
IDE11477-ENG128654-Interior lighting: parameters-p_farbauswahl_HMI, 00, 256
IDE11477-ENG128653-Interior lighting: parameters-p_farbwechsel_delay, 00, 256
IDE11477-ENG128596-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit, 100%, 256
IDE11477-ENG128628-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_aus_dach, 100%, 256
IDE11477-ENG128548-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum, 70%, 256
IDE11477-ENG128516-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht, 100%, 256
IDE11477-ENG128580-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_aus_itafel, 100%, 256
IDE11477-ENG128564-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher, 100%, 256
IDE11477-ENG128612-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_aus_miko, 100%, 256
IDE11477-ENG128644-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_aus_psd, 100%, 256
IDE11477-ENG128532-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_aus_tueren, 96%, 256
IDE11477-ENG128593-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit, 100%, 256
IDE11477-ENG128625-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_ein_dach, 100%, 256
IDE11477-ENG128545-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum, 70%, 256
IDE11477-ENG128513-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht, 100%, 256
IDE11477-ENG128577-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_ein_itafel, 100%, 256
IDE11477-ENG128561-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher, 100%, 256
IDE11477-ENG128609-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_ein_miko, 100%, 256
IDE11477-ENG128641-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_ein_psd, 100%, 256
IDE11477-ENG128529-Interior lighting: parameters-p_helligkeit_andereTuer_auf_zuendung_ein_tueren, 96%, 256
IDE11477-ENG128595-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit, 100%, 256
IDE11477-ENG128627-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_aus_dach, 100%, 256
IDE11477-ENG128547-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum, 70%, 256
IDE11477-ENG128515-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht, 100%, 256
IDE11477-ENG128579-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel, 100%, 256
IDE11477-ENG128563-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher, 100%, 256
IDE11477-ENG128611-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_aus_miko, 100%, 256
IDE11477-ENG128643-Interior Lighting: Options-p_helligkeit_dieseTuer_auf_zuendung_aus_psd, 100%, 256
IDE11477-ENG128531-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren, 96%, 256
IDE11477-ENG128592-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit, 100%, 256
IDE11477-ENG128624-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_ein_dach, 100%, 256
IDE11477-ENG128544-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum, 70%, 256
IDE11477-ENG128512-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht, 100%, 256
IDE11477-ENG128576-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel, 100%, 256
IDE11477-ENG128560-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher, 100%, 256
IDE11477-ENG128608-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_ein_miko, 100%, 256
IDE11477-ENG128640-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_ein_psd, 100%, 256
IDE11477-ENG128528-Interior lighting: parameters-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren, 96%, 256
IDE11477-ENG128597-Interior lighting: parameters-p_helligkeit_einausstieg_cockpit, 100%, 256
IDE11477-ENG128629-Interior lighting: parameters-p_helligkeit_einausstieg_dach, 100%, 256
IDE11477-ENG128549-Interior lighting: parameters-p_helligkeit_einausstieg_fussraum, 70%, 256
IDE11477-ENG128517-Interior lighting: parameters-p_helligkeit_einausstieg_innenlicht, 100%, 256
IDE11477-ENG128581-Interior lighting: parameters-p_helligkeit_einausstieg_itafel, 100%, 256
IDE11477-ENG128565-Interior lighting: parameters-p_helligkeit_einausstieg_lautsprecher, 100%, 256
IDE11477-ENG128613-Interior lighting: parameters-p_helligkeit_einausstieg_miko, 100%, 256
IDE11477-ENG128645-Interior lighting: parameters-p_helligkeit_einausstieg_psd, 100%, 256
IDE11477-ENG128533-Interior lighting: parameters-p_helligkeit_einausstieg_tueren, 96%, 256
IDE11477-ENG128588-Interior lighting: parameters-p_helligkeit_entriegelt_cockpit, 100%, 256
IDE11477-ENG128620-Interior lighting: parameters-p_helligkeit_entriegelt_dach, 100%, 256
IDE11477-ENG128540-Interior lighting: parameters-p_helligkeit_entriegelt_fussraum, 0%, 256
IDE11477-ENG128508-Interior lighting: parameters-p_helligkeit_entriegelt_innenlicht, 100%, 256
IDE11477-ENG128572-Interior lighting: parameters-p_helligkeit_entriegelt_itafel, 100%, 256
IDE11477-ENG128556-Interior lighting: parameters-p_helligkeit_entriegelt_lautsprecher, 100%, 256
IDE11477-ENG128604-Interior lighting: parameters-p_helligkeit_entriegelt_miko, 100%, 256
IDE11477-ENG128636-Interior lighting: parameters-p_helligkeit_entriegelt_psd, 100%, 256
IDE11477-ENG128524-Interior lighting: parameters-p_helligkeit_entriegelt_tueren, 0%, 256
IDE11477-ENG128602-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit, 100%, 256
IDE11477-ENG128634-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach, 100%, 256
IDE11477-ENG128554-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum, 70%, 256
IDE11477-ENG128522-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht, 100%, 256
IDE11477-ENG128586-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel, 100%, 256
IDE11477-ENG128570-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher, 100%, 256
IDE11477-ENG128618-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko, 100%, 256
IDE11477-ENG128650-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd, 100%, 256
IDE11477-ENG128538-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren, 96%, 256
IDE11477-ENG128598-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit, 100%, 256
IDE11477-ENG128630-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach, 100%, 256
IDE11477-ENG128550-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum, 127%, 256
IDE11477-ENG128518-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht, 100%, 256
IDE11477-ENG128582-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel, 100%, 256
IDE11477-ENG128566-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher, 100%, 256
IDE11477-ENG128614-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko, 100%, 256
IDE11477-ENG128646-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd, 100%, 256
IDE11477-ENG128534-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren, 127%, 256
IDE11477-ENG128594-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit, 126%, 256
IDE11477-ENG128626-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach, 126%, 256
IDE11477-ENG128546-Interior lighting: parameters-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum, 126%, 256
IDE11477-ENG128514-Interior Lighting:паметры-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht, 0%, 256
IDE11477-ENG128578-Освещение салона: параметры-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel, 126%, 256
IDE11477-ENG128562-Освещение салона: параметры-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher, 126%, 256
IDE11477-ENG128610-Освещение салона: параметры-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko, 126%, 256
IDE11477-ENG128642-Освещение салона: параметры-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd, 126%, 256
IDE11477-ENG128530-Освещение салона: параметры-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren, 126%, 256
IDE11477-ENG128591-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_aus_cockpit, 100%, 256
IDE11477-ENG128623-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_aus_dach, 100%, 256
IDE11477-ENG128543-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_aus_fussraum, 127%, 256
IDE11477-ENG128511-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_aus_innenlicht, 100%, 256
IDE11477-ENG128575-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_aus_itafel, 100%, 256
IDE11477-ENG128559-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_aus_lautsprecher, 100%, 256
IDE11477-ENG128607-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_aus_miko, 100%, 256
IDE11477-ENG128639-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_aus_psd, 100%, 256
IDE11477-ENG128527-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_aus_tueren, 127%, 256
IDE11477-ENG128590-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_ein_cockpit, 100%, 256
IDE11477-ENG128622-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_ein_dach, 100%, 256
IDE11477-ENG128542-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_ein_fussraum, 126%, 256
IDE11477-ENG128510-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_ein_innenlicht, 100%, 256
IDE11477-ENG128574-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_ein_itafel, 100%, 256
IDE11477-ENG128558-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_ein_lautsprecher, 100%, 256
IDE11477-ENG128606-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_ein_miko, 100%, 256
IDE11477-ENG128638-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_ein_psd, 100%, 256
IDE11477-ENG128526-Освещение салона: параметры-p_helligkeit_HD_auf_zuendung_ein_tueren, 126%, 256
IDE11477-ENG128589-Освещение салона: параметры-p-brightness_max_cockpit, 100%, 256
IDE11477-ENG128621-Освещение салона: параметры-p-brightness_max_dach, 100%, 256
IDE11477-ENG128541-Освещение салона: параметры-p-brightness_max_foot space, 70%, 256
IDE11477-ENG128509-Освещение салона: параметры-p-brightness_max_light, 100%, 256
IDE11477-ENG128573-Освещение салона: параметры-p-brightness_max_itafel, 100%, 256
IDE11477-ENG128557-Освещение салона: параметры-p_lightness_max_ loudspeaker, 100%, 256
IDE11477-ENG128605-Освещение салона: параметры-p-brightness_max_miko, 100%, 256
IDE11477-ENG128637-Освещение салона: параметры-p-brightness_max_psd, 100%, 256
IDE11477-ENG128525-Освещение салона: параметры-p-brightness_max_turn, 96%, 256
IDE11477-ENG128599-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit, 100%, 256
IDE11477-ENG128631-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach, 100%, 256
IDE11477-ENG128551-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum, 70%, 256
IDE11477-ENG128519-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht, 100%, 256
IDE11477-ENG128583-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel, 100%, 256
IDE11477-ENG128567-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher, 100%, 256
IDE11477-ENG128615-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko, 100%, 256
IDE11477-ENG128647-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd, 100%, 256
IDE11477-ENG128535-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren, 96%, 256
IDE11477-ENG128600-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit, 100%, 256
IDE11477-ENG128632-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach, 100%, 256
IDE11477-ENG128552-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum, 70%, 256
IDE11477-ENG128520-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht, 100%, 256
IDE11477-ENG128584-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel, 100%, 256
IDE11477-ENG128568-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher, 100%, 256
IDE11477-ENG128616-Освещение салона: параметры-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko, 100%, 256
IDE11477-ENG128648-Interior lighting: parameters-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd, 100%, 256
IDE11477-ENG128536-Interior lighting: parameters-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren, 96%, 256
IDE11477-ENG128601-Interior lighting: parameters-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit, 100%, 256
IDE11477-ENG128633-Interior lighting: parameters-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach, 100%, 256
IDE11477-ENG128553-Interior lighting: parameters-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum, 70%, 256
IDE11477-ENG128521-Interior lighting: parameters-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht, 100%, 256
IDE11477-ENG128585-Interior lighting: parameters-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel, 100%, 256
IDE11477-ENG128569-Interior lighting: parameters-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher, 100%, 256
IDE11477-ENG128617-Interior lighting: parameters-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko, 100%, 256
IDE11477-ENG128649-Interior lighting: parameters-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd, 100%, 256
IDE11477-ENG128537-Interior lighting: parameters-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren, 96%, 256
IDE11477-ENG137165-Interior lighting: parameters-p_t_HMI_verzoegerung_helligkeitswerte, 0 ms, 256
IDE11477-ENG128488-Interior lighting: parameters-p_t_verzoegerung_ausstieg_cockpit, 0 s, 256
IDE11477-ENG128502-Interior lighting: parameters-p_t_verzoegerung_ausstieg_dach, 0 s, 256
IDE11477-ENG128481-Interior lighting: parameters-p_t_verzoegerung_ausstieg_fussraum, 0 s, 256
IDE11477-ENG128467-Interior lighting: parameters-p_t_verzoegerung_ausstieg_innenlicht, 0 s, 256
IDE11477-ENG128495-Interior lighting: parameters-p_t_verzoegerung_ausstieg_miko, 0 s, 256
IDE11477-ENG128474-Interior lighting: parameters-p_t_verzoegerung_ausstieg_tueren, 0 s, 256
IDE11477-ENG128487-Interior lighting: parameters-p_t_verzoegerung_einstieg_cockpit, 0 s, 256
IDE11477-ENG128501-Interior lighting: parameters-p_t_verzoegerung_einstieg_dach, 0 s, 256
IDE11477-ENG128480-Interior lighting: parameters-p_t_verzoegerung_einstieg_fussraum, 20 s, 256
IDE11477-ENG128466-Interior lighting: parameters-p_t_verzoegerung_einstieg_innenlicht, 0 s, 256
IDE11477-ENG128494-Interior lighting: parameters-p_t_verzoegerung_einstieg_miko, 0 s, 256
IDE11477-ENG128473-Interior lighting: parameters-p_t_verzoegerung_einstieg_tueren, 5 s, 256
IDE11477-ENG128490-Interior lighting: parameters-p_t_verzoegerung_entriegelt_cockpit, 0 s, 256
IDE11477-ENG128504-Interior lighting: parameters-p_t_verzoegerung_entriegelt_dach, 0 s, 256
IDE11477-ENG128483-Interior lighting: parameters-p_t_verzoegerung_entriegelt_fussraum, 0 s, 256
IDE11477-ENG128469-Interior lighting: parameters-p_t_verzoegerung_entriegelt_innenlicht, 0 s, 256
IDE11477-ENG128497-Interior lighting: parameters-p_t_verzoegerung_entriegelt_miko, 0 s, 256
IDE11477-ENG128476-Interior lighting: parameters-p_t_verzoegerung_entriegelt_tueren, 0 s, 256
IDE11477-ENG128489-Interior lighting: parameters-p_t_verzoegerung_oeffnen_cockpit, 0 s, 256
IDE11477-ENG128503-Interior lighting: parameters-p_t_verzoegerung_oeffnen_dach, 0 s, 256
IDE11477-ENG128482-Interior lighting: parameters-p_t_verzoegerung_oeffnen_fussraum, 0 s, 256
IDE11477-ENG128468-Interior lighting: parameters-p_t_verzoegerung_oeffnen_innenlicht, 0 s, 256
IDE11477-ENG128496-Interior lighting: parameters-p_t_verzoegerung_oeffnen_miko, 0 s, 256
IDE11477-ENG128475-Interior lighting: parameters-p_t_verzoegerung_oeffnen_tueren, 0 s, 256
IDE11477-ENG128491-Interior lighting: parameters-p_t_verzoegerung_schliessen_cockpit, 0 s, 256
IDE11477-ENG128505-Interior lighting: parameters-p_t_verzoegerung_schliessen_dach, 0 s, 256
IDE11477-ENG128484-Interior lighting: parameters-p_t_verzoegerung_schliessen_fussraum, 0 s, 256
IDE11477-ENG128470-Interior lighting: parameters-p_t_verzoegerung_schliessen_innenlicht, 0 s, 256
IDE11477-ENG128498-Interior lighting: parameters-p_t_verzoegerung_schliessen_miko, 0 s, 256
IDE11477-ENG128477-Interior lighting: parameters-p_t_verzoegerung_schliessen_tueren, 0 s, 256
IDE11477-ENG128492-Interior lighting: parameters-p_t_verzoegerung_schluessel_ab_cockpit, 0 s, 256
IDE11477-ENG128506-Interior lighting: parameters-p_t_verzoegerung_schluessel_ab_dach, 0 s, 256
IDE11477-ENG128485-Interior lighting: parameters-p_t_verzoegerung_schluessel_ab_fussraum, 0 s, 256
IDE11477-ENG128471-Interior lighting: parameters-p_t_verzoegerung_schluessel_ab_innenlicht, 0 s, 256
IDE11477-ENG128499-Interior lighting: parameters-p_t_verzoegerung_schluessel_ab_miko, 0 s, 256
IDE11477-ENG128478-Interior lighting: parameters-p_t_verzoegerung_schluessel_ab_tueren, 0 s, 256
IDE11477-ENG128493-Interior lighting: parameters-p_t_verzoegerung_verriegelt_cockpit, 0 s, 256
IDE11477-ENG128507-Interior lighting: parameters-p_t_verzoegerung_verriegelt_dach, 0 s, 256
IDE11477-ENG128486-Interior lighting: parameters-p_t_verzoegerung_verriegelt_fussraum, 0 s, 256
IDE11477-ENG128472-Interior lighting: parameters-p_t_verzoegerung_verriegelt_innenlicht, 0 s, 256
IDE11477-ENG128500-Lighting Salona: parameters-p_t_verzoegerung_verriegelt_miko, 0 s, 256
IDE11477-ENG128479-Interior lighting: parameters-p_t_verzoegerung_verriegelt_tueren, 0 s, 256
IDE11477-ENG128663-Interior lighting: parameters-p_verzoegerung_berechnen, 00, 256
IDE11714-ENG133432-Aesthetic lighting: color list-Blauwert Farbe 10, E1, 30
IDE11714-ENG133414-Aesthetic lighting: color list-Blauwert Farbe 4, E1, 30
IDE11714-ENG133417-Aesthetic lighting: color list-Blauwert Farbe 5, E1, 30
IDE11714-ENG133420-Aesthetic lighting: color list-Blauwert Farbe 6, E1, 30
IDE11714-ENG133423-Aesthetic lighting: color list-Blauwert Farbe 7, E1, 30
IDE11714-ENG133426-Aesthetic lighting: color list-Blauwert Farbe 8, E1, 30
IDE11714-ENG133429-Aesthetic lighting: color list-Blauwert Farbe 9, E1, 30
IDE11714-ENG133431-Aesthetic lighting: color list-Gruenwert Farbe 10, E1, 30
IDE11714-ENG133413-Aesthetic lighting: color list-Gruenwert Farbe 4, E1, 30
IDE11714-ENG133416-Aesthetic lighting: color list-Gruenwert Farbe 5, E1, 30
IDE11714-ENG133419-Aesthetic lighting: color list-Gruenwert Farbe 6, E1, 30
IDE11714-ENG133422-Aesthetic lighting: color list-Gruenwert Farbe 7, E1, 30
IDE11714-ENG133425-Aesthetic lighting: color list-Gruenwert Farbe 8, E1, 30
IDE11714-ENG133428-Aesthetic lighting: color list-Gruenwert Farbe 9, E1, 30
IDE11714-ENG133430-Aesthetic lighting: color list-Rotwert Farbe 10, E1, 30
IDE11714-ENG133412-Aesthetic lighting: color list-Rotwert Farbe 4, E1, 30
IDE11714-ENG133415-Aesthetic lighting: color list-Rotwert Farbe 5, E1, 30
IDE11714-ENG133418-Aesthetic lighting: color list-Rotwert Farbe 6, E1, 30
IDE11714-ENG133421-Aesthetic lighting: color list-Rotwert Farbe 7, E1, 30
IDE11714-ENG133424-Aesthetic lighting: color list-Rotwert Farbe 8, E1, 30
IDE11714-ENG133427-Aesthetic lighting: color list-Rotwert Farbe 9, E1, 30
MAS01490-ENG116830-Energy Management System-Energy_Management_Adaptation, Energy Management System Act. ,one
MAS01490-ENG133400-Energy Management System-Praediktives_Energiemanagement, not active, 1
MAS05055-Angular Position: Bottom, 31.49 °, 2
MAS05056-Angular Position: Top, 170.49 °, 2
MAS05934-ENG116716-Powered folding roof drive-Doppelpuls nur Verdeck, act. ,8
MAS05934-ENG116718-Powered folding roof drive-Heckdeckel sperren bei Verdeckbetrieb, not active, 8
MAS05934-ENG122193-Powered folding roof drive-Heckschloss oeffnen durch Verdeck-SG, not active, 8
MAS05934-ENG116711-Powered folding roof drive-Komfortbedienung Verdeck global, act. ,8
MAS05934-ENG122189-Powered folding roof drive-Komfortbedienung Verdeck oeffnen, act. ,8
MAS05934-ENG116712-Powered folding roof drive-Komfortbedienung Verdeck schlie? En, act. ,8
MAS05934-ENG126630-Powered folding roof drive-Reichweitenbegrenzung fuer Servoheck schliessen, not active, 8
MAS05934-ENG133391 - Foldable Roof Drive - Remote Lock Unlock Timer s1.0 s, 8
MAS05934-ENG133392-Powered folding roof drive-Remote Lock Unlock Timer s3.0.000 ms, 8
MAS05934-ENG116717-Foldable roof drive works-Verdeck mit Schiebedach, not active, 8
MAS05934-ENG122191-Powered folding roof drive-Verdeck oeffnen via Funkfernbedienung, act. ,8
MAS05934-ENG122192-Powered folding roof drive-Verdeck oeffnen via Kessy, act. ,8
MAS05934-ENG122190-Powered folding roof drive-Verdeck oeffnen via Schliesszylinder, not active, 8
MAS05934-ENG116714-Foldable roof drive works - Verdeck schlie? En via Funkfernbedienung, act. ,8
MAS05934-ENG116715-Foldable roof drive works-Verdeck schlie? En via Kessy, not active, 8
MAS05934-ENG116713-Foldable roof drive works-Verdeck schlie? En via Schlie? Zylinder, not active, 8
MAS05934-ENG126843-Foldable roof drive works-ZV verriegeln bei Klemme 15 Ein, not active, 8
MAS08228-ENG133434-Light Sensor-Daemmerungsgrenze: Hysterese_obergrenze, 60 lx, 24
MAS08228-ENG133435-Light Sensor-Daemmerungsgrenze_Hysterese_untergrenze, 110 lx, 24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle, 1000 lx, 24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO, 30 lx, 24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten, 60 lx, 24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten, 110 lx, 24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red, 80, 24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell, 100 lx, 24
MAS08228-ENG133442-Light Sensor-Maximale_Ausgangsspannung, 4500 mV, 24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke, 300 lx, 24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung, 2000 mV, 24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke, 0 lx, 24
MAS08228-ENG133443-Light Sensor-Tunnel_einschalt_verzoegerung, 02, 24
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_correct_factor_group_1,1.00, 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_correction factor_group_10,1.00, 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_correct_factor_group_11,1.00, 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_correction factor_group_12,1.00, 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_correct_factor_group_13,1.00, 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_correction factor_group_14,1.00, 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_correction factor_group_15,1.00, 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_correction factor_group_2,1.00, 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_correction factor_group_3,1.00, 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_correction factor_group_4,1.00, 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_correct_factor_group_5,1.00, 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_correct_factor_group_6,1.00, 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_correction factor_group_7,1.00, 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_correction factor_group_8,1.00, 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_correct_factor_group_9,1.00, 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1, Дверь, 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10, Дверь, 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11, Дверь, 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12, Дверь, 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13, Дверь, 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14, Дверь, 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15, Дверь, 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2, Дверь, 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3, Дверь, 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4, Дверь, 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5, Дверь, 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6, Дверь, 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7, Дверь, 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8, ​​Дверь, 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9, Дверь, 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1, not your own. , 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10, not your own. , 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11, not your own. , 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12, not your own. , 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13, not your own. , 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14, not your own. , 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15, not установл. , 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2, not your own. , 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3, not your own. , 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4, not your own. , 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5, not your own. , 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6, not your own. , 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7, not your own. , 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8, ​​not your own. , 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9, not your own. , 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_: 12.0, 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0, 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0, 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0, 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0, 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0, 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0, 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0, 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modulespa_einzeladresse_slave_17,0 ,60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00 ,60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,не установл. ,60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,не установл. ,60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,не установл. ,60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,не установл. ,60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,не установл. ,60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,не установл. ,60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,не установл. ,60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,не установл. ,60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,не установл. ,60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,не установл. ,60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,не установл. ,60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,не установл. ,60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,не установл. ,60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,не установл. ,60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,не установл. ,60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,не установл. ,60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,не установл. ,60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,не установл. ,60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,не установл. ,60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,не установл. ,60
ENG126647-ENG98827-debug_light_function-Отклонение,0 ,11
ENG126647-ENG126823-debug_light_function WBT issue, 0, 11
ENG122934-erase_error_table, 55 00 00, 3
ENG122933-error_mask, 0 bit, 2
ENG117283-ENG122998-Front wash function-factor_washing_delay, 10, 2
ENG117283-ENG108451-Front wash function-Резерв, 0, 2
ENG99457-ENG117394-Подогрев пространства для головы-blower_speed, 1, 2
ENG99457-ENG98971-Подогрев пространства для головы-Температура, -2, 2
ENG116836-ENG115658-Indoor Lighting Abdims-x0.0 ms, 22
ENG116836-ENG101574-Interior lighting Abdims-X1,200 ms, 22
ENG116836-ENG115664-Interior lighting Abdims-x10,2000 ms, 22
ENG116836-ENG99557-Interior lighting Abdims-X2,400 ms, 22
ENG116836-ENG102140-Interior lighting Abdims-X3,600 ms, 22
ENG116836-ENG102936-Interior lighting Abdims-X4,800 ms, 22
ENG116836-ENG103548-Interior Lighting Abdims-X5.1000 ms, 22
ENG116836-ENG113992-Interior lighting Abdims-X6.1200 ms, 22
ENG116836-ENG115661-Interior lighting Abdims-x7.1400 ms, 22
ENG116836-ENG115662-Indoor Lighting Abdims-x8.1600 ms, 22
ENG116836-ENG115663-Interior Lighting Abdims-x9.1800 ms, 22
ENG116836-ENG115659-Interior lighting Abdims-y0,100.00%, 22
ENG116836-ENG99777-Interior lighting Abdims-Y1.72.00%, 22
ENG116836-ENG115668-Interior lighting Abdims-y10,0.00%, 22
ENG116836-ENG100480-Interior Lighting Abdims-Y2.48.00%, 22
ENG116836-ENG100773-Interior lighting Abdims-Y3.33.00%, 22
ENG116836-ENG100631-Interior lighting Abdims-Y4,18.00%, 22
ENG116836-ENG102174-Interior lighting Abdims-Y5,12.00%, 22
ENG116836-ENG113993-Interior lighting Abdims-Y6,8.00%, 22
ENG116836-ENG115665-Interior lighting Abdims-y7,6.00%, 22
ENG116836-ENG115666-Interior lighting Abdims-y8,4.00%, 22
ENG116836-ENG115667-Interior lighting Abdims-y9,2.00%, 22
ENG116831-ENG115658-Interior Lighting Photosensor-x0.0, 22
ENG116831-ENG101574-Interior Lighting Photosensor-X1.50, 22
ENG116831-ENG115664-Interior Lighting Photosensor-x10.0, 22
ENG116831-ENG99557-Interior Lighting Photosensor-X2,100, 22
ENG116831-ENG102140 Interior Lighting Photosensor-X3,200, 22
ENG116831-ENG102936-Interior Lighting Photosensor-X4,253, 22
ENG116831-ENG103548 Interior Lighting Photosensor-X5.0, 22
ENG116831-ENG113992-Interior Lighting Photosensor-X6.0, 22
ENG116831-ENG115661-Interior Lighting Photosensor-x7.0, 22
ENG116831-ENG115662-Interior Lighting Photosensor-x8.0, 22
ENG116831-ENG115663-Interior Lighting Photosensor-x9.0, 22
ENG116831-ENG115659 Indoor Lighting Photosensor-y0.0 lx, 22
ENG116831-ENG99777 Indoor Lighting Photosensor-Y1.50 lx, 22
ENG116831-ENG115668-Interior Lighting Photosensor-y10.0 lx, 22
ENG116831-ENG100480 Indoor Lighting Photosensor-Y2,100 lx, 22
ENG116831-ENG100773 Interior Lighting Photosensor-Y3,200, 22
ENG116831-ENG100631 Interior Lighting Photosensor-Y4,500, 22
ENG116831-ENG102174-Interior Lighting Photosensor-Y5.0, 22
ENG116831-ENG113993-Interior Lighting Photosensor-Y6.0 lx, 22
ENG116831-ENG115665 Indoor Lighting Photosensor-y7.0 lx, 22
ENG116831-ENG115666-Interior Lighting Photosensor-y8.0 lx, 22
ENG116831-ENG115667-Interior Lighting Photosensor-y9.0 lx, 22
ENG116835-ENG115658-Interior lighting Highlights-x0.0 ms, 22
ENG116835-ENG101574-Interior lighting Highlights-X1,200 ms, 22
ENG116835-ENG115664-Interior lighting Highlights-x10,2000 ms, 22
ENG116835-ENG99557-Interior lighting Highlights-X2,400 ms, 22
ENG116835-ENG102140-Interior lighting Highlights-X3,600 ms, 22
ENG116835-ENG102936-Interior lighting Highlights-X4,800 ms, 22
ENG116835-ENG103548-Interior lighting Highlights-X5.1000 ms, 22
ENG116835-ENG113992-Interior lighting Hochdimmen-X6.1200 ms, 22
ENG116835-ENG115661-Indoor lighting Highlights-x7.1400 ms, 22
ENG116835-ENG115662-Indoor lighting Highlights-x8.1600 ms, 22
ENG116835-ENG115663-Indoor lighting Highlights-x9.1800 ms, 22
ENG116835-ENG115659-Interior lighting Highlights-y0.0.00%, 22
ENG116835-ENG99777-Interior lighting Highlights-Y1,1.00%, 22
ENG116835-ENG115668-Interior lighting Hochdimmen-y10,100.00%, 22
ENG116835-ENG100480-Interior lighting Highlights-Y2,3.00%, 22
ENG116835-ENG100773-Interior lighting Highlights-Y3.5.00%, 22
ENG116835-ENG100631-Interior lighting Highlights-Y4,11.00%, 22
ENG116835-ENG102174-Interior lighting Hochdimmen-Y5,22.00%, 22
ENG116835-ENG113993-Interior lighting Hochdimmen-Y6.40.00%, 22
ENG116835-ENG115665-Interior lighting Highlights-y7,80.00%, 22
ENG116835-ENG115666-Interior lighting Highlights-y8.95.00%, 22
ENG116835-ENG115667-Interior lighting Highlights-y9,100.00%, 22
ENG116975-ENG115658 Interior Lighting KL 58xd log Bus-x0.0.00%, 12
ENG116975-ENG101574-Interior lighting KL 58xd log Bus-X1.6.00%, 12
ENG116975-ENG99557 Interior Lighting KL 58xd log Bus-X2.16.00%, 12
ENG116975-ENG102140 Interior Lighting KL 58xd log Bus-X3.30.00%, 12
ENG116975-ENG102936-Interior lighting KL 58xd log Bus-X4.60.00%, 12
ENG116975-ENG103548 Interior Lighting KL 58xd log Bus-X5,100.00%, 12
ENG116975-ENG115659-Interior lighting KL 58xd log Bus-y0,10, 12
ENG116975-ENG99777-Interior lighting KL 58xd log Bus-Y1,10, 12
ENG116975-ENG100480 Interior Lighting KL 58xd log Bus-Y2,100, 12
ENG116975-ENG100773-Inner Belt KL 58xd log bus Y3,150, 12
ENG116975-ENG100631-Indoor lighting KL 58xd log Bus-Y4,220, 12
ENG116975-ENG102174 interior lighting KL 58xd log Bus-Y5,253, 12
ENG116976-ENG115658-Indoor lighting KL 58xd max-x0,0 lx, 10
ENG116976-ENG101574-Interior lighting KL 58xd max-X1,8 lx, 10
ENG116976-ENG99557 interior lighting KL 58xd max-X2,200 lx, 10
ENG116976-ENG102140-Indoor lighting KL 58xd max-X3,300 lx, 10
ENG116976-ENG102936-Indoor lighting KL 58xd max-X4,500 lx, 10
ENG116976-ENG115659-Interior lighting KL 58xd max-y0,16.00, 10
ENG116976-ENG99777-Interior lighting KL 58xd max-Y1,16.00, 10
ENG116976-ENG100480-Indoor lighting KL 58xd max-Y2,100.00, 10
ENG116976-ENG100773-Indoor lighting KL 58xd max-Y3,100.00, 10
ENG116976-ENG100631-Indoor lighting KL 58xd max-Y4,100.00, 10
ENG116980-ENG115658-Interior lighting KL 58xd min-x0,0 lx, 10
ENG116980-ENG101574-Interior lighting KL 58xd min-X1,8 lx, 10
ENG116980-ENG99557-Interior lighting KL 58xd min-X2,220 lx, 10
ENG116980-ENG102140-Indoor lighting KL 58xd min-X3,300 lx, 10
ENG116980-ENG102936-Interior lighting KL 58xd min-X4,500 lx, 10
ENG116980-ENG115659-Interior lighting KL 58xd min-y0,6.00, 10
ENG116980-ENG99777-Interior lighting KL 58xd min-Y1,6.00, 10
ENG116980-ENG100480-Indoor lighting KL 58xd min-Y2,100.00, 10
ENG116980-ENG100773-Indoor lighting KL 58xd min-Y3,100.00, 10
ENG116980-ENG100631-Indoor lighting KL 58xd min-Y4,100.00, 10
ENG116979-ENG115658-Indoor lighting KL 58xd PWM-x0,0, 12
ENG116979-ENG101574-Interior lighting KL 58xd PWM-X1,10, 12
ENG116979-ENG99557 interior lighting KL 58xd PWM-X2,50, 12
ENG116979-ENG102140-Indoor lighting KL 58xd PWM-X3,100, 12
ENG116979-ENG102936-Indoor lighting KL 58xd PWM-X4,220, 12
ENG116979-ENG103548-Indoor lighting KL 58xd PWM-X5,253, 12
ENG116979-ENG115659-Indoor lighting KL 58xd PWM-y0,2.00%, 12
ENG116979-ENG99777-Indoor lighting KL 58xd PWM-Y1,2.00%, 12
ENG116979-ENG100480-Indoor lighting KL 58xd PWM-Y2,6.00%, 12
ENG116979-ENG100773-Indoor lighting KL 58xd PWM-Y3,10.00%, 12
ENG116979-ENG100631-Indoor lighting KL 58xd PWM-Y4,80.00%, 12
ENG116979-ENG102174-Indoor lighting KL 58xd PWM-Y5,100.00%, 12
ENG116972-ENG115658-Interior lighting KL 58xs max-x0,0 lx, 8
ENG116972-ENG101574-Indoor lighting KL 58xs max-X1,8 lx, 8
ENG116972-ENG99557-Interior lighting KL 58xs max-X2,50 lx, 8
ENG116972-ENG102140 indoor lighting KL 58xs max-X3,500 lx, 8
ENG116972-ENG115659-Interior lighting KL 58xs max-y0,100.00, 8
ENG116972-ENG99777-Interior lighting KL 58xs max-Y1,100.00, 8
ENG116972-ENG100480-Indoor lighting KL 58xs max-Y2,100.00, 8
ENG116972-ENG100773-Indoor lighting KL 58xs max-Y3,100.00, 8
ENG126561-ENG115658-interior lighting KL 58xs min-x0,0 lx, 8
ENG126561-ENG101574-Interior lighting KL 58xs min-X1,8 lx, 8
ENG126561-ENG99557 interior lighting KL 58xs min-X2,50 lx, 8
ENG126561-ENG102140 interior lighting KL 58xs min-X3,500 lx, 8
ENG126561-ENG115659-interior lighting KL 58xs min-y0,6.00, 8
ENG126561-ENG99777-Interior lighting KL 58xs min-Y1,6.00, 8
ENG126561-ENG100480-Indoor lighting KL 58xs min-Y2,100.00, 8
ENG126561-ENG100773-Interior lighting KL 58xs min-Y3,100.00, 8
ENG116977-ENG115658-Interior lighting KL 58xs PWM-x0,0.00%, 6
ENG116977-ENG101574-Indoor lighting KL 58xs PWM-X1,50.00%, 6
ENG116977-ENG99557-Indoor Lighting KL 58xs PWM-X2,100.00%, 6
ENG116977-ENG115659-Indoor lighting KL 58xs PWM-y0,0.00%, 6
ENG116977-ENG99777-Interior lighting KL 58xs PWM-Y1,50.00%, 6
ENG116977-ENG100480-Indoor Lighting KL 58xs PWM-Y2,100.00%, 6
ENG116974-ENG115658-Indoor lighting KL 58xt max-x0,0 lx, 8
ENG116974-ENG101574-Interior lighting KL 58xt max-X1,8 lx, 8
ENG116974-ENG99557-Interior lighting KL 58xt max-X2,50 lx, 8
ENG116974-ENG102140-Indoor lighting KL 58xt max-X3,500 lx, 8
ENG116974-ENG115659-Interior lighting KL 58xt max-y0,100.00, 8
ENG116974-ENG99777-Interior lighting KL 58xt max-Y1,100.00, 8
ENG116974-ENG100480-Indoor lighting KL 58xt max-Y2,100.00, 8
ENG116974-ENG100773-Indoor lighting KL 58xt max-Y3,100.00, 8
ENG116973-ENG115658-Interior lighting KL 58xt min-x0,0 lx, 8
ENG116973-ENG101574-Interior lighting KL 58xt min-X1,8 lx, 8
ENG116973-ENG99557-Interior lighting KL 58xt min-X2,50 lx, 8
ENG116973-ENG102140-Indoor lighting KL 58xt min-X3,500 lx, 8
ENG116973-ENG115659-Interior lighting KL 58xt min-y0,6.00, 8
ENG116973-ENG99777-Interior lighting KL 58xt min-Y1,6.00, 8
ENG116973-ENG100480-Indoor lighting KL 58xt min-Y2,100.00, 8
ENG116973-ENG100773-Indoor lighting KL 58xt min-Y3,100.00, 8
ENG116978-ENG115658-Indoor lighting KL 58xt PWM-x0,0.00%, 6
ENG116978-ENG101574-Indoor lighting KL 58xt PWM-X1,50.00%, 6
ENG116978-ENG99557-Indoor lighting KL 58xt PWM-X2,100.00%, 6
ENG116978-ENG115659-Interior lighting KL 58xt PWM-y0,0.00%, 6
ENG116978-ENG99777-Interior lighting KL 58xt PWM-Y1,50.00%, 6
ENG116978-ENG100480-Indoor lighting KL 58xt PWM-Y2,100.00%, 6
ENG116834-ENG115633-Indoor lighting Button dimming button dimming x0.0 ms, 10
ENG116834-ENG115634-Interior lighting button dimmer ung button dimming x1,100 ms, 10
ENG116834-ENG115635-Indoor lighting Button dimming button dimming x2,160 ms, 10
ENG116834-ENG115636-Indoor lighting Button dimming button dimming x3,200 ms, 10
ENG116834-ENG115637-Indoor lighting Button dimming button dimming x4,260 ms, 10
ENG116834-ENG115638-Indoor lighting Button dimming button dimming y0,1.00%, 10
ENG116834-ENG115639-Indoor lighting Button dimming button dimming y1,5.00, 10
ENG116834-ENG115640-Indoor lighting Button dimming button dimming y2,15.00, 10
ENG116834-ENG115641-Indoor lighting Button dimming button dimming y3,10.00, 10
ENG116834-ENG115642-Indoor lighting Button dimming button dimming y4,100.00, 10
ENG116936-ENG115883 light 0 BLK VL B36 dimming Direction CD 0, maximize, 16
ENG116936-ENG115887 light 0 BLK VL B36 dimming Direction EF 0, maximize, 16
ENG116936-ENG115891 light 0 BLK VL B36 Dimming Direction GH 0, maximize, 16
ENG116936-ENG115878 light 0 BLK VL B36 dimming value AB 0.100, 16
ENG116936-ENG115882 light 0 BLK VL B36 dimming value CD 0.0, 16
ENG116936-ENG115886 lamp 0 BLK VL B36 dimming value EF 0,0, 16
ENG116936-ENG115890 light 0 BLK VL B36 dimming value GH 0.0, 16
ENG116936-ENG115875 light 0 BLK VL B36 fault location medium byte DTC-DFCC 0,14, 16
ENG116936-ENG116547 light 0 BLK VL B36 lamp defect bit Position 0.34, 16
ENG116936-ENG115873 light 0 BLK VL B36 load type 0.12 - flashing lights, 16
ENG116936-ENG115879 light 0 BLK VL B36 light control HD AB 0, всегда, 16
ENG116936-ENG115876 light 0 BLK VL B36 light function A 0, left flashing light phase, 16
ENG116936-ENG115877 light 0 BLK VL B36 light function B 0, not active, 16
ENG116936-ENG115880 light 0 BLK VL B36 light function C 0, not active, 16
ENG116936-ENG115881 light 0 BLK VL B36 light function D 0, not active, 16
ENG116936-ENG115884 light 0 BLK VL B36 light function E 0, not active, 16
ENG116936-ENG115885 light 0 BLK VL B36 light function F 0, not active, 16
ENG116936-ENG115888 light 0 BLK VL B36 light function G 0, not active, 16
ENG116936-ENG115889 light 0 BLK VL B36 light function H 0, not active, 16
ENG116946-ENG116072-Lamp10SHUTTER LB23-Dimming Direction CD 10, maximize, 16
ENG116946-ENG116076-Lamp10SHUTTER LB23-Dimming Direction EF 10, maximize, 16
ENG116946-ENG116080-Lamp10SHUTTER LB23-Dimming Direction GH 10, maximize, 16
ENG116946-ENG116067-Leuchten10SHUTTER LB23 dimming value AB 10.0, 16
ENG116946-ENG116071 luminaire10SHUTTER LB23 dimming value CD 10.0, 16
ENG116946-ENG116075 lamp10SHUTTER LB23 dimming value EF 10.0, 16
ENG116946-ENG116079 luminaire10SHUTTER LB23 dimming value GH 10.0, 16
ENG116946-ENG116064-Luminaire10SHUTTER LB23 error location medium byte DTC-DFCC 10.00, 16
ENG116946-ENG116560 lamp10SHUTTER LB23 lamp defect bit position 10.00, 16
ENG116946-ENG116062-Lamp10SHUTTER LB23 Load Type 10, not active, 16
ENG116946-ENG116068-Lamp10SHUTTER LB23-Light Controller HD AB 10, всегда, 16
ENG116946-ENG116065 lamp10SHUTTER LB23 light function A 10, not active, 16
ENG116946-ENG116066-Lamp10SHUTTER LB23 Light Function B 10, not active, 16
ENG116946-ENG116069-Leuchten10SHUTTER LB23-Lichtfunktion C 10, not active, 16
ENG116946-ENG116070-Leuchten10SHUTTER LB23-Lichtfunktion D 10, not active, 16
ENG116946-ENG116073-Leuchten10SHUTTER LB23 light function E 10, not active, 16
ENG116946-ENG116074-Leuchten10SHUTTER LB23 light function F 10, not active, 16
ENG116946-ENG116077-Licht10SHUTTER LB23 light function G 10, not active, 16
ENG116946-ENG116078-Leuchten10SHUTTER LB23-Lichtfunktion H 10, not active, 16
ENG116947-ENG116091-Lamp11SHUTTER RB22-Dimming Direction CD 11, maximize, 16
ENG116947-ENG116095-Lamp11SHUTTER RB22-Dimming Direction EF 11, maximize, 16
ENG116947-ENG116099-Lamp11SHUTTER RB22-Dimming Direction GH 11, maximize, 16
ENG116947-ENG116086-Lamp11SHUTTER RB22 dimming value AB 11,0, 16
ENG116947-ENG116090-Leuchten11SHUTTER RB22 dimming value CD 11,0, 16
ENG116947-ENG116094 light11SHUTTER RB22 dimming value EF 11,0, 16
ENG116947-ENG116098-Lamp11SHUTTER RB22 dimming value GH 11,0, 16
ENG116947-ENG116083 light11SHUTTER RB22 fault location medium byte DTC-DFCC 11,00, 16
ENG116947-ENG116561 light11SHUTTER RB22 lamp defect bit position 11,00, 16
ENG116947-ENG116081-Lamp11SHUTTER RB22-Load Type 11, not active, 16
ENG116947-ENG116087-light11SHUTTER RB22-light control HD AB 11, всегда, 16
ENG116947-ENG116084 light11SHUTTER RB22 light function A 11, not active, 16
ENG116947-ENG116085 light11SHUTTER RB22 light function B 11, not active, 16
ENG116947-ENG116088-Leuchten11SHUTTER RB22-Lichtfunktion C 11, not active, 16
ENG116947-ENG116089-Leuchten11SHUTTER RB22-Lichtfunktion D 11, not active, 16
ENG116947-ENG116092-Leuchten11SHUTTER RB22-Lichtfunktion E 11, not active, 16
ENG116947-ENG116093 light11SHUTTER RB22 light function F 11, not active, 16
ENG116947-ENG116096-Leuchten11SHUTTER RB22-Lichtfunktion G 11, not active, 16
ENG116947-ENG116097-Leuchten11SHUTTER RB22-Lichtfunktion H 11, not active, 16
ENG116948-ENG116110 Light 12NL LB45 Dimming Direction CD 12, maximize, 16
ENG116948-ENG116114 Light 12NL LB45 Dimming Direction EF 12, maximize, 16
ENG116948-ENG116118 Lamp 12NL LB45 Dimming Direction GH 12, maximize, 16
ENG116948-ENG116105 light 12NL LB45 dimming value AB 12,100, 16
ENG116948-ENG116109 light 12NL LB45 dimming value CD 12.0, 16
ENG116948-ENG116113 light 12NL LB45 dimming value EF 12.0, 16
ENG116948-ENG116117 light 12NL LB45 dimming value GH 12.0, 16
ENG116948-ENG116102 light 12NL LB45 fault location middle byte DTC-DFCC 12,22, 16
ENG116948-ENG116562 light 12NL LB45 lamp defect bit position 12,38, 16
ENG116948-ENG116100-Licht12NL LB45 load type 12,10 - general headlights, 16
ENG116948-ENG116106 light 12NL LB45 light control HD AB 12, всегда, 16
ENG116948-ENG116103 light 12NL LB45 light function A 12, fog light left, 16
ENG116948-ENG116104 light 12NL LB45 light function B 12, cornering light left, 16
ENG116948-ENG116107-Lamp12NL LB45 light function C 12, not active, 16
ENG116948-ENG116108 luminaire12NL LB45 light function D 12, not active, 16
ENG116948-ENG116111 luminaire12NL LB45 light function E 12, not active, 16
ENG116948-ENG116112-Leuchten12NL LB45 light function F 12, not active, 16
ENG116948-ENG116115 luminaire12NL LB45 light function G 12, not active, 16
ENG116948-ENG116116 luminaire12NL LB45 light function H 12, not active, 16
ENG116949-ENG116129-Luminaire13NL RB5-Dimming Direction CD 13, maximize, 16
ENG116949-ENG116133-Luminaire13NL RB5-Dimming Direction EF 13, maximize, 16
ENG116949-ENG116137-Luminaire13NL RB5-Dimming Direction GH 13, maximize, 16
ENG116949-ENG116124 light13NL RB5 dimming value AB 13,100, 16
ENG116949-ENG116128 light13NL RB5 dimming value CD 13.0, 16
ENG116949-ENG116132 light13NL RB5 dimming value EF 13.0, 16
ENG116949-ENG116136 light13NL RB5 dimming value GH 13,0, 16
ENG116949-ENG116121 light13NL RB5 fault location middle byte DTC-DFCC 13,23, 16
ENG116949-ENG116563 light13NL RB5 lamp defect bit position 13,42, 16
ENG116949-ENG116119-Luminaire13NL RB5-Load-Type 13,10 - general headlights, 16
ENG116949-ENG116125 light13NL RB5 light control HD AB 13, всегда, 16
ENG116949-ENG116122 light13NL RB5 light function A 13, fog light right, 16
ENG116949-ENG116123-Leuchten13NL RB5-Lichtfunktion B 13, cornering light right, 16
ENG116949-ENG116564 light13NL RB5 light function C 13, not active, 16
ENG116949-ENG116127 light13NL RB5 light function D 13, not active, 16
ENG116949-ENG116130 light13NL RB5 light function E 13, not active, 16
ENG116949-ENG116131 light13NL RB5 light function F 13, not active, 16
ENG116949-ENG116134 light13NL RB5 light function G 13, not active, 16
ENG116949-ENG116135 light13NL RB5 light function H 13, not active, 16
ENG116951-ENG116167-Luminaire15AL RB44-Dimming Direction CD 15, maximize, 16
ENG116951-ENG116171-Luminaire15AL RB44-Dimming Direction EF 15, maximize, 16
ENG116951-ENG116175-Luminaire15AL RB44-Dimming Direction GH 15, maximize, 16
ENG116951-ENG116162 luminaire15AL RB44 dimming value AB 15.0, 16
ENG116951-ENG116166 luminaire15AL RB44 dimming value CD 15.0, 16
ENG116951-ENG116170 luminaire15AL RB44 dimming value EF 15.0, 16
ENG116951-ENG116174-Leuchten15AL RB44 dimming value GH 15,0, 16
ENG116951-ENG116159-Luminaire15AL RB44 fault location medium byte DTC-DFCC 15,00, 16
ENG116951-ENG116566 luminaire15AL RB44 lamp defect bit position 15.00, 16
ENG116951-ENG116157 luminaire15AL RB44 load type 15, not active, 16
ENG116951-ENG116163-Luminaire15AL RB44 lighting control HD AB 15, всегда, 16
ENG116951-ENG116160 luminaire15AL RB44 light function A 15, not active, 16
ENG116951-ENG116161 luminaire15AL RB44 light function B 15, not active, 16
ENG116951-ENG116164 luminaire15AL RB44 light function C 15, not active, 16
ENG116951-ENG116165 luminaire15AL RB44 light function D 15, not active, 16
ENG116951-ENG116168 luminaire15AL RB44 light function E 15, not active, 16
ENG116951-ENG116169 luminaire15AL RB44 light function F 15, not active, 16
ENG116951-ENG116172 luminaire15AL RB44 light function G 15, not active, 16
ENG116951-ENG116173 luminaire15AL RB44 light function H 15, not active, 16
ENG116952-ENG116186-Leuchten16BLK SLB35BLK SL KC9-Dimming Direction CD 16, maximize, 16
ENG116952-ENG116190-Leuchten16BLK SLB35BLK SL KC9-Dimming Direction EF16, maximize, 16
ENG116952-ENG116194-Leuchten16BLK SLB35BLK SL KC9-Dimming Direction GH 16, maximize, 16
ENG116952-ENG116181-Leuchten16BLK SLB35BLK SL KC9 dimming value AB 16,0, 16
ENG116952-ENG116185-Leuchten16BLK SLB35BLK SL KC9 dimming value CD 16,0, 16
ENG116952-ENG116189-Leuchten16BLK SLB35BLK SL KC9 dimming value EF 16,0, 16
ENG116952-ENG116193-Leuchten16BLK SLB35BLK SL KC9 dimming value GH 16,0, 16
ENG116952-ENG116178-Leuchten16BLK SLB35BLK SL KC9-error location medium byte DTC-DFCC 16,00, 16
ENG116952-ENG116567 light16BLK SLB35BLK SL KC9 lamp defect bit position 16.00, 16
ENG116952-ENG116176-Leuchten16BLK SLB35BLK SL KC9 load type 16, not active, 16
ENG116952-ENG116182 light16BLK SLB35BLK SL KC9 light control HD AB 16, всегда, 16
ENG116952-ENG116179-Leuchten16BLK SLB35BLK SL KC9-Lichtfunktion A 16, not active, 16
ENG116952-ENG116180-Leuchten16BLK SLB35BLK SL KC9-Lichtfunktion B 16, not active, 16
ENG116952-ENG116183-Leuchten16BLK SLB35BLK SL KC9 light function C 16, not active, 16
ENG116952-ENG116184-Leuchten16BLK SLB35BLK SL KC9 light function D 16, not active, 16
ENG116952-ENG116187-Leuchten16BLK SLB35BLK SL KC9 light function E 16, not active, 16
ENG116952-ENG116188-Leuchten16BLK SLB35BLK SL KC9 light function F 16, not active, 16
ENG116952-ENG116191-Leuchten16BLK SLB35BLK SL KC9 light function G 16, not active, 16
ENG116952-ENG116192-Leuchten16BLK SLB35BLK SL KC9-Lichtfunktion H 16, not active, 16
ENG116953-ENG116205 Luminaire17TFL R BLK SRB3TFL R BLK SR KC3 Dimming Direction CD 17, maximize, 16
ENG116953-ENG116209-Luminaire17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17, maximize, 16
ENG116953-ENG116213-Luminaire17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17, maximize, 16
ENG116953-ENG116200-Leuchten17TFL R BLK SRB3TFL R BLK SR KC3 dimming value AB 17,0, 16
ENG116953-ENG116204-Leuchten17TFL R BLK SRB3TFL R BLK SR KC3 dimming value CD 17,0, 16
ENG116953-ENG116208-Leuchten17TFL R BLK SRB3TFL R BLK SR KC3 dimming value EF 17,0, 16
ENG116953-ENG116212-Leuchten17TFL R BLK SRB3TFL R BLK SR KC3 dimming value GH 17,0, 16
ENG116953-ENG116197 light17TFL R BLK SRB3TFL R BLK SR KC3 fault location medium byte DTC-DFCC 17,00, 16
ENG116953-ENG116568 light17TFL R BLK SRB3TFL R BLK SR KC3 lamp defect bit position 17.00, 16
ENG116953-ENG116195-Leuchten17TFL R BLK SRB3TFL R BLK SR KC3 load type 17, not active, 16
ENG116953-ENG116201-light17TFL R BLK SRB3TFL R BLK SR KC3-light control HD AB 17, всегда, 16
ENG116953-ENG116198-Leuchten17TFL R BLK SRB3TFL R BLK SR KC3 light function A 17, not active, 16
ENG116953-ENG116569-Leuchten17TFL R BLK SRB3TFL R BLK SR KC3 light function B 17, not active, 16
ENG116953-ENG116202-Leuchten17TFL R BLK SRB3TFL R BLK SR KC3 light function C 17, not active, 16
ENG116953-ENG116203-Leuchten17TFL R BLK SRB3TFL R BLK SR KC3 light function D 17, not active, 16
ENG116953-ENG116206-Leuchten17TFL R BLK SRB3TFL R BLK SR KC3 light function E 17, not active, 16
ENG116953-ENG116207-Leuchten17TFL R BLK SRB3TFL R BLK SR KC3 light function F 17, not active, 16
ENG116953-ENG116210-Leuchten17TFL R BLK SRB3TFL R BLK SR KC3 light function G 17, not active, 16
ENG116953-ENG116211-Leuchten17TFL R BLK SRB3TFL R BLK SR KC3 light function H 17, not active, 16
ENG116954-ENG116224-Leuchten18BLK HLA60-Dimming Direction CD 18, maximize, 16
ENG116954-ENG116228-Leuchten18BLK HLA60-Dimming Direction EF 18, maximize, 16
ENG116954-ENG116232 Luminaire18BLK HLA60 Dimming Direction GH 18, maximize, 16
ENG116954-ENG116219-Leuchten18BLK HLA60 dimming value AB 18,100, 16
ENG116954-ENG116223-Leuchten18BLK HLA60 dimming value CD 18,0, 16
ENG116954-ENG116227-Leuchten18BLK HLA60 dimming value EF 18,0, 16
ENG116954-ENG116231-Leuchten18BLK HLA60 dimming value GH 18,0, 16
ENG116954-ENG116216 Luminaire18BLK HLA60 fault location medium byte DTC-DFCC 18,16, 16
ENG116954-ENG116570 luminaire18BLK HLA60 lamp defect bit position 18,08, 16
ENG116954-ENG116214 light18BLK HLA60 load type 18,12 - turn signals, 16
ENG116954-ENG116220 light18BLK HLA60 light control HD AB 18, всегда, 16
ENG116954-ENG116217 light18BLK HLA60 light function A 18, left flashing light phase, 16
ENG116954-ENG116218-Leuchten18BLK HLA60 light function B 18, not active, 16
ENG116954-ENG116221-Leuchten18BLK HLA60 light function C 18, not active, 16
ENG116954-ENG116222-Leuchten18BLK HLA60-Lichtfunktion D 18, not active, 16
ENG116954-ENG116225-Leuchten18BLK HLA60 light function E 18, not active, 16
ENG116954-ENG116226-Leuchten18BLK HLA60 light function F 18, not active, 16
ENG116954-ENG116229-Leuchten18BLK HLA60 light function G 18, not active, 16
ENG116954-ENG116230-Leuchten18BLK HLA60-Lichtfunktion H 18, not active, 16
ENG116955-ENG116243-Leuchten19BLK HRC31-Dimming Direction CD 19, maximize, 16
ENG116955-ENG116247-Leuchten19BLK HRC31-Dimming Direction EF 19, maximize, 16
ENG116955-ENG116251-Leuchten19BLK HRC31-Dimming Direction GH 19, maximize, 16
ENG116955-ENG116238-Leuchten19BLK HRC31 dimming value AB 19,100, 16
ENG116955-ENG116242-Leuchten19BLK HRC31 dimming value CD 19,0, 16
ENG116955-ENG116246 light19BLK HRC31 dimming value EF 19.0, 16
ENG116955-ENG116250-Leuchten19BLK HRC31 dimming value GH 19,0, 16
ENG116955-ENG116235-Luminaire19BLK HRC31 fault location medium byte DTC-DFCC 19,18, 16
ENG116955-ENG116571 light19BLK HRC31 lamp defect bit position 19,18, 16
ENG116955-ENG116233-Luminaire19BLK HRC31-Load Type 19,12 - Indicator Lights, 16
ENG116955-ENG116239-light19BLK HRC31-light control HD AB 19, всегда, 16
ENG116955-ENG116236 light19BLK HRC31 light function A 19, right flashing light phase, 16
ENG116955-ENG116237-Leuchten19BLK HRC31 light function B 19, not active, 16
ENG116955-ENG116240 light19BLK HRC31 light function C 19, not active, 16
ENG116955-ENG116241-Leuchten19BLK HRC31-Lichtfunktion D 19, not active, 16
ENG116955-ENG116244-Leuchten19BLK HRC31 light function E 19, not active, 16
ENG116955-ENG116245-Leuchten19BLK HRC31 light function F 19, not active, 16
ENG116955-ENG116248-Leuchten19BLK HRC31 light function G 19, not active, 16
ENG116955-ENG116249-Leuchten19BLK HRC31 light function H 19, not active, 16
ENG116937-ENG115902 Luminaire1BLK VRB20 Dimming Direction CD 1, maximize, 16
ENG116937-ENG115906 light1BLK VRB20 dimming direction EF 1, maximize, 16
ENG116937-ENG115909-Leuchten1BLK VRB20-Dimming Direction GH 1, maximize, 16
ENG116937-ENG115897 light1BLK VRB20 dimming value AB 1,100, 16
ENG116937-ENG115901 light1BLK VRB20 dimming value CD 1,0, 16
ENG116937-ENG115905 light1BLK VRB20 dimming value EF 1,0, 16
ENG116937-ENG115908 light1BLK VRB20 dimming value GH 1,0, 16
ENG116937-ENG115894 light1BLK VRB20 fault location medium byte DTC DFCC 1.15, 16
ENG116937-ENG116548 light1BLK VRB20 lamp defect bit position 1,3E, 16
ENG116937-ENG115892 light1BLK VRB20 load type 1,12 - flashing lights, 16
ENG116937-ENG115898 light1BLK VRB20 light control HD AB 1, всегда, 16
ENG116937-ENG115895 light1BLK VRB20 light function A 1, right flashing light phase, 16
ENG116937-ENG115896 light1BLK VRB20 light function B 1, not active, 16
ENG116937-ENG115899 light1BLK VRB20 light function C 1, not active, 16
ENG116937-ENG115900 light1BLK VRB20 light function D 1, not active, 16
ENG116937-ENG115903 light1BLK VRB20 light function E 1, not active, 16
ENG116937-ENG115904 light1BLK VRB20 light function F 1, not active, 16
ENG116937-ENG115907 light1BLK VRB20 light function G 1, not active, 16
ENG116937-ENG116549 light1BLK VRB20 light function H 1, not active, 16
ENG116956-ENG116262 Luminaire20BR LA71 Dimming Direction CD 20, maximize, 16
ENG116956-ENG116266 Luminaire20BR LA71 Dimming Direction EF20, maximize, 16
ENG116956-ENG116270 Luminaire20BR LA71 Dimming Direction GH 20, maximize, 16
ENG116956-ENG116257 Luminaire20BR LA71 dimming value AB 20,100, 16
ENG116956-ENG116261 Luminaire20BR LA71 dimming value CD 20,25, 16
ENG116956-ENG116265-Luminaire20BR LA71 dimming value EF 20,0, 16
ENG116956-ENG116269 Luminaire20BR LA71 dimming value GH 20.0, 16
ENG116956-ENG116254 Luminaire20BR LA71 fault location medium byte DTC DFCC 20,39,16
ENG116956-ENG116572 Luminaire20BR LA71 lamp defect bit position 20.10, 16
ENG116956-ENG116252 Luminaire20BR LA71 Load Type 20,13 - Brake Lights, 16
ENG116956-ENG116258 luminaire20BR LA71 lighting control HD AB 20, всегда, 16
ENG116956-ENG116255 Luminaire20BR LA71 Light Function A 20, Стоп-сигнал, 16
ENG116956-ENG116256 Luminaire20BR LA71 Light Function B 20, Дверь багажного отсека открыта, 16
ENG116956-ENG116259-Leuchten20BR LA71-Lichtfunktion C 20, parking light general (tail light: position light: limiting light), 16
ENG116956-ENG116260 Luminaire20BR LA71 light function D 20, not active, 16
ENG116956-ENG116263-Luminaire20BR LA71 light function E 20, not active, 16
ENG116956-ENG116264L20BR LA71 light function F 20, not active, 16
ENG116956-ENG116267-Luminaire20BR LA71 light function G 20, not active, 16
ENG116956-ENG116268 Luminaire20BR LA71 Light Function H 20, not active, 16
ENG116957-ENG116281 Luminaire21BR RC8 Dimming Direction CD 21, maximize, 16
ENG116957-ENG116285 Luminaire21BR RC8 Dimming Direction EF 21, maximize, 16
ENG116957-ENG116289 Luminaire21BR RC8 Dimming Direction GH 21, maximize, 16
ENG116957-ENG116276 luminaire21BR RC8 dimming value AB 21,100, 16
ENG116957-ENG116280 luminaire21BR RC8 dimming value CD 21,25, 16
ENG116957-ENG116284 luminaire21BR RC8 dimming value EF 21,0, 16
ENG116957-ENG116288 luminaire21BR RC8 dimming value GH 21,0, 16
ENG116957-ENG116273 Luminaire21BR RC8 Fault Location Medium Byte DTC DFCC 21.3A, 16
ENG116957-ENG116573 luminaire21BR RC8 lamp defect bit position 21,20, 16
ENG116957-ENG116271 luminaire21BR RC8 load type 21,13 - brake lights, 16
ENG116957-ENG116277 luminaire21BR RC8 lighting control HD AB 21, всегда, 16
ENG116957-ENG116274 luminaire21BR RC8 light function A 21, Стоп-сигнал, 16
ENG116957-ENG116275 luminaire21BR RC8 light function B 21, Дверь багажного отсека открыта, 16
ENG116957-ENG116278-Leuchten21BR RC8 light function C 21, parking light general (tail light: position light: limiting light), 16
ENG116957-ENG116279-Leuchten21BR RC8-Lichtfunktion D 21, not active, 16
ENG116957-ENG116282 luminaire21BR RC8 light function E 21, not active, 16
ENG116957-ENG116283 luminaire21BR RC8 light function F 21, not active, 16
ENG116957-ENG116286 luminaire21BR RC8 light function G 21, not active, 16
ENG116957-ENG116287 luminaire21BR RC8 light function H 21, not active, 16
ENG116958-ENG116300 Luminaire22BR MA57 Dimming Direction CD 22, maximize, 16
ENG116958-ENG116304 Luminaire22BR MA57 Dimming Direction EF 22, maximize, 16
ENG116958-ENG116308 Luminaire22BR MA57 Dimming Direction GH 22, maximize, 16
ENG116958-ENG116295-Luminaire22BR MA57 dimming value AB 22,100, 16
ENG116958-ENG116299 luminaire22BR MA57 dimming value CD 22,100, 16
ENG116958-ENG116303 Luminaire22BR MA57 dimming value EF 22,0, 16
ENG116958-ENG116307 luminaire22BR MA57 dimming value GH 22,0, 16
ENG116958-ENG116292 Luminaire22BR MA57 Fault Location Medium Byte DTC-DFCC 22,2C, 16
ENG116958-ENG116574 luminaire22BR MA57 lamp defect bit position 22, 29, 16
ENG116958-ENG116290 Luminaire22BR MA57 Load Type 22,42 - LED Third Stop Light, 16
ENG116958-ENG116296 luminaire22BR MA57-Light control HD AB 22, всегда, 16
ENG116958-ENG116293-Luminaire22BR MA57 light function A 22, Стоп-сигнал, 16
ENG116958-ENG116294 luminaire22BR MA57 light function B 22, not active, 16
ENG116958-ENG116297-Luminaire22BR MA57 light function C 22, Дверь багажного отсека открыта, 16
ENG116958-ENG116298 luminaire22BR MA57 light function D 22, not active, 16
ENG116958-ENG116301 luminaire22BR MA57 light function E 22, not active, 16
ENG116958-ENG116302 luminaire22BR MA57 light function F 22, not active, 16
ENG116958-ENG116305 luminaire22BR MA57 light function G 22, not active, 16
ENG116958-ENG116306 luminaire22BR MA57 light function H 22, not active, 16
ENG116959-ENG116319-Luminaire23SL HLC10-Dimming Direction CD 23, maximize, 16
ENG116959-ENG116323-Luminaire23SL HLC10-Dimming Direction EF 23, maximize, 16
ENG116959-ENG116327 Luminaire23SL HLC10 Dimming Direction GH 23, maximize, 16
ENG116959-ENG116314-Leuchten23SL HLC10 dimming value AB 23,25, 16
ENG116959-ENG116318 luminaire23SL HLC10 dimming value CD 23,100, 16
ENG116959-ENG116322 luminaire23SL HLC10 dimming value EF 23,0, 16
ENG116959-ENG116326 luminaire23SL HLC10 dimming value GH 23,0, 16
ENG116959-ENG116311 luminaire23SL HLC10 fault location middle byte DTC-DFCC 23,29, 16
ENG116959-ENG116575 lamp23SL HLC10 lamp defect bit position 23,0A, 16
ENG116959-ENG116309 luminaire23SL HLC10 load type 23,9 - general incandescent lamp 27W: also H15, 16
ENG116959-ENG116315 luminaire23SL HLC10 lighting control HD AB 23, всегда, 16
ENG116959-ENG116312-Leuchten23SL HLC10-Lichtfunktion A 23, parking light general (tail light: position light: limiting light), 16
ENG116959-ENG116313-Leuchten23SL HLC10 light function B 23, not active, 16
ENG116959-ENG116316 luminaire23SL HLC10 light function C 23, Стоп-сигнал, 16
ENG116959-ENG116317-Leuchten23SL HLC10-Lichtfunktion D 23, not active, 16
ENG116959-ENG116320 luminaire23SL HLC10 light function E 23, not active, 16
ENG116959-ENG116321 luminaire23SL HLC10 light function F 23, not active, 16
ENG116959-ENG116324 luminaire23SL HLC10 light function G 23, not active, 16
ENG116959-ENG116325 luminaire23SL HLC10 light function H 23, not active, 16
ENG116960-ENG116338-Luminaire24SL HRA65-Dimming Direction CD 24, maximize, 16
ENG116960-ENG116342-Lamp24SL HRA65-Dimming Direction EF 24, maximize, 16
ENG116960-ENG116346-Lamp24SL HRA65-Dimming Direction GH 24, maximize, 16
ENG116960-ENG116333-Leuchten24SL HRA65 dimming value AB 24,25, 16
ENG116960-ENG116337-Leuchten24SL HRA65 dimming value CD 24,100, 16
ENG116960-ENG116341-Leuchten24SL HRA65 dimming value EF 24,0, 16
ENG116960-ENG116345-Leuchten24SL HRA65 dimming value GH 24,0, 16
ENG116960-ENG116330 Luminaire24SL HRA65 fault location medium byte DTC-DFCC 24,2A, 16
ENG116960-ENG116576 lamp24SL HRA65 lamp defect bit position 24,1A, 16
ENG116960-ENG116328-Lamp24SL HRA65-load type 24,9 - general torch 27W: also H15, 16
ENG116960-ENG116334-Lamp24SL HRA65-Light Control HD AB 24, всегда, 16
ENG116960-ENG116331-Leuchten24SL HRA65-Lichtfunktion A 24, parking light general (tail light: position light: limiting light), 16
ENG116960-ENG116332-Leuchten24SL HRA65 light function B 24, not active, 16
ENG116960-ENG116335-Leuchten24SL HRA65-Lichtfunktion C 24, Стоп-сигнал, 16
ENG116960-ENG116336-Leuchten24SL HRA65-Lichtfunktion D 24, not active, 16
ENG116960-ENG116339-Leuchten24SL HRA65 light function E 24, not active, 16
ENG116960-ENG116340-Leuchten24SL HRA65-light function F 24, not active, 16
ENG116960-ENG116343-Leuchten24SL HRA65 light function G 24, not active, 16
ENG116960-ENG116344-Leuchten24SL HRA65-light function H 24, not active, 16
ENG116961-ENG116357-Lamp25KZL HA59-Dimming Direction CD 25, maximize, 16
ENG116961-ENG116361 luminaire25KZL HA59-Dimming Direction EF 25, maximize, 16
ENG116961-ENG116365-Lamp25KZL HA59-Dimming Direction GH 25, maximize, 16
ENG116961-ENG116352 luminaire25KZL HA59 dimming value AB 25.127, 16
ENG116961-ENG116356 luminaire25KZL HA59 dimming value CD 25.0, 16
ENG116961-ENG116360 luminaire25KZL HA59 dimming value EF 25.0, 16
ENG116961-ENG116364 luminaire25KZL HA59 dimming value GH 25.0, 16
ENG116961-ENG116349 luminaire25KZL HA59 fault location medium byte DTC-DFCC 25,30, 16
ENG116961-ENG116577 luminaire25KZL HA59 lamp defect bit position 25,28, 16
ENG116961-ENG116347 luminaire25KZL HA59 load type 25.43 - general LED, 16
ENG116961-ENG116353 light25KZL HA59 light control HD AB 25, всегда, 16
ENG116961-ENG116350-Leuchten25KZL HA59-Lichtfunktion A 25, parking light general (tail light: position light: limiting light), 16
ENG116961-ENG116351 luminaire25KZL HA59 light function B 25, not active, 16
ENG116961-ENG116354 luminaire25KZL HA59 light function C 25, not active, 16
ENG116961-ENG116355 luminaire25KZL HA59 light function D 25, not active, 16
ENG116961-ENG116358 luminaire25KZL HA59 light function E 25, not active, 16
ENG116961-ENG116359 luminaire25KZL HA59 light function F 25, not active, 16
ENG116961-ENG116362 luminaire25KZL HA59 light function G 25, not active, 16
ENG116961-ENG116363 luminaire25KZL HA59 light function H 25, not active, 16
ENG116962-ENG116376-Lamp26NSL LA72-Dimming Direction CD 26, maxi NG116962-ENG116380-Luminaire26NSL LA72-Dimming Direction EF 26, maximize, 16
ENG116962-ENG116384 light26NSL LA72-Dimming Direction GH 26, maximize, 16
ENG116962-ENG116371 light26NSL LA72 dimming value AB 26,100, 16
ENG116962-ENG116375-Lamp26NSL LA72-Dimming value CD 26,0, 16
ENG116962-ENG116379 luminaire26NSL LA72 dimming value EF 26.0, 16
ENG116962-ENG116383 light26NSL LA72 dimming value GH 26,0, 16
ENG116962-ENG116368 luminaire26NSL LA72 fault location middle byte DTC-DFCC 26,2E, 16
ENG116962-ENG116578 lamp 26NSL LA72 lamp defect bit position 26,0C, 16
ENG116962-ENG116366 luminaire26NSL LA72 load type 26.9 - general 27W incandescent lamp: also H15, 16
ENG116962-ENG116372 light26NSL LA72 light control HD AB 26, only_if_closed, 16
ENG116962-ENG116369-Leuchten26NSL LA72-Lichtfunktion A 26, rear fog light if no trailer is plugged in and right hand drive, 16
ENG116962-ENG116370 luminaire26NSL LA72 light function B 26, not active, 16
ENG116962-ENG116373 light26NSL LA72 light function C 26, not active, 16
ENG116962-ENG116374 light26NSL LA72 light function D 26, not active, 16
ENG116962-ENG116377 light26NSL LA72 light function E 26, not active, 16
ENG116962-ENG116378 luminaire26NSL LA72 light function F 26, not active, 16
ENG116962-ENG116381 light26NSL LA72 light function G 26, not active, 16
ENG116962-ENG116382 luminaire26NSL LA72 light function H 26, not active, 16
ENG116963-ENG116395-Luminaire27NSL RC6-Dimming Direction CD 27, maximize, 16
ENG116963-ENG116399 Light27NSL RC6 Dimming Direction EF 27, maximize, 16
ENG116963-ENG116403 Light27NSL RC6 Dimming Direction GH 27, maximize, 16
ENG116963-ENG116390 luminaire27NSL RC6 dimming value AB 27,0, 16
ENG116963-ENG116394 light27NSL RC6 dimming value CD 27,100, 16
ENG116963-ENG116398 light27NSL RC6 dimming value EF 27.0, 16
ENG116963-ENG116402 luminaire27NSL RC6 dimming value GH 27,0, 16
ENG116963-ENG116387 light27NSL RC6 fault location medium byte DTC-DFCC 27,00, 16
ENG116963-ENG116579 light27NSL RC6 lamp defect bit position 27,00, 16
ENG116963-ENG116385 light27NSL RC6 load type 27, not active, 16
ENG116963-ENG116391 light27NSL RC6 light control HD AB 27, всегда, 16
ENG116963-ENG116388 light27NSL RC6 light function A 27, not active, 16
ENG116963-ENG116389 luminaire27NSL RC6 light function B 27, not active, 16
ENG116963-ENG116392 luminaire27NSL RC6 light function C 27, not active, 16
ENG116963-ENG116393 light27NSL RC6 light function D 27, Стоп-сигнал, 16
ENG116963-ENG116396 light27NSL RC6 light function E 27, not active, 16
ENG116963-ENG116397 light27NSL RC6 light function F 27, not active, 16
ENG116963-ENG116400 luminaire27NSL RC6 light function G 27, not active, 16
ENG116963-ENG116401 light27NSL RC6 light function H 27, not active, 16
ENG116964-ENG116414 Luminaire28RFL LC11 Dimming Direction CD 28, maximize, 16
ENG116964-ENG116418 Luminaire28RFL LC11 Dimming Direction EF 28, maximize, 16
ENG116964-ENG116422 Luminaire28RFL LC11 Dimming Direction GH 28, maximize, 16
ENG116964-ENG116409 luminaire28RFL LC11 dimming value AB 28,100, 16
ENG116964-ENG116413 Luminaire28RFL LC11 Dimming Value CD 28.0, 16
ENG116964-ENG116417 luminaire28RFL LC11 dimming value EF 28.0, 16
ENG116964-ENG116421 luminaire28RFL LC11 dimming value GH 28.0, 16
ENG116964-ENG116406 Luminaire28RFL LC11 Fault Location Medium Byte DTC-DFCC 28,31, 16
ENG116964-ENG116580 Luminaire28RFL LC11 lamp defect bit position 28,0B, 16
ENG116964-ENG116404 luminaire28RFL LC11 load type 28,9 - general 27W incandescent lamp: also H15, 16
ENG116964-ENG116410-Licht28RFL LC11-Lichtansteuerung HD AB 28, всегда, 16
ENG116964-ENG116407-Licht28RFL LC11-Lichtfunktion A 28, rear-view light, 16
ENG116964-ENG116408 luminaire28RFL LC11 light function B 28, not active, 16
ENG116964-ENG116411 luminaire28RFL LC11 light function C 28, not active, 16
ENG116964-ENG116412 luminaire28RFL LC11 light function D 28, not active, 16
ENG116964-ENG116415 luminaire28RFL LC11 light function E 28, not active, 16
ENG116964-ENG116416 luminaire28RFL LC11 light function F 28, not active, 16
ENG116964-ENG116419 light 28RFL LC11 light function G 28, not active, 16
ENG116964-ENG116420 luminaire28RFL LC11 light function H 28, not active, 16
ENG116965-ENG116433-Luminaire29RFL RA64-Dimming Direction CD 29, maximize, 16
ENG116965-ENG116437 Luminaire29RFL RA64 Dimming Direction EF 29, maximize, 16
ENG116965-ENG116441 Luminaire29RFL RA64 Dimming Direction GH 29, maximize, 16
ENG116965-ENG116428 luminaire29RFL RA64 dimming value AB 29,100, 16
ENG116965-ENG116432 luminaire29RFL RA64 dimming value CD 29.0, 16
ENG116965-ENG116436 luminaire29RFL RA64 dimming value EF 29,0, 16
ENG116965-ENG116440 luminaire29RFL RA64 dimming value GH 29,0, 16
ENG116965-ENG116425 luminaire29RFL RA64 fault location medium byte DTC-DFCC 29,32, 16
ENG116965-ENG116581 luminaire29RFL RA64 lamp defect bit position 29,1B, 16
ENG116965-ENG116423 luminaire29RFL RA64 load type 29,9 - general incandescent lamp 27W: also H15, 16
ENG116965-ENG116430 luminaire29RFL RA64 lighting control HD AB 29, всегда, 16
ENG116965-ENG116426 luminaire29RFL RA64 light function A 29, rear-view light, 16
ENG116965-ENG116427 luminaire29RFL RA64 light function B 29, not active, 16
ENG116965-ENG116429 luminaire29RFL RA64 light function C 29, not active, 16
ENG116965-ENG116431 luminaire29RFL RA64 light function D 29, not active, 16
ENG116965-ENG116434 luminaire29RFL RA64 light function E 29, not active, 16
ENG116965-ENG116435 luminaire29RFL RA64 light function F 29, not active, 16
ENG116965-ENG116438 luminaire29RFL RA64 light function G 29, not active, 16
ENG116965-ENG116439 luminaire29RFL RA64 light function H 29, not active, 16
ENG116938-ENG115920-Luminaire2SL VLB10-Dimming Direction CD 2, maximize, 16
ENG116938-ENG115924 Light2SL VLB10 Dimming Direction EF 2, maximize, 16
ENG116938-ENG115928-Luminaire2SL VLB10-Dimming Direction GH 2, maximize, 16
ENG116938-ENG115915 luminaire2SL VLB10 dimming value AB 2,100, 16
ENG116938-ENG115919 luminaire2SL VLB10 dimming value CD 2,0, 16
ENG116938-ENG115923 luminaire2SL VLB10 dimming value EF 2.0, 16
ENG116938-ENG115927 luminaire2SL VLB10 dimming value GH 2,0, 16
ENG116938-ENG115912 luminaire2SL VLB10 fault location medium byte DTC-DFCC 2,45, 16
ENG116938-ENG116550 luminaire2SL VLB10 lamp defect bit position 2.00, 16
ENG116938-ENG115910 luminaire2SL VLB10 load type 2.8 - general bulb 12W, 16
ENG116938-ENG115916 light2SL VLB10 light control HD AB 2, всегда, 16
ENG116938-ENG115913-Leuchten2SL VLB10-Lichtfunktion A 2, parking light general (tail light: position light: limiting light), 16
ENG116938-ENG115914 luminaire2SL VLB10 light function B 2, not active, 16
ENG116938-ENG115917 luminaire2SL VLB10 light function C 2, not active, 16
ENG116938-ENG115918 luminaire2SL VLB10 light function D 2, not active, 16
ENG116938-ENG115921 luminaire2SL VLB10 light function E 2, not active, 16
ENG116938-ENG115922 luminaire2SL VLB10 light function F 2, not active, 16
ENG116938-ENG115925 luminaire2SL VLB10 light function G 2, not active, 16
ENG116938-ENG115926 luminaire2SL VLB10 light function H 2, not active, 16
ENG116966-ENG116452 Luminaire30FR LC72 Dimming Direction CD 30, maximize, 16
ENG116966-ENG116456 Luminaire30FR LC72 Dimming Direction EF30, maximize, 16
ENG116966-ENG116460 Luminaire30FR LC72 Dimming Direction GH 30, maximize, 16
ENG116966-ENG116447 luminaire30FR LC72 dimming value AB 30,100, 16
ENG116966-ENG116451 luminaire30FR LC72 dimming value CD 30.0, 16
ENG116966-ENG116455 luminaire30FR LC72 dimming value EF 30.0, 16
ENG116966-ENG116459 luminaire30FR LC72 dimming value GH 30.0, 16
ENG116966-ENG116444 luminaire30FR LC72 fault location medium byte DTC-DFCC 30.02, 16
ENG116966-ENG116582 luminaire30FR LC72 lamp defect bit position 30.00, 16
ENG116966-ENG116442 luminaire30FR LC72 load type 30.36 - low power LED, 16
ENG116966-ENG116448 luminaire30FR LC72 lighting control HD AB 30, всегда, 16
ENG116966-ENG116445 luminaire30FR LC72 light function A 30, Подсветка пространства для ног, 16
ENG116966-ENG116446 luminaire30FR LC72 light function B 30, not active, 16
ENG116966-ENG116449 luminaire30FR LC72 light function C 30, not active, 16
ENG116966-ENG116450 luminaire30FR LC72 light function D 30, not active, 16
ENG116966-ENG116453 luminaire30FR LC72 light function E 30, not active, 16
ENG116966-ENG116454 luminaire30FR LC72 light function F 30, not active, 16
ENG116966-ENG116457 luminaire30FR LC72 light function G 30, not active, 16
ENG116966-ENG116458 luminaire30FR LC72 light function H 30, not active, 16
ENG116967-ENG116471-Luminaire31AMBL 1C61-Dimming Direction CD 31, maximize, 16
ENG116967-ENG116475-Luminaire31AMBL 1C61-Dimming Direction EF 31, maximize, 16
ENG116967-ENG116479-Luminaire31AMBL 1C61-Dimming Direction GH 31, maximize, 16
ENG116967-ENG116466 luminaire31AMBL 1C61 dimming value AB 31,0, 16
ENG116967-ENG116470 luminaire31AMBL 1C61 dimming value CD 31,0, 16
ENG116967-ENG116474-Luminaire31AMBL 1C61 dimming value EF 31,0, 16
ENG116967-ENG116478-Leuchten31AMBL 1C61 dimming value GH 31,0, 16
ENG116967-ENG116463-Luminaire31AMBL 1C61 fault location medium byte DTC-DFCC 31,00, 16
ENG116967-ENG116583 light31AMBL 1C61 lamp defect bit position 31,00, 16
ENG116967-ENG116461 luminaire31AMBL 1C61 load type 31, not active, 16
ENG116967-ENG116467 light31AMBL 1C61 light control HD AB 31, всегда, 16
ENG116967-ENG116464 luminaire31AMBL 1C61 light function A 31, not active, 16
ENG116967-ENG116465-Leuchten31AMBL 1C61-Lichtfunktion B 31, not active, 16
ENG116967-ENG116468 luminaire31AMBL 1C61 light function C 31, not active, 16
ENG116967-ENG116469-Leuchten31AMBL 1C61-Lichtfunktion D 31, not active, 16
ENG116967-ENG116472 luminaire31AMBL 1C61 light function E 31, not active, 16
ENG116967-ENG116473-Leuchten31AMBL 1C61 light function F 31, not active, 16
ENG116967-ENG116476-Luminaire31AMBL 1C61 light function G 31, not active, 16
ENG116967-ENG116477-Leuchten31AMBL 1C61-Lichtfunktion H 31, not active, 16
ENG116968-ENG116490-Luminaire32AMBL 2C35-Dimming Direction CD 32, maximize, 16
ENG116968-ENG116494-Luminaire32AMBL 2C35-Dimming Direction EF 32, maximize, 16
ENG116968-ENG116498-Luminaire32AMBL 2C35-Dimming Direction GH 32, maximize, 16
ENG116968-ENG116485 luminaire32AMBL 2C35 dimming value AB 32.0, 16
ENG116968-ENG116489 luminaire32AMBL 2C35 dimming value CD 32.0, 16
ENG116968-ENG116493 luminaire32AMBL 2C35 dimming value EF 32.0, 16
ENG116968-ENG116497 luminaire32AMBL 2C35 dimming value GH 32.0, 16
ENG116968-ENG116482 luminaire32AMBL 2C35 fault location medium byte DTC-DFCC 32,00, 16
ENG116968-ENG116584 lamp32AMBL 2C35 lamp defect bit position 32,00, 16
ENG116968-ENG116480 luminaire32AMBL 2C35 load type 32, not active, 16
ENG116968-ENG116486-Lamp32AMBL 2C35-Light Controller HD AB 32, всегда, 16
ENG116968-ENG116483 luminaire32AMBL 2C35 light function A 32, not active, 16
ENG116968-ENG116484 luminaire32AMBL 2C35 light function B 32, not active, 16
ENG116968-ENG116487 luminaire32AMBL 2C35 light function C 32, not active, 16
ENG116968-ENG116488 luminaire32AMBL 2C35 light function D 32, not active, 16
ENG116968-ENG116491 luminaire32AMBL 2C35 light function E 32, not active, 16
ENG116968-ENG116492 luminaire32AMBL 2C35 light function F 32, not active, 16
ENG116968-ENG116495 luminaire32AMBL 2C35 light function G 32, not active, 16
ENG116968-ENG116496 luminaire32AMBL 2C35 light function H 32, not active, 16
ENG116969-ENG116509-Leuchten33AMBL 3C36-Dimming Direction CD 33, maximize, 16
ENG116969-ENG116513-Luminaire33AMBL 3C36-Dimming Direction EF 33, maximize, 16
ENG116969-ENG116517-Luminaire33AMBL 3C36-Dimming Direction GH 33, maximize, 16
ENG116969-ENG116504 luminaire33AMBL 3C36 dimming value AB 33.0, 16
ENG116969-ENG116508 luminaire33AMBL 3C36 dimming value CD 33.0, 16
ENG116969-ENG116512-Leuchten33AMBL 3C36 dimming value EF 33,0, 16
ENG116969-ENG116516 luminaire33AMBL 3C36 dimming value GH 33.0, 16
ENG116969-ENG116501-Leuchten33AMBL 3C36-error location middle byte DTC-DFCC 33,00, 16
ENG116969-ENG116585 lamp33AMBL 3C36 lamp defect bit position 33,00, 16
ENG116969-ENG116499 luminaire33AMBL 3C36 load type 33, not active, 16
ENG116969-ENG116505 light33AMBL 3C36 light control HD AB 33, всегда, 16
ENG116969-ENG116502 luminaire33AMBL 3C36 light function A 33, not active, 16
ENG116969-ENG116503 luminaire33AMBL 3C36 light function B 33, not active, 16
ENG116969-ENG116506 luminaire33AMBL 3C36 light function C 33, not active, 16
ENG116969-ENG116507 luminaire33AMBL 3C36 light function D 33, not active, 16
ENG116969-ENG116510 luminaire33AMBL 3C36 light function E 33, not active, 16
ENG116969-ENG116511 luminaire33AMBL 3C36 light function F 33, not active, 16
ENG116969-ENG116514 luminaire33AMBL 3C36 light function G 33, not active, 16
ENG116969-ENG116515-Leuchten33AMBL 3C36-Lichtfunktion H 33, not active, 16
ENG116970-ENG116528-Luminaire34AMBL 4C37-Dimming Direction CD 34, maximize, 16
ENG116970-ENG116532-Luminaire34AMBL 4C37-Dimming Direction EF 34, maximize, 16
ENG116970-ENG116536-Luminaire34AMBL 4C37-Dimming Direction GH 34, maximize, 16
ENG116970-ENG116523 luminaire34AMBL 4C37 dimming value AB 34,0, 16
ENG116970-ENG116527 luminaire34AMBL 4C37 dimming value CD 34,0, 16
ENG116970-ENG116531 luminaire34AMBL 4C37 dimming value EF 34.0, 16
ENG116970-ENG116535 luminaire34AMBL 4C37 dimming value GH 34.0, 16
ENG116970-ENG116520 luminaire34AMBL 4C37 fault location middle byte DTC-DFCC 34,00, 16
ENG116970-ENG116586 lamp34AMBL 4C37 lamp defect bit position 34,00, 16
ENG116970-ENG116518 luminaire34AMBL 4C37 load type 34, not active, 16
ENG116970-ENG116524 light34AMBL 4C37 light control HD AB 34, всегда, 16
ENG116970-ENG116521 luminaire34AMBL 4C37 light function A 34, not active, 16
ENG116970-ENG116522 luminaire34AMBL 4C37 light function B 34, not active, 16
ENG116970-ENG116525 luminaire34AMBL 4C37 light function C 34, not active, 16
ENG116970-ENG116526 luminaire34AMBL 4C37 light function D 34, not active, 16
ENG116970-ENG116529 luminaire34AMBL 4C37 light function E 34, not active, 16
ENG116970-ENG116530 luminaire34AMBL 4C37 light function F 34, not active, 16
ENG116970-ENG116533 luminaire34AMBL 4C37 light function G 34, not active, 16
ENG116970-ENG116534 luminaire34AMBL 4C37 light function H 34, not active, 16
ENG116939-ENG115939-Luminaire3SL VRB21-Dimming Direction CD 3, maximize, 16
ENG116939-ENG115943 light3SL VRB21-Dimming Direction EF 3, maximize, 16
ENG116939-ENG115947-Luminaire3SL VRB21-Dimming Direction GH 3, maximize, 16
ENG116939-ENG115934 light3SL VRB21 dimming value AB 3,100, 16
ENG116939-ENG115938 light3SL VRB21 dimming value CD 3.0, 16
ENG116939-ENG115942 light3SL VRB21 dimming value EF 3,0, 16
ENG116939-ENG115946 luminaire3SL VRB21 dimming value GH 3,0, 16
ENG116939-ENG115931 light3SL VRB21 fault location middle byte DTC-DFCC 3,46, 16
ENG116939-ENG116551 light3SL VRB21 lamp defect bit position 3.00, 16
ENG116939-ENG115929 light 3SL VRB21 load type 3,8 - general bulb 12W, 16
ENG116939-ENG115935 light3SL VRB21 light control HD AB 3, всегда, 16
ENG116939-ENG115932-Beleuchtung3SL VRB21-Lichtfunktion A 3, parking light general (tail light: position light: limiting light), 16
ENG116939-ENG115933 light3SL VRB21 light function B 3, not active, 16
ENG116939-ENG115936 light3SL VRB21 light function C 3, not active, 16
ENG116939-ENG115937 light3SL VRB21 light function D 3, not active, 16
ENG116939-ENG115940 light3SL VRB21 light function E 3, not active, 16
ENG116939-ENG116552 light3SL VRB21 light function F 3, not active, 16
ENG116939-ENG115944-Leuchten3SL VRB21 light function G 3, not active, 16
ENG116939-ENG115945 light3SL VRB21 light function H 3, not active, 16
ENG116940-ENG115958-Lamp4TFL LB4-Dimming Direction CD 4, minimize, 16
ENG116940-ENG115962 light4TFL LB4 dimming direction EF 4, maximize, 16
ENG116940-ENG115966-Luminaire4TFL LB4-Dimming Direction GH 4, minimize, 16
ENG116940-ENG115953-Leuchten4TFL LB4 dimming value AB 4,100, 16
ENG116940-ENG115957-Leuchten4TFL LB4-Dimmwert CD 4,0, 16
ENG116940-ENG115961-Leuchten4TFL LB4 dimming value EF 4,31, 16
ENG116940-ENG115965-Leuchten4TFL LB4 dimming value GH 4,0, 16
ENG116940-ENG115950 Luminaire4TFL LB4 fault location medium byte DTC-DFCC 4,43, 16
ENG116940-ENG116553 light4TFL LB4 lamp defect bit position 4.48, 16
ENG116940-ENG115948 luminaire4TFL LB4 load type 4.9 - general 27W incandescent lamp: also H15, 16
ENG116940-ENG115954 light4TFL LB4 light control HD AB 4, всегда, 16
ENG116940-ENG115951 light4TFL LB4 light function A 4, Daytime running lights, 16
ENG116940-ENG115952-Leuchten4TFL LB4 light function B 4, not active, 16
ENG116940-ENG115955-Leuchten4TFL LB4 light function C 4, not active, 16
ENG116940-ENG115956-Leuchten4TFL LB4 light function D 4, not active, 16
ENG116940-ENG115959-Leuchten4TFL LB4 light function E 4, parking light general (tail light: position light: limiting light), 16
ENG116940-ENG115960-Leuchten4TFL LB4 light function F 4, not active, 16
ENG116940-ENG115963-Leuchten4TFL LB4-Lichtfunktion G 4, dipped beam left, 16
ENG116940-ENG115964-Leuchten4TFL LB4 light function H 4, not active, 16
ENG116941-ENG115977-Lamp5 TFL RB32-Dimming Direction CD 5, minimize, 16
ENG116941-ENG115981 light5 TFL RB32 dimming Direction EF 5, maximize, 16
ENG116941-ENG115985-Lamp5 TFL RB32-Dimming Direction GH 5, minimize, 16
ENG116941-ENG115972 lamp5 TFL RB32 dimming value AB 5,100, 16
ENG116941-ENG115976 lamp5 TFL RB32 dimming value CD 5.0, 16
ENG116941-ENG115980 lamp5 TFL RB32 dimming value EF 5,31, 16
ENG116941-ENG115984 lamp5 TFL RB32 dimming value GH 5,0, 16
ENG116941-ENG115969 Luminaire5 TFL RB32 fault location medium byte DTC DFCC 5.44, 16
ENG116941-ENG116554 light5 TFL RB32 lamp defect bit position 5,4C, 16
ENG116941-ENG115967-Luminaire5 TFL RB32-load type 5,9 - general incandescent lamp 27W: also H15, 16
ENG116941-ENG115973-Leuchten5 TFL RB32-Lichtansteuerung HD AB 5, всегда, 16
ENG116941-ENG115970 light5 TFL RB32 light function A 5, Daytime running lights, 16
ENG116941-ENG115971 lamp5 TFL RB32 light function B 5, not active, 16
ENG116941-ENG115974 lamp5 TFL RB32 light function C 5, not active, 16
ENG116941-ENG115975-Leuchten5 TFL RB32-Lichtfunktion D 5, not active, 16
ENG116941-ENG115978-Leuchten5 TFL RB32-Lichtfunktion E 5, parking light general (tail light: position light: limiting light), 16
ENG116941-ENG116555 lamp5 TFL RB32 light function F 5, not active, 16
ENG116941-ENG115982-Leuchten5 TFL RB32-Lichtfunktion G 5, dipped beam right, 16
ENG116941-ENG115983-Leuchten5 TFL RB32-Lichtfunktion H 5, not active, 16
ENG116942-ENG115996 Luminaire6ABL LC5 Dimming Direction CD 6, maximize, 16
ENG116942-ENG116000 Luminaire6ABL LC5 Dimming Direction EF 6, maximize, 16
ENG116942-ENG116004 Luminaire6ABL LC5 Dimming Direction GH 6, maximize, 16
ENG116942-ENG115991 luminaire6ABL LC5 dimming value AB 6.100, 16
ENG116942-ENG115995 luminaire6ABL LC5 dimming value CD 6.0, 16
ENG116942-ENG115999 luminaire6ABL LC5 dimming value EF 6.0, 16
ENG116942-ENG116003 luminaire6ABL LC5 dimming value GH 6.0, 16
ENG116942-ENG115988 Luminaire6ABL LC5 Fault Location Medium Byte DTC-DFCC 6.1A, 16
ENG116942-ENG116556 luminaire6ABL LC5 lamp defect bit position 6,36, 16
ENG116942-ENG115986 lamp6ABL LC5 load type 6,11 - dipped beam, 16
ENG116942-ENG115992 luminaire6ABL LC5 light control HD AB 6, всегда, 16
ENG116942-ENG115989-Leuchten6ABL LC5-Lichtfunktion A 6, dipped beam left, 16
ENG116942-ENG115990 luminaire6ABL LC5 light function B 6, not active, 16
ENG116942-ENG115993 luminaire6ABL LC5 light function C 6, not active, 16
ENG116942-ENG115994 luminaire6ABL LC5 light function D 6, not active, 16
ENG116942-ENG115997 luminaire6ABL LC5 light function E 6, not active, 16
ENG116942-ENG115998 luminaire6ABL LC5 light function F 6, not active, 16
ENG116942-ENG116001 luminaire6ABL LC5 light function G 6, not active, 16
ENG116942-ENG116002 luminaire6ABL LC5 light function H 6, not active, 16
ENG116943-ENG116015-Luminaire7ABL RB1-Dimming Direction CD 7, maximize, 16
ENG116943-ENG116019-Luminaire7ABL RB1-Dimming Direction EF 7, maximize, 16
ENG116943-ENG116023 Luminaire7ABL RB1 Dimming Direction GH 7, maximize, 16
ENG116943-ENG116010 luminaire7ABL RB1 dimming value AB 7.100, 16
ENG116943-ENG116014 luminaire7ABL RB1 dimming value CD 7.0, 16
ENG116943-ENG116018 luminaire7ABL RB1 dimming value EF 7,0, 16
ENG116943-ENG116022 luminaire7ABL RB1 dimming value GH 7.0, 16
ENG116943-ENG116007 Luminaire7ABL RB1 Fault Location Medium Byte DTC-DFCC 7,1B, 16
ENG116943-ENG116557 light7ABL RB1 lamp defect bit position 7,40, 16
ENG116943-ENG116005 lamp7ABL RB1 load type 7,11 - dipped beam, 16
ENG116943-ENG116011 light7ABL RB1 light control HD AB 7, всегда, 16
ENG116943-ENG116008 luminaire7ABL RB1 light function A 7, low beam right, 16
ENG116943-ENG116009 luminaire7ABL RB1 light function B 7, not active, 16
ENG116943-ENG116012 luminaire7ABL RB1 light function C 7, not active, 16
ENG116943-ENG116013 luminaire7ABL RB1 light function D 7, not active, 16
ENG116943-ENG116016 luminaire7ABL RB1 light function E 7, not active, 16
ENG116943-ENG116017 luminaire7ABL RB1 light function F 7, not active, 16
ENG116943-ENG116020 luminaire7ABL RB1 light function G 7, not active, 16
ENG116943-ENG116021 luminaire7ABL RB1 light function H 7, not active, 16
ENG116944-ENG116034-Luminaire8FL LB39-Dimming Direction CD 8, maximize, 16
ENG116944-ENG116038-Luminaire8FL LB39-Dimming Direction EF 8, maximize, 16
ENG116944-ENG116042 Luminaire8FL LB39 Dimming Direction GH 8, maximize, 16
ENG116944-ENG116029 light 8FL LB39 dimming value AB 8,100, 16
ENG116944-ENG116033 Luminaire8FL LB39 dimming value CD 8.0, 16
ENG116944-ENG116037 light8FL LB39 dimming value EF 8.0, 16
ENG116944-ENG116041 luminaire8FL LB39 dimming value GH 8.0, 16
ENG116944-ENG116026 Luminaire8FL LB39 Fault Location Medium Byte DTC-DFCC 8,1C, 16
ENG116944-ENG116558 Luminaire 8FL LB39 lamp defect bit position 8.37, 16
ENG116944-ENG116024-Luminaire8FL LB39-Load Type 8,10 - general headlights, 16
ENG116944-ENG116030 light 8FL LB39 light control HD AB 8, всегда, 16
ENG116944-ENG116027 light8FL LB39 light function A 8, Дальний свет слева, 16
ENG116944-ENG116028-Leuchten8FL LB39-Lichtfunktion B 8, flare horn general, 16
ENG116944-ENG116031-Leuchten8FL LB39 light function C 8, not active, 16
ENG116944-ENG116032-Leuchten8FL LB39-Lichtfunktion D 8, not active, 16
ENG116944-ENG116035-Licht8FL LB39 light function E 8, not active, 16
ENG116944-ENG116036-Luminaire8FL LB39 light function F 8, not active, 16
ENG116944-ENG116039 luminaire8FL LB39 light function G 8, not active, 16
ENG116944-ENG116040 luminaire8FL LB39 light function H 8, not active, 16
ENG116945-ENG116053-Luminaire9FL RB2-Dimming Direction CD 9, maximize, 16
ENG116945-ENG116057-Luminaire9FL RB2-Dimming Direction EF 9, maximize, 16
ENG116945-ENG116061 Luminaire9FL RB2 Dimming Direction GH 9, maximize, 16
ENG116945-ENG116048 light 9FL RB2 dimming value AB 9,100, 16
ENG116945-ENG116052 Luminaire9FL RB2 dimming value CD 9.0, 16
ENG116945-ENG116056 luminaire9FL RB2 dimming value EF 9.0, 16
ENG116945-ENG116060 Luminaire9FL RB2 dimming value GH 9.0, 16
ENG116945-ENG116045 Luminaire9FL RB2 Fault Location Medium Byte DTC-DFCC 9.1D, 16
ENG116945-ENG116559 light 9FL RB2 lamp defect bit position 9,41, 16
ENG116945-ENG116043-Luminaire9FL RB2-load type 9,10 - general headlamps, 16
ENG116945-ENG116049 light 9FL RB2 light control HD AB 9, всегда, 16
ENG116945-ENG116046 light9FL RB2 light function A 9, Дальний свет справа, 16
ENG116945-ENG116047 luminaire9FL RB2 light function B 9, flasher generally, 16
ENG116945-ENG116050-Leuchten9FL RB2-Lichtfunktion C 9, not active, 16
ENG116945-ENG116051-Leuchten9FL RB2-Lichtfunktion D 9, not active, 16
ENG116945-ENG116054 luminaire9FL RB2 light function E 9, not active, 16
ENG116945-ENG116055-Leuchten9FL RB2-Lichtfunktion F 9, not active, 16
ENG116945-ENG116058 luminaire9FL RB2 light function G 9, not active, 16
ENG116945-ENG116059-Leuchten9FL RB2-Lichtfunktion H 9, not active, 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14, maximize, 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF14, maximize, 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14, maximize, 16
ENG116950-ENG116143-Leuchten14AL LB6 dimming value AB 14.0, 16
ENG116950-ENG116147-Leuchten14AL LB6 dimming value CD 14.0, 16
ENG116950-ENG116151 lights14AL LB6 dimming value EF 14.0, 16
ENG116950-ENG116155-Leuchten14AL LB6 dimming value GH 14,0, 16
ENG116950-ENG116140 luminaires14AL LB6 fault location medium byte DTC DFCC 14,00, 16
ENG116950-ENG116565 lights14AL LB6 lamp defect bit position 14.00, 16
ENG116950-ENG116138-Leuchten14AL LB6 load type 14, not active, 16
ENG116950-ENG116144-Leuchten14AL LB6 lighting control HD AB 14, всегда, 16
ENG116950-ENG116141 luminaires14AL LB6 light function A 14, not active, 16
ENG116950-ENG116142 luminaires14AL LB6 light function B 14, not active, 16
ENG116950-ENG116145 luminaires14AL LB6 light function C 14, not active, 16
ENG116950-ENG116146 luminaires14AL LB6 light function D 14, not active, 16
ENG116950-ENG116149-Leuchten14AL LB6 light function E 14, not active, 16
ENG116950-ENG116150 luminaires14AL LB6 light function F 14, not active, 16
ENG116950-ENG116153-Leuchten14AL LB6 light function G 14, not active, 16
ENG116950-ENG116154-Leuchten14AL LB6 light function H 14, not active, 16
ENG126648-MAS10452-LIN-Mirrormode-Шина LIN 1, акт. ,1
ENG126648-MAS10453-LIN-Mirrormode-Шина LIN 2, акт. ,1
ENG126648-MAS10454-LIN-Mirrormode-Шина LIN 3, акт. ,1
ENG126648-MAS12782-LIN-Mirrormode-Шина LIN 4, акт. ,1
ENG126648-MAS12783-LIN-Mirrormode-Шина LIN 5, акт. ,1
ENG126648-MAS12784-LIN-Mirrormode-Шина LIN 6, акт. ,1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ, not active, 1
ENG117284-ENG115658-LuB light router characteristic 1-x0,0.00%, 12
ENG117284-ENG101574-LuB light router characteristic 1-X1,5.00%, 12
ENG117284-ENG99557-LuB Light Routers Characteristic 1-X2,50.00%, 12
ENG117284-ENG102140-LuB light router characteristic 1-X3,75.00%, 12
ENG117284-ENG102936-LuB Light Routers Characteristic 1-X4,110.00, 12
ENG117284-ENG103548-LuB light router characteristics 1-X5,126.50, 12
ENG117284-ENG115659-LuB Light Routers Characteristic 1-y0,0.00%, 12
ENG117284-ENG99777-LuB Light Routers Characteristic 1-Y1,6.00%, 12
ENG117284-ENG100480-LuB Light Routers Characteristic 1-Y2,16.00%, 12
ENG117284-ENG100773-LuB Light Routers Characteristic 1-Y3,30.00%, 12
ENG117284-ENG100631-LuB Light Routers Characteristic 1-Y4,60.00%, 12
ENG117284-ENG102174-LuB Light Routers Characteristic 1-Y5,100.00%, 12
ENG98831-ENG126849-Персонализация-Aktivierungsoption_im_HMI-Menue_sichtbar, акт. 16
ENG98831-ENG133401-Персонализация number of user accounts, 4, 16
ENG98831-ENG133402-Персонализация-Automatic key assignment, акт. 16
ENG98831-ENG126850-Персонализация-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar, акт. 16
ENG98831-ENG126848-Персонализация-Personalisierung_aktiv, акт. 16
ENG98831-ENG126851-Персонализация-Personalisierungsfunktionen_in_HMI-Menue_sichtbar, акт. 16
ENG98831-ENG133403-Персонализация-PSO_FSG_Setup2_Bit_0, акт. 16
ENG98831-ENG133404-Персонализация-PSO_FSG_Setup2_Bit_1, акт. 16
ENG98831-ENG133405-Персонализация-PSO_FSG_Setup2_Bit_2, акт. 16
ENG98831-ENG133406-Персонализация-PSO_FSG_Setup2_Bit_3, акт. 16
ENG98831-ENG133407-Персонализация-PSO_FSG_Setup2_Bit_4, акт. 16
ENG98831-ENG133408-Персонализация-PSO_FSG_Setup2_Bit_5, акт. 16
ENG98831-ENG133409-Персонализация-PSO_FSG_Setup2_Bit_6, акт. 16
ENG98831-ENG133410-Персонализация-PSO_FSG_Setup2_Bit_7, акт. 16
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt, акт. ,8th
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung, акт. ,8th
ENG122927-RLS_close_glazing, 2.00 s, 1
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off, 120 s, 3
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on, 10 s, 3
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off, 65 km / h, 3
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on, 140 km / h, 3
ENG122931-ENG123004-RLS_Lights_on_at_Rain-p_lx_reference light threshold, 6000 lx, 2
ENG122931-ENG123002-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_high, 12, 2
ENG122931-ENG123003-RLS_Lights_on_at_Rain-p_n_regenlichtschwelle_low, 6, 2
ENG122931-ENG123005-RLS_Lights_on_at_Rain-p_t_regenlicht, 30 s, 2
ENG122929-RLS_LIN_Communication, 4 s, 1
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn, 200 lx, 1
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day, 500 lx, 1
ENG122930-RLS_tunel_gateway_recognize, 5s, 1
ENG122935-RLS_Washer_Front, 15 s, 1
ENG122926-RLS_wiper_position_parking, 15 s, 1
ENG116971-ENG116537 Networking Diagnostic Functions-can msg 1.00 00, 20
ENG116971-ENG116538 Networking Diagnostic Functions-can msg 2.00 00, 20
ENG116971-ENG116539 Networking Diagnostic Functions-can msg 3.00 00, 20
ENG116971-ENG116540 Networking Diagnostic Functions-can msg 4.00 00, 20
ENG116971-ENG116541 Networking Diagnostic Functions-lin msg 1.00 00, 20
ENG116971-ENG116542 Networking Diagnostic Functions-lin msg 2.00 00, 20
ENG116971-ENG116543 Networking Diagnostic Functions-lin msg 3.00 00, 20
ENG116971-ENG116544 Networking Diagnostic Functions-lin msg 4.00 00, 20
ENG116971-ENG116545 Networking Diagnostic Functions-lin msg 5.00 00, 20
ENG116971-ENG116546 Networking Diagnostic Functions-lin msg 6.00 00, 20
ENG116832-ENG126852-Wipe speeds-continuous between Level_1 cycles per minute, 40, 3
ENG116832-ENG126853 wiping speeds-continuous between level_2 cycles per minute, 60, 3
ENG116832-ENG116699-Wiping speeds-Reduced wiping speed cycles per minute, 30, 3
5F- admap
SW: 3G0-035-021-D HW: 3G0-035-021 --- Electronic Information System 1 --- SA: 20103
Component: MU-H-TND-EU H41 0814, Encoding: 02730201000000005111000200180A101F0104F401200105FE
EV_MUHig4CGen2HBAS, 001001, EV_MUHig4CGen2HBAS_VW37.odx
Tuesday, 01, October, 2019,13: 25: 52: 10463
Software Version: 19.6.0 Protocol Type: Troubleshooting
IDE00001-Production Mode, 00 00 00, 3
IDE00346-Automation of summer time, Europe, 1
IDE00759-The basic volume of voice guidance, 50%, 1
IDE00760-Microphone Sensitivity, 2 dB, 1
IDE00768-Mark of the country of sale, UA, 2
IDE00769-Number 1 for calling the information service, FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF, 23
IDE00770-Number 1 for roadside assistance, FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF, 23
IDE00820-ENG117828-Activating and deactivating all messages-Infotainment_CAN_Messages, OFF, 1
IDE00820-ENG117829-Activation and deactivation of all messages-MIB_CAN_Messages, OFF, 1
IDE00845-Wheel circumference, 0 mm, 2
IDE01996-MAS00076-List of elements: which must be installed-Control unit for instrument cluster, Yes, 3
IDE01996-MAS00839-List of items: which should be installed-TV tuner, No, 3
IDE01996-MAS00844-List of items: which should be installed-Radio, Yes, 3
IDE01996-MAS00847-List of elements: which must be installed-Digital audio system control unit, Yes, 3
IDE01996-MAS00849-List of elements: which must be installed-Control unit of the electronic information system 1, Yes, 3
IDE01996-MAS00850-List of elements: which must be installed-Control unit of the electronic information system 2, No, 3
IDE01996-MAS04300-List of items: which must be installed-DVD-changer, No, 3
IDE01996-MAS14306-List of elements: which must be installed-Projection display control unit, No, 3
IDE01996-SFT271943-List of elements: which must be installed-Control panel of multimedia system, No, 3
IDE01996-ENG154341-List of elements: which should be installed-Reserved_8, No, 3
IDE01996-ENG152491-List of items: which should be installed-Smart Control Carrier 1, No, 3
IDE01996-ENG152490-List of items: which should be installed-Smart Control Carrier 2, No, 3
IDE01996-ENG152488-List of items: which should be installed-Smart Display Carrier 1, No, 3
IDE01996-ENG152492-List of items: which should be installed-Smart Display Carrier 2, No, 3
IDE01996-ENG152493-List of items: which should be installed-Wireless Charger 1, No, 3
IDE01996-ENG152489-List of items: which should be installed-Wireless Charger 2, No, 3
IDE02121-CD eject key, Enabled, 1
IDE02122-Developer mode, incl. ,one
IDE02330-Number 2 for calling the information service, FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF, 23
IDE02331-Number 2 for roadside assistance, FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF, 23
IDE02332-Disable production mode, 0, 3
IDE02476-MAS03001-Speaker Electrical Test-Mode, automatic, 49
IDE02476-ENG117360-Speaker Electrical Test-Parameter_AC-Diagnostics_Channel_1_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117361-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume, 22, 49
IDE02476-ENG117378-Speaker Electrical Test-Parameter_AC-Diagnostics_Channel_10_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117379-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume, 22, 49
IDE02476-ENG117380-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117381-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume, 22, 49
IDE02476-ENG117382-Speaker Electrical Test-Parameter_AC-Diagnostics_Channel_12_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117383-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume, 22, 49
IDE02476-ENG117384-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117385-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume, 22, 49
IDE02476-ENG117386-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117387-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume, 22, 49
IDE02476-ENG117388-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117389-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume, 22, 49
IDE02476-ENG117390-Speaker Electrical Test-Parameter_AC-Diagnostics_Channel_16_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117391-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume, 22, 49
IDE02476-ENG117362-Electrical Testing of Speakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117363-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume, 22, 49
IDE02476-ENG117364-Speaker Electrical Test-Parameter_AC-Diagnostics_Channel_3_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117365-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume, 22, 49
IDE02476-ENG117366-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117367-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume, 22, 49
IDE02476-ENG117368-Speaker Electrical Test-Parameter_AC-Diagnostics_Channel_5_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117369-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume, 22, 49
IDE02476-ENG117370-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117371-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume, 22, 49
IDE02476-ENG117372-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117373-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume, 22, 49
IDE02476-ENG117374-Electrical check of speakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117375-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume, 22, 49
IDE02476-ENG117376-Speaker Electrical Test-Parameter_AC-Diagnostics_Channel_9_Test_Frequency, 19000 Hz, 49
IDE02476-ENG117377-Electrical check of the speakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume, 22, 49
IDE02502-Confirmation of installation changes, 47 3C, 2
IDE02506-MAS03229-Copying multimedia data-Storage medium incl. ,one
IDE02506-MAS03230-Media Copy-Optical Drive, OFF, 1
IDE02607-Impulse from a wheel sensor, 0, 2
IDE02699-Number 1 for roadside assistance, FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF, 23
IDE02701-Number 1 (roaming) for calling assistance, 5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF, 23
IDE03238-ENG117830-Data Connection Parameters (UMTS) -1E_EcLo, 0, 8
IDE03238-ENG117831-Data Connection Parameters (UMTS) -1E_RSCP, 15, 8
IDE03238-ENG117832-Data Connection Parameters (UMTS) -1F_EcLo, 0, 8
IDE03238-ENG117833-Data Connection Parameters (UMTS) -1F_RSCP, 15, 8
IDE03238-ENG122277-Data Connection Parameters (UMTS) -2D_EcLo, 0, 8
IDE03238-ENG122278-Data Connection Parameters (UMTS) -2D_RSCP, 11, 8
IDE03238-ENG122275-Data Connection Parameters (UMTS) -3A_EcLo, 0, 8
IDE03238-ENG122276-Data Connection Parameters (UMTS) -3A_RSCP, 8, 8
IDE03471-ENG117847-Configuration a / m-advanced_range_display, OFF, 30
IDE03471-ENG142146-Configuration a / m-allow_message_editing, OFF, 30
IDE03471-ENG130249-Configuration a / m-Apple_DIO, incl. ,thirty
IDE03471-ENG185764-Configuration a / m-Apple_DIO_Wireless, OFF, 30
IDE03471-ENG152525-Configuration a / m-Baidu_Car_Life, OFF, 30
IDE03471-ENG152559-Configuration a / m-Baidu_Car_Life_ios, OFF, 30
IDE03471-ENG185765-Configuration a / m-Baidu_Car_Life_ios_Wireless, OFF, 30
IDE03471-ENG185766-Configuration a / m-Baidu_Car_Life_Wireless, OFF, 30
IDE03471-ENG152560-Configuration a / m-block_hmi_function_p_epb, blocked. ,thirty
IDE03471-ENG142151-Configuration a / m-conditioning_variant, 0, 30
IDE03471-ENG125043-Configuration a / m-Dtmf_without_active_call, incl. ,thirty
IDE03471-ENG142145-Configuration a / m-esim_data_only_sms_support, OFF, 30
IDE03471-ENG185778-Configuration a / m-FoD, SWaP, 30
IDE03471-ENG130248-Configuration a / m-Google_GAL, incl. ,thirty
IDE03471-ENG185779-Configuration a / m-Google_GAL_Wireless, OFF, 30
IDE03471-ENG117850-Configuration a / m-gracenote_local_coverarts, incl. ,thirty
IDE03471-ENG117851-Configuration a / m-gracenote_local_other, incl. ,thirty
IDE03471-ENG117848-Configuration a / m-gracenote_online_coverarts, OFF, 30
IDE03471-ENG117849-Configuration a / m-gracenote_online_other, OFF, 30
IDE03471-ENG152533-Configuration a / m-Hybrid_Radio_additional_online_data, not activated, 30
IDE03471-ENG152534-Configuration a / m-Hybrid_Radio_Range_Extender, Deactivated, 30
IDE03471-ENG125049-Configuration a / m-Joker_button_1, missing, 30
IDE03471-ENG125050-Configuration a / m-Joker_button_2, missing, 30
IDE03471-ENG127492-Configuration a / m-LGI, OFF, 30
IDE03471-ENG130246-Configuration a / m-LTE_modul, incl. ,thirty
IDE03471-ENG142142-configuration a / m-map_email_support, OFF, 30
IDE03471-ENG142143-configuration a / m-map_instant_messaging_support, OFF, 30
IDE03471-ENG142141-configuration a / m-map_sms_support, OFF, 30
IDE03471-ENG142152-configuration a / m-Map_Style, 0, 30
IDE03471-ENG152537-Configuration a / m-media_control, not activated, 30
IDE03471-ENG138662-Configuration a / m-Mirror_link, OFF, 30
IDE03471-ENG142148-Configuration a / m-MirrorLink_Country_Code, MIB_EU, 30
IDE03471-ENG142150-Configuration A / m-MirrorLink_RGB_Preference Configuration, RGB565, 30
IDE03471-ENG117843-Configuration a / m-my_audi, incl. , 30
IDE03471-ENG117845-Configuration a / m-online_dictation, incl. , 30
IDE03471-ENG127495-Configuration a / m-online_media, incl. , 30
IDE03471-ENG117840-Configuration a / m-online_navigation, incl. , 30
IDE03471-ENG117837-Configuration a / m-online_POI, OFF, 30
IDE03471-ENG117838-Configuration a / m-online_POI_voice, OFF, 30
IDE03471-ENG117839-Configuration a / m-online_portal_browser_services, OFF, 30
IDE03471-ENG152553-A-m-online_radio configuration, Deactivated, 30
IDE03471-ENG117841-Configuration a / m-online_street_view, OFF, 30
IDE03471-ENG125048-Configuration a / m-OPS_display_in_dash_board_display_unit, OFF, 30
IDE03471-ENG167521-Configuration a / m-perso_v_threshold, 00, 30
IDE03471-ENG167522-A / m-perso_v_threshold_hysteresis configuration, 00, 30
IDE03471-ENG152554-A / m-Phone_HMI_Privacy Configuration, 0, 30
IDE03471-ENG125046-a-m-Phone_module_operation_mode Configuration, Active Data Transfer and Telephone Communication, 30
IDE03471-ENG117844-Configuration a / m-picture_navi, incl. , 30
IDE03471-ENG167523-Configuration a / m-Pilot_Parking, incl. , 30
IDE03471-ENG167525-Configuration a / m-Popup_if_GPS_services_in_use, not activated, 30
IDE03471-ENG152555-Configuration a / m-Privacy_WithPINRequest, 0, 30
IDE03471-ENG127496-Configuration a / m-ProbeCar_lgi, OFF, 30
IDE03471-ENG137646-Configuration a / m-ProbeCar_vzo, OFF, 30
IDE03471-ENG125047-Configuration a / m-PSD_Protocol_Version, PSD_1.5, 30
IDE03471-ENG117846-Configuration a / m-remote_HMI, incl. , 30
IDE03471-ENG138661-A / m-RSE_software_component Configuration, incl. , 30
IDE03471-ENG245031-Configuration a / m-rvc_low_black_screen_trunk_open, not activated, 30
IDE03471-ENG244966-A / m-rvc_low_black_screen_velocity_threshold configuration, not activated, 30
IDE03471-ENG245015-Configuration a / m-rvc_low_failsafe, not activated, 30
IDE03471-ENG126143-A / m-RVC_video_input Configuration, FBAS, 30
IDE03471-ENG152556-Configuration a / m-scon_telephony, not activated, 30
IDE03471-ENG142081-Configuration a / m-sd_slot_deactivation, all, 30
IDE03471-ENG138660-Configuration a / m-SDS_Region_Flag, no_region, 30
IDE03471-ENG152557-Configuration a / m-show_volte_hmi_switch, not activated, 30
IDE03471-ENG125045-Configuration a / m-Sim_card_mode_switch, missing, 30
IDE03471-ENG142144-Configuration a / m-sim_data_only_sms_support, OFF, 30
IDE03471-ENG138663-Configuration a / m-Smartphone_interface_for_rhmi, incl. , 30
IDE03471-ENG126993-Configuration of a / m-Station_Logo_DB_Mode, 51, 30
IDE03471-ENG125044-Configuration a / m-Support_for_response_and_hold, OFF, 30
IDE03471-ENG125042-Configuration a / m-Support_of_threeway_calling, incl. , 30
IDE03471-ENG130247-Configuration a / m-Support_second_phone, incl. , 30
IDE03471-ENG167531-Configuration a / m-Tencent_myCar_canceling_share_location, OFF, 30
IDE03471-ENG126994-Configuration a / m-TPEG_availability, OFF, 30
IDE03471-ENG152571-Configuration a / m-unblock_functions_while_piloted_driving, locked. , 30
IDE03471-ENG137647-A / m-UOTA Configuration, OFF, 30
IDE03471-ENG167532-Configuration a / m-UOTA_2, OFF, 30
IDE03471-ENG117852-a / m-UPnP Configuration, incl. , 30
IDE03471-ENG142149-A / m-vehicle_leaving_sound configuration, not activated, 30
IDE03471-ENG142147-A / m-vehicle_readiness_sound configuration, not activated, 30
IDE03471-ENG152558-Configuration a / m-voice_over_lte, not activated, 30
IDE03471-ENG117836-Configuration a / m-VZAPro, OFF, 30
IDE03471-ENG127494-Configuration a / m-VZO, OFF, 30
IDE03471-ENG137648-A / m-WiFi_Client_HMI Configuration, incl. , 30
IDE03471-ENG117842-A / m-WIFI_Hotspot Configuration, incl. , 30
IDE03471-ENG152572-Configuration a / m-wlan_5ghz_switch, incl. , 30
IDE03580-Country code for the mobile network, 0, 2
IDE03902-Automatic Ring Tire Diagnosis, Automatic Start Missing, 1
IDE04295-Bluetooth: Preferred Connection Profile for Phonebook Data, PBAP, 1
IDE04298-MAS01779-Dimensions a / m-Length, 4650 mm, 6
IDE04298-MAS01780-Dimensions a / m-Width, 2000 mm, 6
IDE04298-MAS02230-Dimensions a / m-Height, 1600 mm, 6
IDE04331-Selecting the unlock code for the SWaP function, FF FF FF FF, 4
IDE04484-ENG117426-Regional Codes-Parameter_Set_BlueRay_System_Region_Code, 2, 2
IDE04484-ENG117425-Regional Codes-Parameter_Set_DVD_Region_Code, 2, 2
IDE04521-Detection of sporadic discontinuity of the annular bus, opt. , 1
IDE04522-Vozm. transition into an asset. Connection mode to the optical bus of blocks, OFF, 1
IDE04549-Phone: Data Services, incl. , 1
IDE04550-Bluetooth: Sniff mode, OFF, 1
IDE05111-Paid Traffic Service (TMC), 1039, 2
IDE05113-Infotainment Recorder, incl. , 1
IDE06425-Roller Stand Mode: Functions, not activated, 1
IDE06697-Audio Control: Mute, Mute Audio, 1
IDE07399-ENG142045-Engine type-Engine_type_adaption_1, Gasoline, 1
IDE07399-ENG142046-Engine type-Engine_type_adaption_2, Gasoline, 1
IDE08814-IDE04033-GNSS Navigation Receiver: Configuration-Compass, OFF, 1
IDE08814-MAS01570-GNSS Navigation System Receiver: Configuration-Default, incl. , 1
MAS02614-GNSS Navigation Receiver: Configuration-GPS, OFF, 1
IDE08814-MAS07828-GNSS Navigation Receiver: Configuration-Galileo, OFF, 1
IDE08814-MAS07829-GNSS Navigation Receiver: Configuration-GLONASS, OFF, 1
IDE08814-ENG142047-GNSS Navigation Receiver: Configuration-external_gps_1, OFF, 1
IDE08814-ENG142048-GNSS Navigation Receiver: Configuration-external_gps_2, OFF, 1
IDE09382-ENG125051-Parameter 2 Data Connection (UMTS) -Scan Tune Level 2G, 0, 16
IDE09382-ENG125052-Parameter 2 Data Connection (UMTS) -Scan Tune Level 3G, 0, 16
IDE10221-MAS00839-Audio Control: Input Gain: Generation 2-TV Tuner, -128, 40
IDE10221-MAS00846-Audio Control: Input Gain: Generation 2-Satellite Receiver, 5, 40
IDE10221-MAS01984-Audio control: input gain: 2-radio (FM) generation, - 128, 40
IDE10221-MAS01985-Audio Control: Input Gain: Generation 2-Radio (AM), - 128, 40
IDE10221-MAS01986-Audio Control: Input Gain: Generation 2-Digital Radio (DAB), - 128, 40
IDE10221-ENG125854-Audio Control: Input Gain: Generation 2-Exbox_DMB, -128, 40
IDE10221-ENG117430-Audio Control: Input Gain: 2-HFP Generation, -128, 40
IDE10221-ENG125846-Audio Control: Input Gain: Generation 2-Media_Airplay, -128, 40
IDE10221-ENG125837-Audio Control: Input Gain: Generation 2-Media_AUX_Adapter, -128, 40
IDE10221-ENG125836-Audio Control: Input Gain: Generation 2-Media_AUXIN, -128, 40
IDE10221-ENG125843-Audio Control: Input Gain: Generation 2-Media_Bluray, -128, 40
IDE10221-ENG125841-Audio Control: Input Gain: Generation 2-Media_BTDevice, -128, 40
IDE10221-ENG125838-Audio Control: Input Gain: 2-Media_CDA Generation, -128, 40
IDE10221-ENG125848-Audio Control: Input Gain: 2-Media_Cloud Generation, -128, 40
IDE10221-ENG125839-Audio Control: Input Gain: Generation 2-Media_DVD, -128, 40
IDE10221-ENG125844-Audio Control: Input Gain: Generation 2-Media_HDMI, -128, 40
IDE10221-ENG125840-Audio Control: Input Gain: 2-Media_MFP Generation, -128, 40
IDE10221-ENG125847-Audio Control: Input Gain: Generation 2-Media_UPNP, -128, 40
IDE10221-ENG125855-Audio Control: Input Gain: 2-Mirrorlink Generation, -128, 40
IDE10221-ENG125859-Audio Control: Input Gain: Generation 2-Phone_Ringer_MFP, -128, 40
IDE10221-ENG125860-Audio Control: Input Gain: Generation 2-Phone_Ringer_OB, -3, 40
IDE10221-ENG125858-Audio Control: Input Gain: Generation 2-Phone_Voice, -128, 40
IDE10221-ENG125842-Audio control: input gain: 2-TA_Tuner_FM generation, -128, 40
IDE10221-ENG125850-Audio Control: Input Gain: 2-Tone_Beep Generation, -128, 40
IDE10221-ENG125853-Audio Control: Input Gain: 2-Tone_Messaging Generation, -128, 40
IDE10221-ENG125852-Audio Control: Input Gain: 2-Tone_Touchscreen Generation, -128, 40
IDE10221-ENG125851-Audio Control: Input Gain: 2-Tone_Warning Generation, -128, 40
IDE10221-ENG125856-Audio control: input gain: 2-TTS_Nav generation, -128, 40
IDE10221-ENG125857-Audio control: input gain: 2-TTS_SDS generation, -128, 40
IDE10221-ENG125845-Audio Control: Input Gain: Generation 2-Tuner_Online, -128, 40
IDE10221-ENG125849-Audio Control: Input Gain: Generation 2-Tuner_Personal, -128, 40
IDE10221-ENG125835-Audio Control: Input Gain: Generation 2-Tuner_TI, -128, 40
IDE10221-ENG125861-Audio Control: Input Gain: Generation 2-TV_AV_IN, -128, 40
IDE10480-MAS10741-Interface for external data carriers: activation-Connector 1, incl. ,four
IDE10480-MAS10742-Interface for external data carriers: activation-Connector 2, not activated, 4
IDE10480-MAS10743-Interface for external data carriers: activation-Connector 3, not activated, 4
IDE10480-MAS10744-Interface for external data carriers: activation-Connector 4, not activated, 4
IDE10604-Menu Items for Mobile Online Services, not activated, 1
IDE10668-Internal SIM: Application, automatic, 1
IDE11104-ENG127502-FM tuner: Mono Stereo settings-l_hf_stereo_lower_threshold, 37 dBµV, 3
IDE11104-ENG127503-FM tuner: Mono stereo settings-l_nf_max_stereo_channel_separation, 32 dB, 3
IDE11104-ENG127504-FM tuner: Mono stereo settings-t_hysteresis_mono_to_stereo, 15.0 s, 3
IDE11105-Display of Connect applications for the brand of the car,, 256
IDE11122-Designation of the country of sale HMI, RU, 2
IDE11153-ENG152487-Display the environment: virtual camera positions-focallength, 0, 330
IDE11153-ENG152487-Environment mapping: virtual camera position-focallength, 0, 330
IDE11153-ENG152457-Display of the environment: virtual camera positions-Pitchangle, 0, 330
IDE11153-ENG152445-Ambient Display: Virtual Camera Positions-Rollangle, 0, 330
IDE11153-ENG147432-Display the environment: virtual camera positions-xpos, 0, 330
IDE11153-ENG147432-Display of environment: virtual camera positions-xpos, 0, 330
IDE11153-ENG152451-Display of the environment: virtual camera positions-Yawangle, 0, 330
IDE11153-ENG147433-Display of the environment: virtual camera positions-ypos, 0, 330
IDE11153-ENG147434-Display the environment: virtual camera positions-zpos, 0, 330
IDE11153-ENG147434-Display of the environment: virtual camera positions-zpos, 0, 330
IDE11502-ENG127601-Locked menu items-FB_CAR_0, non_blocked, 21
IDE11502-ENG127602-Locked menu items-FB_CAR_1, non_blocked, 21
IDE11502-ENG127611-Locked menu items-FB_CAR_10, non_blocked, 21
IDE11502-ENG127612-Locked menu items-FB_CAR_11, non_blocked, 21
IDE11502-ENG127613-Locked menu items-FB_CAR_12, non_blocked, 21
IDE11502-ENG127614-Locked menu items-FB_CAR_13, non_blocked, 21
IDE11502-ENG127615-Locked menu items-FB_CAR_14, non_blocked, 21
IDE11502-ENG127616-Locked menu items-FB_CAR_15, non_blocked, 21
IDE11502-ENG127617-Locked menu items-FB_CAR_16, non_blocked, 21
IDE11502-ENG127618-Locked menu items-FB_CAR_17, non_blocked, 21
IDE11502-ENG127619-Locked menu items-FB_CAR_18, non_blocked, 21
IDE11502-ENG127620-Locked menu items-FB_CAR_19, non_blocked, 21
IDE11502-ENG127603-Locked menu items-FB_CAR_2, non_blocked, 21
IDE11502-ENG127621-Locked menu items-FB_CAR_20, non_blocked, 21
IDE11502-ENG127622-Locked menu items-FB_CAR_21, non_blocked, 21
IDE11502-ENG127623-Locked menu items-FB_CAR_22, non_blocked, 21
IDE11502-ENG127624-Locked menu items-FB_CAR_23, non_blocked, 21
IDE11502-ENG127604-Locked menu items-FB_CAR_3, non_blocked, 21
IDE11502-ENG127605-Locked menu items-FB_CAR_4, non_blocked, 21
IDE11502-ENG127606-Locked menu items-FB_CAR_5, non_blocked, 21
IDE11502-ENG127607-Locked menu items-FB_CAR_6, non_blocked, 21
IDE11502-ENG127608-Locked menu items-FB_CAR_7, non_blocked, 21
IDE11502-ENG127609-Locked menu items-FB_CAR_8, non_blocked, 21
IDE11502-ENG127610-Locked menu items-FB_CAR_9, non_blocked, 21
IDE11502-ENG127521-Locked menu items-FB_MEDIA_0, non_blocked, 21
IDE11502-ENG127522-Locked menu items-FB_MEDIA_1, non_blocked, 21
IDE11502-ENG127531-Locked menu items-FB_MEDIA_10, non_blocked, 21
IDE11502-ENG127532-Locked menu items-FB_MEDIA_11, non_blocked, 21
IDE11502-ENG127533-Locked menu items-FB_MEDIA_12, non_blocked, 21
IDE11502-ENG127534-Locked menu items-FB_MEDIA_13, non_blocked, 21
IDE11502-ENG127535-Locked menu items-FB_MEDIA_14, non_blocked, 21
IDE11502-ENG127536-Blocked menu items-FB_MEDIA_15, non_blocked, 21
IDE11502-ENG127537-Locked menu items-FB_MEDIA_16, non_blocked, 21
IDE11502-ENG127538-Locked menu items-FB_MEDIA_17, non_blocked, 21
IDE11502-ENG127539-Locked menu items-FB_MEDIA_18, non_blocked, 21
IDE11502-ENG127540-Locked menu items-FB_MEDIA_19, non_blocked, 21
IDE11502-ENG127523-Locked menu items-FB_MEDIA_2, non_blocked, 21
IDE11502-ENG127541-Locked menu items-FB_MEDIA_20, non_blocked, 21
IDE11502-ENG127542-Locked menu items-FB_MEDIA_21, non_blocked, 21
IDE11502-ENG127543-Locked menu items-FB_MEDIA_22, non_blocked, 21
IDE11502-ENG127544-Locked menu items-FB_MEDIA_23, non_blocked, 21
IDE11502-ENG127524-Locked menu items-FB_MEDIA_3, non_blocked, 21
IDE11502-ENG127525-Locked menu items-FB_MEDIA_4, non_blocked, 21
IDE11502-ENG127526-Locked menu items-FB_MEDIA_5, non_blocked, 21
IDE11502-ENG127527-Locked menu items-FB_MEDIA_6, non_blocked, 21
IDE11502-ENG127528-Locked menu items-FB_MEDIA_7, non_blocked, 21
IDE11502-ENG127529-Locked menu items-FB_MEDIA_8, non_blocked, 21
IDE11502-ENG127530-Locked menu items-FB_MEDIA_9, non_blocked, 21
IDE11502-ENG127625-Locked menu items-FB_MISC_0, non_blocked, 21
IDE11502-ENG127626-Locked menu items-FB_MISC_1, non_blocked, 21
IDE11502-ENG127635-Locked menu items-FB_MISC_10, non_blocked, 21
IDE11502-ENG127636-Locked menu items-FB_MISC_11, non_blocked, 21
IDE11502-ENG127637-Locked menu items-FB_MISC_12, non_blocked, 21
IDE11502-ENG127638-Locked menu items-FB_MISC_13, non_blocked, 21
IDE11502-ENG127639-Locked menu items-FB_MISC_14, non_blocked, 21
IDE11502-ENG127640-Locked menu items-FB_MISC_15, non_blocked, 21
IDE11502-ENG127641-Locked menu items-FB_MISC_16, non_blocked, 21
IDE11502-ENG127642-Locked menu items-FB_MISC_17, non_blocked, 21
IDE11502-ENG127643-Locked menu items-FB_MISC_18, non_blocked, 21
IDE11502-ENG127644-Locked menu items-FB_MISC_19, non_blocked, 21
IDE11502-ENG127627-Locked menu items-FB_MISC_2, non_blocked, 21
IDE11502-ENG127645-Locked menu items-FB_MISC_20, non_blocked, 21
IDE11502-ENG127646-Locked menu items-FB_MISC_21, non_blocked, 21
IDE11502-ENG127647-Locked menu items-FB_MISC_22, non_blocked, 21
IDE11502-ENG127648-Locked menu items-FB_MISC_23, non_blocked, 21
IDE11502-ENG127649-Locked menu items-FB_MISC_24, non_blocked, 21
IDE11502-ENG127650-Locked menu items-FB_MISC_25, non_blocked, 21
IDE11502-ENG127651-Locked menu items-FB_MISC_26, non_blocked, 21
IDE11502-ENG127652-Locked menu items-FB_MISC_27, non_blocked, 21
IDE11502-ENG127653-Locked menu items-FB_MISC_28, non_blocked, 21
IDE11502-ENG127654-Locked menu items-FB_MISC_29, non_blocked, 21
IDE11502-ENG127628-Locked menu items-FB_MISC_3, non_blocked, 21
IDE11502-ENG127655-Locked menu items-FB_MISC_30, non_blocked, 21
IDE11502-ENG127656-Locked menu items-FB_MISC_31, non_blocked, 21
IDE11502-ENG127657-Locked menu items-FB_MISC_32, non_blocked, 21
IDE11502-ENG127658-Locked menu items-FB_MISC_33, non_blocked, 21
IDE11502-ENG127659-Locked menu items-FB_MISC_34, non_blocked, 21
IDE11502-ENG127660-Locked menu items-FB_MISC_35, non_blocked, 21
IDE11502-ENG127661-Locked menu items-FB_MISC_36, non_blocked, 21
IDE11502-ENG127662-Locked menu items-FB_MISC_37, non_blocked, 21
IDE11502-ENG127663-Locked menu items-FB_MISC_38, non_blocked, 21
IDE11502-ENG127664-Locked menu items-FB_MISC_39, non_blocked, 21
IDE11502-ENG127629-Locked menu items-FB_MISC_4, non_blocked, 21
IDE11502-ENG127665-Locked menu items-FB_MISC_40, non_blocked, 21
IDE11502-ENG127666-Locked menu items-FB_MISC_41, non_blocked, 21
IDE11502-ENG127667-Locked menu items-FB_MISC_42, non_blocked, 21
IDE11502-ENG127668-Locked menu items-FB_MISC_43, non_blocked, 21
IDE11502-ENG127669-Locked menu items-FB_MISC_44, non_blocked, 21
IDE11502-ENG127670-Locked menu items-FB_MISC_45, non_blocked, 21
IDE11502-ENG127671-Locked menu items-FB_MISC_46, non_blocked, 21
IDE11502-ENG127672-Locked menu items-FB_MISC_47, non_blocked, 21
IDE11502-ENG127630-Locked menu items-FB_MISC_5, non_blocked, 21
IDE11502-ENG127631-Locked menu items-FB_MISC_6, non_blocked, 21
IDE11502-ENG127632-Locked menu items-FB_MISC_7, non_blocked, 21
IDE11502-ENG127633-Locked menu items-FB_MISC_8, non_blocked, 21
IDE11502-ENG127634-Locked menu items-FB_MISC_9, non_blocked, 21
IDE11502-ENG127561-Locked menu items-FB_NAV_0, non_blocked, 21
IDE11502-ENG127562-Locked menu items-FB_NAV_1, non_blocked, 21
IDE11502-ENG127571-Locked menu items-FB_NAV_10, non_blocked, 21
IDE11502-ENG127572-Locked menu items-FB_NAV_11, non_blocked, 21
IDE11502-ENG127573-Blocked menu items-FB_NAV_12, non_blocked, 21
IDE11502-ENG127574-Locked menu items-FB_NAV_13, non_blocked, 21
IDE11502-ENG127575-Locked menu items-FB_NAV_14, non_blocked, 21
IDE11502-ENG127576-Locked menu items-FB_NAV_15, non_blocked, 21
IDE11502-ENG127577-Locked menu items-FB_NAV_16, non_blocked, 21
IDE11502-ENG127578-Locked menu items-FB_NAV_17, non_blocked, 21
IDE11502-ENG127579-Locked menu items-FB_NAV_18, non_blocked, 21
IDE11502-ENG127580-Locked menu items-FB_NAV_19, non_blocked, 21
IDE11502-ENG127563-Locked menu items-FB_NAV_2, non_blocked, 21
IDE11502-ENG127581-Locked menu items-FB_NAV_20, non_blocked, 21
IDE11502-ENG127582-Locked menu items-FB_NAV_21, non_blocked, 21
IDE11502-ENG127583-Locked menu items-FB_NAV_22, non_blocked, 21
IDE11502-ENG127584-Locked menu items-FB_NAV_23, non_blocked, 21
IDE11502-ENG127585-Locked menu items-FB_NAV_24, non_blocked, 21
IDE11502-ENG127586-Locked menu items-FB_NAV_25, non_blocked, 21
IDE11502-ENG127587-Locked menu items-FB_NAV_26, non_blocked, 21
IDE11502-ENG127588-Locked menu items-FB_NAV_27, non_blocked, 21
IDE11502-ENG127589-Locked menu items-FB_NAV_28, non_blocked, 21
IDE11502-ENG127590-Locked menu items-FB_NAV_29, non_blocked, 21
IDE11502-ENG127564-Locked menu items-FB_NAV_3, non_blocked, 21
IDE11502-ENG127591-Locked menu items-FB_NAV_30, non_blocked, 21
IDE11502-ENG127592-Locked menu items-FB_NAV_31, non_blocked, 21
IDE11502-ENG127593-Locked menu items-FB_NAV_32, non_blocked, 21
IDE11502-ENG127594-Locked menu items-FB_NAV_33, non_blocked, 21
IDE11502-ENG127595-Locked menu items-FB_NAV_34, non_blocked, 21
IDE11502-ENG127596-Blocked menu items-FB_NAV_35, non_blocked, 21
IDE11502-ENG127597-Locked menu items-FB_NAV_36, non_blocked, 21
IDE11502-ENG127598-Locked menu items-FB_NAV_37, non_blocked, 21
IDE11502-ENG127599-Locked menu items-FB_NAV_38, non_blocked, 21
IDE11502-ENG127600-Locked menu items-FB_NAV_39, non_blocked, 21
IDE11502-ENG127565-Locked menu items-FB_NAV_4, non_blocked, 21
IDE11502-ENG127566-Locked menu items-FB_NAV_5, non_blocked, 21
IDE11502-ENG127567-Locked menu items-FB_NAV_6, non_blocked, 21
IDE11502-ENG127568-Locked menu items-FB_NAV_7, non_blocked, 21
IDE11502-ENG127569-Locked menu items-FB_NAV_8, non_blocked, 21
IDE11502-ENG127570-Locked menu items-FB_NAV_9, non_blocked, 21
IDE11502-ENG127545-Locked menu items-FB_PHONE_0, non_blocked, 21
IDE11502-ENG127546-Locked menu items-FB_PHONE_1, non_blocked, 21
IDE11502-ENG127555-Locked menu items-FB_PHONE_10, non_blocked, 21
IDE11502-ENG127556-Blocked menu items-FB_PHONE_11, non_blocked, 21
IDE11502-ENG127557-Locked menu items-FB_PHONE_12, non_blocked, 21
IDE11502-ENG127558-Locked menu items-FB_PHONE_13, non_blocked, 21
IDE11502-ENG127559-Locked menu items-FB_PHONE_14, non_blocked, 21
IDE11502-ENG127560-Locked menu items-FB_PHONE_15, non_blocked, 21
IDE11502-ENG127547-Locked menu items-FB_PHONE_2, non_blocked, 21
IDE11502-ENG127548-Locked menu items-FB_PHONE_3, non_blocked, 21
IDE11502-ENG127549-Locked menu items-FB_PHONE_4, non_blocked, 21
IDE11502-ENG127550-Locked menu items-FB_PHONE_5, non_blocked, 21
IDE11502-ENG127551-Locked menu items-FB_PHONE_6, non_blocked, 21
IDE11502-ENG127552-Locked menu items-FB_PHONE_7, non_blocked, 21
IDE11502-ENG127553-Locked menu items-FB_PHONE_8, non_blocked, 21
IDE11502-ENG127554-Locked menu items-FB_PHONE_9, non_blocked, 21
IDE11502-ENG127505-Locked menu items-FB_TUNER_0, non_blocked, 21
IDE11502-ENG127506-Locked menu items-FB_TUNER_1, non_blocked, 21
IDE11502-ENG127515-Locked menu items-FB_TUNER_10, non_blocked, 21
IDE11502-ENG127516-Locked menu items-FB_TUNER_11, non_blocked, 21
IDE11502-ENG127517-Locked menu items-FB_TUNER_12, non_blocked, 21
IDE11502-ENG127518-Locked menu items-FB_TUNER_13, non_blocked, 21
IDE11502-ENG127519-Locked menu items-FB_TUNER_14, non_blocked, 21
IDE11502-ENG127520-Locked menu items-FB_TUNER_15, non_blocked, 21
IDE11502-ENG127507-Locked menu items-FB_TUNER_2, non_blocked, 21
IDE11502-ENG127508-Locked menu items-FB_TUNER_3, non_blocked, 21
IDE11502-ENG127509-Locked menu items-FB_TUNER_4, non_blocked, 21
IDE11502-ENG127510-Locked menu items-FB_TUNER_5, non_blocked, 21
IDE11502-ENG127511-Locked menu items-FB_TUNER_6, non_blocked, 21
IDE11502-ENG127512-Locked menu items-FB_TUNER_7, non_blocked, 21
IDE11502-ENG127513-Locked menu items-FB_TUNER_8, non_blocked, 21
IDE11502-ENG127514-Locked menu items-FB_TUNER_9, non_blocked, 21
IDE11638-Codec Bluetooth Audio, FF, 1
IDE12266-Car phone operating time after turning the ignition off, on ,one
IDE12353-Traffic light configuration-online, incl. ,one
MAS00951-Bluetooth, incl. ,one
MAS02809-MAS02870-Auditory Test Frequency -HF Frequency Range, 4000 Hz, 6
MAS02809-MAS02871-The frequency of the test sound signal-The frequency range of the mid frequency signal, 1000 Hz, 6
MAS02809-MAS02872-The frequency of the test sound signal-The frequency range of the low-frequency signal, 100 Hz, 6
MAS03690-Phone, Active Data and Telephony, 1
MAS03782-WLAN incl. ,one
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off, OFF, 12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time, 0.00 ms, 12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off, OFF, 12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time, 0.00 ms, 12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off, OFF, 12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time, 0.00 ms, 12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off, OFF, 12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time, 0.00 ms, 12
ENG117920-Audio_Managment_Soundset_Menu, incl. ,one
ENG117917-BAP_Debug_Mode_Release, not_released, 1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization, not activated, 60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer, not activated, 60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off, not activated, 60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high, not activated, 60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill, not activated, 60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation, not activated, 60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer, not activated, 60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off, not activated ,60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high,not activated ,60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill,not activated ,60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent,not activated ,60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer,not activated ,60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off,not activated ,60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high,not activated ,60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill,not activated ,60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,включ. ,60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated ,60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,включ. ,60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated ,60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated ,60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated ,60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated ,60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated ,60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated ,60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated ,60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated ,60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated ,60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated ,60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated ,60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated ,60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,not activated ,60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated ,60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,включ. ,60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,включ. ,60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated ,60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated ,60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated ,60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated ,60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,not activated ,60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated ,60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated ,60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated ,60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated ,60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,not activated ,60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated ,60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated ,60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated ,60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,not activated ,60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,включ. ,60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated ,60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,включ. ,60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated ,60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated ,60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated ,60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,включ. ,60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,включ. ,60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated ,60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,включ. ,60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated ,60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,включ. ,60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated ,60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated ,60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,включ. ,60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,включ. ,60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated ,60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,включ. ,60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,not activated ,60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated ,60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,not activated ,60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated ,60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,включ. ,60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated ,60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated ,60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,включ. ,60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated ,60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,включ. ,60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated ,60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated ,60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,включ. ,60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated ,60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,включ. ,60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated ,60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated ,60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,включ. ,60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated ,60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,включ. ,60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,включ. ,60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated ,60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,включ. ,60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated ,60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated ,60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,включ. ,60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated ,60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,включ. ,60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated ,60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated ,60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,включ. ,60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated ,60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated ,60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,включ. ,60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated ,60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated ,60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated ,60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated ,60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated ,60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated ,60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated ,60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated ,60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,not activated ,60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated ,60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,включ. ,60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated ,60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,включ. ,60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated ,60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated ,60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated ,60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated ,60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated ,60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated ,60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,включ. ,60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated ,60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,включ. ,60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated ,60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,включ. ,60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated ,60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated ,60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,включ. ,60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated ,60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated ,60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated ,60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,not activated ,60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated ,60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated ,60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated ,60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,not activated ,60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated ,60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,включ. ,60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated ,60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,включ. ,60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated ,60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,включ. ,60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated ,60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,включ. ,60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated ,60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated ,60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated ,60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated ,60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,not activated ,60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated ,60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated ,60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated ,60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated ,60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,not activated ,60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated ,60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated ,60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated ,60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated ,60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,not activated ,60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated ,60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,включ. ,60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated ,60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,включ. ,60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated ,60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated ,60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated ,60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,not activated ,60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated ,60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,включ. ,60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_displayafter_disclaimer,not activated ,60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,включ. ,60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated ,60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated ,60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated ,60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated ,60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,not activated ,60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated ,60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated ,60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated ,60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,not activated ,60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated ,60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,включ. ,60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated ,60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,включ. ,60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated ,60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated ,60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,not activated ,60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated ,60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated ,60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated ,60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated ,60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,not activated ,60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated ,60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,включ. ,60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated ,60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated ,60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,включ. ,60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated ,60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated ,60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated ,60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated ,60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,not activated ,60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated ,60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated ,60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated ,60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated ,60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,not activated ,60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated ,60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated ,60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated ,60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated ,60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated ,60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated ,60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated ,60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated ,60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated ,60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated ,60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,not activated ,60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated ,60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,not activated ,60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated ,60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated ,60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated ,60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated ,60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,not activated ,60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated ,60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated ,60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated ,60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated ,60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,not activated ,60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated ,60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated ,60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated ,60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated ,60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,not activated ,60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,включ. ,60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated ,60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,включ. ,60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated ,60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,включ. ,60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated ,60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated ,60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,включ. ,60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated ,60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated ,60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,not activated ,60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,включ. ,60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated ,60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,включ. ,60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_not activated ,60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,включ. ,60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated ,60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated ,60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,включ. ,60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated ,60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated ,60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated ,60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated ,60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated ,60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,включ. ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Дополнительная шина данных ,64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Шина данных Ходовая часть ,64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,not activated ,64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,not activated ,64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,включ. ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Клемма 15 ,64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Шина данных Привод ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,включ. ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Шина данных информационно-командной системы Infotainment ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,включ. ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Шина данных Ходовая часть ,64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,включ. ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,not activated ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Шина данных информационно-командной системы Infotainment ,64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,включ. ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,включ. ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,включ. ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,not activated ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Data Bus Comfort ,64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,включ. ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Шина данных Комфорт ,64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated ,64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,включ. ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Data Bus Comfort ,64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38,not activated ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Data Bus Comfort ,64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,включ. ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Шина данных Привод ,64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,включ. ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,включ. ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Дополнительная шина данных ,64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,включ. ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Шина данных информационно-командной системы Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,включ. ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,not activated ,64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,включ. ,64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Клемма 15 ,64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Дополнительная шина данных ,64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Шина данных информационно-командной системы Infotainment ,64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Шина данных Привод ,64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Шина данных Комфорт ,64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Шина данных Комфорт ,64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Шина данных Комфорт ,64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,включ. ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,not activated ,64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Шина данных Комфорт ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,not activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Шина данных информационно-командной системы Infotainment ,64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,включ. ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Дополнительная шина данных ,64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,включ. ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Шина данных Ходовая часть ,64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Дополнительная шина данных ,64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Шина данных Комфорт ,64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Клемма 15 ,64
ENG122229-ENG 117728-Car_Function_List_BAP_Gen2-unit_master_0x13,включ. ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Шина данных Комфорт ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Шина данных информационно-командной системы Infotainment ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Шина данных информационно-командной системы Infotainment ,64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,включ. ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Шина данных Комфорт ,64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available ,8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Шина данных Комфорт ,8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Шина данных информационно-командной системы Infotainment ,8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,доступн. ,8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Шина данных информационно-командной системы Infotainment ,8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Шина данных Привод ,8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,доступн. ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Шина данных Ходовая часть ,8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Зарезервировано,Not available ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Шина данных Комфорт ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Шина данных Комфорт ,8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3,Not available ,8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,доступн. ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Шина данных Комфорт ,8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps,OFF ,10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,вкл. ,10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,вкл. ,10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode,H264 ,10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution,resolution_1 ,10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode,OFF ,10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon,0 ,10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most,OFF ,10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264 ,10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution,resolution_1 ,10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,OFF ,10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart,OFF ,10
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0 ,6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50 ,6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100 ,6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0 ,6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50 ,6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100 ,6
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,50 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,100 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,150 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,3 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,6 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,44 %,12
ENG117911-ENG117768-FM_Delay_Adaption-Parameter_Adaption_FM_Delay,0 ms,3
ENG117911-ENG117769-FM_Delay_Adaption-Seamless_linking_automatic,вкл. ,3
ENG107658-ENG126192-mobile phone voice control availability-apple_device,установл. ,1
ENG107658-ENG126193-mobile phone voice control availability-other_devices,установл. ,1
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,01 01 3C 02 3C 02 3C 02 50 02 50 02 64 02 6E 02 78 02 3C 02 3C 02 3C 02 50 02 1E 02 1E 02 1E 02 1E 02 02 02 02 14 05 5C ,40
ENG117809-p_damping_Display,5 ms,1
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 01 ,2
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
South Molton, UK
The adpmaps are great, but please also post a full unedited VCDS Auto-Scan
Actually, those maps smell of fish and the fish isn't fresh.
If I were a betting man......
SerCaddy
Pirate
Ukraine
I don't have VCDS.
Only VASIA Diagnost.
Admaps records in Russian.
SerCaddy
Pirate
Ukraine
[b]Removed.  Data from a clone/pirate copy of VCDS is not welcome here.[/b]
SerCaddy
Pirate
Ukraine
I noticed that in block 5F, for any change in the adaptation channels, the value for the channel changes:
IDE02502-Confirmation of installation changes, 47 3C, 2
This is normal?
I see my sense of smell is working fine.
Getting help on this forum requires the use of a legitimate VCDS system, not an illegally hacked-up version like ВАСЯ диагност.
If/when the OP gets one, he's welcome to PM me and I'll adjust his forum status.
SerCaddy
Pirate
Ukraine
Good afternoon.
I took the original vcds and removed the info
[b]Removed.  Not original either. [/b]
SerCaddy
Pirate
Ukraine
[b]Removed.   Still from a clone/pirate system.[/b]
