EA189 Rollback
Boothy
Manchester UK
C?ID=305263
Hi, I hope this is posted in the correct place.
I am looking to get a rollback on my VW Caddy 1.6tdi dsg, but the tuner has had trouble locating the original files on the ECU or his database (wiped by VW no doubt).
The ECU label is of no use either as it just shows the number 03L-907-425c, which is the hardware number according to the coding.
Is there any way or place I can retrieve the original files?.
Address 01: Engine Labels: 03L-906-023-CAY.clb
Control Module Part Number: 03L 906 023 TK HW: 03L 907 425 C
Component and/or Version: R4 1.6l TDI H43 9977
Software Coding: 00254014032500080000
Work Shop Code: WSC 35110 790 50316
ASAM Dataset: EV_ECM16TDI02103L906023TK 003001 (VN35)
ROD: EV_ECM16TDI02103L997557M.rod
VCID: 025E838A748E7EF7DCD-8056
Many thanks Steve
Boothy
Manchester UK
C?ID=305263
Thanks for your reply
The only files on this site for my software number are all files post Vag emissions fix. I am looking for files pre emissions fix i.e. earlier than revision 9976
TBAx
C?ID=287144
It should have had another software part number prior to the emissions update. Just check your old Auto-Scan logs. The TK in "03L 906 023 TK" came only after the update as far as I am informed.
