Hi,
Thank you UWE for creating a new thread in the right section.
Here is the latest scan, I've made :
Sunday,29,September,2019,00:18:25:04899
-- Windows Based VAG/VAS Emulator Running on Windows 10 x64
Version: 19.6.1.0 (x64)
VIN: TMBLJ9NP0J7xxxxxx License Plate:
Mileage: 33701km-20940mi Repair Order:
Chassis Type NP-SK48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 3C 42 44 47
4B 52 5F 69 6C 6D 75 A5 BB BC CA
VIN: TMBLJ9NP0J7xxxxxx Mileage: 33701km-20940miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: OK 0000
4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-DFCA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 MT HW: 04L 907 309 M
Component: R4 2.0l TDI H25 3076
Revision: B4H25---
Coding: 011D0012047605083000
Shop #: 33361 790 00109
Dataset: EV_ECM20TDI01104L906026MT 004001
ROD: EV_ECM20TDI01104L906026FN_004_SK48.rod
VCID: 08317829B320180FD1-805C
Part No SW: 0D9 300 014 T HW: 02E 927 770 AS
Component: DQ250-6A H54 5202
Revision: 06454104 Serial number: TFK01708021627
Shop #: 33361 790 00140
Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 29771DAD48EA0107EE-807C
P1734 00 [002] - -
Address 03: Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 62577000002069
Coding: 1E076A9C34230B6F4777070040CC4978562CD0E2E0029275386150F8C2A9420000000012121212B835351919323200
Dataset: EV_Brake1UDSContiMK100IPB 036010
ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
VCID: 79D70DEDF8CA7187DE-802C
Address 05: /Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0455510043
Coding: 032C0C070F
Dataset: EV_KessyHellaMQBAB 004041
ROD: EV_KessyHellaMQBAB_VW48.rod
VCID: 3E5DDEF1A16496BFAB-806A
Address 08: Auto HVAC (E87) Labels:| 3V0-907-044.clb
Part No SW: 3V0 907 044 HW: 3V0 907 044
Component: AC Automat H34 4402
Revision: 20K10000 Serial number: 00000B00659263
Coding: 1201010400041001100510410010112A
Dataset: EV_ACClimaPrehVW37X 002025
ROD: EV_ACClimaPrehVW37X.rod
VCID: 04296C198F083C6FBD-8050
Subsystem 2 - Part No SW: 3V0 907 049 E HW: 3V0 907 049 E
Component: E265KlimaHeck H02 0101
Serial number: 06051501850797
Part No SW: 5Q0 937 084 CQ HW: 5Q0 937 084 CG
Component: MQBAB H H36 0253
Serial number: 01001726400631
Dataset: EV_BCMMQB 018001
ROD: EV_BCMBOSCH_018.rod
VCID: 09377D2DA82A6107CE-805C
Subsystem 1 - Part No SW: 3V1 955 119 HW: 3V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: 48x LL 170728 032 0121
Serial number: 00000001707240308713
Coding: 1E4DFD
Component: 047 0105
Serial number: S3Y17M09D20H23M56S04
Coding: 0088DF
Seat Backrest Fan 1 Front Left:
Subsystem 3 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0297558
Seat Cushion Fan 1 Front Left:
Subsystem 4 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0297476
Seat Backrest Fan 1 Front Right:
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0339294
Seat Cushion Fan 1 Front Right:
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0339646
Part No SW: 5QA 919 294 B HW: 5QA 919 294
Component: 8 KanalH07 0044
Serial number: 000308418617265
Coding: 0471155951
Dataset: EV_EPHVA18AU3700000 009035
VCID: 4BBB8725E2D633173C-801E
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 C HW: 3Q0 907 572 C
Component: BOSCH H04 0195
Coding: 320067CA55FFC428949C8045
Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 354FC1DD945255E77A-8060
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 23081741350119
Dataset: EV_DRCONTITEMIC 001019
ROD: EV_DRCONTITEMIC_VW37.rod
VCID: 3851C8E98340A88F61-806C
Part No SW: 5Q0 959 655 BK HW: 5Q0 959 655 BK
Component: AirbagVW21 005 0336
Serial number: 003VXR38H597
Coding: 98FCC0C0000000005C5400CF004800000065
Dataset: EV_AirbaVW20SMEVW37X 002158
ROD: EV_AirbaVW20SMEVW37X.rod
VCID: 0A354221AD2C6A1FC7-805E
Subsystem 1 - Part No SW: ----------- HW: 480 001 709 17
Serial number: 35700000000176FCF72.
Subsystem 2 - Part No SW: ----------- HW: 480 001 709 17
Serial number: 3580000000029261D72F
Subsystem 3 - Part No SW: ----------- HW: 480 402 009 17
Serial number: 3510001AB2644260F59+
Subsystem 4 - Part No SW: ----------- HW: 480 401 409 17
Serial number: 3520001C325187C123C-
Subsystem 5 - Part No SW: ----------- HW: 480 401 309 17
Serial number: 3550001AB270BC54866A
Part No SW: 5Q0 953 521 GE HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF035035 Serial number: 20170917500107
Coding: 6414
Dataset: EV_SMLSVALEOMQB 001015
ROD: EV_SMLSVALEOMQB.rod
VCID: 7BDB17E5F2F64397CC-802E
Part No SW: 3V0 920 711 B HW: 3V0 920 711 B
Component: KOMBI 301 0310
Coding: 07A5081AFF840008018B7B0B5001000800000000
Shop #: 73430 031 00140
Dataset: EV_DashBoardVDDMQBAB 009060
ROD: EV_DashBoardVDDMQBAB_SK48.rod
VCID: 2F43F3B5760E6F3730-807A
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW High 518 5304
Serial number: 17091710520284
Coding: 030100345F087300EB00025A9C0F00010001070000000000000000000000
Shop #: 33361 790 00160
Dataset: EV_GatewNF 013023
ROD: EV_GatewNF.rod
VCID: 334BFFC59A264BD754-8066
Subsystem 2 - Part No SW: 3V0 919 719 B HW: 3V0 919 719 B
Component: E221__MFL-PR6 H02 0160
Serial number: 000000000B0915010917
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 1649925204
Part No SW: 0CQ 907 554 J HW: 0CQ 525 130
Serial number: HA1-00021.07.17
Coding: 0301
Dataset: EV_AllWheelContrHA1VW37X 004013
VCID: 4CB98439E7D8342F35-8018
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000247550008
Coding: 0800000000000000
Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 71C735CDA0BA39C766-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0022
Serial number: Y0006QIE10314
Coding: 0010000000000500018280808080000000008181000000D400
Dataset: EV_SeatMemorDriveSide 002021
VCID: 3C59D4F9B77884AF85-8068
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Serial number: 0454107103
Coding: 02012103
Dataset: EV_HREntryHella 001028
ROD: EV_HREntryHella_VW37.rod
VCID: 3D5FD9FDAC628DA7B2-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0080
Serial number: 0453826901
Coding: 020121
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: FS 011 0032
Serial number: 0000279145654
Coding: 001D0920DE00040000001100
Dataset: EV_DCUDriveSideEWMAXCONT 006001
VCID: 47B3BB15FEBED77718-8012
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0002000025
Coding: 01000011004001
Dataset: EV_SteerAssisVWBSMQBA 009129
ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
VCID: 40A1A009DB90E04FD9-8014
Address 47: Sound System (J525) Labels:| 81A-035-466.clb
Part No SW: 81A 035 223 HW: 81A 035 223
Component: MIB2_amp_P_SK H10 0410
Revision: 00000001 Serial number: SKZ8Z1HJE02T7CC
Coding: 0384020000AA002FAA0000000000
Dataset: EV_AMPMst16C5Gen2ALPI 001001
ROD: EV_AMPMst16C5Gen2ALPI.rod
VCID: 59976D6D580A5187BE-800C
Address 4B: Multifunc. Module
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: BFS 011 0032
Serial number: 0000279001333
Coding: 001D0320DE00040000001100
Dataset: EV_DCUPasseSideEWMAXCONT 006001
VCID: 46ADB611F9B4CE7FE3-8012
Address 5F: Information Electr. (J794) Labels:| 3V0-035--HGH2.clb
Part No SW: 565 035 043 A HW: 565 035 043
Component: MU-H-N-EU H54 1163
Serial number: A856E0HB011659
Coding: 03840201000000005111000200080A002F0103E4012085009E
Dataset: EV_MUHig4CGen2HBAS 001001
ROD: EV_MUHig4CGen2HBAS_SK37.rod
VCID: 10015049CB7050CF09-8044
Subsystem 1 - Part No SW: 3V0 919 606 D HW: 3V0 919 606 D
Component: ABT_High-2 H52 9130
Serial number: SKZ6ZHV3001064
Subsystem 2 - Part No SW: V03 959 801 JN HW: -----------
Component: ECE 2017/2018 --- 0161
Compact Disc Database:
Component: Gracenote2 --- 1016
Part No SW: 5Q0 907 383 M HW: 5Q0 907 383 M
Component: Anhaenger H27 0260
Revision: 8B001004 Serial number: 0453918798
Coding: 0100000202000000
Dataset: EV_TrailFunctGener2Hella 001008
VCID: 41A7A50DD09AE947D6-8014
Component: RVC Compact H12 0231
Coding: 04840201A3002017000040
Dataset: EV_CamSysRVRVCPANAMQBAB 006009
VCID: 3957CDEDB84AB1879E-806C
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: 31544363000000
Coding: 0D88
Dataset: EV_DeckLidCONTIAU736 001014
ROD: EV_DeckLidCONTIAU736_AU73.rod
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5NA 035 284 B HW: 5NA 035 284 B
Component: OCULowMQBLGE H17 0717
Revision: --------
Coding: 03840201EA423A0D3B1C9E020045400382E608
Dataset: EV_OCULowMQBLGE 004044
ROD: EV_OCULowMQBLGE_004_VW25.rod
Part No SW: 3QD 980 654 HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 1272
Serial number: 21081741P10043
Coding: 0204080200000401002623558150A90098000E100040
Dataset: EV_MFKBoschMQBB 001001
1275 - Unknown Error Code
B182E F0 [008] - Unknown Error Elaboration
Reset counter: 5
Mileage: 30950 km
Date: 2019.08.18
Time: 22:54:34
Control Module temperature: 39 °C
Outside air temperature: 16.0 °C
Vehicle speed: 88.42 km/h
System run time: 5269.4 s
Voltage terminal 15: 13.7 V
mid: 01 63
Status of camera: operational
Engine_Running_Info: 1
Software_Info_4: 2
Software_Info_3: 7
Software_Info_2: 2
Software_Info_1: 1
Part No SW: 5Q4 959 395 E HW: 5Q4 959 395 B
Component: HFS 012 0032
Serial number: 0000278699949
Coding: 001C01208000040000001100
Dataset: EV_DCURearDriveMAXCONT 006001
Component: HBFS 012 0032
Serial number: 0000277609186
Dataset: EV_DCURearPasseMAXCONT 006001
Address CA: Sunroof
End-------------------------(Elapsed Time: 05:28)--------------------------
I did not change anything to the current setting of the S&S system yet. It's still at 7,6V.
@ DV52 : By "too sensitive", I effectively mean, that it triggers quite too often to my needs and my "taste". I'd like to preserve the life time of some components such as battery and starter. I'd rather the S&S triggers later, when the engine is warm enough and the battery correctly charged.
The S&S start limit voltage, is the only one parameter, whom I can have access to tune it.
I don't know if changing its value to 9,5 or 10V would comply to my goal, but this is why I ask if it's worth a try.
@ PertolDave : This is another point I'd would like to get rid of too... Foot on brake pedal, the S&S effectively shuts the engine down below 5 km/h. Very nerving, when you only want to decelerate, while approaching a "give way" road sign, or in traffic jam...
If someone knows how to change the speed threshold from 5 to 0 km/h, I'd be glad to get the trick!
But this not the most prejudictable to me at this time...
Thanks for your advices and opinions.
