Golf MK7 Halogen to FULL LED
Carat10
Poland
C?ID=210097
Hi friends
I have golf 2016 with halogen and make retrofit full led, I have some errors in scan, becouse golf have little crash. Have you tutorial ?
I install module 4B, and connect lamp to this module, have communication with led module and what next ?
I need change BCM ? or maybe change coding in BCM ?
Thanks for help
Tuesday,01,October,2019,17:46:04:16059
Dealer/Shop Name: ECUDoctor
VIN: 3VW4T7AUXHM013105   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 29 39 42 44 4B 52 5F 75 A9 D6
          D7
VIN: 3VW4T7AUXHM013105   Mileage: 14228km-8840miles
29-Left Light -- Status: Not registered 0011
39-Right Light -- Status: Not registered 0011
D6-Light Ctrl Left 2 -- Status: Cannot be reached 0100
D7-Light Ctrl Right 2 -- Status: Cannot be reached 0100
Address 01: Engine (J623-CXCA)       Labels:. 06K-907-425-V1.clb
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Revision: --H13---
   Coding: 091D00324424002F0000
   Shop #: WSC 00066 790 00064
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001004
   ROD: EV_ECM20TFS0205G0906259L.rod
   VCID: 372B2B965FCE6F0F3B3-8062
17178 - Databus
          U1123 00 [039] - Received Error Message
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:53:05
                    Engine speed: 0.00 /min
                    Coolant temperature: 16 °C
                    Intake air temperature: 21 °C
                    Voltage terminal 30: 11.933 V
                    Drivetrain coordinator: ACC fault status-ACC is active despite EPB deceleration: No
                    Drivetrain coordinator: ACC fault status-ACC active: although TSK passive: No
                    Drivetrain coordinator: ACC fault status-Start off or stop request at stopping speed not set: No
                    Drivetrain coordinator: ACC fault status-Start off and stop request sent simultaneously: No
                    Drivetrain coordinator: ACC fault status-ACC active: although limiter active: No
                    Drivetrain coordinator: ACC fault status-ACC reactivates itself after locking: No
                    Drivetrain coordinator: ACC fault status-ACC sends undefined signals: No
                    Drivetrain coordinator: ACC fault status-ACC active although main switch off: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite driver braking: No
                    Drivetrain coordinator: ACC fault status-ACC is active despite ESP/ASR passive sampling: No
                    Drivetrain coordinator: brake fault status-ESP system error: No
Readiness: 1110 1101
   Part No SW: 0D9 300 042 H    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H54 4902
   Revision: 06354004    Serial number: TFK01607161888
   ROD: EV_TCMDQ250021.rod
   VCID: 1E65DE32D0343E47D85-804A
          P1734 00 [002] - -
Address 03: ABS Brakes (J104)       Labels:* 5Q0-907-379-ESP-V1.clb
   Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0398
   Revision: 00000000    Serial number: 52046000001597
   Coding: 01FA6BA13421096F8078020081C82980D62C90014081943400430050C00903
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
   ROD: EV_Brake1UDSContiMK100ESP_035_VW37.rod
   VCID: 75B7E19E0542DD1FE9F-8020
0297 - Steering Angle Sensor
          B1168 F2 [137] - Not Initialized
                    Reset counter: 200
                    Date: 2018.09.25
                    Time: 00:23:05
16412 - Display for Tire Pressure Monitoring
          C1146 02 [137] - Signal Failure
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:16
16413 - Display for Tire Pressure Monitoring
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:16
   Part No SW: 5GM 907 426 C    HW: 5GM 907 426 C
   Component: AC Manuell    H03 1601
   Revision: 00001K03
   Coding: 00020004200100000000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004132
   VCID: 48C9586A223010F7429-801C
262914 - Refrigerant Pressure
          B10AB F0 [009] - Too Low
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:04
                    Outside air temperature: 18.5 °C
                    Engine speed: 0 /min
                    Compressor current: actual value: 0.005 A
                    Temperature after evaporator: 17.3 °C
                    System run time-Terminal 15 on: 255 s
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 865829061602FE
   Coding: 000018464041B04969E44000001407201000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 7AADF2A22C5CB26784D-802E
   Component: WWS    160819  043 0581
   Serial number:         160827113218
14 Faults Found:
568836 - Databus
          [LWR AFS - Kein Signal/Kommunikation]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:04
568086 - Databus
          [LCM links - Blinker defekt]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:19
568342 - Databus
          [LCM rechts - Blinker defekt]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:19
6666 - Bulb for Low Beam Headlamp Left
          B1217 15 [009] - Open or Short to Plus
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:55:27
7178 - Bulb for High Beam Headlamp Left
          B1219 15 [009] - Open or Short to Plus
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:55:23
5130 - Bulb for Front Left Turn Signal
          B11E8 15 [009] - Open or Short to Plus
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:19
10506 - Bulb for Left Tail Light
          B12BE 15 [009] - Open or Short to Plus
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:55:24
6922 - Bulb for Low Beam Headlamp Right
          B1218 15 [009] - Open or Short to Plus
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 01:20:13
7434 - Bulb for High Beam Headlamp Right
          B121A 15 [009] - Open or Short to Plus
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:55:23
5386 - Bulb for Front Right Turn Signal
          B11EA 15 [009] - Open or Short to Plus
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:19
17162 - Bulb for Left DRL and Parking Lamp
          B12EA 15 [009] - Open or Short to Plus
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:06
17418 - Bulb for Right DRL and Parking Lamp
          B12EB 15 [009] - Open or Short to Plus
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:06
17674 - Bulb for Front Left Side Marker Lamp
          B12BA 15 [009] - Open or Short to Plus
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:55:22
17930 - Bulb for Front Right Side Marker Lamp
          B12BB 15 [009] - Open or Short to Plus
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:55:22
   Part No SW: 5Q0 919 294 L    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0056
   Revision: --------    Serial number: 39391604900115
   Coding: 0021150011
   VCID: 44D14C5A1E183497AE1-8010
12658704 - Databus
          [Steuergerät für elektrische Park-/Handbremse-J540 - EPB_01 - kein Signal/keine Kommunikation]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:04
13637426 - Databus
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:04
   Serial number: 003GCR05BZ4R
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 47CB5B562F2E1F8F4B3-8012
   Occupant Detection:
   Serial number: IBH000000000005N9F8K
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 907 16
   Serial number: 357000000005EC8CDC16
   Subsystem 3 - Part No SW: -----------    HW: 480 000 907 16
   Serial number: 35800000000AF761DC1
   Subsystem 4 - Part No SW: -----------    HW: 480 402 806 16
   Serial number: 3510002AF20FC742115%
   Subsystem 5 - Part No SW: -----------    HW: 480 402 806 16
   Serial number: 3520002B920FC4C4A1AG
   Subsystem 6 - Part No SW: -----------    HW: 480 401 207 16
   Serial number: 3550002C521160D1423M
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 207 16
   Serial number: 3560002C321160D4738X
9440539 - Driver's Safety Belt Tensioner Igniter 2
          B100D 1B [137] - Resistance Too High
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:07
9441051 - Front passenger's safety belt tensioner igniter 2
          B100F 1B [137] - Resistance Too High
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:07
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20160706400960
   Coding: 0410
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3FDB43B677FE574FF33-806A
   Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
   Component: KOMBI         344 8311
   Coding: 0BBD090AA190CF0502086A001000000000000000
   VCID: 2D0709FEAD92D5DF51F-8078
16776980 - Databus
          [PLA_Status_01 keine Kommunikation]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:04
9456433 - Key
          B104B 31 [009] - No Signal
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:56:48
   Part No SW: 5Q0 907 530 AL    HW: 5Q0 907 530 L
   Component: GW MQB Mid    211 2265
   Revision: --------    Serial number: 24061610801720
   Coding: 0101000830085900FB0000281C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 00074
   ROD: EV_GatewConti_013.rod
   VCID: 7BA3F7A623668B6F9FB-802E
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160001051270046225
   Coding: 31FFFF
131734 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x96]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:56:37
                    Supply voltage: Terminal 30: 11.9 V
                    Terminal 15: On
131735 - No Communications with Undefined Control Module
          U1126 00 [009] - -
          [Timeout Knoten 0x97]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:56:37
                    Terminal 15: On
131753 - Multifunction Module
          U1326 00 [008] - No Communication
          [Time_out_node_0xA9_multifunction_module_on_second_bus]
                    Reset counter: 240
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:57:12
                    Terminal 15: OFF
Address 29: Left Light (J1018)       Labels: 8V0-907-399.clb
   Part No SW: 8V0 907 399 D    HW: 8V0 907 399 D
   Component: LCM_MLBevoH08 0014
0018 - Data Set Implausible
          B2012 00 [009] - -
          [Implausible dataset]
0033 - Supply voltage
          U1011 00 [009] - Voltage too Low
          [Supply voltage - lower limit exceeded]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 01:20:40
0036 - Terminal 15
          U1405 00 [009] - Implausible signal
          [Clamp 15 implausible signal]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 01:19:28
Address 39: Right Light (J1023)       Labels: 8V0-907-399.clb
   Component: LCM_MLBevoH05 0011
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:54:12
0608 - LED Turn Signal Lights
          C11BF F0 [009] - Current Coding Electrical Malfunction
                    Reset counter: 102
0036 - Terminal 15
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:53:05
0356 - Temperature sensor
          C11C1 01 [009] - Electrical Failure
                    Reset counter: 102
                    Mileage: 10851 km
   Serial number: 170816060501RI
   Coding: 003E03200000020000000000
   VCID: 43D34F461B1633AF97B-8016
   Serial number: 00000000000004027979
   Coding: 011000
   Coding: 8302
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A2D32A26CDC7267C4D-806E
16275 - Steering Angle Sensor
          B1168 F2 [009] - Not Initialized
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:04
                    Motor status: 00
                    Supply voltage: 12.00 V
                    Temperature: 28.0 °C
                    KFC: 3F
                    KFA: 00 93
                    Environmental conditions: 5F
                    uioUdNotFilt_xdu16: 11.91 V
                    uAdSensI_SwitchedKl30_xdu16: 11.91 V
                    NoInitCause_AsicSens: [0x12] ASC_CTRL_SAS_PERIOD_ERR - SASPERIOD content lost after last ignition off
                    NoInitCause_RackPos_Rohwert: 01 C0
                    RP_VALCNTSAV: activated
                    RP_DIAGJOB: not activated
                    RP_RPS: not activated
                    RP_STARTUP: not activated
                    RP_L2PLAUSI: not activated
                    RP_INDEXPLAUSI: not activated
                    RP_RUKUCNTR: not activated
                    RP_UNDERVOLT: activated
                    RP_CNTERR: activated
23552 - Databus
          [PLA_01 Botschaft - CAN-Timeout]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:05
                    Motor status: 00
                    KFC: 5C
                    KFA: 00 00
                    uioUdNotFilt_xdu16: 12.11 V
                    uAdSensI_SwitchedKl30_xdu16: 12.11 V
   Component: FCM MQB Low   002 0342
   Serial number: 04101710800808
   Coding: 000000040900196C02202B07020000000000000000000000000000000000
   Shop #: WSC 06745 128 28888
   ASAM Dataset: EV_MultiModulContiVW48X 002004
   ROD: EV_MultiModulContiVW48X_002_VW37.rod
   VCID: 3537219E45C29D1F29F-8060
7 Faults Found:
0016 - Databus
          U1121 00 [137] - Missing Message
          [BCM_05 data bus missing message]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 01:19:28
12601088 - Extended CAN Bus (SAE Bus C)
          U0047 00 [137] - Performance
          [Databus extended no communication]
                    Reset counter: 149
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 01:19:27
0035 - Databus for Front Lighting
          U12EB 00 [009] - Additional Installations Detected
          [CAN_AFS_multiple_plug_LCM_identified]
                    Reset counter: 149
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 01:19:27
13706046 - Databus
          [LV_Abblendlicht_li_def received error value]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 01:20:14
13706047 - Databus
          [LV_Abblendlicht_re_def received error value]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 01:20:14
66881 - Databus
          [LED_L_falsch_codiert received error value]
                    Reset counter: 200
66882 - Databus
          [LED_R_falsch_codiert received error value]
                    Reset counter: 200
   Serial number: 21041606050184
   VCID: 42DD4A42040C3AA79CD-8016
   Serial number: 00000000000004022415
   Coding: 091000
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0751
   Coding: 02730000FF00000051220001001808009F0203D40120010002
   ROD: EV_MUStd4CDELP_VW37.rod
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9SJW00YLS
0523 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
          [Hochtonlautsprecher Kanal 3: Unterbrechung (AC-Diagnose)]
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:04
                    Voltage terminal 30: 11.9 V
0005 - Antenna Amplifier 1 for Radio
          B126D 13 [009] - Open Circuit
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:04
                    Status of antenna 1 for radio-Antenna current: 0 mA
                    Status of antenna 1 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 1 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 1 for radio-Reception level antenna 1: 51 dBµV
0006 - Antenna Amplifier 2 for Radio
          B126E 13 [009] - Open Circuit
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:04
                    Status of antenna 2 for radio-Antenna current: 0 mA
                    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Open circuit
                    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Not available
                    Status of antenna 2 for radio-Reception level antenna 2: 51 dBµV
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
13639680 - Mobile Data Services
          B149A 00 [009] - -
                    Reset counter: 200
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:23:04
   Component: SAS-GEN 2     H06 0014
   Serial number: 160604200234
   VCID: 6B83C7E653061BEF0FB-803E
   Part No SW: 7P5 941 572 AG    HW: 7P5 941 572 A
   Component: LED1L         H07 0008
   ASAM Dataset: EV_LEDMinMaxL_KEBODAVW481 001003
   ROD: EV_LEDMinMaxL_KEBODAVW481.rod
   VCID: 0059804A4A80E8B7CA9-8054
0017 - invalid data record
          B2005 00 [175] - -
          [Invalid Dataset]
                    Reset counter: 0
0257 - Databus
          U1201 00 [040] - No Communications
          [can data bus - no communication]
                    Reset counter: 0
0338 - ROD - Unknown Error Code
          - 00 [237]
                    Reset counter: 0
                    Mileage: 14228 km
                    Date: 2018.09.25
                    Time: 00:53:05
Address D7: Light Ctrl Right 2
End----(Elapsed Time: 01:25, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
downtime
Finland
C?ID=280813
          B2005 00 [175] - -
          [Invalid Dataset]
                    Reset counter: 0
                    Time: 00:00:0
For this you need something else than VCDS unfortunately.
Also can you please run clear all DTCs and the take a new autoscan so we'll see what errors are valid and whatnot.
myounus
Northwest UK
C?ID=321059
You need to change the BCM definitely and the Gateway. Have you fitted a level sensor too?
^^^ ...............and if I may add to myounus's advice - you will also need to deal with Component Protection error messages from a variety of modules in the CP constellation because the CP master (i.e. hex19 module) is changed!.
Officially, this needs a FAZIT connection with a registered VW agent. Regardless of whether you do this the official way, or by a "hack", my advice is to arrange this before you start swapping modules (and incidentally, make admaps of the modules before starting the exercise) - down here in the very deep south, some dealers won't delete CP errors if they don't also do the module swap (and as I understand, independent workshops haven't been able to get a FAZIT license, yet).
Carat10
Poland
C?ID=210097
hi, have little problem,
Change gateway, bcm, connection wire etc.. but:
- left lamp is 29 & D6 ID can driver
- right lamp is 39 & D7 ID can driver
D6 & D7 have correct, but on both driver have ID 29 (left lamp) so when I connect both, can't conenction with 29 & 39 driver, when I disconnect (left or right) I connect only 29 (left lamp) can driver. When I connect to phisical right lamp only can connect via 29 ID can driver, how chagne this driver to 39 id can ? Phisical left and right can are connect to the same can to 4B module.
Thanks for help
myounus
Northwest UK
C?ID=321059
Thanks for help
Can you please clear all faults and please post an updated scan. I take it you are referring to the Gateway installations. If you've updated to the correct gateway then the additional installations should be recognised and require coding. Once we see the updated scan we will be able to advise you.
