DPF warning light
grittysoup
C?ID=362815
Hi,
LT3 VW Crafter R5 2008 V5 2.5
The DPF warning light has come on, I have driven up the motorway for 20 minutes straight away, but the light has not gone out, a few shotr journeys later and the coil light is on, and I suspect the vehicle is in limp mode - what happened to the regenerations ?? as far as I am aware it has not done any regerations since owning (3 months) with mostly short journeys.
Should I force regen, or get it taken off and cleaned ... I am willing to follow this: http://wiki.ross-tech.com/wiki/index.php/Diesel_Particle_Filter_Emergency_Regeneration
But do not know the DPF spec, VCDS is measuring:
26.0 % Particle Filter Load Coefficient
57.0 Particle Filter Carbon Mass
0.0 % Carbon Mass Learned Value
I am worried I might burn the van down, could anyone help with what the above number tell me, and is it say to force regen.
Log and measuring blocks below:
I have posted about the previously cleaned DPF here:
https://forums.ross-tech.com/showthread.php?18938-DPF-just-cleaned-how-to-reset-things-with-VCDS
Tuesday,01,October,2019,11:31:27:43490
VIN: WV1ZZZ2EZ86033313   License Plate:
Chassis Type: 2E (2E - VW Crafter Panel Van (LT3 / 2006 > 2016))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 905 843 D    HW: 906 900 380 3
   Component: IMMO          1423  1322
   Revision: 00423000    Serial number: VWZDZ0Q4002050
   Shop #: WSC 65439 002 1048576
   VCID: 2809F9BA0EF98567A17-807C
01312 - Powertrain Data Bus
Address 94: LT3 Airbag
   Part No HW: 9064461442
   Shop #: WSC 00117 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3331.rod (*)
   VCID: 55F7804E658BC88FCA1-8000
Address 95: LT3 ESP
   Part No SW: 9064481553    HW: 0004460053
   ASAM Dataset: 3 4099
   ROD: CRFT_ESP_3_36928.rod (*)
   VCID: 0D47A82E8DDBC04FB21-8058
42A4 - Voltage supply: Lower limit not reached
            MIL ON - Test Complete - Stored
Address 96: LT3 Instruments
   Part No SW: 9064482021    HW: 0034468021
   ASAM Dataset: 32 776
   ROD: CRFT_KOMBI_32_776.rod
   VCID: 04518D0ADE918107EDF-8050
Address 99: LT3 Ign. Switch
   Part No HW: 9069003803
   Shop #: WSC 00000 288 01315
   ASAM Dataset: 67 259
   ROD: CRFT_EZS_67_259.rod
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-93.clb
   Component: HF-FFB        1423  1322
   Revision: 00423000    Serial number: 12345678901234
   Shop #: WSC 00082 210 103452
00171 - Key 1 not learned
Address 9B: LT3 Driver Door
   Part No HW: 9068203926
   ASAM Dataset: 33 771
   ROD: CRFT_FTUHR_33_771.rod (*)
Address B0: LT3 Roof Display
   Part No SW: 9064480323    HW: 9068203601
   ASAM Dataset: 21 3
   ROD: CRFT_DBE_21_3.rod (*)
   VCID: 074B9A06EFA7AA1F88D-8052
909B - Alarm Horn (H12): No communication
            Test Complete - Active/Stored
909C - Alarm Horn (H12): No or incorrect basic setting
Address B1: LT3 Upper Console
   Part No HW: 9065454107
   ASAM Dataset: 67 3
   ROD: CRFT1_OBF_67_3.rod (*)
Address B4: LT3 Central Elec.
   Part No SW: 9064420600    HW: 9065450601
   ROD: CRFT_EZE_33_771.rod (*)
   VCID: 7F5B02E6B777E2DFB0D-802A
900D - Left High Beam Lamp (L125): Short to Plus
Address B6: LT3 Steering Wheel
   Part No SW: 9065402345    HW: 9065402345
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 06559702E8ADB317F3B-8052
End----------(Elapsed Time: 01:17, VBatt start/end: 14.1V/14.2V)-----------
Tuesday,01,October,2019,11:38:56:43490
                Address 91: LT3 Engine  (074 906 032 AT)
11:38:53 Group 070: Particle Filter (Regeneration Status II)
  00000100  Status 4 Regeneration
  4393.0 s  Time
  0.0  Failed Regenerations
  0.0  Successful Regenerations
11:38:53 Group 008
  756 /min  RPM
  0.0 Nm  Torque
  158.6 Nm  Torque
  185.4 Nm  Torque
11:39:00 Group 069: Particle Filter (Regeneration Status I)
  00000000  Status 1 Regeneration
  00000000  Status 2 Regeneration
  00000000  Status 3 Regeneration
11:39:00 Group 008
  756 /min  RPM
  0.0 Nm  Torque
  158.6 Nm  Torque
  185.4 Nm  Torque
11:39:02 Group 069: Particle Filter (Regeneration Status I)
11:39:02 Group 008
  735 /min  RPM
  0.0 Nm  Torque
  158.6 Nm  Torque
  185.4 Nm  Torque
11:39:06 Group 068: Particle Filter (Exhaust Gas II)
11:39:06 Group 008
  756 /min  RPM
  0.0 Nm  Torque
  158.6 Nm  Torque
  185.4 Nm  Torque
11:39:10 Group 067: Particle Filter (Exhaust Gas I)
  108.0°C  Temperature bef. Turbo Charger
  102.0°C  Temperatur in Particle Filter
  17.85  Press. Difference Particle Filter
  0.00  Press. Difference Offset
11:39:10 Group 008
  735 /min  RPM
  0.0 Nm  Torque
  158.6 Nm  Torque
  183.0 Nm  Torque
grittysoup
C?ID=362815
OK, have followed the instructions under:
Diesel Particle Filter Emergency Regeneration: http://wiki.ross-tech.com/wiki/index.php/Diesel_Particle_Filter_Emergency_Regeneration
After 'do-it' I saw no indication on the dash that regen was taking place (I thought some warning light would be flashing). I just received a message in VCDS stating that the code had been accepted (which was in fact 20016, not 21295 for "Enable Regeneration".
I immediatley drove up the motorway again, temps got up to 500-700, within a few minutes the "Particle Filter Load Coefficient" dropped steadily to zero (from 26%) over about 10 miles, with revs at 2500rpm, the DPF warning light went off a few minutes later.
Should I presume: "Enable Regeneration" 20016 did what it says it would do, could a regen simply not have started on its own with the motorway drive - confused why it didn't sort itself out on the first motorway drive since seeing the warning light.
Should I still expect to have the DPF removed and cleaned, or will this have burnt off soot in the DPF properly, my journeys are mostly short urban, and have omitted to do the weekly zip up the motorway.
