Audi A3 has had a new repaired ABS unit fitted but now throwing up the following faults in the ABS system. Any advice
Saturday,28,September,2019,11:19:20:32681
VCDS Version: 19.6.1.0 (x64) HEX-NET CB: 0.4508.4
VIN: WAUZZZ8P9AA143444 License Plate:
Chassis Type: 8P-AU35 (1K0)
Scan: 01 03 08 09 10 15 16 17 19 25 42 44 46 47 52 56 61 77
VIN: WAUZZZ8P9AA143444 Mileage: 150640km-93603miles
Address 01: Engine (CDA) Labels:. 06J-907-115-CDA.clb
Part No SW: 8P7 907 115 K HW: 8P0 907 115 Q
Component: 1.8l R4/4V TFSI 0020
Revision: AAH03--- Serial number: AUX7Z0J1FNO00V
Coding: 0143000C18070160
Shop #: WSC 06314 000 00000
VCID: 41CAA03818F66347D6-8014
P0299 - 000 - Control Range Not Reached
Mileage: 137606 km
Date: 2019.02.27
Time: 14:54:48
RPM: 2327 /min
Load: 88.6 %
Speed: 103.0 km/h
Temperature: 95.0°C
Temperature: 21.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.478 V
000256 - Mass Air Flow Sensor (G70)
P0100 - 000 - Supply Voltage - Intermittent
Temperature: 10.0°C
Temperature: 12.0°C
Absolute Pres.: 980.0 mbar
Voltage: 12.573 V
Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
Component: ESP MK60EC1 H30 0107
Revision: 00H30001
Coding: 13424012492600FDC80F02E8921D0081380800
Shop #: WSC 00665 002 00010
VCID: 78BC0DDCCBACE28FA1-802C
01486 - System Function Test Activated
Reset counter: 251
Mileage: 150642 km
Date: 2019.09.17
Time: 00:41:47
Count: 16387
Count: 12800
Count: 320
Count: 51968
Count: 6400
Fault Status: 01101000
Reset counter: 251
Mileage: 150642 km
Date: 2019.09.17
Time: 00:41:47
Count: 16387
Count: 12800
Count: 8212
Count: 51968
Count: 6400
Part No SW: 8P0 820 043 BM HW: 8P0 820 043 BM
Component: KlimavollautomatH09 0150
Revision: 000005 Serial number: 8P0820043BM
VCID: 78BC0DDC0BACE28FA1-802C
Address 09: Cent. Elect. (J519) Labels:. 8P0-907-063.clb
Part No SW: 8P0 907 063 A HW: 8P0 907 063 A
Component: BCM PQ35 M 105 0575
Revision: 00105 AK
Coding: 0E000A2FB005F000207041E00100014C437A23AA106DC929E4000E800041
VCID: 3228FFF46D50C8DF5F-8066
Subsystem 1 - Part No SW: 8P2 955 119 F HW: 8P2 955 119 F Labels: 1KX-955-119.CLB
Component: Wischer AU350 H10 0040
Coding: 00DD13
Subsystem 2 - Part No SW: 8K0 910 557 HW: 8K0 955 559 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSEN H04 0003
Coding: 024C2D
Subsystem 3 - Part No: 8P0 951 177
Component: Innenraumuebe H04 0020
Subsystem 5 - Part No: 1K0 907 719 C
Component: Neigungssenso 005 0003
Address 10: Park/Steer Assist (J446) Labels:. 8P0-919-475-7X1.clb
Part No SW: 8P0 919 475 G HW: 8P0 919 475
Component: PARKHILFE 4K H06 0120
Revision: 11001001 Serial number: 93631005410947
Coding: 000003
VCID: 42C8AF34DDF0785FCF-8016
Address 15: Airbags (J234) Labels:* 8P0-959-655-10.clb
Part No SW: 8P0 959 655 P HW: 8P0 959 655 P
Component: Airbag AU1042 H06 0160
Revision: -------- Serial number: 003FB005YVZ5
Coding: 303142413039303030384A55305238503053
ROD: EV_Airba10AURB4.rod
VCID: 4FEE960016A2853750-801A
Serial number: 34928RB4000056D8C7E4
Serial number: 35028RB4000056D8057I
Serial number: 35128RB4000056D8BE2Y
Serial number: 35228RB4000056D8118I
Serial number: 35547RB40000572D872O
Serial number: 35647RB40000572D892R
Address 16: Steering wheel Labels: 8P0-953-549.lbl
Part No SW: 8P0 953 549 K HW: 8P0 953 549 K
Component: J0527 H37 0070
Coding: 0004042
VCID: 46C0B32431D8447FE3-8012
Component: E0221 H02 0100
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 M HW: 8P0 920 982 M
Component: KOMBIINSTR. VDO H03 0990
Revision: D0H03005 Serial number: 2241J005008803
Coding: 0004428
Shop #: WSC 36188 001 1048576
VCID: 43C6AA3002EA7157C4-8016
Part No SW: 1K0 907 530 AF HW: 1K0 907 951
Component: J533 Gateway H17 0233
Revision: H17 Serial number: 1521J10305017F
Coding: E9A01F06100602040101
VCID: 6B9622904AFA59175C-803E
Revision: D0H03005 Serial number: AUX7Z0J1FNO00V
Shop #: WSC 38504 001 1048576
Address 42: Door Elect, Driver Labels: 8P0-959-801-MAX3.lbl
Part No SW: 8P0 959 801 M HW: 8P0 959 801 M
Component: Tuer-SG H04 0100
Coding: 0000564
VCID: 45C2B4280CDE4F67EA-8010
Part No: 1K0 909 144 J
Component: EPS_ZFLS Kl. 000 3001
Revision: 00H17000
VCID: 312AF0F8A856F3C726-8064
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P3 035 382 E HW: 8P3 035 382 E
Component: AB2 SUBWOOFERBOXH31 0160
Revision: 00007 Serial number: 92157948774829
VCID: 3522C4E85C3EDFE77A-8060
Part No SW: 8P0 959 802 M HW: 8P0 959 802 M
Coding: 0000564
Address 56: Radio Labels: 8J0-035-1xx-56.clb
Part No SW: 8P0 035 186 S HW: 8P0 035 186 S
Component: R Concert2+ H03 0280
Revision: 00H03000 Serial number: AUZ1Z3K6020286
Coding: 0710111
VCID: 42C8AF341DF0785FCF-8016
Part No SW: 1K0 907 534 HW: 1K0 907 951
Component: Batt.regelung H17 0233
Revision: -------- Serial number: 1521J10305017F
Coding: 0302085A
VCID: 689C5D9C9B0C720F31-803C
Subsystem 1 - Part No SW: 1K0 915 181 E HW: 1K0 915 181 A
Component: J367-BDM H07 0140
Serial number: 00000000005651040600
Part No SW: 8P0 862 335 AA HW: 8P0 862 335 S
Component: FSE_256x BT H38 0600
Revision: 00000000 Serial number: 00000005176549
Coding: 0001222
VCID: 75A204E81CBE9FE7BA-8020
End----------(Elapsed Time: 01:23, VBatt start/end: 12.4V/12.4V)-----------
