2012 Leon window wiper malfunction
pascal
C?ID=208672
Saturday,28,September,2019,21:38:04:13476
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VMWare)
VCDS Version 18.9.1.0
VIN: VSSZZZ1PZDR024026   License Plate: CUPRA
Chassis Type: 1P-SE35 (7N0)
Scan: 01 03 08 09 10 15 16 17 19 25 2E 42 44 46 52 55 56 62 72 77
Address 01: Engine (J623-CFHC)       Labels:. 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 FJ    HW: 03L 906 018 FJ
   Component: R4 2.0l TDI   H25 9978
   Revision: 42H25---    Serial number:
   Coding: 00190012042500080000
   Shop #: WSC 00000 210 00000
   ASAM Dataset: EV_ECM20TDI01103L906018FJ 003006
   ROD: EV_ECM20TDI01103L906018FJ.rod
   VCID: 77FB877ACEF9E0F2EC-8023
9 Faults Found:
5229 - Fuel Rail/System Pressure
          P0088 00 [096] - Too High
5196 - Relay for Fuel Pump 2 (J49)
          P2632 00 [032] - Open Circuit
                    Mileage: 131921 km
                    Date: 2079.14.18
                    Time: 01:32:02
                    Engine speed: 0.00 /min
                    Coolant temperature: 22 °C
                    Intake air temperature: 19 °C
                    Voltage terminal 30: 12.040 V
                    Engine status: COENG_READY
5200 - Fuel Pump Relay Control Circuit
          P0627 00 [032] - Open Circuit
                    Mileage: 131921 km
                    Date: 2079.14.18
                    Time: 01:32:08
                    Voltage terminal 30: 12.020 V
4984 - Cylinder 1 Glow Plug Circuit (Q10)
          P0671 00 [109] - Electrical Fault
                    Mileage: 120800 km
                    Date: 2071.14.13
                    Time: 08:55:52
                    Engine speed: 221.00 /min
                    Normed load value: 100.0 %
                    Coolant temperature: 9 °C
                    Intake air temperature: 9 °C
                    Voltage terminal 30: 10.620 V
                    Electric auxiliary heater: shut-off conditions-Bits 0-7: 0
                    Electric auxiliary heater: relay activation-Bits 0-7: 0
                    Preheat time: 2500 ms
                    Glow status-Bits 0-7: 0
                    Time since ignition off: 56509 s
                    Outside air temperature: 8.5 °C
4708 - No Communications with HVAC Control Module (J301)
          U0164 00 [032] - -
                    Mileage: 131920 km
                    Date: 2079.14.17
                    Time: 18:26:19
                    Coolant temperature: 28 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 12.100 V
                    Limitation: accelerator pedal: 126.7 Nm
                    Cruise Control System (CCS): status-Bits 0-7: 40
                    selected gear-Bits 0-7: 0
4713 - No Communication with ABS Brake Control Module
          U0121 00 [036] - -
                    Mileage: 131921 km
                    Date: 2079.14.18
                    Time: 01:37:29
                    Coolant temperature: 32 °C
                    Voltage terminal 30: 12.520 V
5174 - Fuel Pressure Regulation
          P1065 00 [104] - Regulation Discrepancy
                    Mileage: 120800 km
                    Date: 2071.14.13
                    Time: 09:00:18
                    Engine speed: 2837.50 /min
                    Normed load value: 36.1 %
                    Vehicle speed: 48 km/h
                    Coolant temperature: 29 °C
                    Intake air temperature: 11 °C
                    Voltage terminal 30: 14.600 V
                    Engine status: COENG_RUNNING
4891 - EGR Valve (N18)
          P0403 00 [096] - Malfunction
4892 - EGR Valve (N18)
   Revision: 00H31001
   Coding: 133B4012092400FEC80B02E6901F0082350800
   Shop #: WSC 04941 000 00000
   VCID: 7DF79552E4C5CAA2B6-8029
                    Fault Status: 00101100
                    Reset counter: 34
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 18:14:04
                    Count: 2
                    Count: 20480
                    Count: 105
                    Count: 43776
                    Count: 64000
                    Reset counter: 34
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 19:25:36
                    Count: 3
                    Count: 2
                    Count: 20480
                    Count: 8194
                    Count: 43264
                    Count: 2048
            000 -  -
                    Reset counter: 34
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 01:30:51
                    Count: 3
                    Count: 2
                    Count: 20480
                    Count: 294
                    Count: 43008
   Part No SW: 5P0 907 044 T    HW: 5P0 907 044 T
   Component: Climatronic   H19 0909
   Revision: 00001001
   Coding: 0000000002
   Shop #: WSC 06402 785 00200
   ROD: EV_ClimaAutoBasis_SE35.rod
   VCID: 418F29A2D0BD6E4292-8015
          U1111 00 [008] - -
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2079.14.17
                    Time: 19:25:35
13701392 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 74
                    Mileage: 131921 km
                    Date: 2079.14.18
                    Time: 01:37:30
          B10AB F0 [009] - Too Low
                    Reset counter: 73
                    Mileage: 124242 km
                    Date: 2074.14.07
                    Time: 17:12:24
   Part No SW: 5K0 937 087 R    HW: 5K0 937 087 R
   Component: BCM PQ35 H    021 0068
   Revision: BE021001
   Coding: 46180A3E8025B0C042080080950089C442550008627D8160008040000040
   VCID: 448120B6C7AF7B6AB9-8011
   Subsystem 1 - Part No: 1P0 951 171
   Component: Innenraumuebe  010 4971
16 Faults Found:
                    Fault Status: 00101011
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 18:25:17
                    Voltage: 11.90 V
00153 - Windshield Wiper Motor;  Driver Side (V216)
                    Reset counter: 31
                    Mileage: 131890 km
                    Date: 2015.14.15
                    Time: 15:01:30
                    Voltage: 12.55 V
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 19:27:51
                        Term 15 Off
                    Voltage: 12.00 V
                    Reset counter: 74
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 01:31:33
                    Voltage: 11.85 V
                    Fault Status: 00101001
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 18:26:27
                    Voltage: 11.65 V
00924 - Relay for Headlamp Cleaning System (J39)
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 18:22:46
                    Voltage: 12.00 V
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 18:26:39
                    Voltage: 11.95 V
                    Reset counter: 74
                    Mileage: 131906 km
                    Date: 2015.14.16
                    Time: 17:08:59
                        Term 15 Off
                    Voltage: 12.45 V
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 19:25:37
                    Voltage: 11.90 V
                    Reset counter: 74
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 01:37:33
                    Voltage: 12.35 V
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 18:26:21
                    Voltage: 11.95 V
                    Reset counter: 74
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 01:30:48
                    Voltage: 11.85 V
                    Reset counter: 31
                    Mileage: 131890 km
                    Date: 2015.14.15
                    Time: 15:01:31
                    Voltage: 12.50 V
02071 - Local Databus
                    Fault Status: 01101100
                    Reset counter: 31
                    Mileage: 131890 km
                    Date: 2015.14.15
                    Time: 15:01:25
                    Voltage: 12.60 V
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 18:26:33
                    Voltage: 11.95 V
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 18:24:48
                    Voltage: 11.95 V
Address 10: Park/Steer Assist (J446)       Labels:. 3C8-919-475.clb
   Part No SW: 5P0 919 475 B    HW: 8P0 919 475 M
   Component: PARKHILFE 4K  H08 0008
   Revision: --------    Serial number: 36861226700173
   Coding: 000004
   VCID: 3A7D5E4EB56B3D9AD3-806F
   Component: J234__A0E VW10 HI   2118
   Revision: 24017000    Serial number: 003L7PKUTB2J
   Coding: 0012357
   VCID: 7CF198563FDFC3AA81-8029
   Subsystem 1 - Serial number: 6332MTS600632472
   Subsystem 2 - Serial number: 6342MTS626272472
   Subsystem 3 - Serial number: 6351HTS6DDJQCBKJ
   Subsystem 4 - Serial number: 6361HTS6PGEPBBKR
                    Reset counter: 74
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 01:37:31
   Part No SW: 5K0 953 521 BN    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20120925301115
   Coding: 108A140002
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 79FF8142F8EDF6829A-802D
   Subsystem 1 - Part No SW: 1P0 959 538 D    HW: 1P0 959 538 D  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAP  H02 0103
   Coding: E20000
227335 - Windshield Wiper Switch
          B1145 11 [008] - Short to Ground
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2079.14.17
                    Time: 18:49:40
227339 - Windshield Wiper Switch
          B1145 13 [008] - Open Circuit
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2079.14.17
                    Time: 18:50:11
227351 - Windshield Wiper/Washer Switch
          B1149 11 [008] - Short to Ground
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2079.14.17
                    Time: 18:49:52
          B1149 13 [008] - Open Circuit
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2079.14.17
                    Time: 18:50:11
Address 17: Instruments
   Part No SW: 7N0 907 530 AB    HW: 7N0 907 530 AB
   Component: J533  Gateway H47 1633
   Revision:   H47       Serial number: 090912F6000768
   Coding: 350203
   VCID: 70E9BC66A397B7CA2D-8025
                    Fault Status: 00110100
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 19:25:36
                    Reset counter: 74
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 01:37:31
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 18:47:36
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 19:32:36
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 19:27:51
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 18:26:20
   Component: IMMO          H03 0705
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADDAE0E8D4B4D1A63-FFFF
   Revision: A1001003    Serial number: 7663459626
   Coding: 010100
   VCID: 2A5D6E0E45CB8D1AA3-807F
                    Reset counter: 74
   Part No SW: 3C8 959 701     HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0508
   Revision: 12110009    Serial number: 0005327298
   Coding: 0012B0
   ROD: EV_TSGFPQ35BRFVW46X_SE35.rod
   VCID: 6DD7A512BCA55A2206-8039
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 704 E    HW: 3C0 959 794 E  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1501
   Serial number: 00000007218287
   Coding: 000290
68099 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2079.14.17
                    Time: 18:26:19
68107 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
                    Reset counter: 74
                    Mileage: 131921 km
                    Date: 2079.14.18
                    Time: 01:30:45
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 142    3305
   Revision: 00H22000
   VCID: 377B477A467920F22C-8063
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 19:25:36
                    Voltage: 12.00 V
                        DU
                    Temperature: 22.0°C
                    RPM: 1498 /min
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Battery Volts: 12.3 V
                        PD
                    Temperature: 17.0°C
                    Count: 2
                    Steering Angle: 0.00°
                        SteerAng n.Init
                    Reset counter: 74
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 01:37:30
                    Voltage: 12.38 V
                        DD
                    Temperature: 21.0°C
   Part No SW: 3C8 959 702     HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0508
   Revision: 14110009    Serial number: 0005326246
   Coding: 0012B0
   VCID: 6ED5A21EB1A3A13A3F-803B
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 703 E    HW: 3C0 959 795 E  Labels: 1K0-959-70X-GEN4.CLB
008 1501
   Serial number: 00000007195237
   Coding: 4A3338385F5F5453472D484C20
66561 - Motor for mirror fold-in
          B11F6 01 [009] - Electrical Failure
                    Reset counter: 183
                    Mileage: 98296 km
                    Date: 2055.14.28
                    Time: 23:10:33
          U1111 00 [008] - -
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2079.14.17
                    Time: 18:26:19
          U1111 00 [008] - -
                    Reset counter: 74
                    Mileage: 131921 km
                    Date: 2079.14.18
                    Time: 01:30:45
   Coding: 2557189
   VCID: 34617076570FCBEA09-8061
   Subsystem 1 - Part No: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Coding: 00000039
   Subsystem 2 - Part No: 7L6 941 329 C  Labels: 3D0-941-329.CLB
   Coding: 00000039
                    Reset counter: 74
                    Mileage: 131920 km
                    Date: 2015.14.17
                    Time: 19:25:36
                    Voltage: 11.93 V
                        ABS 1
                    Reset counter: 74
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 01:37:31
                    Voltage: 12.35 V
                        ABS 0
   Part No SW: 5P0 035 186 B    HW: 5P0 035 186 B
   Component: Media2.0      004 0082
   Revision: 01000001    Serial number: SEZ1Z3M5083718
   Coding: 01060400040000
   VCID: 2E55621E7923E13A7F-807B
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663451405
   Coding: 0200000000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 3A7D5E4EBD6B3D9AD3-806F
End-------------------------(Elapsed Time: 04:09)--------------------------
Address 01: DTCs cleared
Address 03: DTCs cleared
                Address 09: Cent. Elect.       Labels: 1K0-937-08x-09.clb
Control Module Part Number: 5K0 937 087 R    HW: 5K0 937 087 R
  Component and/or Version: BCM PQ35 H    021 0068
           Software Coding: 46180A3E8025B0C042080080950089C442550008627D8160008040000040
            Work Shop Code: WSC 04941 000 00000
                    Reset counter: 34
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 05:53:55
                    Voltage: 11.85 V
                    Reset counter: 34
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 05:53:56
                    Voltage: 11.85 V
                    Reset counter: 34
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 05:53:56
                    Voltage: 11.85 V
                    Reset counter: 34
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 05:53:55
                    Voltage: 11.85 V
                    Reset counter: 34
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 05:53:56
                    Voltage: 11.85 V
                    Reset counter: 34
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 05:53:56
                    Voltage: 11.85 V
                    Reset counter: 34
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 05:53:55
                    Voltage: 11.85 V
                    Reset counter: 34
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 05:53:56
                    Voltage: 11.85 V
                    Reset counter: 34
                    Mileage: 131921 km
                    Date: 2015.14.18
                    Time: 05:53:56
                    Voltage: 11.85 V
                Address 09: Cent. Elect.  (5K0 937 087 R)
22:14:16
  Not Installed   Left Motor (V399)
  Not Installed   Right Motor (V398)
  No Commun.   Rain Sensor
  3.0   Wiper Signal Steering Column
  No Commun.   Front Wiper
  No Commun.   Wiper End Position
  No Commun.   Wiper cycle
  OFF   Washer Pump (Front)
22:14:17
22:14:47
  0.0   Wiper Signal Steering Column
Address 09: DTCs cleared
Hi guys, front window wipers are not working, motor has been replaced twice already, Fuses are fine and motors are receiving power. measuring blocks (recorded above) appear to show wiper steering column stalk/switch is working as shows 0.0, 1.0, 2.0, 3.0 and 4.0 for different switch positions. Engine Hood Contact Switch is operational (confirmed via measuring blocks). Wiki page states: 'Check Central Electronics Control Module (J519) Coding' I have opened coding but not sure what to look for? does a new motor require recoding?
please see cent electrics faults-
Thank you
downtime
Finland
C?ID=280813
I would say you have a wiring issue somewhere. Both LIN and CAN bus affected. Wiper motor, rain sensor, alarm are all connected via LIN. Engine and others via CAN.
Check your wiring to/from BCM. I’d say the issue is there.
pascal
C?ID=208672
Thanks downtime, we will check the wiring then. I don't suppose you know if there is a wiper relay in this model?... it may have brought up a different fault if a relay was the problem.
downtime
Finland
C?ID=280813
No wiper relay in the newer BCMs neither front or back.
The error messages clearly indicate an issue in the control bus as it does not have a connection to the wiper motor or rain sensor. Those both are LIN bus connected modules.
