Hi all,
Last week about half way through an 8 hour drive on the highway, my beloved TDI wagon's CEL came on. No noticed performance degradation, just the CEL. I scanned it as soon as I drove back to the house with my cheap little bluetooth reader and P2002 popped up. I then cleared it, but it came back on maybe 15 minutes into the next drive. Here is the Ross-tech wiki page for P2002.
So, I ordered up a real programmer- the Hex V2, and performed an auto scan with the below results.
I was hoping it would come up with another code related to the p2002 but no such luck. I had heard p2002 may be caused by the exhaust flapper pressure control valve being faulty, so I then performed an output test on it and verified it moving open and closed properly. No code came up for the flapper valve either so I think that is ok.
I then read the DPF related values while at idle, logged them(below), inspected the differential pressure sensor for loose wires and performed an adaptation because I figured why not.
The pressure sensor seems to be reading ok; reads 0 when not running and 3 at idle, moving higher/lower as I step on/off the gas pedal, and there isn't an accompanying code up for it, so I think I can rule that out.
I then performed a manual regeneration while driving and watched the temperatures jump up while driving down the highway in 5th keeping rpms between 2000 and 2500. The DPF light came on for the first time while regenerating and then went off after about 10 minutes once the calculated soot dropped from 11.1 to 1.2. I then pulled over, logged values and cleared the code. Then drove home and logged the soot load, and time since last regen(now 30kms). See below for log in the above order.
The below code came up again 15 minutes in the next drive.
What are the values in the freeze frame? Is there a problem with one of them?
Here is the log containing values related to the DPF, taken right after the code flashed up again:
What other tests can I do? What do you think is the problem? It doesn't look the soot levels before manual regen were very high and the regens looked to be happening correctly. It doesn't look like the tailpipe is super sooty but when I wipe my finger in there it does turn black. Do you think the DPF is cracked? If it should need replacing, should I replace the EGR filter along with it?
Thanks a lot for the help.
Thursday,26,September,2019,17:20:09:33381
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: 3VWPL7AJ6EM605504 License Plate:
Chassis Type: AJ-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
VIN: 3VWPL7AJ6EM605504 Mileage: 114990km-71451miles
Part No SW: 03L 906 019 JT HW: 03L 907 309 AA
Component: R4 2,0L EDC G000AG 8184
Revision: 12H16--- Serial number:
Coding: 0350078
Shop #: WSC 00066 000 00000
VCID: 065596CFE42F0B67F05-8052
008194 - Particulate Trap Bank 1
P2002 - 007 - Efficiency Below Threshold - MIL ON
Fault Status: 11100111
Mileage: 114762 km
Date: 2014.02.10
Time: 06:03:05
RPM: 1610 /min
Speed: 50.0 km/h
(no units): 40.8
(no units): 25.5
(no units): 2.00
Pressure: 72 mbar
Pressure: 31 mbar
Readiness: 1 1 0 0 0
Part No SW: 02E 300 058 M HW: 02E 927 770 AL
Component: GSG DSG AG6 512 3524
Revision: 05551213 Serial number: 00001207150408
VCID: 2411EC4772D3D9778E1-8070
Part No SW: 1K0 907 379 BL HW: 1K0 907 379 BL
Revision: 00H31001
Coding: 114B600C492200FF881006E4921D0042310000
VCID: 7DA7F923BDF948BFA1F-8028
Part No SW: 7N0 907 426 BH HW: 7N0 907 426 BH
Component: AC Manuell H20 0505
Revision: 00001019
Coding: 0010004002
Shop #: WSC 00066 000 00119
VCID: 7BA3F73BA36D468F9FB-802E
Part No SW: 5K0 937 086 R HW: 5K0 937 086 R
Component: BCM PQ35 M 122 0173
Revision: BJ122001
Coding: AF380E1A802F3EC4008800C17000054449000086535D0520648020200040
VCID: 43D34FDB9B9DFE4F97B-8016
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 12071 26 0512
Coding: 009795
Part No SW: 5C0 959 655 M HW: 5C0 959 655 M
Component: AirbagVW10G 014 0726
Serial number: 003L4R027RGL
Coding: 00004E43
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 3C213427E6E381B7D61-8068
Subsystem 1 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME684C2178ZZZ+
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME5D4C2178ZZZ3
Serial number: 3511HSME0754612FZZZL
Serial number: 3521HSME5A08622FZZZU
Serial number: 35527SME1D0B7929ZZZS
Serial number: 35627SME6A5C4A2EZZZ/
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Component: Lenks.Modul 008 0090
Revision: -------- Serial number: 90422MG50019T
Coding: 188A140000
Shop #: WSC 00066 000 00213
ROD: EV_SMLSNGKUDS_A05.rod
VCID: 76B5E60F984F1BE7E05-8022
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Serial number: 0354372 FLE 20130624
Coding: 820000
617735 - Selector Lever Park Position Lock Switch
B1162 11 [008] - Short to Ground
Fault Frequency: 241
Reset counter: 31
Mileage: 110541 km
Date: 2019.08.30
Time: 07:24:20
Part No SW: 5K0 920 873 D HW: 5K0 920 873 D
Component: KOMBI H04 0811
Coding: 370F00
VCID: 313F151331A17CDF757-8064
Part No SW: 7N0 907 530 AK HW: 7N0 907 530 AK
Component: J533 Gateway H57 1642
Revision: H57 Serial number: 14081303000380
Coding: 352002
VCID: 79AFED33A9D1749F8D7-802C
Component: IMMO H04 0811
ROD: EV_Immo_UDS_VDD_RM09.rod
VCID: 6A8DC27FDCF7CF0774D-803E
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0007218669
Coding: 0004B5
Shop #: WSC 01383 790 50316
VCID: 5BE397BB03ADA68FFFB-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 C HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1509
Serial number: 00000008037824
Coding: 000490
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 70 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
VCID: 392F2D33E551B49FCD7-806C
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0007225812
Coding: 0004B4
VCID: 5CE194A706A3A1B7F61-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 C HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1509
Serial number: 00000007959857
Coding: 000490
Part No SW: 1K0 035 164 D HW: 1K0 035 164 D
Component: LOW NAR H02 0006
Revision: -----06S Serial number: VWZ4Z6N3620355
Coding: 05000400040007
VCID: 2313EF5B7BDDDE4FF7B-8076
Part No SW: 7P6 035 730 K HW: 7P6 035 730 K
Component: TELEFON H15 3200
Revision: 1B001001 Serial number: 00007664719638
Coding: 0A10040000010110
ASAM Dataset: EV_UHVNA 002720
ROD: EV_UHVNA_002.rod
VCID: 3A2D323FECD7BF87C4D-806E
End----(Elapsed Time: 01:07, VBatt start/end: 12.0V/12.0V. VIgn 11.9V)-----
Friday,27,September,2019,16:55:40:33381
Address 01: Engine (03L 906 019 JT)
16:55:22
3 mbar Particle Filter Different. Pressure
0 mbar Particle Filter Offset Different. Pressure
3.0 Requested Regenerations
130 km Mileage Since last Regen
11.1 Soot Load(g) Calculated
0.0 Soot Load(g) Measured
Address 01,03L 906 019 JT,channel 13,adapted from,0,to,1,
18:17:18
210.0°C Temperature prior Turbo Charger
246.0°C Temperature prior Particle Filter
270.0°C Temperature after Particle Filter
210 ml Particle Filter Oil Ash Volume
1.2 Soot Load(g) Calculated
Address 01: DTCs cleared
18:40:35
2.1 Soot Load(g) Calculated
Saturday,28,September,2019,17:35:21:33381
VCDS Version: Release 19.6.1 (x64) Running on Windows 10 x64
Address 01: Engine Labels: 03L-906-022-CBE.clb
Control Module Part Number: 03L 906 019 JT HW: 03L 907 309 AA
Component and/or Version: R4 2,0L EDC G000AG 8184
Software Coding: 0350078
Work Shop Code: WSC 00066 000 00000
Mileage: 115104 km
Date: 2014.02.18
Time: 02:39:14
RPM: 1633 /min
Speed: 83.0 km/h
(no units): 35.7
(no units): 25.5
(no units): 2.00
Pressure: 64 mbar
Pressure: 23 mbar
Readiness: 1 1 0 1 0
Saturday,28,September,2019,17:39:42:33381
Mileage: 115120km-71532mi Repair Order:
17:39:35
1.0 Requested Regenerations
3.2 l Fuel Consumption Since last Regen
60 km Mileage Since last Regen
72.0 Time elapsed since Regeneration
3.3 Soot Load(g) Calculated
