2011 VW Jetta 2.5 SE, DOOR CONTROL MODULE/RADIATOR FAN ISSUE
Vanidla
C?ID=261175
Help needed!
I have couple issues here, I'v recently replaced a radiator fan assembly, which I ordered form EuropaParts. And now,any time I open a door or a trunk, or unlock/lock the car with key mob, fans will run for 5-10 seconds and then go off, with no engine running or keys in the ignition. I verified that this fan is compatible with my car by calling and providing a vin# to EuropaParts. Also i verified there is no water/damage in the ECM/ECU.
Second issue, passenger front door window will roll up or down in increments of like 2in at the time, then I need to release the window switch and press again.
Any thoughts.?
Thank you
And here is Auto Scan:
Monday,23,September,2019,14:23:14:36338
VCDS Version: 19.6.1.0 (x64)
VIN: 3VWDZ7AJ6BM04XXXX
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 56
VIN: 3VWDZ7AJ6BM048736   Mileage: 160120km-99493miles
Address 01: Engine (CBU)       Labels: 07K-906-055-CBT.clb
   Part No SW: 07K 906 055 G    HW: 07K 906 055
   Component: 2,5l R5/4V      G01 8236
   Revision: T4H04---    Serial number:
   Coding: 0000075
   Shop #: WSC 00066 000 00000
   VCID: 326B4402ADA293DF5F-8066
005386 - Engine Off Timer Performance
               P150A - 000 -  - Intermittent
                    Mileage: 160122 km
                    Date: 2014.01.30
                    Time: 00:50:52
                    RPM: 1120 /min
                    Load: 23.1 %
                    Temperature: 79.0°C
                    Temperature: 53.0°C
                    Absolute Pres.: 1020.0 mbar
Readiness: 1110 0101
   Part No SW: 09G 927 750 LF    HW: 09G 927 750 LF
   Component: AQ 250 6F           1741
   Revision: 00H90000    Serial number:
   Coding: 0000840
   VCID: 000FDECA538EF14F99-8054
   Part No SW: 1K0 907 379 BG    HW: 1K0 907 379 BG
   Component: ESP MK60EC1   H31 0106
   Revision: 00H31001
   Coding: B14B440C492608028D1222E7921F1061A70000
   VCID: 78FFB62ACB5EB98FA1-802C
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 P    HW: 5C0 820 047 P
   Component: J301  Klimaanlage   0103
   Revision: 2000908S    Serial number: 00000000174599
   VCID: 2D51577EB49CCC2702-8078
   Part No SW: 5C0 937 087 C    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0226
   Revision: B2066001    Serial number: 03311341100532
   Coding: 7B994B1808AB0B0000302000240884D400C2502E60000000300000000000
   VCID: 2D51577E749CCC2702-8078
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3463
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: -------------  002 3xxx
   Coding: 020000
   Subsystem 3 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3463
   Coding: 800000
   Subsystem 4 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3463
   Coding: 800000
03302 - Response Closing Status of Passenger's Door
                    Fault Status: 01101000
                    Reset counter: 67
                    Mileage: 160122 km
                    Date: 2014.02.12
                    Time: 23:06:31
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 67
                    Mileage: 160122 km
                    Date: 2014.01.30
                    Time: 00:42:54
   Part No SW: 5C0 959 655 E    HW: 5C0 959 655 E
   Component: AirbagVW10G   013 0807
   Serial number: 003GTD08L6EO
   Coding: 00003932
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01020
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3467421A9FB69DEF4D-8060
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y1000001ZVB03
   Coding: 303144
   Serial number: 3572MSME77472358ZZZ-
   Serial number: 3582MSME47653259ZZZZ
   Serial number: 3516KSME7000330DZZZF
   Serial number: 3526KSME7F0F330DZZZ3
   Serial number: 3556LSME7542610DZZZW
   Serial number: 3566LSME3E5E7F2FZZZR
          B10B4 00 [137] - Function Restriction due to Undervoltage
                    Reset counter: 67
                    Mileage: 160122 km
                    Date: 2019.09.23
                    Time: 00:21:35
   Part No SW: 5C6 920 950 D    HW: 5C6 920 950 D
   Component: KOMBI         H07 0406
   Coding: 270201
   Shop #: WSC 00066 000 00149
   VCID: 2B5559664288C2171C-807E
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 0226
   Coding: 102200
   VCID: 70EF8E0AA32EE1CF69-8024
   Component: IMMO          H07 0406
   ROD: EV_Immo_UDS_VDD_RM09.rod
   VCID: 6ADB9C628DF21B1F27-803E
   Part No SW: 1K0 035 164 A    HW: 1K0 035 164 A
   Component: LOW NAR       H14 0043
   Revision: -----06S    Serial number: VWZ4Z6K3060260
   Coding: 0500040001
   VCID: 204FBE4A334E114FB9-8074
End-------------------------(Elapsed Time: 02:47)--------------------------
DrPeter
16.4905° S, 151.7375° W
The coolant fans will run when there is either a command from the ECM and the 15-power (key on power) is present or there is ONLY one of the following present:
- 15-power to the J293
- Fan (PWM) signal from the ECM.
So in other words, if for some reason, the ECM is waking up and then sending a PWM signal to the J293-Fan Controller and there is NO 15-power, the fans will run. Also if there is somehow 15-power to the J293-Fan Controller and no PWM signal from the ECM, the fans will run.
So it will be necessary to check and monitor at the J293 which is the case. Are you getting 15-Power to the J293 or are you getting a PWM to the J293 when you open the doors? We recommend to use the wiring diagrams in the Official Factory Repair manuals to identify the powers, ground and signal to the J293.
The fault code P150A would indicate the ECM maybe powering up for some reason. This fault code will set when the "Difference between engine off time and ECM after run time less than or greater than 8.0 seconds", according to the Official Factory Repair manuals.
I would have the passenger door controller, wiring, connections, etc. (see link below for the wiki page). This maybe related to your concern too.
014 - Defective
By the way, there is an ECM update for fault codes [P0106, P0507, P050A], ref: VW TSB: 2034012
Hope this helps,
drpeter
