Hello, new user here but I searched for an answer to my question before posting.
I am getting prepared (with tools and knowledge) to change the trans fluid and wanted to understand how to access the trans temperature via VCDS to properly check the fill level. This was a major reason to buy this SW.
-My issue is the Meas. Block 08 under Trans Module is “grayed out” so it cannot be selected and show me the Trans Temp.
-I tried accessing it with the ignition on, engine off; and ignition on, engine on
-My firmware is up to date, I am running VCDS 19.6.1
-Is this module/measuring block unavailable on the Atlas?
-Am I accessing it incorrectly?
Any suggestions would be appreciated.
(I tried to wrap my auto scan so if I did it wrong let me know)
Thanks, Chris
Thanks, Chris
Thursday,26,September,2019,17:04:09:44657
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: 1V2NR2CA4JC535519 License Plate:
Mileage: 39866km-24771mi Repair Order:
Chassis Type: CA-VW41 (3Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 22 2B 36 3C 42 44 47 4B
52 5F 69 6C 6D 75 A5 CA D6 D7
VIN: 1V2NR2CA4JC535519 Mileage: 39866km-24771miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (0-32-CDVC) Labels:. 03H-907-309-V1.clb
Part No SW: 03H 906 026 J HW: 03H 907 309 K
Component: VR6 3.6l FSI H21 6697
Revision: 52H21000
Coding: 012A003244740108B0000000000000000000000000000000
Shop #: WSC 26061 444 00000
ASAM Dataset: EV_ECM36FSI01103H906026J 001007
ROD: EV_ECM36FSI01103H906026J.rod
VCID: 2C0106063681D077461-8078
CAN Converter 01:
Address 02: Auto Trans (J217) Labels: 09G-927-749-V2.clb
Part No SW: 09G 927 158 A HW: 09G 927 158
Component: AISIN AQ8 206 3387
Coding: 0000000100000000000000000000000000000000
Shop #: WSC 09003 957 00200
ROD: EV_TCMAQ450031_VW37.rod
VCID: 313F177211A3BD9F757-8064
Part No SW: 5Q0 614 517 CF HW: 5Q0 614 517 AD
Component: ESC H25 0513
Revision: 00000000 Serial number: 50837000000495
Coding: 44FC6B8D84231A71C57C0301A2CC6922D62158A3C045967E38415058C2AA4200002F641C12141A118DDB45506CC8CF
ROD: EV_Brake1UDSContiMK100IPB_036_VW41.rod
VCID: 77ABE96ABF47A3AFFB3-8022
Part No SW: 3Q0 959 435 G HW: 3Q0 959 435 G
Component: VWKESSYMQB 037 0906
Revision: 00037000 Serial number: 0456461475
Coding: 1F20000723
VCID: 3E253C4ED0FD52E7F85-806A
Subsystem 1 - Part No SW: 3G0 962 243 B HW: 3G0 962 243 B
Component: GEB.F.Heckoef H17 0904
Serial number: 58253618
Address 08: Auto HVAC (J255) Labels:* None
Part No SW: 3CN 907 044 H HW: 3CN 907 044 H
Component: Climatronic H05 2009
Revision: 00001K01
Coding: 1602062620001C001104210C1210150C
Shop #: WSC 49096 002 1048576
ASAM Dataset: EV_ACClimaBHBVW416 002012
ROD: EV_ACClimaBHBVW416.rod
VCID: 44D14EA6BE113837AE1-8010
Fresh Air Blower Back:
Part No SW: 5Q0 937 085 BP HW: 5Q0 937 085 BG
Component: BCM MQBAB HNA H36 0253
Serial number: 7264007002ÿÿÿÿ
ROD: EV_BCMBOSCH_018.rod
VCID: 08499A96C2B9DC57829-805C
Subsystem 1 - Part No SW: 5Q0 955 555 HW: 5Q0 955 555
Component: RLHSS 046 0120
Serial number: S7Y17M09D18H12M42S50
Coding: 00382D
Subsystem 2 - Part No SW: 4M0 907 410 A HW: 4M0 907 410 A
Component: USHL5 H08 0050
Serial number: 0000009600363Z00BS02
Coding: 150000
Garage Door Opener Operating Unit:
Subsystem 3 - Part No SW: 3CN 959 719 HW: 3CN 959 719
Component: GTO BF H06 0007
Serial number: 8MW00128031700010104
Seat Backrest Fan 1 Front Left:
Subsystem 4 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Component: SysNameFanLin 014 0101
Serial number: ESE0334391
Seat Cushion Fan 1 Front Left:
Subsystem 5 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0817807
Seat Backrest Fan 1 Front Right:
Subsystem 6 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0334317
Seat Cushion Fan 1 Front Right:
Subsystem 7 - Part No SW: 3G0 963 345 HW: 3G0 963 345
Serial number: ESE0233342
204290 - Remote key 1
B1479 18 [009] - Current Too Low
Reset counter: 233
Mileage: 39502 km
Date: 2019.09.19
Time: 14:42:20
Part No SW: 5QA 919 298 C HW: 5QA 919 298 A
Component: PLA 3.0 12KH07 0045
Serial number: 000308417617168
Coding: 0271667951
ASAM Dataset: EV_EPHVA2CAU3700000 009037
ROD: EV_EPHVA2CAU3700000.rod
VCID: 50F972F67A69D4971A9-8004
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 5Q0 907 572 J HW: 3QF 907 572
Component: ACC BOSCH MQB H10 0654
Coding: 320007C959FFC728949C810530401600000000000000000000
ASAM Dataset: EV_ACCBOSCHVW416 002006
0836 - Databus
[FAULT_PREDICTIVE_ROUTEDATA_SIGNALERROR_RECEIVED]
Fault Frequency: 19
Reset counter: 9
Mileage: 38682 km
Date: 2019.09.14
Time: 13:54:58
Control Module temperature: 26 °C
Voltage terminal 15: 14.2 V
Velocity_vehicle_reference: 0.06 m/s
Longitudinal_acceleration_vehicle_reference: -0.01 m/s²
1236 - Databus
[FAULT_TIMEOUT_BV1_POSITION]
Reset counter: 1
Mileage: 36555 km
Date: 2019.08.19
Time: 15:30:45
Control Module temperature: 47 °C
Voltage terminal 15: 13.0 V
Velocity_vehicle_reference: 3.54 m/s
Longitudinal_acceleration_vehicle_reference: 1.21 m/s²
Part No SW: 3Q0 959 655 BN HW: 3Q0 959 655 BN
Component: Airbag VW21 006 0713
Revision: -------- Serial number: 003SUMGH2FDH
Coding: 8CCCDC00000000005000001A420800000065
ROD: EV_AirbaVW21TS6VW48X.rod
VCID: 0B43A59AD3CFB74FAFB-805E
Occupant Detection:
Component: Occ.Detection H13 0022
Serial number: IBH0000J170007SL6J0P
Coding: 303030
Subsystem 2 - Part No SW: ----------- HW: 454 000 908 17
Serial number: 35700000000B6471462D
Subsystem 3 - Part No SW: ----------- HW: 454 000 708 17
Serial number: 35800000000140D0C72C
Subsystem 4 - Part No SW: ----------- HW: 454 802 108 17
Serial number: 3510085280112000000-
Subsystem 5 - Part No SW: ----------- HW: 454 802 008 17
Serial number: 352003B660212000000+
Subsystem 6 - Part No SW: ----------- HW: 454 802 708 17
Serial number: 355009DEDC710000000$
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 454 802 708 17
Component: FrontSensor_P 304 0149
Serial number: 35600406DE910000000I
Part No SW: 5Q0 953 507 JF HW: 5Q0 953 549 D
Component: Lenks. Modul 004 0140
Revision: -------- Serial number: 13081704401254
Coding: 0C10
VCID: 03538DBAFB9FFF0FD7B-8056
Address 17: Instruments (J285) Labels:* None-SRI3
Part No SW: 3CN 920 891 A HW: 3CN 920 891 A
Component: KOMBI 405 3193
Coding: 0BA40F1DEF88CF0502886B0B5001000020000000
VCID: 42DD48BEA40536079CD-8016
Part No SW: 3Q0 907 530 G HW: 3Q0 907 530 C
Component: GW MQB High 518 5304
Serial number: 02081700840040
Coding: 0B0500347F087300FB0722581E0F00010001070000000000000000000000
ROD: EV_GatewNF.rod
VCID: 33331D7AEBBF8F8F07B-8066
Subsystem 2 - Part No SW: 5G0 959 442 R HW: 5G0 959 442 R Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 33170001907300021439
Coding: 36FFFF
Subsystem 3 - Part No SW: 5QA 915 181 D HW: 5QA 915 181 D
Serial number: 2595915204
Power Converter DC AC:
Subsystem 4 - Part No SW: 3CN 907 155 HW: 3CN 907 155
Component: U13DCAC H23 0860
Serial number: 0015254
Serial number: HA1-00008.08.17
Coding: 0301
VCID: 4ACD609E9C35EE4754D-801E
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 17000219244015
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD772D123FD9F357-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 5Q0 959 760 B HW: 5Q0 959 760 B
Component: Sitzmemory H08 0022
Serial number: Y0006QHP19502
Coding: 0010000000000500018280808080000000008100000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002021
VCID: 3C213646C6E140F7D61-8068
Address 3C: Lane Change (J1086) Labels:| 5Q0-907-686.clb
Part No SW: 5Q0 907 686 C HW: 5Q0 907 686 C
Component: HRE_Master H12 0080
Serial number: 0453930314
Coding: 02012103
ROD: EV_HREntryHella_VW27.rod
VCID: 3D273B42DDFB49FFE1F-8068
Lane Change Assistant 2:
Subsystem 1 - Part No SW: 5Q0 907 685 C HW: 5Q0 907 685 C
Component: HRE_Slave H12 0080
Serial number: 0454958793
Coding: 020121
Component: TSG FS 020 0041
Serial number: 310717A00808W2
Coding: 003F1B205200020000000000
VCID: 43D34DBABB1F3F0F97B-8016
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000006914293
Coding: 011000
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 P HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2051
Revision: 00000000 Serial number: 0002029239
Coding: 01010311004001
ROD: EV_SteerAssisVWBSMQBA_009_VW41.rod
VCID: 40D942B6AA0924178A9-8014
Address 47: Sound System (J525) Labels:| 5Q0-035-456.clb
Part No SW: 5Q0 035 456 A HW: 5Q0 035 456 A
Component: MIB2_lite_amp H40 0200
Revision: 00000001 Serial number: VWZ8Z1HMD00LZD5
Coding: 2214060002AAAFAA000000000000
ASAM Dataset: EV_AMPMst12C3Gen2ALPI 001001
ROD: EV_AMPMst12C3Gen2ALPI.rod
VCID: 2E050C0E009DA267685-807A
Address 4B: Multifunc. Module (J745) Labels:| 3Q0-907-338-V1.clb
Part No SW: 3Q0 907 338 HW: 3Q0 907 338
Component: FCM MQB Low 002 0286
Serial number: 18091700840716
Coding: 000000070100135200010000000000000000000000000000000000000000
VCID: 72BDD87ED425C687CCD-8026
Component: TSG BFS 020 0041
Serial number: 290717A00804E5
Coding: 003F13205E00020000000000
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000007068568
Coding: 091000
Part No SW: 3QF 035 876 A HW: 3QF 035 876 A
Component: MU-S-NS-US 851 0842
Coding: 021406020000000051220002001808001F0500E401200405CE
ROD: EV_MUStd4CDELP_VW37.rod
VCID: 48C95A9682391C57429-801C
Subsystem 1 - Part No SW: 5G6 919 605 D HW: 5G6 919 605 D
Component: ABT_Std-2_Nav H50 8130
Serial number: VWZ6ZJT2386164
Subsystem 2 - Part No SW: 3G0 919 866 BH HW: -----------
Component: NAR 2017/18 --- 0620
Part No SW: 5Q0 907 383 L HW: 5Q0 907 383 L
Component: Anhaenger H27 0260
Revision: 8C001004 Serial number: 0448510814
Coding: 0200000200000000
Part No SW: 5Q0 907 556 C HW: 5Q0 907 556
Component: Areaview 2 H13 0608
Serial number: C854707JG016829
Coding: 01140604A30F20000000400C
ASAM Dataset: EV_CamSysRVAV2ARCE2MQBAB 006017
ROD: EV_CamSysRVAV2ARCE2MQBAB.rod
VCID: 392F2F52C9D375DFCD7-806C
9591827 - Video Signal Line
B125C 13 [008] - Open Circuit
Fault Frequency: 44
Reset counter: 31
Mileage: 37024 km
Date: 2019.09.01
Time: 13:20:21
Part No SW: 5Q0 959 107 L HW: 5Q0 959 107 J
Component: HDSG-Modul H13 0261
Revision: -------- Serial number: ÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Coding: 0988
ROD: EV_DeckLidCONTIAU736_VW41.rod
VCID: 41DF47B2A1032D1F857-8014
Address 75: Telematics (J949) Labels:| 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 009 0570
Coding: 02140602C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
Part No SW: 3Q0 980 654 H HW: 3Q0 980 654 A
Component: MQB_B_MFK H08 0272
Serial number: 28071712P20369
Coding: 000401060001020100221355C150490084000E200120
ROD: EV_MFKBoschMQBB_001_VW27.rod
Part No SW: 4M0 907 594 J HW: 4M0 907 594
Component: SAD_STG_1 014 0005
Coding: 00804074160C
ROD: EV_SunRoofCONTIAU736_006.rod
Address D6: Light Ctrl Left 2 (A31) Labels: 7P5-941-591.clb
Part No SW: 7P5 941 591 AA HW: 7P5 941 591 A
Component: LED1L H06 0003
ROD: EV_LED_PLUS_L_KEBODAVW416_VW37.rod
VCID: 7BA3F55A836F87CF9FB-802E
Address D7: Light Ctrl Right 2 (A27) Labels: 7P5-941-591.clb
Component: LED1R H06 0003
ROD: EV_LED_PLUS_R_KEBODAVW416_VW41.rod
End----------(Elapsed Time: 02:07, VBatt start/end: 12.1V/12.1V)-----------
