Haldex not working 2003 audi tt
krisnordal
Canada
C?ID=377967
here is the scan
Wednesday,25,September,2019,14:15:11:14605
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Address 22: AWD Labels: 02D-900-554.LBL
Control Module Part Number: 02D 900 554 C
Component and/or Version: HALDEX LSC ECC 0010
Software Coding:
Work Shop Code:
VCID: 2019E015D3D073D7EA9-4B00
07-00 - Signal too Low
01155 - Clutch
04-10 - Mechanical Malfunction - Intermittent
79-10 - Please Check Fault Codes - Intermittent
vin TRUWT28N031******
the connector was clean and dry.
voltage at teh connector
2-3 11V
the grounding strap to the housing of the Haldex clutch good
infinite resistance from pin 2 to the grounding strap
2-4 0V with the parking brake on or off
2-7 600 ohms
2-8 600 ohms
7-8 60 ohms
Any suggestions?
South Molton, UK
That's an extract from an Auto-Scan, to help we'll ned to see the FULL UNEDITED Auto-Scan.
DrPeter
16.4905° S, 151.7375° W
I would have a look at the Measuring Value Block group [002], field (1) is current the Voltage supply value as seen by the controller. This value needs to reflect the current battery voltage (+/-1.0V) of the vehicle, if the voltage is correct, it sounds like there could be a concern with the J492-All Wheel Drive Control Module.
Also we have a Ross-Tech wiki page for the 00532 - Supply Voltage B+: Signal too Low
Hope this helps,
drpeter
krisnordal
Canada
C?ID=377967
here is the full scan
Friday,27,September,2019,08:42:46:14605
VIN: TRUWT28N031000517   License Plate:
Mileage: 118680km-73744mi   Repair Order:
Chassis Type: 8N (8N - Audi TT (1999 > 2007))
Scan: 01 02 03 08 15 17 22 35 37 45 55 56 76 77
VIN: TRUWT28N031000517   Mileage: 118680km-73744miles
   Part No: 8N0 906 018 BB
   Component: 1.8L R4/5VT     G   0002
   Coding: 07710
   Shop #: WSC 01236
   VCID: 72BDDA5D4DBCB147CCD-513C
   TRUWT28N031000517     AUZ5Z0B6125113
17840 - Secondary Air Injection Solenoid Valve (N112)
            P1432 - 35-10 - Open Circuit - Intermittent
18010 - Power Supply Terminal 30
            P1602 - 35-10 - Voltage too Low - Intermittent
Readiness: 0110 1101
Address 03: ABS Brakes        Labels: 8N0-907-379-MK60-A.lbl
   Part No: 8N0 907 379 H
   Component: ESP ALLRAD MK60     0101
   Coding: 0022544
   Shop #: WSC 01236 785 00200
   VCID: 41DF45913D9A5ADF857-513C
01324 - Control Module for All Wheel Drive (J492)
Address 08: Auto HVAC        Labels: 8N0-820-043.lbl
   Part No: 8N0 820 043 A
   Component: TT-KLIMAVOLLAUTOMAT D03
   Coding: 00140
   Shop #: WSC 01236
   VCID: 2809F835BBE08B97A29-2580
00792 - A/C Pressure Switch (F129)
            31-00 - Open or Short to Ground
Address 15: Airbags        Labels: 8N0-959-655.lbl
   Part No: 8N0 959 655 B
   Component: Airbag Front+Seite 6000
   Coding: 01103
   Shop #: WSC 01236
   VCID: 3FDB43694E6E2C2FF33-513C
01218 - Side Airbag Igniter; Passenger Side (N200)
            32-10 - Resistance Too High - Intermittent
Address 17: Instruments        Labels: 8Nx-920-xxx-17.lbl
   Part No: 8N1 920 930 S
   Component: KOMBI+WEGFAHRS. M73 D04
   Coding: 07344
   VCID: 41DF4591389A5ADF857-4B00
01039 - Coolant Temperature Sensor (G2)
            30-00 - Open or Short to Plus
01304 - Radio
            49-00 - No Communications
            37-00 - Faulty
Address 22: AWD        Labels: 02D-900-554.lbl
   Part No: 02D 900 554 C
   Component: HALDEX LSC  ECC     0010
01155 - Clutch
Address 35: Centr. Locks        Labels:. 8Nx-962-267.lbl
   Part No: 8N8 962 267 F
   Component: Central Lock/Alarm  D08
   Coding: 15884
   Shop #: WSC 01236
   VCID: 44D14C8527884FF7AE1-4EC8
01371 - Alarm triggered by Door Contact Switch; Driver's Side
            35-00 - -
01374 - Alarm triggered by Terminal 15
            35-00 - -
Address 55: Headlight Range        Labels: 4B0-907-357-AUT.lbl
   Part No: 4B0 907 357
   Component: LEUCHTWEITEREGLER  D004
   Coding: 00010
   Shop #: WSC 01236
   VCID: 6597B1018C7256FF59F-5184
End----(Elapsed Time: 02:53, VBatt start/end: 11.4V/11.3V. VIgn 11.3V)-----
I do have my work cut out for me!
I have ordered the SAIR selenoid and a new connector for the wheel sensor.
The A/C and the door and the air bag I have not started to look at yet.
NostraJackAss
Twisted pair for W-CAN might be dropped out from ABS to AWD controller due to gateway in cluster being FUBAR.
37-00 - Faulty
krisnordal
Canada
C?ID=377967
I suspect that is due to an aftermarket radio being installed.
krisnordal
Canada
C?ID=377967
the voltage at battery is 12.4 (on a trickle charger)
Measuring Value Block group [002], field (1) shows 12.3
measuring at connector it is 12.3 pin 2-3 on the harness side.
krisnordal
Canada
C?ID=377967
I also did an oil and filter change and the oil came out looking clean and the filter was not dirty.
