Wednesday,25,September,2019,10:36:54:15046
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
VIN: TMBFB6NJXGZ043405 License Plate:
Chassis Type: NJ-SK26 (6C0)
Scan: 01 03 08 09 10 13 15 17 19 44 5F
VIN: TMBFB6NJXGZ043405 Mileage: 16536km-10274miles
Address 01: Engine (J623-CHYB) Labels:. 04C-906-020-CHY.clb
Part No SW: 04C 906 057 A HW: 04C 907 309 J
Component: R3 1.0l MPI H24 8994
Revision: 31H24000
Coding: 01110072020405080000
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_ECM10MPI01104C906057A 001015
ROD: EV_ECM10MPI01104C906057A.rod
VCID: 2313EFFB7B56547FF7B-8076
4651 - Implausible Data Received from ESP Control Module
U0416 00 [039] - -
Mileage: 16536 km
Date: 2019.09.25
Time: 10:34:40
Engine speed: 792.50 /min
Normed load value: 25.9 %
Coolant temperature: 51 °C
Intake air temperature: 20 °C
Voltage terminal 30: 15.007 V
Mass flow through throttle valve: 7.0 kg/h
Engine operating condition: Idling
Readiness: 1110 0001
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08504620150709
Coding: 43F5247D492733C3091810690056C22492CC9008000DCAF98F00
Shop #: WSC 13765 031 00063
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
ROD: EV_Brake1ESP90iBOSCHPQ26.rod
VCID: 372B2BABDFCE28DF3B3-8062
1031 - Vacuum sensor
C10A3 01 [009] - Electrical Failure
[VacSent1Sensor]
Reset counter: 129
Mileage: 16536 km
Date: 2019.09.25
Time: 10:34:38
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6V0 820 045 A HW: 6V0 820 045 A
Component: AC Manuell H01 0108
Serial number: 1506201B-0048
Coding: 100000001000100000
ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 303910B73AA0FFE77A9-8064
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 D HW: 6C0 937 089
Component: BCM PQ26 Hi4R H08 0094
Serial number: 001378122834
Coding: 0F0008404205405303A04080B10703080000D800D6013500000000000000
Shop #: WSC 73430 790 00063
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_VW26.rod
VCID: 313F15B331AAF6EF757-8064
Subsystem 1 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150752CAB
Subsystem 2 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000032619022
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-283.clb
Part No SW: 5Q0 919 283 D HW: 5Q0 919 283
Component: PARKHILFE 3K H10 0048
Revision: -------- Serial number: 39231519501291
Coding: 0001050001
ASAM Dataset: EV_EPHVA14AU3700000 002022
ROD: EV_EPHVA14AU3700000_SK25.rod
VCID: 3A2D329FECDC35B7C4D-806E
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 13061503213006
Coding: 00000000FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001016
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 F HW: 6C0 959 655 F
Component: VW20Airbag73D 001 0360
Revision: -------- Serial number: 003RJ004578U
Coding: 88CCC000000000005C5400CF008800000000
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 363526AFD8C4D1D7205-8062
Subsystem 1 - Part No SW: ----------- HW: 410 822 306 15
Component: SideSensor_Df 151 0800
Serial number: 3575H00AF1B7F3F170E7
Subsystem 2 - Part No SW: ----------- HW: 410 822 306 15
Component: SideSensor_Pf 151 0800
Serial number: 3585H00A91B7F3F380F6
Subsystem 3 - Part No SW: ----------- HW: 442 150 907 15
Component: SideSensor_Dr 1CA 0148
Serial number: 3517A00B91B6A762D16N
Subsystem 4 - Part No SW: ----------- HW: 442 151 407 15
Component: SideSensor_Pr 1CA 0148
Serial number: 3527A00C11B0CBA43017
Part No SW: 6V0 920 940 A HW: 6V0 920 940 A
Component: KOMBI 205 1420
Coding: 272501002180260001887A011000000000000000
ROD: EV_DashBoardVDDMQBAB_SK25.rod
VCID: 353721A3C5C2DACF29F-8060
16777022 - Function Restricted due to Interrupted Communications
U1110 00 [009] - -
[BAP_NAV SD_0x32 keine Kommunikation]
Reset counter: 129
Mileage: 16536 km
Date: 2019.09.25
Time: 10:34:41
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H08 0094
Revision: -------- Serial number: 001378122834
Coding: 030100042F0A640000000000000000010001050000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_SK25.rod
VCID: 2615F6EF0864A157905-8072
Subsystem 1 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000D1449010715
Subsystem 2 - Part No SW: 6C0 915 181 A HW: 6C0 915 181 A
Component: J367-BDM H08 0223
Serial number: 22182A40572821386123
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C2 909 144 AG HW: 6C2 909 144 D
Component: EPS_TRW_ALow 322 3232
Serial number: CF7G1115
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
VCID: 6E85CECFE014A917285-803A
Part No SW: 5Q0 035 842 A HW: 5Q0 035 842 A
Component: MU-S-D-ER H24 0241
Serial number: SKZAZ2R8697921
Coding: 03620000BE00000011111204008808002F0100C60120010000
ROD: EV_MUStd4CTSAT_SK26.rod
VCID: 2D0709C32D92920F51F-8078
Subsystem 1 - Part No SW: 6V0 919 604 HW: 6V0 919 604
Component: ABTm_Std2 H41 1028
Serial number: SKZ8Z9RFF000MD
0012 - Digital Radio Antenna
B1103 11 [009] - Short to Ground
Reset counter: 129
Mileage: 16536 km
Date: 2019.09.25
Time: 10:34:38
Voltage terminal 30: 14.9 V
Status of digital radio antenna 1-Antenna current: 0 mA
Status of digital radio antenna 1-Connection between radio and antenna amplifier: Electrical OK
Status of digital radio antenna 1-Connection between antenna amplifier and antenna: Electrical OK
Status of digital radio antenna 1-DAB_Bit_Error_Rate_FIC: 0.000000
Status of digital radio antenna 1-DAB_Bit_Error_Rate_MSC: 0.000000
End----------(Elapsed Time: 00:47, VBatt start/end: 15.0V/14.9V)-----------
