Different values in the freeze frames (misleading)
AIB Wolfgang
Hello
Here is the auto-scan with the freeze frames in the ECU 02 transmission.
The stored speed is implausible.
Readings with ODIS showed other values.
Wednesday,25,September,2019,08:53:16:14348
VCDS Version: 19.6.1.0 (x64)  HEX-NET CB: 0.4513.4
Dealer/Shop Name: Auto-Intern GmbH Bochum Herner Str299
Workshop Code: 133 44831 200556
VIN: WVWZZZAUZGW573434   License Plate:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 5F
VIN: WVWZZZAUZGW573434   Mileage: 62321km-38724miles
Address 01: Engine (J623-CYVB)       Labels:. 04E-907-309-V1.clb
   Part No SW: 04E 906 027 GR    HW: 04E 907 309 BL
   Component: R4 1.2l TFS   H23 2394
   Revision: R4H23---
   Coding: 0125003223241D082000
   ASAM Dataset: EV_ECM12TFS01104E906027GR 001005
   ROD: EV_ECM12TFS01104E906027GR.rod
   VCID: 7AB83EC4FDE7559FD7-802E
   CAN Converter 01:
Readiness: 0110 0001
   Part No SW: 0CW 300 048 K    HW: 0AM 927 769 E
   Component: GSG DQ200G2_M H05 0610
   Revision: 00005005    Serial number: CU501512106034
   Shop #: WSC 17734 418 534600
   ROD: EV_TCMDQ200021_VW31.rod
   VCID: 44C4803CCFA3D36FFD-8010
10632 - No Communication with Gear Selector Module
          U0103 00 [040] - -
                    Mileage: 62316 km
                    Date: 2019.09.23
                    Time: 18:59:32
                    Engine speed: 14854.00 /min
                    Engine torque: -100 Nm
                    Vehicle speed: 82 km/h
                    Control Module temperature: 49 °C
                    CURRENT pressure: -9.5 bar
                    selected gear: GANG_5
                    Driving position: N
                    Accelerator position: 0.0 %
                    DTC memory status: 0
10633 - Selector Lever
          P0914 00 [040] - Electrical Malfunction
                    Mileage: 62316 km
                    Date: 2019.09.23
                    Time: 19:02:11
                    Engine speed: 5.50 /min
                    Vehicle speed: 89 km/h
                    Control Module temperature: 37 °C
                    CURRENT pressure: -10.0 bar
                    Clutch: primary stat: Driving
                    Driving position: N
                    DTC memory status: 256
          P1734 00 [040] - -
                    Mileage: 62316 km
                    Date: 2019.09.23
                    Time: 18:59:37
                    Engine speed: 12550.25 /min
                    Control Module temperature: 46 °C
                    Driving position: N
                    DTC memory status: 33792
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 63625000002805
   Coding: 03FA6AA11427916F077B060341C725C0562889E06082A4F31022F07AC202
   ROD: EV_Brake1UDSContiMK100IPB_034_VW37.rod
   VCID: 79BA21C8F8E15E87DE-802C
8388 - Databus
          [FCAN: GE_Fahrstufe_inv signal is invalid]
                    Reset counter: 122
                    Mileage: 62316 km
                    Date: 2019.09.23
                    Time: 19:02:11
32870 - Databus
          [IPB-BUS: Getriebe_11 / GE_Zielgang invalid]
                    Reset counter: 122
                    Mileage: 62316 km
                    Date: 2019.09.23
                    Time: 19:02:12
   Part No SW: 5G0 907 044 BD    HW: 5G0 907 044 BD
   Revision: 00001K08
   Coding: 08020004200100011005000000101002
   ROD: EV_ACClimaBHBVW37X_004_VW37.rod
   VCID: 6A980E848D47E51F27-803E
   Air quality sensor:
          B10CD 00 [008] - -
                    Fault Frequency: 8
                    Reset counter: 122
                    Mileage: 62233 km
                    Date: 2019.09.19
                    Time: 09:13:17
                    Voltage terminal 30: 8.9 V
                    CAN input signal(s) status-Energy management deactivation stage: Deactivation stage 2
                    CAN input signal(s) status-Back-up light: OFF
   Part No SW: 5Q0 937 086 AK    HW: 5Q0 937 086 AK
   Revision: --------    Serial number: 86580901161711
   Coding: 00001846C24102FB4BE44000001C07081000000000000000000000000000
   ROD: EV_BCMBOSCH_015.rod
   VCID: 034643208A2D145784-8056
   Subsystem 1 - Part No SW: 517 955 119     HW: 517 955 119
   Component: WWS    151209  042 0596
   Serial number:         160109220101
   Component: RLHS  037 0059
   Serial number: S5Y16M01D22H07M31S48
   Coding: 90A8DD
558356 - Databus
                    Fault Frequency: 12
                    Reset counter: 122
                    Mileage: 62316 km
                    Date: 2019.09.23
                    Time: 16:47:05
   Part No SW: 5Q0 919 298 K    HW: 5Q0 919 298
   Component: PARKHILFE PLA H12 0054
   Revision: --------    Serial number: 39491533701538
   Coding: 0031061051
   ASAM Dataset: EV_EPHVA2CAU3700000 003021
   ROD: EV_EPHVA2CAU3700000_003.rod
   VCID: 47DE9730FE95F87718-8012
8 Faults Found:
12664864 - Databus
          [Steuergerät für BCM - Dimmung_01 - kein Signal/keine Kommunikation]
                    Reset counter: 120
                    Mileage: 62312 km
                    Date: 2019.09.23
                    Time: 14:31:25
12666389 - Databus
          [Diagnose-Interface für Datenbus-J533 - Gateway_72 - kein Signal/keine Kommunikation]
                    Reset counter: 120
                    Mileage: 62312 km
                    Date: 2019.09.23
                    Time: 14:31:26
12666390 - Databus
          [Diagnose-Interface für Datenbus-J533 - Gateway_79 - kein Signal/keine Kommunikation]
                    Reset counter: 120
                    Mileage: 62312 km
                    Date: 2019.09.23
                    Time: 14:31:23
13637632 - Databus
          [Getriebe - Getriebe_11.GE_Fahrstufe - Fehlerspeicher auslesen]
                    Fault Frequency: 9
                    Reset counter: 122
                    Mileage: 62316 km
                    Date: 2019.09.23
                    Time: 16:46:55
12665088 - Databus
          [Bodycomputer 2 / Zentralmodul Komfortsystem / ZKE - Klemmen_Status_01 - kein Signal/keine Kommunikation]
                    Reset counter: 120
                    Mileage: 62312 km
                    Date: 2019.09.23
                    Time: 14:31:26
13638913 - Databus
          [Steuergerät für Lenkhilfe-J500 - LH_EPS_03 - kein Signal/keine Kommunikation]
                    Reset counter: 113
                    Mileage: 62238 km
                    Date: 2019.09.19
                    Time: 12:09:38
12648466 - Databus
          [Motorsteuergerät - Motor_14 - kein Signal/keine Kommunikation]
                    Reset counter: 120
                    Mileage: 62312 km
                    Date: 2019.09.23
                    Time: 14:31:26
13639168 - Databus
          [Steuergerät für Rear Cross Traffic Alert - RCTA_01 - kein Signal / keine Kommunikation]
                    Reset counter: 120
                    Mileage: 62312 km
                    Date: 2019.09.23
                    Time: 14:31:25
   Part No SW: 5Q0 907 572 F    HW: 5Q0 907 572 F
   Component: ACC Bosch MQB H05 0400
   Serial number: 08121504402387
   Coding: 00001100FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001016
   VCID: 3A38FEC4BD67959F97-806E
1051 - Databus
          [FAULT_CIS_GPOS_FAIL]
                    Fault Frequency: 9
                    Reset counter: 122
                    Mileage: 62316 km
                    Date: 2019.09.23
                    Time: 16:46:55
                    Control Module temperature: 22 °C
                    Voltage terminal 15: 11.8 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/s²
1052 - Databus
          [FAULT_CIS_GPOS_INIT]
                    Fault Frequency: 14
                    Reset counter: 122
                    Mileage: 62315 km
                    Date: 2019.09.23
                    Time: 15:49:49
                    Control Module temperature: 30 °C
                    Voltage terminal 15: 14.1 V
                    Vehicle speed: 15.64 m/s
                    Acceleration: -0.04 m/s²
0077 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
          [FAULT_VMON_VZ_LOW]
                    Reset counter: 112
                    Mileage: 62233 km
                    Date: 2019.09.19
                    Time: 09:32:14
                    Control Module temperature: 38 °C
                    Voltage terminal 15: 8.9 V
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Component: AirbagVW20    015 0388
   Serial number: 003F6R1DMFBR
   Coding: 98CCC000000000005C5400CF004800000065
   ROD: EV_AirbaVW20SMEVW37X.rod
   VCID: 41CA8928D0B1C647D6-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 001 701 16
   Serial number: 35767000000E0590091N
   Subsystem 2 - Part No SW: -----------    HW: 480 001 701 16
   Serial number: 35867000000C748CF81A
   Subsystem 3 - Part No SW: -----------    HW: 480 401 601 16
   Serial number: 3516502AB1E9F105038D
   Subsystem 4 - Part No SW: -----------    HW: 480 401 101 16
   Serial number: 35265029D1E9F10612CK
   Subsystem 5 - Part No SW: -----------    HW: 480 402 001 16
   Serial number: 3556502A91E9F101C19M
   Part No SW: 5Q0 953 507 GH    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 12011604220391
   Coding: 0410
   ASAM Dataset: EV_SMLSKLOMQB 020001
   VCID: 0248462495371D5F8F-8056
   Part No SW: 517 920 740 A    HW: 517 920 740 A
   Component: KOMBI         202 6420
   Coding: 07A402082390000801886A011400000000000000
   VCID: 1464707CFF4383EF2D-8040
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004406269
   Coding: 030100043F085700FB0002481C0F00010001050000000000000000000000
   ROD: EV_GatewLear_013.rod
   Subsystem 2 - Part No SW: 5G0 959 442 J    HW: 5G0 959 442 J  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H17 0103
   Serial number: 29160000034600096016
   Coding: 29FFFF
   Serial number: 4537048903
131594 - Parallel Parking Assistance Control Module
          U104E 00 [008] - No communication
          [Timeout Knoten 0x0A / 76 - Steuergerät für Parklenkassistent]
                    Reset counter: 120
                    Mileage: 62312 km
                    Date: 2019.09.23
                    Time: 14:31:26
                    Supply voltage: Terminal 30: 14.0 V
                    Terminal 15: On
66052 - Infotainment CAN Bus (SAE Bus E)
          U0065 00 [008] - Performance
          [Globaler Timeout CAN-Infotainment]
                    Reset counter: 121
                    Mileage: 62312 km
                    Date: 2019.09.23
                    Time: 15:32:39
                    Supply voltage: Terminal 30: 12.0 V
                    Terminal 15: OFF
65793 - Powertrain Databus (VAG Single-Wire Mode) (SAE  L Shorted H)
          U0009 00 [008] - -
          [Eindrahtfehler CAN-Antrieb]
                    Fault Frequency: 108
                    Reset counter: 122
                    Mileage: 62316 km
                    Date: 2019.09.23
                    Time: 16:46:55
                    Supply voltage: Terminal 30: 11.7 V
                    Terminal 15: On
   Serial number: 231115BKM00329
   Coding: 00310320D000040000001000
   VCID: 43C68320CAADD457C4-8016
   Serial number: 00000000000008521939
   Coding: 110000
589829 - Window Regulator; Rear Driver side
          B131F F5 [008] - Supply Voltage too Low
                    Reset counter: 121
   Part No SW: 5Q0 909 143 M    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2041
   Revision: 00000000    Serial number: 0000566424
   Coding: 01010010005000
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008028
   ROD: EV_SteerAssisVWBSMQBA_008_VW37.rod
   VCID: 3D32F5D8AC49A2A7B2-8068
16648 - Supply voltage
          [Dauerhafte Unterspannung]
                    Reset counter: 122
                    Mileage: 62233 km
                    Date: 2019.09.19
                    Time: 09:03:52
                    Write only channel
   Serial number: 211115BKK14511
   Coding: 00310120DE00040000801000
   VCID: 42C88624D5B7DD5FCF-8016
   Serial number: 00000000000008621358
   Coding: 090000
589845 - Window Regulator; Front Passenger side
          B1320 F5 [008] - Supply Voltage too Low
                    Reset counter: 121
   Part No SW: 3Q0 035 846     HW: 3Q0 035 846
   Component: MU-S-N-ER     820 0624
   Coding: 02730901FF00000051110001000808001F01008401200100CF
   ROD: EV_MUStd4CDELP_VW37.rod
   VCID: 6E900294B1AF093F7B-803A
   Subsystem 1 - Part No SW: 3G0 919 605 D    HW: 3G0 919 605 D
   Component: ABT_Std-2_Nav  H43 4063
   Serial number: VWZ6Z9S0190448
   Subsystem 2 - Part No SW: 3G0 919 866 M    HW: -----------
   Component: ECE 2016  --- 0521
6691 - Local Data Bus
          U10BA 00 [008] - No Communication
          [Sub-Bus keine Kommunikation]
                    Fault Frequency: 16
                    Reset counter: 122
                    Mileage: 62233 km
                    Date: 2019.09.19
                    Time: 09:34:07
                    Voltage terminal 30: 14.4 V
                    Network diagnosis-Status: not enabled
End------(Elapsed Time: 01:28, VBatt start/end: 13.2V/13.2V, udsna)--------
Identification
               Adresse 02: Getriebe
   Steuergerät-Teilenummer: 0CW 300 048 K
  Bauteil und/oder Version: GSG DQ200G2_M H05 0610
                 Codierung: 0014
            Betriebsnummer: WSC 17734
Erweiterte Identifikation/FAZIT
     Seriennummer: CU501512106034
     Identifikation: CU5-072
     Revision: 00005005
     Datum: 10.12.15
     Herstellernummer: 0000
     Prüfstandsnummer: 6034
Flash Status
     Programmierungs Versuche(Anwendung): 1/1/3
     Flash Datum: 15.12.10
Sonstiges
     Hardwarenummer: 0AM 927 769 E
     Systemkurzzeichen: J743
     Ausstattung/PR-Code: FFFFFFFFFFFFFFFFFFFFFFFF
     ASAM Datensatz: EV_TCMDQ200021
     ASAM Datensatz Revision: 001001
Fahrzeug Informationen
     Fahrzeug-Ident.-Nr.: WVWZZZAUZGW573434
VCDS Info:
       Labeldatei: DRV\0CW-927-769.clb
readings with ODIS:
ECU: 002- Getriebeelektronik
LL_TransContrModulUDS (EV_TCMDQ200021 / 001037)
Identification
Systembezeichnung                        GSG DQ200G2_M
Softwareversion                             0610
Hardwareversion                            H05
VW/AUDI Teilenummer                   0CW300048K
Hardware-Teilenummer                  0AM927769E
Codierung                                      0014
ASAM/ODX Datei Kennzeichnung      EV_TCMDQ200021
ASAM/ODX Datei Version                 001001
Ereignisspeicher (3)
U0103 Lost Communication with Gear Shift Module
       DTC Freeze Frame
       Datum                                     18:59:32 - 23.09.2019
       Kilometerstand                         62.316 km
       Priorität                                   0   ( passiv/sporadisch)
       Verlernzähler                           255
       Motordrehzahl                          698,00 1/min
       Motordrehmoment                    -4Nm
       Fahrzeuggeschwindigkeit           0 km/h
       Steuergerätetemperatur            42° C
       IST-Druck                                 34,5 bar
Vehicle is repaired, it's all about the values in the Freeze Frames. Thank you
