Hi, the central driver instrument display LCD has failed after intermittent failures for the last year or so. When the display fails the left hand control buttons on the multi-function steering wheel also stop working but the right hand volume button still operates correctly. Given the dual failures it would suggest a common failure point rather than the LCD or multi-function buttons individually but I could not trace a common point but it may just be a coincident.
I have done the basic checking to see if any loose connectors, failed fuse etc but couldn't find anything. Running the autoscan didn't identify anything relevant to this failure to me but this is the first time I have used VCDS (plenty other failures to check which I will work through!)
Any suggestions on what to investigate further would be appreciated on the display or other faults identified.
thanks
Greg
thanks
Greg
Sunday,15,September,2019,11:21:25:60591
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x86(VirtualBox)
VCDS Version 19.6.1.0 HEX-V2 CB: 0.4508.4
VIN: WAUZZZ4L7BD014153 License Plate:
Mileage: 158830km-98692mi Repair Order:
Chassis Type: 4L-AU56 (4F0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 34 3D 42 46 47 4F 52 55 56
5F 62 6C 6D 6F 72 76
VIN: WAUZZZ4L7BD014153 Mileage: 158830km-98692miles
3D-Special Function -- Status: OK 0000
Address 01: Engine (J623-CJGA) Labels:. 059-907-401-V2.clb
Part No SW: 4L1 910 401 H HW: 4L0 907 401 C
Component: 3.0TDI EDC17 H37 0003
Revision: 53H37--- Serial number:
Coding: 2A2A4012A52701020000
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_ECM30TDI0114L1910401H 001008
ROD: EV_ECM30TDI0114L1910401H.rod
VCID: 28080D0D627DD1B7A29-807D
4629 - ECM Power Relay Load Circuit
P068A 00 [032] - Opens Too Early
Engine speed: 0.00 /min
Coolant temperature: -40 °C
Intake air temperature: -40 °C
Ambient air pressure: 0 mbar
Voltage terminal 30: 0.000 V
Unlearning counter according OBD: 32
Starter control: Interlock- or P/N-signal-Bits 0-7: 0
Engine status: COENG_STANDBY
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 0
5242 - Fuel Pressure Sensor (G247)
P0191 00 [096] - Implausible Signal
Mileage: 155132 km
Date: 2011.01.24
Time: 10:19:04
Coolant temperature: 70 °C
Intake air temperature: 27 °C
Voltage terminal 30: 12.160 V
Unlearning counter according OBD: 13
Engine status: COENG_FINISH
Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 5
Address 02: Auto Trans (J217) Labels:| 0C8-927-750.clb
Part No SW: 0C8 927 750 AE HW: 0C8 927 750 AE
Component: AL1000 AISIN 001 1815
Coding: 001578
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_001_AU56.rod
VCID: 6FBA26118713C68F233-803B
Address 03: ABS Brakes Labels:. 4L0-910-517-V2.clb
Part No SW: 4L0 910 517 M HW: 4L0 614 517 L
Component: ESP ALLRAD MK25E1 0020
Revision: 00H02001
Coding: 2200689
VCID: 3430E97DA235A5571E1-8061
Reset counter: 36
Mileage: 158091 km
Date: 2011.04.25
Time: 09:03:43
Count: 128
Count: 2885
Count: 297
Count: 32000
Part No SW: 4F0 910 852 B HW: 4F0 905 852 F
Component: FBSAUDIC6 ELV H05 0130
Revision: 00H05000 Serial number: 10602901673760
Coding: 0000211
VCID: 2516043919EFCCDF99F-8071
Subsystem 1 - Part No: 4F0 910 132 E
Component: FBSAUDIC6 EZS H03 0020
Subsystem 2 - Part No: 4F0 910 220 D
Component: FBSAUDIC6 IDG H01 0054
Address 08: Auto HVAC (J255) Labels: None
Part No SW: 4L0 910 043 D HW: 4L0 820 043 AE
Component: KLIMA 4 ZONEN H13 0060
Revision: 00---022 Serial number: 00000000251951
Coding: 01009416
VCID: 2516043915EFCCDF99F-8071
Part No SW: 4F0 910 279 AH HW: 4F0 907 279 D
Component: ILM Fahrer H29 0390
Coding: 0033121
VCID: 6FBA26118B93C68F233-803B
Subsystem 1 - Part No: 4L2 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0100
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 8K0 910 557 Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 D HW: 4L0 959 655 C
Component: 71 AIRBAG AUDI8RH43 0230
Revision: 04H43000 Serial number: 00399D0767MX
Coding: 0014129
VCID: 2E04FB154C198F87685-807B
Subsystem 1 - Serial number: 6332QSME3B732F10H
Subsystem 2 - Serial number: 6342QSME3C6E1226M
Subsystem 3 - Serial number: 6352QSME39731F16M
Subsystem 4 - Serial number: 6362QSME3F6E0F34
Subsystem 5 - Serial number: 63734SME32652904W
Subsystem 6 - Serial number: 63834SME1D671732%
Part No SW: 4F0 910 549 A HW: 4F0 953 549 D
Component: J0527 0530
Revision: 00H05000 Serial number: 90025102740169
Coding: 0102142
VCID: 270A0E3163E3DECFAB3-8073
Component: E0221 H02 0100
Address 17: Instruments (J285) Labels:. 4L0-920-xxx-17.clb
Part No SW: 4L0 920 983 T HW: 4L0 920 983 T
Component: KOMBIINSTR. H10 0209
Revision: 00000000 Serial number: FLN01R4AA
Coding: 2F56630400012600010400
VCID: 43D2BAA1FB9B12EF97B-8017
Address 18: Aux. Heat Labels: 4L0-910-105.lbl
Part No SW: 4L0 910 105 HW: 4L0 815 071 G
Component: Heizgeraet H09 0140
Revision: 0000000C Serial number: 00000009021078
Coding: 0000101
VCID: 6098552D464D69F7AA9-8035
01412 - Glow-Plug with Flame Monitoring (Q8)
02251 - Heater Unit Locked
Address 19: CAN Gateway (J533) Labels:. 4F0-907-468.clb
Part No SW: 4F0 907 468 P HW: 4F0 907 468 F
Component: GW-BEM 4CAN-M H06 0047
Revision: LB200032 Serial number: 3200L10912807B
Coding: 00CF07
VCID: 3C20C15D86656D17D61-8069
Subsystem 1 - Part No SW: 8K0 915 181 D HW: 8K0 915 181 D
Component: J367-BDM H07 0125
Serial number: 00000000002790070918
Subsystem 2 - Part No SW: 8K0 959 663 HW: 8K0 959 663
Component: J532_DCDCStab H17 0042
Serial number: 10274000634011200181
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 H HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7870
Revision: --H03001 Serial number: 15.1528-0123.2
Coding: 0015510
VCID: 2F3AE6114B13868F633-807B
01577 - Turn-Off due to Over-Temp
Fault Status: 00100001
Fault Frequency: 49
Reset counter: 38
Mileage: 149570 km
Date: 2010.04.21
Time: 00:40:30
Error Code: 68
01772 - Signal from Level Control Pressure Sensor (G291)
Fault Frequency: 88
Reset counter: 38
Mileage: 150616 km
Date: 2010.05.26
Time: 11:09:33
Error Code: 78
Reset counter: 30
Error Code: 13
Reset counter: 30
Error Code: 64
Reset counter: 30
Mileage: 158091 km
Date: 2011.04.25
Time: 09:06:09
Error Code: 112
Address 3D: Special Function Labels: 8K0-907-440.clb
Part No SW: 8K0 907 440 HW: 8K0 907 440
Component: STS H04 0040
Revision: S0H04000 Serial number: 00000000025864
Coding: 01010101000000000000000202
VCID: 6B823201BF8B3AAF0FB-803F
Address 42: Door Elect, Driver (J386) Labels:. 4F0-959-793.clb
Part No SW: 4F0 959 793 T HW: 8K0 959 793 M
Component: TSG FA H12 0361
Revision: Serial number: 0008000055635
Coding: 011F06205061440004
VCID: 48C8AD8DC2BD31B7429-801D
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 H HW: 4L0 907 289 H
Component: Komfortgeraet H10 0110
Revision: 0110 --- Serial number: 01361960250000
Coding: 3809531
VCID: 3536D479A94FBC5F29F-8061
Subsystem 2 - Part No: 4F0 910 177
Component: Innenraumueberw.H01 0020
Part No SW: 4L0 035 223 G HW: 4L0 035 223 G
Component: BOSE G3 Q7 H03 0040
Revision: CH003000 Serial number: 00000000007643
VCID: 2614033568E9C7C7905-8073
03405 - Bass Loudspeaker
Fault Status: 00111011
Reset counter: 39
Part No SW: 4F0 910 280 HW: 4F0 907 280 E
Component: ILM Beifahrer H14 0100
Revision: Serial number: 00000000186477
Coding: 0011101
VCID: 5EE46BD57C395F07985-800B
Address 52: Door Elect, Pass. (J387) Labels:. 4F0-959-792.clb
Part No SW: 4F0 959 792 T HW: 8K0 959 792 M
Component: TSG BF H12 0361
Revision: Serial number: 0008000056665
VCID: 47CAAEB1CFA33ECF4B3-8013
Address 55: Headlight Range Labels: 8P0-907-357.lbl
Part No: 8P0 907 357 H
Component: Dynamische LWR H01 0010
Coding: 0000008
VCID: 3FDAB6519B73760FF33-806B
Part No SW: 4G0 035 053 HW: 4G0 035 053
Component: Radio U Basic H52 0051
Revision: AB001007 Serial number: 496J10A7570236
Coding: 010003010000000000
VCID: 5BE262C1632B4A2FFFB-800F
Part No SW: 4L0 035 670 B HW: 4L0 035 670 A
Component: H-BNT-EU H50 0143
Revision: -------- Serial number: 474JB0A7538795
Coding: 010101060004D3EF01000315EF6300030000
VCID: 270A0E316FE3DECFAB3-8073
Subsystem 1 - Part No: 8R0 060 884 R
Component: EUR 2010 1107
Subsystem 2 - Part No SW: 8F0 919 604 HW: 8F0 919 604
Component: DU7 High H43 0084
Serial number: 9466JX0A0406714
Subsystem 3 - Part No SW: 4L0 910 609 HW: 4L0 919 611 B
Component: E0380 Bedient H05 0060
Serial number: 00000001695629
Component: CD-Database 1886
Address 62: Door, Rear Left (J388) Labels:. 4F0-959-795.clb
Part No SW: 4F0 959 795 P HW: 4F0 959 795 P
Component: TSG HL H11 0361
Revision: Serial number: 0008000055213
Coding: 010E06204061230004
VCID: 46D4A3B5C8A927C7B05-8013
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 B HW: 4L0 907 441 B
Component: J772__Rearview 0030
Revision: --H04--- Serial number: 525PA8-J0941H0
Coding: 1021001
Address 6D: Trunk Elect. Labels: None
Part No SW: 4L0 910 945 HW: 4L0 827 851 E
Component: ValeoHeckdeckel H55 0500
Revision: --H55001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
VCID: 6C80311DBA853D97061-8039
Subsystem 3 - Serial number: RD08.10.10--H55001001B0002ÿ
Subsystem 4 - Serial number: 1B0002ÿ
Reset counter: 30
Mileage: 158091 km
Date: 2011.04.25
Time: 09:01:56
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 HW: 4L0 907 290
Component: ILM HINTEN 2 H05 0070
Revision: AAH05061 Serial number: 108810990-----
Coding: 0000001
VCID: 65964439596F0CDF59F-8031
Address 72: Door, Rear Right (J389) Labels:. 4F0-959-795.clb
Component: TSG HR H11 0361
Revision: Serial number: 0008000055216
Part No SW: 4L0 910 283 E HW: 4L0 919 283 E
Component: Parkhilfe 8-Kan H03 0100
Revision: 00H03000 Serial number: 37331027404129
Coding: 0221066
VCID: 2C00F11D7A05FD97461-8079
End----------(Elapsed Time: 01:54, VBatt start/end: 14.6V/14.7V)-----------
