hi,im a new customer,and even newer at VW's .Swapped my mk iv 's tiptronic out for The tdi 5 speed and need to recode engine to a manual .car runs and idles like a new one ,only no power.must get it road worthy,any help would put someone forever in my good graces.
Wednesday,25,September,2019,16:42:46:47328
VCDS Version: 19.6.1.0 (x64) HEX-V2 CB: 0.4508.4
Chassis Type: 9M - VW Jetta IV (1998 > 2014)
Scan: 01 02 03 08 09 15 16 17 19 22 29 35 36 37 39 46 47 55 56 57
75 76
Mileage: 375900km-233573miles
Address 01: Engine Labels: 06A-906-032-AWD.lbl
Part No: 06A 906 032 CM
Component: 1.8l 5V 110kW TLG V005
Coding: 06530
Shop #: WSC 09252
VCID: 6B83C75C2A9E7E5F0FB-5160
16622 - Manifold Pressure / Boost Sensor (G31)
P0238 - 35-00 - Signal too High
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 35-00 - Implausible Signal
17953 - Throttle Valve Controller
P1545 - 35-10 - Malfunction - Intermittent
17950 - Angle Sensor 1 for Throttle Actuator (G187)
P1542 - 35-10 - Implausible Signal - Intermittent
17579 - Angle Sensor 2 for Throttle Actuator (G188) Implausible Signal
P1171 - 35-10 - - Intermittent
16486 - Mass Air Flow Sensor (G70)
P0102 - 35-00 - Signal too Low
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01M-927-733.lbl
Part No: 01M 927 733 FB
Component: AG4 Getriebe 01M 4794
Coding: 00000
VCID: 75B7E1247CDAB8AFE9F-0962
11 Faults Found:
00258 - Solenoid Valve 1 (N88)
36-00 - Open Circuit
00260 - Solenoid Valve 2 (N89)
00262 - Solenoid Valve 3 (N90)
00264 - Solenoid Valve 4 (N91)
00266 - Solenoid Valve 5 (N92)
00270 - Solenoid Valve 7 (N94)
00293 - Multi-function Switch (F125)
25-00 - Unknown Switch Condition
00281 - Vehicle Speed Sensor (G68)
03-00 - No Signal
00300 - Transmission Fluid Temp. Sensor (G93)
34-10 - No Elaboration Available - Intermittent
01236 - Shift Selector Locking Solenoid (N110)
31-00 - Open or Short to Ground
00297 - Gearbox Speed Sensor (G38)
03-00 - No Signal
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 AF
Component: ASR 20 IE CAN 0001
Coding: 13204
Shop #: WSC 00066
VCID: 75B7E1247CDAB8AFE9F-4B3C
79-00 - Please Check Fault Codes
00283 - ABS Wheel Speed Sensor; Front Left (G47)
35-10 - - - Intermittent
Part No: 6Q0 909 605 A
Component: 15 AIRBAG VW5 02 0004
Coding: 12597
Shop #: WSC 00066
VCID: 353721243C5AF8AF29F-4B3C
00-10 - - - Intermittent
Address 17: Instruments Labels: 1J0-920-xx0-17.lbl
Part No: 1J0 920 900 K
Component: A4-KOMBIINSTR. VDO V60
Coding: 07242
Shop #: WSC 09252
VCID: 2A0D0258E5E4A757B4D-5160
Subsystem 1 - Part No: IMMO
Component: IDENTNR: VWZ7Z0Y2477878
IMMO-IDENTNR: VWZ7Z0Y2477878
00771 - Fuel Level Sensor (G)
Part No: 6N0 909 901
Coding: 00007
Shop #: WSC 00066
VCID: 70B9D03003B89D873A9-5160
Address 46: Central Conv. Labels: 1J0-959-799.lbl
Part No: 1J0 959 799 AJ
Component: 61 Zentral-SG Komf. 0001
Coding: 04096
Shop #: WSC 00066
VCID: 065596E8113CA337F05-4B1E
Subsystem 1 - Part No: 1J1959801C
Component: 61 Tõrsteuerger. FS0002F
Subsystem 2 - Part No: 1J1959802D
Component: 61 Tõrsteuerger. BF0002r
Subsystem 3 - Part No: 1J4959811C
Component: 61 Tõrsteuerger. HL0002r
Subsystem 4 - Part No: 1J4959812C
Component: 61 Tõrsteuerger. HR0002r
13 Faults Found:
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
01329 - Convenience System Data Bus in Emergency Mode
52-10 - Supply Voltage Too High - Intermittent
00912 - Window Regulator Switch; Front Left (E40)
35-00 - -
Address 56: Radio Labels: 1J0-035-18x-56.lbl
Part No: 1J0 035 180 B
Component: Radio DE2 0005
Coding: 00401
Shop #: WSC 05311
VCID: 1E65DE88A9AC5BF7D85-51CE
00853 - Loudspeaker(s); Rear
36-10 - Open Circuit - Intermittent
00856 - Radio Antenna
End----------(Elapsed Time: 05:56, VBatt start/end: 12.5V/12.3V)-----------
