- Mar 29, 2014
- 263
- 302
- Wilkes-Barre, PA
- C?ID=7573
Got a 2004 Passat 4 motion 1.8T AWM
ABS lost all communication common problem with these.
Never was a any problem before this as I have worked on car for years.
Reinstall same ABS module after sending out for rebuild and I am getting these codes they will not clear also have the yellow triangle with (!) on in dash.
Before all I had was beeping and ABS light and Brake light on. (Due to no communication with ABS module)
Just don't know if it's car or screw up on rebuild?
Tuesday,24,September,2019,19:04:33:45379
VCDS Version: 19.6.1.0 HEX-V2 CB: 0.4508.4
VIN: WVWPD63B34P321241 License Plate:
Mileage: 339480km-210943mi Repair Order: ron 04 passat
Chassis Type: 3B (3B - VW Passat B5 (1997 > 2005))
VIN: WVWPD63B34P321241 Mileage: 339480km-210943miles
Address 01: Engine Labels: 06B-906-018-AWM.clb
Part No SW: 4B0 906 018 DQ HW: 8E0 909 018 A
Component: 1.8L R4/5VT G 0060
Revision: 00000000 Serial number: VWZ7Z0D9306446
Coding: 0016751
Shop #: WSC 06436 444 84396
VCID: 73B3DEA8C7AE3CAFC7B-5160
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller
Readiness: 0110 1101
Address 02: Auto Trans Labels: 01V-927-156.lbl
Part No: 3B0 927 156 AQ
Component: AG5 01V 1.8l5VT USA 1213
Coding: 0001102
Shop #: WSC 00028 028 00001
VCID: 75B7E0B0C9DA229FE9F-5160
Address 03: ABS Brakes Labels: 4B0-614-517.lbl
Part No: 4B0 614 517 H
Component: ABS/ESP allrad 3428
Coding: 04277
Shop #: WSC 00028
VCID: 2615F7FC41FC1907905-51F2
18031 - Powertrain Data Bus
P1623 - 35-00 - No Communication
Part No: 1C0 909 605 C
Component: 09 AIRBAG VW61 04 0003
Coding: 12345
Shop #: WSC 00028
VCID: 2411EDF437C0EB178E1-513C
Address 17: Instruments Labels: 3B0-920-xx5-17.lbl
Part No: 3B0 920 929 B
Component: KOMBI+WEGFAHRSP VDO V04
Coding: 15235
VCID: 2615F7FC41FC1907905-513C
WVWPD63B34P321241 VWZ7Z0D9306446
Part No: 6N0 909 901
Coding: 00006
Shop #: WSC 00028
VCID: 70B9D1A4B3B807B73A9-513C
Part No: 1C0 959 799 C
Component: 08 Komfortgerát HLO 0003
Coding: 00258
Shop #: WSC 00028
VCID: 372B2AB89656908F3B3-4B1E
Subsystem 1 - Part No: 1C1959801
Component: 08 Tõrsteuer.FS KLO 0202
Subsystem 2 - Part No: 1C1959802
Component: 08 Tõrsteuer.BF KLO 0202
Subsystem 3 - Part No: 1C0959811
Component: 08 Tõrsteuer.HL KLO 0202
Subsystem 4 - Part No: 1C0959812
Component: 08 Tõrsteuer.HR KLO 0202
Address 56: Radio Labels: 3B7-035-1xx-56.lbl
Part No: 3B7 035 180 G
Component: Radio PM6 0016
Coding: 00031
Shop #: WSC 00028
End(Elapsed Time: 04:58, VBatt start/end: 12.0V/12.0V. VIgn 12.0V, udsna)--
